Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/63184 )
Change subject: util/amdfwtool: select A/B recovery when ISH is used ......................................................................
In newer AMD SoCs, the image slot header is used in the AMD A/B recovery scheme, so set recovery_ab to true when need_ish is true. Also move the block of code before the process_config call, since that call will already use the recovery_ab field of the cb_config struct.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I65903765514f215bf5cc9b949d0b95aff781eb34 Reviewed-on: https://review.coreboot.org/c/coreboot/+/63184 Reviewed-by: Raul Rangel rrangel@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M util/amdfwtool/amdfwtool.c 1 file changed, 6 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Raul Rangel: Looks good to me, approved
diff --git a/util/amdfwtool/amdfwtool.c b/util/amdfwtool/amdfwtool.c index 9e7f920..7c977a2 100644 --- a/util/amdfwtool/amdfwtool.c +++ b/util/amdfwtool/amdfwtool.c @@ -1684,6 +1684,12 @@ } }
+ if (cb_config.need_ish) + cb_config.recovery_ab = true; + + if (cb_config.recovery_ab) + cb_config.multi_level = true; + if (config) { config_handle = fopen(config, "r"); if (config_handle == NULL) { @@ -1724,10 +1730,6 @@ retval = 1; }
- if (cb_config.recovery_ab) { - cb_config.multi_level = true; - } - if (retval) { usage(); return retval;
