Daniel Peng has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/78892?usp=email )
Change subject: mb/google/dedede/var/pirika: Support for CXMT CXDB4CBAM-ML-A ......................................................................
Add the new memory support: CXDB4CBAM-ML-A
BUG=b:304932936 BRANCH=firmware-dedede-13606.B TEST=Run command "go run \ ./util/spd_tools/src/part_id_gen/part_id_gen.go \ JSL lp4x src/mainboard/google/dedede/variants/pirika/memory/ \ src/mainboard/google/dedede/variants/pirika/memory/\ mem_parts_used.txt" And confirm boot normally on mainboard with CXDB4CBAM-ML-A memory.
Change-Id: Iff2ed16bcbc9b0755e60a284246aa928625fa26a Signed-off-by: Daniel_Peng Daniel_Peng@pegatron.corp-partner.google.com --- M src/mainboard/google/dedede/variants/pirika/memory/Makefile.inc M src/mainboard/google/dedede/variants/pirika/memory/dram_id.generated.txt M src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt 3 files changed, 5 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/78892/1
diff --git a/src/mainboard/google/dedede/variants/pirika/memory/Makefile.inc b/src/mainboard/google/dedede/variants/pirika/memory/Makefile.inc index 66919de..8b4d130 100644 --- a/src/mainboard/google/dedede/variants/pirika/memory/Makefile.inc +++ b/src/mainboard/google/dedede/variants/pirika/memory/Makefile.inc @@ -1,7 +1,8 @@ # SPDX-License-Identifier: GPL-2.0-or-later # This is an auto-generated file. Do not edit!! # Generated by: -# /tmp/go-build352956073/b001/exe/part_id_gen JSL lp4x src/mainboard/google/dedede/variants/pirika/memory/ src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt +# /tmp/go-build469829719/b001/exe/part_id_gen JSL lp4x src/mainboard/google/dedede/variants/pirika/memory/ src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt
SPD_SOURCES = SPD_SOURCES += spd/lp4x/set-1/spd-1.hex # ID = 0(0b0000) Parts = H9HCNNNBKMMLXR-NEE, K4U6E3S4AA-MGCR, K4U6E3S4AB-MGCL +SPD_SOURCES += spd/lp4x/set-1/spd-11.hex # ID = 1(0b0001) Parts = CXDB4CBAM-ML-A diff --git a/src/mainboard/google/dedede/variants/pirika/memory/dram_id.generated.txt b/src/mainboard/google/dedede/variants/pirika/memory/dram_id.generated.txt index 7a6b135..76ab7e0 100644 --- a/src/mainboard/google/dedede/variants/pirika/memory/dram_id.generated.txt +++ b/src/mainboard/google/dedede/variants/pirika/memory/dram_id.generated.txt @@ -1,9 +1,10 @@ # SPDX-License-Identifier: GPL-2.0-or-later # This is an auto-generated file. Do not edit!! # Generated by: -# /tmp/go-build352956073/b001/exe/part_id_gen JSL lp4x src/mainboard/google/dedede/variants/pirika/memory/ src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt +# /tmp/go-build469829719/b001/exe/part_id_gen JSL lp4x src/mainboard/google/dedede/variants/pirika/memory/ src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt
DRAM Part Name ID to assign H9HCNNNBKMMLXR-NEE 0 (0000) K4U6E3S4AA-MGCR 0 (0000) K4U6E3S4AB-MGCL 0 (0000) +CXDB4CBAM-ML-A 1 (0001) diff --git a/src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt b/src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt index a6490b2..b93cdbf 100644 --- a/src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt +++ b/src/mainboard/google/dedede/variants/pirika/memory/mem_parts_used.txt @@ -1,3 +1,4 @@ H9HCNNNBKMMLXR-NEE K4U6E3S4AA-MGCR K4U6E3S4AB-MGCL +CXDB4CBAM-ML-A
