Hello Zheng Bao,
https://review.coreboot.org/c/coreboot/+/48842
Change subject: soc/amd/common: Detect SOC before access ESPI register ......................................................................
Cezanne doesn't have eSPIx00034 register define in PPR.
Change-Id: Icb8e8a1a59393849395125108bfaa884839ce10f Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/soc/amd/common/block/lpc/espi_util.c 1 file changed, 4 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/1
diff --git a/src/soc/amd/common/block/lpc/espi_util.c b/src/soc/amd/common/block/lpc/espi_util.c index 0878fb7..ddeae98 100644 --- a/src/soc/amd/common/block/lpc/espi_util.c +++ b/src/soc/amd/common/block/lpc/espi_util.c @@ -824,6 +824,10 @@ static void espi_setup_subtractive_decode(const struct espi_config *mb_cfg) { uint32_t global_ctrl_reg; + + if (CONFIG(SOC_AMD_CEZANNE)) + return; + global_ctrl_reg = espi_read32(ESPI_GLOBAL_CONTROL_1);
if (mb_cfg->subtractive_decode) {
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/48842/1/src/soc/amd/common/block/lp... File src/soc/amd/common/block/lpc/espi_util.c:
https://review.coreboot.org/c/coreboot/+/48842/1/src/soc/amd/common/block/lp... PS1, Line 828: SOC_AMD_CEZANNE Please do not add SoC specific checks in common code. Instead this should be handled by adding a new Kconfig option that explains what the config is and why a certain SoC might select it.
Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 1:
Please do not add SoC specific checks in common code. […]
only had a very brief look, but adding a Kconfig option in soc/amd/common/block/lpc/Kconfig like ESPI_SUPPORTS_SUBTRACTIVE_DECODE that gets selected by stoneyridge and picasso should probably be the way to go. might also be worth a look if LPC still supports subtractive decode; if that was also dropped there, dropping the ESPI_ from the kconfig symbol and also using it in the LPC code would be good
Patch Set 1:
only had a very brief look, but adding a Kconfig option in soc/amd/common/block/lpc/Kconfig like ESP […]
might also be worth a thought to move the check to espi_setup and only call espi_setup_subtractive_decode if the platform supports subtractive decodes
Hello build bot (Jenkins), Jason Glenesk, Marshall Dawson, Zheng Bao, Felix Held,
to look at the new patch set (#23).
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/23
to look at the new patch set (#24).
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/24
to look at the new patch set (#25).
Change-Id: Icb8e8a1a59393849395125108bfaa884839ce10f Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/soc/amd/common/block/lpc/Kconfig M src/soc/amd/common/block/lpc/espi_util.c M src/soc/amd/picasso/Kconfig 3 files changed, 10 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/25
to look at the new patch set (#26).
Change-Id: Icb8e8a1a59393849395125108bfaa884839ce10f Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/soc/amd/common/block/lpc/Kconfig M src/soc/amd/common/block/lpc/espi_util.c M src/soc/amd/picasso/Kconfig 3 files changed, 9 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/26
to look at the new patch set (#27).
Change subject: soc/amd/common: Add an option to selete if suports ESPI sub decode ......................................................................
Cezanne doesn't have eSPIx00034 register define in PPR. Currently only Picasso need this option.
Change-Id: Icb8e8a1a59393849395125108bfaa884839ce10f Signed-off-by: Zheng Bao fishbaozi@gmail.com --- M src/soc/amd/common/block/lpc/Kconfig M src/soc/amd/common/block/lpc/espi_util.c M src/soc/amd/picasso/Kconfig 3 files changed, 8 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/27
to look at the new patch set (#28).
Change subject: soc/amd/: Add an option to select if SOC supports ESPI sub decode ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/28
Attention is currently required from: Furquan Shaikh, Felix Held. Bao Zheng has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 28:
(2 comments)
https://review.coreboot.org/c/coreboot/+/48842/comment/5d6b7a13_d10d613d PS1, Line 828: SOC_AMD_CEZANNE
might also be worth a thought to move the check to espi_setup and only call espi_setup_subtractive_d […]
Done
https://review.coreboot.org/c/coreboot/+/48842/comment/50e3da75_00c119bb PS1, Line 828: SOC_AMD_CEZANNE
Done
Attention is currently required from: Bao Zheng, Furquan Shaikh, Felix Held. Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 28:
Commit Message:
https://review.coreboot.org/c/coreboot/+/48842/comment/d09d6b76_a807852f PS28, Line 7: soc/amd/: Please remove the trailing slash from the prefix.
Attention is currently required from: Bao Zheng, Furquan Shaikh. Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 28: Code-Review+2
Attention is currently required from: Furquan Shaikh. Hello build bot (Jenkins), Jason Glenesk, Marshall Dawson, Zheng Bao, Felix Held,
to look at the new patch set (#29).
Change subject: soc/amd: Add an option to select if SOC supports ESPI sub decode ......................................................................
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/42/48842/29
Attention is currently required from: Furquan Shaikh, Paul Menzel. Bao Zheng has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 29:
(2 comments)
Commit Message:
https://review.coreboot.org/c/coreboot/+/48842/comment/1ae8d2e8_ca33d97e PS28, Line 7: soc/amd/:
Done
Patchset:
PS29: Need to wait other general code about LPC, eSPI
Attention is currently required from: Bao Zheng, Furquan Shaikh, Paul Menzel. Felix Held has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Patch Set 29: Code-Review+2
Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/48842 )
Change-Id: Icb8e8a1a59393849395125108bfaa884839ce10f Signed-off-by: Zheng Bao fishbaozi@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/48842 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Felix Held felix-coreboot@felixheld.de --- M src/soc/amd/common/block/lpc/Kconfig M src/soc/amd/common/block/lpc/espi_util.c M src/soc/amd/picasso/Kconfig 3 files changed, 8 insertions(+), 1 deletion(-)
diff --git a/src/soc/amd/common/block/lpc/Kconfig b/src/soc/amd/common/block/lpc/Kconfig index 1ec8dd4..3aaccf3 100644 --- a/src/soc/amd/common/block/lpc/Kconfig +++ b/src/soc/amd/common/block/lpc/Kconfig @@ -24,3 +24,8 @@ help Select this option if mainboard uses eSPI instead of LPC (if supported by platform). + +config SOC_AMD_COMMON_BLOCK_HAS_ESPI_SUB_DECODE + bool + depends on SOC_AMD_COMMON_BLOCK_HAS_ESPI + default n diff --git a/src/soc/amd/common/block/lpc/espi_util.c b/src/soc/amd/common/block/lpc/espi_util.c index 0878fb7..7ee5386 100644 --- a/src/soc/amd/common/block/lpc/espi_util.c +++ b/src/soc/amd/common/block/lpc/espi_util.c @@ -916,7 +916,8 @@ }
/* Enable subtractive decode if configured */ - espi_setup_subtractive_decode(cfg); + if (CONFIG(SOC_AMD_COMMON_BLOCK_HAS_ESPI_SUB_DECODE)) + espi_setup_subtractive_decode(cfg);
return 0; } diff --git a/src/soc/amd/picasso/Kconfig b/src/soc/amd/picasso/Kconfig index da3903b..93d2ef8 100644 --- a/src/soc/amd/picasso/Kconfig +++ b/src/soc/amd/picasso/Kconfig @@ -29,6 +29,7 @@ select SOC_AMD_COMMON select SOC_AMD_COMMON_BLOCK_NONCAR select SOC_AMD_COMMON_BLOCK_HAS_ESPI + select SOC_AMD_COMMON_BLOCK_HAS_ESPI_SUB_DECODE select SOC_AMD_COMMON_BLOCK_IOMMU select SOC_AMD_COMMON_BLOCK_ACPIMMIO select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS
