Hello Patrick Rudolph, build bot (Jenkins),
https://review.coreboot.org/19500
Change subject: nb/intel/gm45: Set display backlight according to EDID string ......................................................................
Add some known good values for some thinkpads displays.
Known good means that at this pwm frequency the display is evenly lit on all duty cycles, the display makes minimal to no noise at lower duty cycles and the display does not flicker. This values differs from vendor (which uses an obviously wrong display clock (190MHz instead of 320MHz) resulting in frequency more than 60% off the intended value.
Change-Id: Id7bc0d453fac31e806852206ba2c895720b2c843 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/drivers/intel/gma/edid.h M src/mainboard/lenovo/t400/Makefile.inc A src/mainboard/lenovo/t400/blc.c M src/mainboard/lenovo/x200/Makefile.inc A src/mainboard/lenovo/x200/blc.c M src/mainboard/roda/rk9/Makefile.inc A src/mainboard/roda/rk9/blc.c M src/northbridge/intel/gm45/chip.h M src/northbridge/intel/gm45/gma.c 9 files changed, 146 insertions(+), 6 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/00/19500/11
