Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/79956?usp=email )
Change subject: libpayload/vboot/Makefile.inc: Pass FIRMWARE_ARCH=mock if LP_ARCH_MOCK ......................................................................
If CONFIG_LP_ARCH_MOCK, pass FIRMWARE_ARCH=mock when building vboot fwlib, so that vboot's Makefile will append the correct flags to CFLAGS.
BUG=none TEST=(depthcharge) make unit-tests -j BRANCH=none
Cq-Depend: chromium:5182247 Change-Id: I9ead7f2f93eac5f5c3887074423fb9aa50a489c0 Signed-off-by: Yu-Ping Wu yupingso@chromium.org Reviewed-on: https://review.coreboot.org/c/coreboot/+/79956 Reviewed-by: Julius Werner jwerner@chromium.org Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M payloads/libpayload/vboot/Makefile.inc 1 file changed, 11 insertions(+), 8 deletions(-)
Approvals: build bot (Jenkins): Verified Julius Werner: Looks good to me, approved
diff --git a/payloads/libpayload/vboot/Makefile.inc b/payloads/libpayload/vboot/Makefile.inc index 9904fff..bdc9ad2a 100644 --- a/payloads/libpayload/vboot/Makefile.inc +++ b/payloads/libpayload/vboot/Makefile.inc @@ -13,22 +13,25 @@ $(patsubst include/%.h,$(top)/include/%.h,\ $(filter-out -I$(obj),\ $(filter-out -I$(coreboottop)/%,$(1))))) -ifeq ($(CONFIG_LP_ARCH_MOCK),) -VBOOT_CFLAGS += $(call vboot-fixup-includes,$(CFLAGS)) -VBOOT_CFLAGS += -I$(abspath $(obj)) -endif - -# Enable vboot debug by default -VBOOT_CFLAGS += -DVBOOT_DEBUG
VBOOT_FIRMWARE_ARCH-$(CONFIG_LP_ARCH_ARM) := arm VBOOT_FIRMWARE_ARCH-$(CONFIG_LP_ARCH_X86) := x86 VBOOT_FIRMWARE_ARCH-$(CONFIG_LP_ARCH_ARM64) := arm64
-ifeq ($(CONFIG_LP_ARCH_MOCK)$(VBOOT_FIRMWARE_ARCH-y),) +ifneq ($(CONFIG_LP_ARCH_MOCK),) +VBOOT_FIRMWARE_ARCH-y := mock +else +VBOOT_CFLAGS += $(call vboot-fixup-includes,$(CFLAGS)) +VBOOT_CFLAGS += -I$(abspath $(obj)) +endif + +ifeq ($(VBOOT_FIRMWARE_ARCH-y),) $(error vboot requires architecture to be set in the configuration) endif
+# Enable vboot debug by default +VBOOT_CFLAGS += -DVBOOT_DEBUG + ifeq ($(CONFIG_LP_VBOOT_X86_RSA_ACCELERATION),y) CPPFLAGS_common += -DVB2_X86_RSA_ACCELERATION endif
