Attention is currently required from: Angel Pons, Keith Hui.
Hello Bill XIE, Nicholas Chin, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/85413?usp=email
Change subject: mb/asus/p8z77-v: Attempt to correctly route PCIe lanes ......................................................................
Bill Xie documented in his initial code drop that he was unsuccessful in reproducing all the PCIe configurations possible with vendor firmware. I obtained a boardview to this board and have identified the PCIe lane topology and the required control signals.
There are PCIe slot presence signals wired to GPIOs 34,20,7 for PCIEX1_1,PCIEX1_2,PCIEX16_3 respectively, the last one only sense the presence of a PCIe x4 or larger card. PCIe lanes 1-4 are routed by way of three ASM1440 2-way switches controlled by GP54-GP56 on NCT6779D super I/O chip. PCIe lanes 5-8 are fixed.
With these details, it is now possible to attempt to reproduce all the vendor PCIe configurations.
1. Change GPIO20 of PCH to GPIO input so coreboot can detect a card inserted into PCIEX1_2. 2. Add an nvram option to force PCIe lane 4 to serve ASM1061 and its two SATA 6Gbps ports. Another one needs to be added later to enable users to allocate all lanes to PCIEX16_3 and make it x4. 3. Add code to bootblock to check the PCHSTRP9 soft strap and whether (1) is true. There is a sanity check to warn of a PCIe configuration that is not valid on this board. 4. Based on (1) and (2), program SIO GPIO5 as appropriate. Remove all GPIO5 settings from devicetree so this code has full control.
Changing PCIEX16_3 from x1 to x4 (and vice versa) requires changing PCHSTRP9 in the SPI flash descriptor. How coreboot can manage this is TBD.
This is based on boardview only, and is untested because I have no hardware.
Change-Id: If41197a1f817a48c209d25fc1ae461ec97ccf16c Signed-off-by: Keith Hui buurin@gmail.com --- M src/mainboard/asus/p8x7x-series/variants/p8z77-v/cmos.default M src/mainboard/asus/p8x7x-series/variants/p8z77-v/cmos.layout M src/mainboard/asus/p8x7x-series/variants/p8z77-v/early_init.c M src/mainboard/asus/p8x7x-series/variants/p8z77-v/gpio.c M src/mainboard/asus/p8x7x-series/variants/p8z77-v/overridetree.cb 5 files changed, 120 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/85413/6
