Marc Jones has uploaded this change for review. ( https://review.coreboot.org/28277
Change subject: update all FADT version 3.0 to use the get tables function ......................................................................
Most FADT report using ACPIv3 FADT table. Using the get revision function keeps the table versions in sync.
Change-Id: Ie554faf1be65c7034dd0836f0029cdc79eae1aed Signed-off-by: Marc Jones marcj303@gmail.com --- M src/mainboard/aopen/dxplplusu/fadt.c M src/mainboard/google/auron/fadt.c M src/mainboard/google/beltino/fadt.c M src/mainboard/google/cyan/fadt.c M src/mainboard/google/jecht/fadt.c M src/mainboard/google/rambi/fadt.c M src/mainboard/google/slippy/fadt.c M src/mainboard/purism/librem_bdw/fadt.c M src/soc/amd/stoneyridge/acpi.c M src/soc/intel/common/block/acpi/acpi.c M src/soc/intel/fsp_baytrail/acpi.c M src/soc/intel/fsp_broadwell_de/acpi.c M src/soc/intel/skylake/acpi.c M src/southbridge/amd/agesa/hudson/fadt.c M src/southbridge/amd/cimx/sb800/fadt.c M src/southbridge/amd/pi/hudson/fadt.c M src/southbridge/intel/fsp_rangeley/acpi.c 17 files changed, 17 insertions(+), 17 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/77/28277/1
diff --git a/src/mainboard/aopen/dxplplusu/fadt.c b/src/mainboard/aopen/dxplplusu/fadt.c index 418d547..9e44b85 100644 --- a/src/mainboard/aopen/dxplplusu/fadt.c +++ b/src/mainboard/aopen/dxplplusu/fadt.c @@ -37,7 +37,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = 4; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/auron/fadt.c b/src/mainboard/google/auron/fadt.c index dea67d0..c96ae68 100644 --- a/src/mainboard/google/auron/fadt.c +++ b/src/mainboard/google/auron/fadt.c @@ -24,7 +24,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/beltino/fadt.c b/src/mainboard/google/beltino/fadt.c index 486a343..806902d 100644 --- a/src/mainboard/google/beltino/fadt.c +++ b/src/mainboard/google/beltino/fadt.c @@ -27,7 +27,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/cyan/fadt.c b/src/mainboard/google/cyan/fadt.c index d62c28d..29e2d2a 100644 --- a/src/mainboard/google/cyan/fadt.c +++ b/src/mainboard/google/cyan/fadt.c @@ -24,7 +24,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/jecht/fadt.c b/src/mainboard/google/jecht/fadt.c index dea67d0..c96ae68 100644 --- a/src/mainboard/google/jecht/fadt.c +++ b/src/mainboard/google/jecht/fadt.c @@ -24,7 +24,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/rambi/fadt.c b/src/mainboard/google/rambi/fadt.c index b0fe9d6..4aa4ec6 100644 --- a/src/mainboard/google/rambi/fadt.c +++ b/src/mainboard/google/rambi/fadt.c @@ -23,7 +23,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/google/slippy/fadt.c b/src/mainboard/google/slippy/fadt.c index fe86f56..8a04591 100644 --- a/src/mainboard/google/slippy/fadt.c +++ b/src/mainboard/google/slippy/fadt.c @@ -27,7 +27,7 @@ memset((void *) fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/mainboard/purism/librem_bdw/fadt.c b/src/mainboard/purism/librem_bdw/fadt.c index 9cbcd3f..fbce9d7 100644 --- a/src/mainboard/purism/librem_bdw/fadt.c +++ b/src/mainboard/purism/librem_bdw/fadt.c @@ -23,7 +23,7 @@ memset(fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/soc/amd/stoneyridge/acpi.c b/src/soc/amd/stoneyridge/acpi.c index 7b4f07b..4094c38 100644 --- a/src/soc/amd/stoneyridge/acpi.c +++ b/src/soc/amd/stoneyridge/acpi.c @@ -77,7 +77,7 @@ memset((void *)fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/soc/intel/common/block/acpi/acpi.c b/src/soc/intel/common/block/acpi/acpi.c index ae645a5..8fdaeee 100644 --- a/src/soc/intel/common/block/acpi/acpi.c +++ b/src/soc/intel/common/block/acpi/acpi.c @@ -110,7 +110,7 @@ const uint16_t pmbase = ACPI_BASE_ADDRESS;
/* Use ACPI 3.0 revision. */ - fadt->header.revision = ACPI_FADT_REV_ACPI_3_0; + fadt->header.revision = get_acpi_table_revision(FADT);
fadt->sci_int = acpi_sci_irq(); fadt->smi_cmd = APM_CNT; diff --git a/src/soc/intel/fsp_baytrail/acpi.c b/src/soc/intel/fsp_baytrail/acpi.c index 748b6cf..f4dd545 100644 --- a/src/soc/intel/fsp_baytrail/acpi.c +++ b/src/soc/intel/fsp_baytrail/acpi.c @@ -191,7 +191,7 @@ /* FADT Header Structure */ memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/soc/intel/fsp_broadwell_de/acpi.c b/src/soc/intel/fsp_broadwell_de/acpi.c index 38b4d47..9b64edc 100644 --- a/src/soc/intel/fsp_broadwell_de/acpi.c +++ b/src/soc/intel/fsp_broadwell_de/acpi.c @@ -167,7 +167,7 @@ /* FADT Header Structure */ memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/soc/intel/skylake/acpi.c b/src/soc/intel/skylake/acpi.c index cff610f..44096cd 100644 --- a/src/soc/intel/skylake/acpi.c +++ b/src/soc/intel/skylake/acpi.c @@ -241,7 +241,7 @@ const uint16_t pmbase = ACPI_BASE_ADDRESS;
/* Use ACPI 3.0 revision */ - fadt->header.revision = ACPI_FADT_REV_ACPI_3_0; + fadt->header.revision = get_acpi_table_revision(FADT);
fadt->sci_int = acpi_sci_irq(); fadt->smi_cmd = APM_CNT; diff --git a/src/southbridge/amd/agesa/hudson/fadt.c b/src/southbridge/amd/agesa/hudson/fadt.c index c1d9b72..1cb9875 100644 --- a/src/southbridge/amd/agesa/hudson/fadt.c +++ b/src/southbridge/amd/agesa/hudson/fadt.c @@ -49,7 +49,7 @@ memset((void *)fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/southbridge/amd/cimx/sb800/fadt.c b/src/southbridge/amd/cimx/sb800/fadt.c index ad47ad7..59e61da 100644 --- a/src/southbridge/amd/cimx/sb800/fadt.c +++ b/src/southbridge/amd/cimx/sb800/fadt.c @@ -53,7 +53,7 @@ memset((void *)fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/southbridge/amd/pi/hudson/fadt.c b/src/southbridge/amd/pi/hudson/fadt.c index 84c6a1d..c2a3ff4 100644 --- a/src/southbridge/amd/pi/hudson/fadt.c +++ b/src/southbridge/amd/pi/hudson/fadt.c @@ -49,7 +49,7 @@ memset((void *)fadt, 0, sizeof(acpi_fadt_t)); memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); diff --git a/src/southbridge/intel/fsp_rangeley/acpi.c b/src/southbridge/intel/fsp_rangeley/acpi.c index 45f0558..ca711dc 100644 --- a/src/southbridge/intel/fsp_rangeley/acpi.c +++ b/src/southbridge/intel/fsp_rangeley/acpi.c @@ -48,7 +48,7 @@ /* FADT Header Structure */ memcpy(header->signature, "FACP", 4); header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; + header->revision = get_acpi_table_revision(FADT); memcpy(header->oem_id, OEM_ID, 6); memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4);
