Johnny Lin has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/36843 )
Change subject: mb/ocp/monolake: Override SMBIOS UUID with the value get from BMC ......................................................................
Tested on OCP Mono Lake with dmidecode -t 1 and the UUID is expected.
Change-Id: I0aab4df67b7aaba8be6ddbb13984fffb2b14fe6b Signed-off-by: Johnny Lin johnny_lin@wiwynn.com --- M src/mainboard/ocp/monolake/mainboard.c 1 file changed, 5 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/36843/1
diff --git a/src/mainboard/ocp/monolake/mainboard.c b/src/mainboard/ocp/monolake/mainboard.c index dffd19f..3cfb3b6 100644 --- a/src/mainboard/ocp/monolake/mainboard.c +++ b/src/mainboard/ocp/monolake/mainboard.c @@ -95,3 +95,8 @@ dimm->dimm_num); t->bank_locator = smbios_add_string(t->eos, locator); } +/* Override SMBIOS uuid from the value get from BMC. */ +void smbios_system_set_uuid(u8 *uuid) +{ + ipmi_get_system_guid(BMC_KCS_BASE, uuid); +}
Johnny Lin has removed Alexander Morgan from this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Removed reviewer Alexander Morgan.
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Patch Set 1: Code-Review+1
https://review.coreboot.org/c/coreboot/+/36843/1/src/mainboard/ocp/monolake/... File src/mainboard/ocp/monolake/mainboard.c:
https://review.coreboot.org/c/coreboot/+/36843/1/src/mainboard/ocp/monolake/... PS1, Line 97: } add a newline please
Hello Andrey Petrov, Patrick Rudolph, Jingle Hsu, Morgan Jang, Patrick Rudolph, Jonathan Zhang, David Hendricks, Philipp Deppenwiese, build bot (Jenkins),
Change-Id: I0aab4df67b7aaba8be6ddbb13984fffb2b14fe6b Signed-off-by: Johnny Lin johnny_lin@wiwynn.com --- M src/mainboard/ocp/monolake/mainboard.c 1 file changed, 6 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/43/36843/4
Johnny Lin has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Patch Set 4:
Done
David Hendricks has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Patch Set 4: Code-Review+2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Patch Set 4:
(3 comments)
https://review.coreboot.org/c/coreboot/+/36843/4//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/36843/4//COMMIT_MSG@7 PS4, Line 7: value get from BMC
value sent by BMC
or
value from BMC
https://review.coreboot.org/c/coreboot/+/36843/4//COMMIT_MSG@9 PS4, Line 9: and the UUID is expected the expected UUID is visible.
https://review.coreboot.org/c/coreboot/+/36843/4/src/mainboard/ocp/monolake/... File src/mainboard/ocp/monolake/mainboard.c:
https://review.coreboot.org/c/coreboot/+/36843/4/src/mainboard/ocp/monolake/... PS4, Line 99: value get from BMC value from BMC
Patch Set 4:
Patch Set 4:
(3 comments)
Hi Pual, Because BROADWELL-DE support will be removed from master branch, I think I will abandon this change and cherry-pick it to 4.11_branch and continue. Is that ok? Thanks.
Johnny Lin has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/36843 )
Abandoned
Broadwell-DE will be removed on master, cherry-pick to 4.11_branch to continue.
