Thomas Weißschuh has uploaded this change for review. ( https://review.coreboot.org/23047
Change subject: [util/vgabios_extract] hookup to build system ......................................................................
Allows the automatic extraction and usage of a VGA BIOS from an UEFI dump.
Change-Id: Ib792ff7c22853eb11ebec7fc834353eb3cbc5ad9 Signed-off-by: Thomas Weißschuh thomas@t-8ch.de --- M src/arch/x86/Makefile.inc M src/device/Kconfig 2 files changed, 30 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/23047/1
diff --git a/src/arch/x86/Makefile.inc b/src/arch/x86/Makefile.inc index cc227b3..3f2f1e4 100644 --- a/src/arch/x86/Makefile.inc +++ b/src/arch/x86/Makefile.inc @@ -38,9 +38,24 @@ $(NVRAMTOOL) -y $(top)/src/mainboard/$(MAINBOARDDIR)/cmos.layout -H $@ endif # CONFIG_HAVE_OPTION_TABLE
+vgabios-rom=$(obj)/vgabios.rom + +ifeq ($(CONFIG_VGA_BIOS_EXTRACT),y) + +$(vgabios-rom): $(call strip_quotes,$(CONFIG_VGA_BIOS_EXTRACT_FILE)) + @printf " VGA_BIOS_EXTRACT $(CONFIG_VGA_BIOS_EXTRACT_FILE) $(vgabios-rom)\n" + util/vgabios_extract/vgabios_extract.py $(CONFIG_VGA_BIOS_EXTRACT_FILE) $(vgabios-rom) + +else + +$(vgabios-rom): $(call strip_quotes,$(CONFIG_VGA_BIOS_FILE)) + $(CP) $(vgabios-rom) $(CONFIG_VGA_BIOS_FILE) + +endif + stripped_vgabios_id = $(call strip_quotes,$(CONFIG_VGA_BIOS_ID)) cbfs-files-$(CONFIG_VGA_BIOS) += pci$(stripped_vgabios_id).rom -pci$(stripped_vgabios_id).rom-file := $(call strip_quotes,$(CONFIG_VGA_BIOS_FILE)) +pci$(stripped_vgabios_id).rom-file := $(vgabios-rom) pci$(stripped_vgabios_id).rom-type := optionrom
cbfs-files-$(CONFIG_INTEL_MBI) += mbi.bin diff --git a/src/device/Kconfig b/src/device/Kconfig index 28298d5..a6b1168 100644 --- a/src/device/Kconfig +++ b/src/device/Kconfig @@ -566,11 +566,23 @@ like to add to your ROM.
You will be able to specify the location and file name of the - image later. + false + +config VGA_BIOS_EXTRACT + bool "Extract VGA BIOS from BIOS image" + depends on VGA_BIOS + default n + +config VGA_BIOS_EXTRACT_FILE + string "VGA BIOS extract path and filename" + depends on VGA_BIOS_EXTRACT + default "3rdpart/blobs/mainboard/$(MAINBOARDDIR)/bios.bin" + help + The path and filename of the file to extract the VGA BIOS from.
config VGA_BIOS_FILE string "VGA BIOS path and filename" - depends on VGA_BIOS + depends on VGA_BIOS && !VGA_BIOS_EXTRACT default "vgabios.bin" help The path and filename of the file to use as VGA BIOS.
