Attention is currently required from: Nicholas Chin, Riku Viitanen.
Hello Riku Viitanen, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85796?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Riku Viitanen, Verified+1 by build bot (Jenkins)
The change is no longer submittable: Code-Review and Verified are unsatisfied now.
Change subject: util/find_usbdebug: Check for lsusb and lspci ......................................................................
Add a check to make sure lsusb and lspci are installed, as the script relies on them to function properly. Previously, if lsusb was not installed, the script proceeded as if nothing was wrong, but never found any devices plugged into the debug port. If lspci was not found, the script exited saying that no EHCI debug capable controller was found. The "command not found" messages that normally would have been shown in these situations was not being shown, as stderr is redirected to /dev/null to hide error messages that don't matter as per the comment near the top of the script.
Change-Id: Ib56a20aab9552aa6321c2fb9ad0d2ca7d6cd00c7 Signed-off-by: Nicholas Chin nic.c3.14@gmail.com --- M util/find_usbdebug/find_usbdebug.sh 1 file changed, 13 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/96/85796/3
