Attention is currently required from: Patrick Rudolph. Kyösti Mälkki has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/49251 )
Change subject: sb,soc/intel: Refactor power_on_after_fail option ......................................................................
It's only necessary to call get_option() with SLP_TYP S5.
Change-Id: Ic821b429a58a2c0713ec338904364ec57bfbcfce Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/soc/intel/broadwell/pch/smihandler.c M src/southbridge/intel/common/smihandler.c M src/southbridge/intel/lynxpoint/smihandler.c 3 files changed, 40 insertions(+), 32 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/51/49251/1
diff --git a/src/soc/intel/broadwell/pch/smihandler.c b/src/soc/intel/broadwell/pch/smihandler.c index c6632da..3a54749 100644 --- a/src/soc/intel/broadwell/pch/smihandler.c +++ b/src/soc/intel/broadwell/pch/smihandler.c @@ -125,13 +125,9 @@ printk(BIOS_INFO, "Backlight turned off\n"); }
-static void southbridge_smi_sleep(void) +static int power_on_after_fail(void) { - u8 reg8; - u32 reg32; - u8 slp_typ; u8 s5pwr = CONFIG_MAINBOARD_POWER_FAILURE_STATE; - u16 pmbase = get_pmbase();
/* save and recover RTC port values */ u8 tmp70, tmp72; @@ -140,6 +136,15 @@ get_option(&s5pwr, "power_on_after_fail"); outb(tmp70, 0x70); outb(tmp72, 0x72); + return (s5pwr == MAINBOARD_POWER_ON); +} + +static void southbridge_smi_sleep(void) +{ + u8 reg8; + u32 reg32; + u8 slp_typ; + u16 pmbase = get_pmbase();
/* First, disable further SMIs */ disable_smi(SLP_SMI_EN); @@ -193,12 +198,10 @@ /* Always set the flag in case CMOS was changed on runtime. For * "KEEP", switch to "OFF" - KEEP is software emulated */ - reg8 = pci_read_config8(PCH_DEV_LPC, GEN_PMCON_3); - if (s5pwr == MAINBOARD_POWER_ON) - reg8 &= ~1; + if (power_on_after_fail()) + pci_and_config8(PCH_DEV_LPC, GEN_PMCON_3, ~1); else - reg8 |= 1; - pci_write_config8(PCH_DEV_LPC, GEN_PMCON_3, reg8); + pci_or_config8(PCH_DEV_LPC, GEN_PMCON_3, 1);
/* also iterates over all bridges on bus 0 */ busmaster_disable_on_bus(0); diff --git a/src/southbridge/intel/common/smihandler.c b/src/southbridge/intel/common/smihandler.c index 18f171d..90d2f7a 100644 --- a/src/southbridge/intel/common/smihandler.c +++ b/src/southbridge/intel/common/smihandler.c @@ -93,20 +93,25 @@ { }
- // save and recover RTC port values + /* save and recover RTC port values */ u8 tmp70, tmp72; tmp70 = inb(0x70); tmp72 = inb(0x72); get_option(&s5pwr, "power_on_after_fail"); outb(tmp70, 0x70); outb(tmp72, 0x72); + return (s5pwr == MAINBOARD_POWER_ON); +} + +static void southbridge_smi_sleep(void) +{ + u8 reg8; + u32 reg32; + u8 slp_typ;
/* First, disable further SMIs */ write_pmbase8(SMI_EN, read_pmbase8(SMI_EN) & ~SLP_SMI_EN); @@ -156,13 +161,10 @@ /* Always set the flag in case CMOS was changed on runtime. For * "KEEP", switch to "OFF" - KEEP is software emulated */ - reg8 = pci_read_config8(PCI_DEV(0, 0x1f, 0), D31F0_GEN_PMCON_3); - if (s5pwr == MAINBOARD_POWER_ON) { - reg8 &= ~1; - } else { - reg8 |= 1; - } - pci_write_config8(PCI_DEV(0, 0x1f, 0), D31F0_GEN_PMCON_3, reg8); + if (power_on_after_fail()) + pci_and_config8(PCI_DEV(0, 0x1f, 0), D31F0_GEN_PMCON_3, ~1); + else + pci_or_config8(PCI_DEV(0, 0x1f, 0), D31F0_GEN_PMCON_3, 1);
/* also iterates over all bridges on bus 0 */ busmaster_disable_on_bus(0); diff --git a/src/southbridge/intel/lynxpoint/smihandler.c b/src/southbridge/intel/lynxpoint/smihandler.c index 5e31808..948e216 100644 --- a/src/southbridge/intel/lynxpoint/smihandler.c +++ b/src/southbridge/intel/lynxpoint/smihandler.c @@ -76,13 +76,9 @@ } }
/* save and recover RTC port values */ u8 tmp70, tmp72; @@ -91,6 +87,15 @@ get_option(&s5pwr, "power_on_after_fail"); outb(tmp70, 0x70); outb(tmp72, 0x72); + return (s5pwr == MAINBOARD_POWER_ON); +} + +static void southbridge_smi_sleep(void) +{ + u8 reg8; + u32 reg32; + u8 slp_typ; + u16 pmbase = get_pmbase();
/* First, disable further SMIs */ disable_smi(SLP_SMI_EN); @@ -142,12 +147,10 @@ /* Always set the flag in case CMOS was changed on runtime. For * "KEEP", switch to "OFF" - KEEP is software emulated */ - reg8 = pci_read_config8(PCH_LPC_DEV, GEN_PMCON_3); - if (s5pwr == MAINBOARD_POWER_ON) - reg8 &= ~1; + if (power_on_after_fail()) + pci_and_config8(PCH_DEV_LPC, GEN_PMCON_3, ~1); else - reg8 |= 1; - pci_write_config8(PCH_LPC_DEV, GEN_PMCON_3, reg8); + pci_or_config8(PCH_DEV_LPC, GEN_PMCON_3, 1);
