the following patch was just integrated into master: commit bb0d1ea24736b96789c10823b1a194818943cc3c Author: Duncan Laurie dlaurie@chromium.org Date: Tue Dec 3 10:00:20 2013 -0800
baytrail: Add ACPI code to describe GPIO controller
There are 3 banks of GPIOs that need to be described with specific _UID and memory/interrupt values.
BUG=chrome-os-partner:24314 BRANCH=none TEST=build and boot on rambi, check for probed driver:
gpiochip_find_base: found new base at 154 gpiochip_add: registered GPIOs 154 to 255 on device: INT33FC:00 gpiochip_find_base: found new base at 126 gpiochip_add: registered GPIOs 126 to 153 on device: INT33FC:01 gpiochip_find_base: found new base at 82 gpiochip_add: registered GPIOs 82 to 125 on device: INT33FC:02
fed0c000-fed0cfff : INT33FC:00 fed0c000-fed0cfff : INT33FC:00 fed0d000-fed0dfff : INT33FC:01 fed0d000-fed0dfff : INT33FC:01 fed0e000-fed0efff : INT33FC:02 fed0e000-fed0efff : INT33FC:02
Change-Id: I9619e2af4e1ccdf3d7b2e4ae280aadf22e278aeb Signed-off-by: Duncan Laurie dlaurie@chromium.org Reviewed-on: https://chromium-review.googlesource.com/178601 Reviewed-by: Aaron Durbin adurbin@chromium.org Signed-off-by: Aaron Durbin adurbin@chromium.org Reviewed-on: http://review.coreboot.org/4985 Reviewed-by: Kyösti Mälkki kyosti.malkki@gmail.com Tested-by: build bot (Jenkins)
See http://review.coreboot.org/4985 for details.
