Attention is currently required from: Jason Glenesk, Raul Rangel, Martin Roth, Marshall Dawson, Paul Menzel, Fred Reitberger, Rob Barnes, Karthik Ramasubramanian, Felix Held. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson, Fred Reitberger, Rob Barnes, Karthik Ramasubramanian, Felix Held,
https://review.coreboot.org/c/coreboot/+/61259
to look at the new patch set (#32).
Change subject: soc/amd/cezanne: Turn off gpp clock request for disabled devices ......................................................................
The current behavior does not actually check if a device is present before enabling the corresponding gpp_clkx_clock_request_mapping bits which may cause issues with L1SS. This change sets the corresponding gpp_clkx_clock_request_mapping to off if the corresponding device is disabled.
BUG=b:202252869 TEST=Checked that value of GPP_CLK_CNTRL matched the expected value when devices are enabled/disabled, checked that physically removing a device that is marked as enabled also disables the corresponding clk req BRANCH=guybrush
Signed-off-by: Robert Zieba robertzieba@google.com Change-Id: I77389372c60bdec572622a3b49484d4789fd4e4c --- M src/mainboard/amd/majolica/Makefile.inc M src/mainboard/google/guybrush/Makefile.inc M src/soc/amd/cezanne/chip.h M src/soc/amd/cezanne/fch.c 4 files changed, 99 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/59/61259/32
