Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35207 )
Change subject: soc/intel: Remove unsued code ......................................................................
Delete acpi_create_intel_hpet() which has been replaced by acpi_write_hpet() in the corresponding soc folders some time ago.
Change-Id: I788c9ef27cdc575eb8467cbef64ee52f4053e197 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M src/soc/intel/baytrail/acpi.c M src/soc/intel/baytrail/include/soc/acpi.h M src/soc/intel/broadwell/acpi.c M src/soc/intel/broadwell/include/soc/acpi.h M src/soc/intel/denverton_ns/include/soc/acpi.h M src/soc/intel/fsp_baytrail/acpi.c M src/soc/intel/fsp_baytrail/include/soc/acpi.h M src/soc/intel/fsp_broadwell_de/acpi.c M src/soc/intel/fsp_broadwell_de/include/soc/acpi.h 9 files changed, 0 insertions(+), 128 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/35207/1
diff --git a/src/soc/intel/baytrail/acpi.c b/src/soc/intel/baytrail/acpi.c index c322cce..db6b271 100644 --- a/src/soc/intel/baytrail/acpi.c +++ b/src/soc/intel/baytrail/acpi.c @@ -131,37 +131,6 @@ return sci_irq; }
-void acpi_create_intel_hpet(acpi_hpet_t * hpet) -{ - acpi_header_t *header = &(hpet->header); - acpi_addr_t *addr = &(hpet->addr); - - memset((void *) hpet, 0, sizeof(acpi_hpet_t)); - - /* fill out header fields */ - memcpy(header->signature, "HPET", 4); - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - - header->length = sizeof(acpi_hpet_t); - header->revision = get_acpi_table_revision(HPET); - - /* fill out HPET address */ - addr->space_id = 0; /* Memory */ - addr->bit_width = 64; - addr->bit_offset = 0; - addr->addrl = (unsigned long long)HPET_BASE_ADDRESS & 0xffffffff; - addr->addrh = (unsigned long long)HPET_BASE_ADDRESS >> 32; - - hpet->id = 0x8086a201; /* Intel */ - hpet->number = 0x00; - hpet->min_tick = 0x0080; - - header->checksum = - acpi_checksum((void *) hpet, sizeof(acpi_hpet_t)); -} - unsigned long acpi_fill_mcfg(unsigned long current) { current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, diff --git a/src/soc/intel/baytrail/include/soc/acpi.h b/src/soc/intel/baytrail/include/soc/acpi.h index 29acda7..2851f92 100644 --- a/src/soc/intel/baytrail/include/soc/acpi.h +++ b/src/soc/intel/baytrail/include/soc/acpi.h @@ -19,7 +19,6 @@ #include <arch/acpi.h> #include <soc/nvs.h>
-void acpi_create_intel_hpet(acpi_hpet_t * hpet); void acpi_fill_in_fadt(acpi_fadt_t *fadt); unsigned long acpi_madt_irq_overrides(unsigned long current); void acpi_init_gnvs(global_nvs_t *gnvs); diff --git a/src/soc/intel/broadwell/acpi.c b/src/soc/intel/broadwell/acpi.c index 705bc00..c0455b4 100644 --- a/src/soc/intel/broadwell/acpi.c +++ b/src/soc/intel/broadwell/acpi.c @@ -185,37 +185,6 @@ #endif }
-void acpi_create_intel_hpet(acpi_hpet_t *hpet) -{ - acpi_header_t *header = &(hpet->header); - acpi_addr_t *addr = &(hpet->addr); - - memset((void *) hpet, 0, sizeof(acpi_hpet_t)); - - /* fill out header fields */ - memcpy(header->signature, "HPET", 4); - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - - header->length = sizeof(acpi_hpet_t); - header->revision = get_acpi_table_revision(HPET); - - /* fill out HPET address */ - addr->space_id = 0; /* Memory */ - addr->bit_width = 64; - addr->bit_offset = 0; - addr->addrl = (unsigned long long)HPET_BASE_ADDRESS & 0xffffffff; - addr->addrh = (unsigned long long)HPET_BASE_ADDRESS >> 32; - - hpet->id = 0x8086a201; /* Intel */ - hpet->number = 0x00; - hpet->min_tick = 0x0080; - - header->checksum = - acpi_checksum((void *) hpet, sizeof(acpi_hpet_t)); -} - unsigned long acpi_fill_mcfg(unsigned long current) { current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, diff --git a/src/soc/intel/broadwell/include/soc/acpi.h b/src/soc/intel/broadwell/include/soc/acpi.h index 24fe3ae..d075464 100644 --- a/src/soc/intel/broadwell/include/soc/acpi.h +++ b/src/soc/intel/broadwell/include/soc/acpi.h @@ -25,7 +25,6 @@ #define PSS_LATENCY_TRANSITION 10 #define PSS_LATENCY_BUSMASTER 10
-void acpi_create_intel_hpet(acpi_hpet_t *hpet); void acpi_fill_in_fadt(acpi_fadt_t *fadt); unsigned long acpi_madt_irq_overrides(unsigned long current); void acpi_init_gnvs(global_nvs_t *gnvs); diff --git a/src/soc/intel/denverton_ns/include/soc/acpi.h b/src/soc/intel/denverton_ns/include/soc/acpi.h index 5de58ea..5ab77e0 100644 --- a/src/soc/intel/denverton_ns/include/soc/acpi.h +++ b/src/soc/intel/denverton_ns/include/soc/acpi.h @@ -21,7 +21,6 @@ #include <arch/acpi.h> #include <soc/nvs.h>
-void acpi_create_intel_hpet(acpi_hpet_t *hpet); void acpi_create_serialio_ssdt(acpi_header_t *ssdt); unsigned long acpi_madt_irq_overrides(unsigned long current); void acpi_init_gnvs(global_nvs_t *gnvs); diff --git a/src/soc/intel/fsp_baytrail/acpi.c b/src/soc/intel/fsp_baytrail/acpi.c index fb941ab..565c181 100644 --- a/src/soc/intel/fsp_baytrail/acpi.c +++ b/src/soc/intel/fsp_baytrail/acpi.c @@ -128,37 +128,6 @@ return sci_irq; }
-void acpi_create_intel_hpet(acpi_hpet_t * hpet) -{ - acpi_header_t *header = &(hpet->header); - acpi_addr_t *addr = &(hpet->addr); - - memset((void *) hpet, 0, sizeof(acpi_hpet_t)); - - /* fill out header fields */ - memcpy(header->signature, "HPET", 4); - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - - header->length = sizeof(acpi_hpet_t); - header->revision = get_acpi_table_revision(HPET); - - /* fill out HPET address */ - addr->space_id = 0; /* Memory */ - addr->bit_width = 64; - addr->bit_offset = 0; - addr->addrl = (unsigned long long)HPET_BASE_ADDRESS & 0xffffffff; - addr->addrh = (unsigned long long)HPET_BASE_ADDRESS >> 32; - - hpet->id = 0x8086a201; /* Intel */ - hpet->number = 0x00; - hpet->min_tick = 0x0080; - - header->checksum = - acpi_checksum((void *) hpet, sizeof(acpi_hpet_t)); -} - unsigned long acpi_fill_mcfg(unsigned long current) { current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, diff --git a/src/soc/intel/fsp_baytrail/include/soc/acpi.h b/src/soc/intel/fsp_baytrail/include/soc/acpi.h index 27b7000..917419e 100644 --- a/src/soc/intel/fsp_baytrail/include/soc/acpi.h +++ b/src/soc/intel/fsp_baytrail/include/soc/acpi.h @@ -21,7 +21,6 @@ #include <soc/nvs.h> #include <device/device.h>
-void acpi_create_intel_hpet(acpi_hpet_t * hpet); void acpi_create_serialio_ssdt(acpi_header_t *ssdt); void acpi_fill_in_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt); unsigned long acpi_madt_irq_overrides(unsigned long current); diff --git a/src/soc/intel/fsp_broadwell_de/acpi.c b/src/soc/intel/fsp_broadwell_de/acpi.c index 6b1d3f6..e8aebe2 100644 --- a/src/soc/intel/fsp_broadwell_de/acpi.c +++ b/src/soc/intel/fsp_broadwell_de/acpi.c @@ -114,36 +114,6 @@ return sci_irq; }
-void acpi_create_intel_hpet(acpi_hpet_t *hpet) -{ - acpi_header_t *header = &(hpet->header); - acpi_addr_t *addr = &(hpet->addr); - - memset((void *) hpet, 0, sizeof(acpi_hpet_t)); - - /* fill out header fields */ - memcpy(header->signature, "HPET", 4); - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - - header->length = sizeof(acpi_hpet_t); - header->revision = get_acpi_table_revision(HPET); - - /* fill out HPET address */ - addr->space_id = 0; /* Memory */ - addr->bit_width = 64; - addr->bit_offset = 0; - addr->addrl = (unsigned long long)HPET_BASE_ADDRESS & 0xffffffff; - addr->addrh = (unsigned long long)HPET_BASE_ADDRESS >> 32; - - hpet->id = 0x8086a201; /* Intel */ - hpet->number = 0x00; - hpet->min_tick = 0x0080; - - header->checksum = acpi_checksum((void *) hpet, sizeof(acpi_hpet_t)); -} - unsigned long acpi_fill_mcfg(unsigned long current) { current += acpi_create_mcfg_mmconfig((acpi_mcfg_mmconfig_t *)current, diff --git a/src/soc/intel/fsp_broadwell_de/include/soc/acpi.h b/src/soc/intel/fsp_broadwell_de/include/soc/acpi.h index 44e17d0..419f229 100644 --- a/src/soc/intel/fsp_broadwell_de/include/soc/acpi.h +++ b/src/soc/intel/fsp_broadwell_de/include/soc/acpi.h @@ -20,7 +20,6 @@
-void acpi_create_intel_hpet(acpi_hpet_t *hpet); void acpi_fill_in_fadt(acpi_fadt_t *fadt, acpi_facs_t *facs, void *dsdt); unsigned long acpi_madt_irq_overrides(unsigned long current); uint16_t get_pmbase(void);
David Guckian has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35207 )
Patch Set 1: Code-Review+1
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35207 )
Patch Set 1: Code-Review+2
Lynxpoint still has that function, but is using it. I wonder if it could be cleaned up
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35207 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/35207/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/35207/1//COMMIT_MSG@7 PS1, Line 7: unsued I certainly hope so. I guess you meant unused though
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/35207/1//COMMIT_MSG@9 PS1, Line 9: acpi_write_hpet() Please move this to the next line
Patrick Georgi has uploaded a new patch set (#2) to the change originally created by Patrick Rudolph. ( https://review.coreboot.org/c/coreboot/+/35207 )
Change subject: soc/intel: Remove unused code ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/35207/2
Patch Set 2:
(2 comments)
I certainly hope so. […]
Done
Done
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35207 )
Change-Id: I788c9ef27cdc575eb8467cbef64ee52f4053e197 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/35207 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: David Guckian Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/soc/intel/baytrail/acpi.c M src/soc/intel/baytrail/include/soc/acpi.h M src/soc/intel/broadwell/acpi.c M src/soc/intel/broadwell/include/soc/acpi.h M src/soc/intel/denverton_ns/include/soc/acpi.h M src/soc/intel/fsp_baytrail/acpi.c M src/soc/intel/fsp_baytrail/include/soc/acpi.h M src/soc/intel/fsp_broadwell_de/acpi.c M src/soc/intel/fsp_broadwell_de/include/soc/acpi.h 9 files changed, 0 insertions(+), 128 deletions(-)
Approvals: build bot (Jenkins): Verified Angel Pons: Looks good to me, approved David Guckian: Looks good to me, but someone else must approve
-void acpi_create_intel_hpet(acpi_hpet_t * hpet); void acpi_fill_in_fadt(acpi_fadt_t *fadt); unsigned long acpi_madt_irq_overrides(unsigned long current); void acpi_init_gnvs(global_nvs_t *gnvs); diff --git a/src/soc/intel/broadwell/acpi.c b/src/soc/intel/broadwell/acpi.c index 7acde68..fe65a01 100644 --- a/src/soc/intel/broadwell/acpi.c +++ b/src/soc/intel/broadwell/acpi.c @@ -185,37 +185,6 @@ #endif }
-void acpi_create_intel_hpet(acpi_hpet_t *hpet); void acpi_create_serialio_ssdt(acpi_header_t *ssdt); unsigned long acpi_madt_irq_overrides(unsigned long current); void acpi_init_gnvs(global_nvs_t *gnvs); diff --git a/src/soc/intel/fsp_baytrail/acpi.c b/src/soc/intel/fsp_baytrail/acpi.c index 59dc6be..5efa82f 100644 --- a/src/soc/intel/fsp_baytrail/acpi.c +++ b/src/soc/intel/fsp_baytrail/acpi.c @@ -128,37 +128,6 @@ return sci_irq; }
-void acpi_create_intel_hpet(acpi_hpet_t * hpet); void acpi_create_serialio_ssdt(acpi_header_t *ssdt); void acpi_fill_in_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt); unsigned long acpi_madt_irq_overrides(unsigned long current); diff --git a/src/soc/intel/fsp_broadwell_de/acpi.c b/src/soc/intel/fsp_broadwell_de/acpi.c index 54429a8..5349c30 100644 --- a/src/soc/intel/fsp_broadwell_de/acpi.c +++ b/src/soc/intel/fsp_broadwell_de/acpi.c @@ -114,36 +114,6 @@ return sci_irq; }
