Attention is currently required from: Arthur Heymans, Christian Walter, Johnny Lin, Jonathan Zhang, Lean Sheng Tan, Patrick Rudolph, Tim Chu.
Hello Arthur Heymans, Christian Walter, Johnny Lin, Jonathan Zhang, Lean Sheng Tan, Patrick Rudolph, Tim Chu, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81377?usp=email
Change subject: soc/intel/xeon_sp/spr: Support dynamic domain SSDT generation ......................................................................
Domain SSDT is dyanmically generated by soc_pci_domain_fill_ssdt.
SPR has 2 SKUs, XCC and MCC. Dynamic domain SSDT generation could better fit both. One possible side-effect might be the extra performance cost for generating these tables, which should not bring big impact on high performance server CPUs.
TEST=intel/archercity CRB
Linux ACPI host bridge parsing logs are kept the same before and after, with some minor issue fixed.
Change-Id: Icc5843feadc840d87c49b2aa4259716264520dba Signed-off-by: Shuo Liu shuo.liu@intel.com --- M src/soc/intel/xeon_sp/chip_common.c M src/soc/intel/xeon_sp/include/soc/chip_common.h D src/soc/intel/xeon_sp/spr/acpi/cxl_resource.asl D src/soc/intel/xeon_sp/spr/acpi/dino_resource.asl D src/soc/intel/xeon_sp/spr/acpi/iiostack.asl D src/soc/intel/xeon_sp/spr/acpi/pci_resource.asl D src/soc/intel/xeon_sp/spr/acpi/ubox_resource.asl M src/soc/intel/xeon_sp/spr/acpi/uncore.asl M src/soc/intel/xeon_sp/spr/soc_acpi.c 9 files changed, 72 insertions(+), 322 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/77/81377/4
