Attention is currently required from: Tim Wawrzynczak, Wisley Chen. Hello build bot (Jenkins), Tim Wawrzynczak, Wisley Chen,
https://review.coreboot.org/c/coreboot/+/60889
Change subject: mb/google/brya/var/agah: move memory makefile to correct path ......................................................................
Move memory Makefile.inc and dram_id.generated.txt to correct path
BUG=b:210970640 TEST=emerge-brya coreboot
Change-Id: Ib5d9d9dd6f881f0b9cf2736809a74e5045c3c217 Signed-off-by: Tony Huang tony-huang@quanta.corp-partner.google.com --- D src/mainboard/google/brya/variants/agah/Makefile.inc M src/mainboard/google/brya/variants/agah/memory/Makefile.inc M src/mainboard/google/brya/variants/agah/memory/dram_id.generated.txt 3 files changed, 27 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/89/60889/3
