Srinidhi N Kaushik has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/40265 )
Change subject: mb/tglrvp: Update iDisp UPD settings. ......................................................................
Signed-off-by: Srinidhi N Kaushik srinidhi.n.kaushik@intel.com Change-Id: I8d3da32d05d12944dc527e347f8afcc634d772cb --- M src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb M src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb 2 files changed, 0 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/40265/1
diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb index 6cef4f8..69b5fb9 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb @@ -115,12 +115,6 @@ register "PchHdaAudioLinkSspEnable[1]" = "0" register "PchHdaAudioLinkSspEnable[2]" = "1" register "PchHdaAudioLinkSndwEnable[0]" = "1" - # iDisp-Link T-Mode 0: 2T, 2: 4T, 3: 8T, 4: 16T - register "PchHdaIDispLinkTmode" = "2" - # iDisp-Link Freq 4: 96MHz, 3: 48MHz. - register "PchHdaIDispLinkFrequency" = "4" - # Not disconnected/enumerable - register "PchHdaIDispCodecDisconnect" = "0"
device domain 0 on #From EDS(575683) diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb b/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb index c5cc800..d7990b5 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb @@ -111,12 +111,6 @@ register "PchHdaAudioLinkSspEnable[1]" = "0" register "PchHdaAudioLinkSspEnable[2]" = "1" register "PchHdaAudioLinkSndwEnable[0]" = "1" - # iDisp-Link T-Mode 0: 2T, 2: 4T, 3: 8T, 4: 16T - register "PchHdaIDispLinkTmode" = "2" - # iDisp-Link Freq 4: 96MHz, 3: 48MHz. - register "PchHdaIDispLinkFrequency" = "4" - # Not disconnected/enumerable - register "PchHdaIDispCodecDisconnect" = "0"
Srinidhi N Kaushik has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/40265 )
Remove explicit setting of iDisp Link parameters. These settings are related to configuration for the link between HD-Audio controller and Display unit for purposes of HDMI/DP Audio playback. During PO, we observed that without setting these params display part was not binding. With the latest code verified that we dont need to explicitly set these parameters anymore. HDMI/DP audio playback works fine with default settings.
BUG=b:151451125 BRANCH:none TEST= build and boot tglrvp and verify HDMI/DP audio playback
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/40265/2
Hello build bot (Jenkins),
Remove explicit setting of iDisp Link parameters. These settings are related to configuration for the link between HD-Audio controller and Display unit for purposes of HDMI/DP Audio playback. During PO, observed that without setting these params display part was not binding. With the latest code verified that we dont need to explicitly set these parameters anymore. HDMI/DP audio playback works fine with default settings.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/65/40265/3
Srinidhi N Kaushik has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/40265 )
Abandoned
