Arthur Heymans (arthur@aheymans.xyz) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18010
commit 506f13dfce2b7f897b68993001ec2b755f6ab5db Author: Arthur Heymans arthur@aheymans.xyz Date: Mon Jan 2 16:16:45 2017 +0100
[TEST ME]mb/lenovo/t400: Implement hybrid graphic in romstage
The hybrid driver in src/drivers/lenovo/hybrid_graphics.c does not work for t400.
Change-Id: I7496876e9b434d4a2388e1ede27ac604670339b7 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- src/mainboard/lenovo/t400/Kconfig | 1 - src/mainboard/lenovo/t400/cmos.layout | 1 + src/mainboard/lenovo/t400/romstage.c | 68 +++++++++++++++++++++++++++++++++-- 3 files changed, 67 insertions(+), 3 deletions(-)
diff --git a/src/mainboard/lenovo/t400/Kconfig b/src/mainboard/lenovo/t400/Kconfig index 47e7688..f0839c7 100644 --- a/src/mainboard/lenovo/t400/Kconfig +++ b/src/mainboard/lenovo/t400/Kconfig @@ -22,7 +22,6 @@ config BOARD_SPECIFIC_OPTIONS # dummy select MAINBOARD_HAS_NATIVE_VGA_INIT_TEXTMODECFG select INTEL_INT15 select SUPERIO_NSC_PC87382 - select DRIVERS_LENOVO_HYBRID_GRAPHICS
config MAINBOARD_DIR string diff --git a/src/mainboard/lenovo/t400/cmos.layout b/src/mainboard/lenovo/t400/cmos.layout index 61212dd..8583027 100644 --- a/src/mainboard/lenovo/t400/cmos.layout +++ b/src/mainboard/lenovo/t400/cmos.layout @@ -142,6 +142,7 @@ enumerations 11 12 352M 12 0 Integrated Only 12 1 Discrete Only +12 2 switchable
# ----------------------------------------------------------------- checksums diff --git a/src/mainboard/lenovo/t400/romstage.c b/src/mainboard/lenovo/t400/romstage.c index d110d4f..bf43f3c 100644 --- a/src/mainboard/lenovo/t400/romstage.c +++ b/src/mainboard/lenovo/t400/romstage.c @@ -36,6 +36,32 @@ #define LPC_DEV PCI_DEV(0, 0x1f, 0) #define MCH_DEV PCI_DEV(0, 0, 0)
+#define HYBRID_GRAPHICS_INTEGRATED_ONLY 0 +#define HYBRID_GRAPHICS_DISCRETE_ONLY 1 +#define HYBRID_GRAPHICS_SWITCHABLE 2 + +#define MUX_GPIO 22 +#define BCL_CTL_GPIO 19 +#define GFX_PWM_GPIO 49 + +#define HYBRID_DETECT_GPIO 21 + +static void configure_mux_gpio(u8 level) +{ + set_gpio(MUX_GPIO, level); + set_gpio(BCL_CTL_GPIO, level); + set_gpio(GFX_PWM_GPIO, level); +} + +static bool hybrid_graphics_installed(void) +{ + if (get_gpio(21)) + return false; + else + return true; +} + + static void early_lpc_setup(void) { /* Set up SuperIO LPC forwards */ @@ -78,6 +104,46 @@ void mainboard_romstage_entry(unsigned long bist)
setup_pch_gpios(&t400_gpio_map);
+ /* Set up hybrid graphics */ + uint8_t hybrid_graphics_mode = HYBRID_GRAPHICS_INTEGRATED_ONLY; + get_option(&hybrid_graphics_mode, "hybrid_graphics_mode"); + + if (hybrid_graphics_installed()) { + /* Select appropriate hybrid graphics device */ + printk(BIOS_DEBUG, "Hybrid graphics available, "); + printk(BIOS_DEBUG, "setting mode %d\n", hybrid_graphics_mode); + switch (hybrid_graphics_mode) { + case HYBRID_GRAPHICS_INTEGRATED_ONLY: + configure_mux_gpio(GPIO_LEVEL_LOW); + sysinfo.enable_igd = 1; + sysinfo.enable_peg = 0; + break; + case HYBRID_GRAPHICS_DISCRETE_ONLY: + configure_mux_gpio(GPIO_LEVEL_HIGH); + sysinfo.enable_igd = 0; + sysinfo.enable_peg = 1; + break; + case HYBRID_GRAPHICS_SWITCHABLE: + configure_mux_gpio(GPIO_LEVEL_LOW); + sysinfo.enable_igd = 1; + sysinfo.enable_peg = 1; + break; + default: + configure_mux_gpio(GPIO_LEVEL_LOW); + sysinfo.enable_igd = 1; + sysinfo.enable_peg = 0; + break; + } + } else { + /* + *The display is not connected to a mux if no hybrid graphics + * is present + */ + printk(BIOS_DEBUG, "Hybrid graphics not installed\n"); + sysinfo.enable_igd = 1; + sysinfo.enable_peg = 0; + } + /* ASPM related setting, set early by original BIOS. */ DMIBAR16(0x204) &= ~(3 << 10);
@@ -101,8 +167,6 @@ void mainboard_romstage_entry(unsigned long bist) memset(&sysinfo, 0, sizeof(sysinfo)); sysinfo.spd_map[0] = 0x50; sysinfo.spd_map[2] = 0x51; - sysinfo.enable_igd = 1; - sysinfo.enable_peg = 0; get_gmch_info(&sysinfo); raminit(&sysinfo, s3resume);
