Joel Kitching has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/31923
Change subject: vboot: move assert in vboot_migrate_cbmem ......................................................................
Fix a potential null pointer dereference when calling memcpy. assert should be before the memcpy call, and not after.
BUG=b:124141368, b:124192753 TEST=util/lint/checkpatch.pl -g origin/master..HEAD TEST=util/abuild/abuild -B -e -y -c 50 -p none -x TEST=make clean && make test-abuild BRANCH=none
Change-Id: I5a2a99e906b9aa3bb33e1564d8d33a0aca7d06ac Signed-off-by: Joel Kitching kitching@google.com --- M src/security/vboot/common.c 1 file changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/23/31923/1
diff --git a/src/security/vboot/common.c b/src/security/vboot/common.c index 496ab78..47e1aa4 100644 --- a/src/security/vboot/common.c +++ b/src/security/vboot/common.c @@ -163,11 +163,12 @@ size_t cbmem_size = wd_preram->buffer_offset + wd_preram->buffer_size; struct vboot_working_data *wd_cbmem = cbmem_add(CBMEM_ID_VBOOT_WORKBUF, cbmem_size); + assert(wd_cbmem != NULL); + printk(BIOS_DEBUG, "VBOOT: copying vboot_working_data (%zu bytes) to CBMEM...\n", cbmem_size); memcpy(wd_cbmem, wd_preram, cbmem_size); - assert(wd_cbmem != NULL); } ROMSTAGE_CBMEM_INIT_HOOK(vboot_migrate_cbmem) #elif CONFIG(VBOOT_STARTS_IN_ROMSTAGE)
Joel Kitching has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31923 )
Patch Set 1: Code-Review+1
Furquan Shaikh has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/31923 )
Patch Set 1: Code-Review+2
Patrick Georgi has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/31923 )
Change-Id: I5a2a99e906b9aa3bb33e1564d8d33a0aca7d06ac Signed-off-by: Joel Kitching kitching@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/31923 Reviewed-by: Furquan Shaikh furquan@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/security/vboot/common.c 1 file changed, 2 insertions(+), 1 deletion(-)
Approvals: build bot (Jenkins): Verified Furquan Shaikh: Looks good to me, approved Joel Kitching: Looks good to me, but someone else must approve
