Lee Leahy (leroy.p.leahy@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15853
commit 62a6a5e36dec2fe4ff972774364363032a0f420f Author: Lee Leahy leroy.p.leahy@intel.com Date: Sun Jul 24 18:18:52 2016 -0700
drivers/intel/fsp2_0: FSP driver handles all FSP errors
Move all FSP error handling into the FSP 2.0 driver. This removes the need to implement error handling within the SOC code.
Change-Id: I4d548b4c90d369d3857c24f50f93e7db7e9d3028 Signed-off-by: Lee Leahy leroy.p.leahy@intel.com --- src/drivers/intel/fsp2_0/include/fsp/api.h | 6 +++--- src/drivers/intel/fsp2_0/memory_init.c | 29 ++++++++++++----------------- src/drivers/intel/fsp2_0/notify.c | 11 +++++++---- src/drivers/intel/fsp2_0/silicon_init.c | 27 ++++++++++++--------------- src/soc/intel/apollolake/chip.c | 10 +++------- src/soc/intel/apollolake/romstage.c | 6 +----- 6 files changed, 38 insertions(+), 51 deletions(-)
diff --git a/src/drivers/intel/fsp2_0/include/fsp/api.h b/src/drivers/intel/fsp2_0/include/fsp/api.h index bc55c50..1348ead 100644 --- a/src/drivers/intel/fsp2_0/include/fsp/api.h +++ b/src/drivers/intel/fsp2_0/include/fsp/api.h @@ -60,9 +60,9 @@ enum fsp_notify_phase {
/* Main FSP stages */ -enum fsp_status fsp_memory_init(bool s3wake); -enum fsp_status fsp_silicon_init(void); -enum fsp_status fsp_notify(enum fsp_notify_phase phase); +void fsp_memory_init(bool s3wake); +void fsp_silicon_init(void); +void fsp_notify(enum fsp_notify_phase phase);
/* Callbacks for updating stage-specific parameters */ void platform_fsp_memory_init_params_cb(struct FSPM_UPD *mupd); diff --git a/src/drivers/intel/fsp2_0/memory_init.c b/src/drivers/intel/fsp2_0/memory_init.c index 78e3d81..0677e74 100644 --- a/src/drivers/intel/fsp2_0/memory_init.c +++ b/src/drivers/intel/fsp2_0/memory_init.c @@ -61,7 +61,7 @@ static void save_memory_training_data(bool s3wake, uint32_t fsp_version) */ #define MRC_DEAD_VERSION (0xdeaddead)
-static enum fsp_status do_fsp_post_memory_init(void *hob_list_ptr, bool s3wake, +static void do_fsp_post_memory_init(void *hob_list_ptr, bool s3wake, uint32_t fsp_version) { struct range_entry fsp_mem; @@ -85,7 +85,7 @@ static enum fsp_status do_fsp_post_memory_init(void *hob_list_ptr, bool s3wake, /* make sure FSP memory is reserved in cbmem */ if (range_entry_base(&fsp_mem) != (uintptr_t)cbmem_find(CBMEM_ID_FSP_RESERVED_MEMORY)) - die("Failed to accommodate FSP reserved memory request"); + die("Failed to accommodate FSP reserved memory request!\n");
/* Now that CBMEM is up, save the list so ramstage can use it */ fsp_save_hob_list(hob_list_ptr); @@ -101,8 +101,6 @@ static enum fsp_status do_fsp_post_memory_init(void *hob_list_ptr, bool s3wake, handoff->s3_resume = s3wake; else printk(BIOS_DEBUG, "Romstage handoff structure not added!\n"); - - return FSP_SUCCESS; }
static void fsp_fill_mrc_cache(struct FSPM_ARCH_UPD *arch_upd, bool s3wake, @@ -182,7 +180,7 @@ static enum cb_err fsp_fill_common_arch_params(struct FSPM_ARCH_UPD *arch_upd, return CB_SUCCESS; }
-static enum fsp_status do_fsp_memory_init(struct fsp_header *hdr, bool s3wake, +static void do_fsp_memory_init(struct fsp_header *hdr, bool s3wake, const struct memranges *memmap) { enum fsp_status status; @@ -196,8 +194,7 @@ static enum fsp_status do_fsp_memory_init(struct fsp_header *hdr, bool s3wake, upd = (struct FSPM_UPD *)(hdr->cfg_region_offset + hdr->image_base);
if (upd->FspUpdHeader.Signature != FSPM_UPD_SIGNATURE) { - printk(BIOS_ERR, "Invalid FSPM signature\n"); - return FSP_INCOMPATIBLE_VERSION; + die("Invalid FSPM signature!\n"); }
/* Copy the default values from the UPD area */ @@ -211,7 +208,7 @@ static enum fsp_status do_fsp_memory_init(struct fsp_header *hdr, bool s3wake, /* Fill common settings on behalf of chipset. */ if (fsp_fill_common_arch_params(arch_upd, s3wake, hdr->fsp_revision, memmap) != CB_SUCCESS) - return FSP_NOT_FOUND; + die("FSPM_ARCH_UPD not found!\n");
/* Give SoC and mainboard a chance to update the UPD */ platform_fsp_memory_init_params_cb(&fspm_upd); @@ -229,13 +226,12 @@ static enum fsp_status do_fsp_memory_init(struct fsp_header *hdr, bool s3wake,
fsp_debug_memory_init(status, hob_list_ptr);
- /* Handle any resets requested by FSPM. */ + /* Handle any errors returned by FspMemoryInit */ fsp_handle_reset(status); - if (status != FSP_SUCCESS) - return status; + die("FspMemoryInit returned an error!\n");
- return do_fsp_post_memory_init(hob_list_ptr, s3wake, hdr->fsp_revision); + do_fsp_post_memory_init(hob_list_ptr, s3wake, hdr->fsp_revision); }
/* Load the binary into the memory specified by the info header. */ @@ -286,7 +282,7 @@ static enum cb_err load_fspm_xip(struct fsp_header *hdr, return CB_SUCCESS; }
-enum fsp_status fsp_memory_init(bool s3wake) +void fsp_memory_init(bool s3wake) { struct fsp_header hdr; enum cb_err status; @@ -298,7 +294,7 @@ enum fsp_status fsp_memory_init(bool s3wake)
if (cbfs_boot_locate(&file_desc, name, NULL)) { printk(BIOS_ERR, "Could not locate %s in CBFS\n", name); - return FSP_NOT_FOUND; + die("FSPM not available!\n"); }
cbfs_file_data(&file_data, &file_desc); @@ -315,12 +311,11 @@ enum fsp_status fsp_memory_init(bool s3wake) status = load_fspm_xip(&hdr, &file_data);
if (status != CB_SUCCESS) { - printk(BIOS_ERR, "Loading FSPM failed.\n"); - return FSP_NOT_FOUND; + die("Loading FSPM failed!\n"); }
/* Signal that FSP component has been loaded. */ prog_segment_loaded(hdr.image_base, hdr.image_size, SEG_FINAL);
- return do_fsp_memory_init(&hdr, s3wake, &memmap); + do_fsp_memory_init(&hdr, s3wake, &memmap); } diff --git a/src/drivers/intel/fsp2_0/notify.c b/src/drivers/intel/fsp2_0/notify.c index 139e172..b002cf8 100644 --- a/src/drivers/intel/fsp2_0/notify.c +++ b/src/drivers/intel/fsp2_0/notify.c @@ -17,14 +17,14 @@ #include <string.h> #include <timestamp.h>
-enum fsp_status fsp_notify(enum fsp_notify_phase phase) +void fsp_notify(enum fsp_notify_phase phase) { enum fsp_status ret; fsp_notify_fn fspnotify; struct fsp_notify_params notify_params = { .phase = phase };
- if (!fsps_hdr.silicon_init_entry_offset) - return FSP_NOT_FOUND; + if (!fsps_hdr.notify_phase_entry_offset) + die("Notify_phase_entry_offset is zero!\n");
fspnotify = (void*) (fsps_hdr.image_base + fsps_hdr.notify_phase_entry_offset); @@ -49,5 +49,8 @@ enum fsp_status fsp_notify(enum fsp_notify_phase phase) } fsp_debug_notify(ret);
- return ret; + /* Handle any errors returned by FspNotify */ + fsp_handle_reset(ret); + if (ret != FSP_SUCCESS) + die("FspNotify returned an error!\n"); } diff --git a/src/drivers/intel/fsp2_0/silicon_init.c b/src/drivers/intel/fsp2_0/silicon_init.c index b9fea66..c539db6 100644 --- a/src/drivers/intel/fsp2_0/silicon_init.c +++ b/src/drivers/intel/fsp2_0/silicon_init.c @@ -23,7 +23,7 @@
struct fsp_header fsps_hdr;
-static enum fsp_status do_silicon_init(struct fsp_header *hdr) +static void do_silicon_init(struct fsp_header *hdr) { struct FSPS_UPD upd, *supd; fsp_silicon_init_fn silicon_init; @@ -32,8 +32,7 @@ static enum fsp_status do_silicon_init(struct fsp_header *hdr) supd = (struct FSPS_UPD *) (hdr->cfg_region_offset + hdr->image_base);
if (supd->FspUpdHeader.Signature != FSPS_UPD_SIGNATURE) { - printk(BIOS_ERR, "Invalid FSPS signature\n"); - return FSP_INCOMPATIBLE_VERSION; + die("Invalid FSPS signature\n"); }
memcpy(&upd, supd, sizeof(upd)); @@ -54,13 +53,13 @@ static enum fsp_status do_silicon_init(struct fsp_header *hdr)
fsp_debug_silicon_init(status);
- /* Handle any resets requested by FSPS. */ + /* Handle any errors returned by FspSiliconInit */ fsp_handle_reset(status); - - return status; + if (status != FSP_SUCCESS) + die("FspSiliconINit returned an error!\n"); }
-enum fsp_status fsp_silicon_init(void) +void fsp_silicon_init(void) { struct fsp_header *hdr = &fsps_hdr; struct cbfsf file_desc; @@ -71,7 +70,7 @@ enum fsp_status fsp_silicon_init(void)
if (cbfs_boot_locate(&file_desc, name, NULL)) { printk(BIOS_ERR, "Could not locate %s in CBFS\n", name); - return FSP_NOT_FOUND; + die("FSPS not available!\n"); }
cbfs_file_data(&rdev, &file_desc); @@ -81,26 +80,24 @@ enum fsp_status fsp_silicon_init(void) dest = cbmem_add(CBMEM_ID_REFCODE, size);
if (dest == NULL) { - printk(BIOS_ERR, "Could not add FSPS to CBMEM.\n"); - return FSP_NOT_FOUND; + die("Could not add FSPS to CBMEM!\n"); }
if (rdev_readat(&rdev, dest, 0, size) < 0) - return FSP_NOT_FOUND; + die("Failed to read FSPS!\n");
if (fsp_component_relocate((uintptr_t)dest, dest, size) < 0) { - printk(BIOS_ERR, "Unable to relocate FSPS.\n"); - return FSP_NOT_FOUND; + die("Unable to relocate FSPS!\n"); }
/* Create new region device in memory after relocation. */ rdev_chain(&rdev, &addrspace_32bit.rdev, (uintptr_t)dest, size);
if (fsp_validate_component(hdr, &rdev) != CB_SUCCESS) - return FSP_NOT_FOUND; + die("Invalid FSPS header!\n");
/* Signal that FSP component has been loaded. */ prog_segment_loaded(hdr->image_base, hdr->image_size, SEG_FINAL);
- return do_silicon_init(hdr); + do_silicon_init(hdr); } diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index 10b71fb..812f663 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -200,8 +200,7 @@ static void soc_init(void *data) * default policy that doesn't honor boards' requirements. */ itss_snapshot_irq_polarities(GPIO_IRQ_START, GPIO_IRQ_END);
- if (fsp_silicon_init() != FSP_SUCCESS) - die("FSP silicon init failed. Giving up."); + fsp_silicon_init();
/* Restore GPIO IRQ polarities back to previous settings. */ itss_restore_irq_polarities(GPIO_IRQ_START, GPIO_IRQ_END); @@ -411,12 +410,9 @@ static void fsp_notify_dummy(void *arg) {
enum fsp_notify_phase ph = (enum fsp_notify_phase) arg; - enum fsp_status ret;
- if ((ret = fsp_notify(ph)) != FSP_SUCCESS) { - printk(BIOS_CRIT, "FspNotify failed, ret = %x!\n", ret); - fsp_handle_reset(ret); - } + fsp_notify(ph); + /* Call END_OF_FIRMWARE Notify after READY_TO_BOOT Notify */ if (ph == READY_TO_BOOT) { fsp_notify_dummy((void *)END_OF_FIRMWARE); diff --git a/src/soc/intel/apollolake/romstage.c b/src/soc/intel/apollolake/romstage.c index da7fcf1..8f17fdd 100644 --- a/src/soc/intel/apollolake/romstage.c +++ b/src/soc/intel/apollolake/romstage.c @@ -114,11 +114,7 @@ asmlinkage void car_stage_entry(void) console_init();
s3wake = fill_power_state(ps) == ACPI_S3; - - if (fsp_memory_init(s3wake) != FSP_SUCCESS) { - die("FSP memory init failed. Giving up."); - } - + fsp_memory_init(s3wake); if (postcar_frame_init(&pcf, 1*KiB)) die("Unable to initialize postcar frame.\n");
