Lee Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15850
commit 4b74fc45daf2138fade0c6af4eff7e5862f19ba4 Author: Lee Leahy leroy.p.leahy@intel.com Date: Sun Jul 24 09:52:38 2016 -0700
drivers/intel/fsp2_0: Verify HOBs returned by FspMemoryInit
Verify that FSP is properly returning: * HOB list pointer * FSP_BOOTLOADER_TOLUM_HOB * FSP_RESERVED_MEMORY_RESOURCE_HOB
Change-Id: I23005d10f7f3ccf06a2e29dab5fa11c7ed79f187 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/drivers/intel/fsp2_0/Kconfig | 7 ++++ src/drivers/intel/fsp2_0/Makefile.inc | 2 + src/drivers/intel/fsp2_0/debug.c | 8 +++- src/drivers/intel/fsp2_0/hand_off_block.c | 15 +++++-- src/drivers/intel/fsp2_0/hob_verify.c | 63 ++++++++++++++++++++++++++++ src/drivers/intel/fsp2_0/include/fsp/debug.h | 2 + src/drivers/intel/fsp2_0/include/fsp/util.h | 5 ++- src/drivers/intel/fsp2_0/memory_init.c | 4 +- 8 files changed, 99 insertions(+), 7 deletions(-)
diff --git a/src/drivers/intel/fsp2_0/Kconfig b/src/drivers/intel/fsp2_0/Kconfig index 06f1a7c..4ff6116 100644 --- a/src/drivers/intel/fsp2_0/Kconfig +++ b/src/drivers/intel/fsp2_0/Kconfig @@ -73,4 +73,11 @@ config FSP_M_XIP help Select this value when FSP-M is execute-in-place.
+config VERIFY_HOBS + bool "Verify the FSP hand-off-blocks" + default n + help + Verify that the HOBs required by coreboot are returned by FSP and + that the resource HOBs are in the correct order and position. + endif diff --git a/src/drivers/intel/fsp2_0/Makefile.inc b/src/drivers/intel/fsp2_0/Makefile.inc index 2b1754e..c42c034 100644 --- a/src/drivers/intel/fsp2_0/Makefile.inc +++ b/src/drivers/intel/fsp2_0/Makefile.inc @@ -19,6 +19,7 @@ romstage-y += debug.c romstage-y += hand_off_block.c romstage-$(CONFIG_DISPLAY_HOBS) += hob_display.c romstage-$(CONFIG_DISPLAY_UPD_DATA) += upd_display.c +romstage-$(CONFIG_VERIFY_HOBS) += hob_verify.c romstage-y += util.c romstage-y += memory_init.c
@@ -26,6 +27,7 @@ ramstage-y += debug.c ramstage-y += graphics.c ramstage-y += hand_off_block.c ramstage-$(CONFIG_DISPLAY_HOBS) += hob_display.c +ramstage-$(CONFIG_VERIFY_HOBS) += hob_verify.c ramstage-y += notify.c ramstage-y += silicon_init.c ramstage-$(CONFIG_DISPLAY_UPD_DATA) += upd_display.c diff --git a/src/drivers/intel/fsp2_0/debug.c b/src/drivers/intel/fsp2_0/debug.c index 52e6765..944edbd 100644 --- a/src/drivers/intel/fsp2_0/debug.c +++ b/src/drivers/intel/fsp2_0/debug.c @@ -44,9 +44,15 @@ void fsp_debug_memory_init(enum fsp_status status, if (IS_ENABLED(CONFIG_DISPLAY_FSP_CALLS_AND_STATUS)) printk(BIOS_DEBUG, "FspMemoryInit returned 0x%08x\n", status);
- /* Display the HOBs */ + /* Verify that the HOB list pointer was set */ + if (hob_list_ptr == NULL) + die("ERROR - HOB list pointer was not returned!\n"); + + /* Display and verify the HOBs */ if (IS_ENABLED(CONFIG_DISPLAY_HOBS)) fsp_display_hobs(hob_list_ptr); + if (IS_ENABLED(CONFIG_VERIFY_HOBS)) + fsp_verify_hobs(hob_list_ptr);
/* Display the MTRRs */ if (IS_ENABLED(CONFIG_DISPLAY_MTRRS)) diff --git a/src/drivers/intel/fsp2_0/hand_off_block.c b/src/drivers/intel/fsp2_0/hand_off_block.c index d3392cd..9693cd2 100644 --- a/src/drivers/intel/fsp2_0/hand_off_block.c +++ b/src/drivers/intel/fsp2_0/hand_off_block.c @@ -43,7 +43,7 @@ static const char *resource_names[] = { };
/* UUIDs (GUIDs) in little-endian, so they can be used with memcmp() */ -static const uint8_t uuid_owner_bootloader_tolum[16] = { +const uint8_t uuid_owner_bootloader_tolum[16] = { 0x56, 0x4f, 0xff, 0x73, 0x8e, 0xaa, 0x51, 0x44, 0xb3, 0x16, 0x36, 0x35, 0x36, 0x67, 0xad, 0x44, }; @@ -185,13 +185,14 @@ struct hob_resource *find_resource_hob_by_uuid(const struct hob_header *hob, return NULL; }
-void fsp_find_reserved_memory(struct range_entry *re, const void *hob_list) +void fsp_find_range_hob(struct range_entry *re, const void *hob_list, + const uint8_t uuid[16]) { const struct hob_resource *fsp_mem;
range_entry_init(re, 0, 0, 0);
- fsp_mem = find_resource_hob_by_uuid(hob_list, uuid_owner_fsp); + fsp_mem = find_resource_hob_by_uuid(hob_list, uuid);
if (!fsp_mem) { return; @@ -200,6 +201,14 @@ void fsp_find_reserved_memory(struct range_entry *re, const void *hob_list) range_entry_init(re, fsp_mem->addr, fsp_mem->addr + fsp_mem->length, 0); }
+struct range_entry fsp_find_reserved_memory(const void *hob_list) +{ + struct range_entry re; + + fsp_find_range_hob(&re, hob_list, uuid_owner_fsp); + return re; +} + /* * Utilities for printing HOB information */ diff --git a/src/drivers/intel/fsp2_0/hob_verify.c b/src/drivers/intel/fsp2_0/hob_verify.c new file mode 100644 index 0000000..ffe8fef --- /dev/null +++ b/src/drivers/intel/fsp2_0/hob_verify.c @@ -0,0 +1,63 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corp. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#include <cbmem.h> +#include <console/console.h> +#include <fsp/util.h> + +struct range_entry fsp_find_bootloader_tolum(const void *hob_list) +{ + struct range_entry re; + + fsp_find_range_hob(&re, hob_list, uuid_owner_bootloader_tolum); + return re; +} + +void fsp_verify_hobs(const struct hob_header *hob_list_ptr) +{ + struct range_entry fsp_mem; + struct range_entry tolum; + + /* Lookup the FSP_BOOTLOADER_TOLUM_HOB */ + tolum = fsp_find_bootloader_tolum(hob_list_ptr); + if ((range_entry_base(&tolum) == 0) + && (range_entry_base(&tolum) == range_entry_end(&tolum))) + die("9.3: FSP_BOOTLOADER_TOLUM_HOB missing!\n"); + if (range_entry_size(&tolum) < cbmem_overhead_size()) { + printk(BIOS_CRIT, + "FSP_BOOTLOADER_TOLUM_SIZE: 0x%08llx < 0x%08lx\n", + range_entry_size(&tolum), cbmem_overhead_size()); + die("ERROR: FSP_BOOTLOADER_TOLUM_HOB too small!\n"); + } + + /* Locate the FSP reserved memory area */ + fsp_mem = fsp_find_reserved_memory(hob_list_ptr); + if ((range_entry_base(&fsp_mem) == 0) + && (range_entry_base(&fsp_mem) == range_entry_end(&fsp_mem))) + die("9.1: FSP_RESERVED_MEMORY_RESOURCE_HOB missing!\n"); + + /* Verify the the bootloader tolum is above the FSP reserved area */ + if (range_entry_end(&tolum) <= range_entry_base(&fsp_mem)) + die("ERROR - FSP reserved region after BIOS TOLUM!\n"); + if (range_entry_base(&tolum) < range_entry_end(&fsp_mem)) + die("ERROR - FSP reserved region overlaps BIOS TOLUM!\n"); + + /* Verify that the FSP reserved area immediately follows the BIOS + * reserved area + */ + if (range_entry_base(&tolum) != range_entry_end(&fsp_mem)) + die("ERROR - Space between FSP reserved region and BIOS TOLUM!\n"); + + if (range_entry_end(&tolum) != (uintptr_t)cbmem_top()) { + printk(BIOS_CRIT, "0x%p: cbmem_top\n", cbmem_top()); + die("ERROR - Space between cbmem_top and BIOS TOLUM!\n"); + } +} diff --git a/src/drivers/intel/fsp2_0/include/fsp/debug.h b/src/drivers/intel/fsp2_0/include/fsp/debug.h index f777c33..44b84a8 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/debug.h +++ b/src/drivers/intel/fsp2_0/include/fsp/debug.h @@ -30,6 +30,7 @@ void fsp_debug_notify(enum fsp_status status); void fspm_display_upd_values(const struct FSPM_UPD *old, const struct FSPM_UPD *new); void fsp_display_hobs(const struct hob_header *hob_list_ptr); +void fsp_verify_hobs(const struct hob_header *hob_list_ptr);
/* Callbacks for displaying UPD parameters - place in a separate file * that is conditionally build with CONFIG_DISPLAY_UPD_DATA. @@ -52,5 +53,6 @@ void fsp_display_upd_value(const char *name, uint32_t size, uint64_t old, const char *fsp_get_hob_type_name(const struct hob_header *hob); const char *fsp_get_guid_name(const uint8_t *guid); void fsp_print_guid_extension_hob(const struct hob_header *hob); +struct range_entry fsp_find_bootloader_tolum(const void *hob_list);
#endif /* _FSP2_0_DEBUG_H_ */ diff --git a/src/drivers/intel/fsp2_0/include/fsp/util.h b/src/drivers/intel/fsp2_0/include/fsp/util.h index bda265a..028e865 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/util.h +++ b/src/drivers/intel/fsp2_0/include/fsp/util.h @@ -57,6 +57,7 @@ enum hob_type { HOB_TYPE_END_OF_HOB_LIST = 0xFFFF, };
+extern const uint8_t uuid_owner_bootloader_tolum[16]; extern const struct uuid_name_map uuid_names[]; extern const size_t uuid_names_entries;
@@ -73,7 +74,9 @@ enum cb_err fsp_fill_lb_framebuffer(struct lb_framebuffer *framebuffer); * Hand-off-block utilities which do not depend on CBMEM, but need to be passed * the HOB list explicitly. */ -void fsp_find_reserved_memory(struct range_entry *re, const void *hob_list); +void fsp_find_range_hob(struct range_entry *re, const void *hob_list, + const uint8_t uuid[16]); +struct range_entry fsp_find_reserved_memory(const void *hob_list); const struct hob_resource *fsp_hob_header_to_resource( const struct hob_header *hob); const struct hob_header *fsp_next_hob(const struct hob_header *parent); diff --git a/src/drivers/intel/fsp2_0/memory_init.c b/src/drivers/intel/fsp2_0/memory_init.c index 4921e88..78e3d81 100644 --- a/src/drivers/intel/fsp2_0/memory_init.c +++ b/src/drivers/intel/fsp2_0/memory_init.c @@ -67,7 +67,7 @@ static enum fsp_status do_fsp_post_memory_init(void *hob_list_ptr, bool s3wake, struct range_entry fsp_mem; struct romstage_handoff *handoff;
- fsp_find_reserved_memory(&fsp_mem, hob_list_ptr); + fsp_mem = fsp_find_reserved_memory(hob_list_ptr);
/* initialize cbmem by adding FSP reserved memory first thing */ if (!s3wake) { @@ -188,7 +188,7 @@ static enum fsp_status do_fsp_memory_init(struct fsp_header *hdr, bool s3wake, enum fsp_status status; fsp_memory_init_fn fsp_raminit; struct FSPM_UPD fspm_upd, *upd; - void *hob_list_ptr; + void *hob_list_ptr = NULL; struct FSPM_ARCH_UPD *arch_upd;
post_code(0x34);
