Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/52874 )
Change subject: soc/intel/{adl,tgl,jsl}: Enable power button smi after BS_CHIPS_EXIT ......................................................................
On tgl, we noticed system hang if a shutdown is triggered before fsps. The dut is unable to shutdown properly due to tcss is stuck before tcss_init in fsps.
This change enable power button smi on jsl, tgl, adl after fsps. it can also prevent a shutdown failure due to lack of fsps init on certain ip.
BUG=b:186194102, b:186815114 TEST=Power on the system and pressing power button repeatedly doesn't cause the system hang during shutdown.
Change-Id: I70b871f2676a89bc782116e02beba5c20ec51eef Signed-off-by: Kane Chen kane.chen@intel.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/52874 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Tim Wawrzynczak twawrzynczak@chromium.org --- M src/soc/intel/alderlake/cpu.c M src/soc/intel/alderlake/pmc.c M src/soc/intel/jasperlake/cpu.c M src/soc/intel/jasperlake/pmc.c M src/soc/intel/tigerlake/cpu.c M src/soc/intel/tigerlake/pmc.c 6 files changed, 38 insertions(+), 6 deletions(-)
diff --git a/src/soc/intel/alderlake/cpu.c b/src/soc/intel/alderlake/cpu.c index 6de1cb0..b975212 100644 --- a/src/soc/intel/alderlake/cpu.c +++ b/src/soc/intel/alderlake/cpu.c @@ -99,10 +99,12 @@ cpu_set_max_ratio();
/* - * Now that all APs have been relocated as well as the BSP let SMIs + * 1. Now that all APs have been relocated as well as the BSP let SMIs * start flowing. + * 2. Skip enabling power button SMI and enable it after BS_CHIPS_INIT + * to avoid shutdown hang due to lack of init on certain IP in FSP-S. */ - global_smi_enable(); + global_smi_enable_no_pwrbtn(); }
static const struct mp_ops mp_ops = { diff --git a/src/soc/intel/alderlake/pmc.c b/src/soc/intel/alderlake/pmc.c index e4c1009..03399c3 100644 --- a/src/soc/intel/alderlake/pmc.c +++ b/src/soc/intel/alderlake/pmc.c @@ -18,6 +18,7 @@ #include <soc/pm.h> #include <soc/soc_chip.h> #include <stdint.h> +#include <bootstate.h>
#define PMC_HID "INTC1026"
@@ -141,6 +142,14 @@ pmc_set_acpi_mode(); }
+static void pm1_enable_pwrbtn_smi(void *unused) +{ + /* Enable power button SMI after BS_DEV_INIT_CHIPS (FSP-S) is done. */ + pmc_update_pm1_enable(PWRBTN_EN); +} + +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT_CHIPS, BS_ON_EXIT, pm1_enable_pwrbtn_smi, NULL); + struct device_operations pmc_ops = { .read_resources = soc_pmc_read_resources, .set_resources = noop_set_resources, diff --git a/src/soc/intel/jasperlake/cpu.c b/src/soc/intel/jasperlake/cpu.c index 8e54eaa..86077ff 100644 --- a/src/soc/intel/jasperlake/cpu.c +++ b/src/soc/intel/jasperlake/cpu.c @@ -93,10 +93,12 @@ cpu_set_max_ratio();
static const struct mp_ops mp_ops = { diff --git a/src/soc/intel/jasperlake/pmc.c b/src/soc/intel/jasperlake/pmc.c index c0507d6..dce791c 100644 --- a/src/soc/intel/jasperlake/pmc.c +++ b/src/soc/intel/jasperlake/pmc.c @@ -93,6 +93,14 @@ pmc_set_acpi_mode(); }
+static void pm1_enable_pwrbtn_smi(void *unused) +{ + /* Enable power button SMI after BS_DEV_INIT_CHIPS (FSP-S) is done. */ + pmc_update_pm1_enable(PWRBTN_EN); +} + +BOOT_STATE_INIT_ENTRY(BS_DEV_INIT_CHIPS, BS_ON_EXIT, pm1_enable_pwrbtn_smi, NULL); + struct device_operations pmc_ops = { .read_resources = soc_pmc_read_resources, .set_resources = noop_set_resources, diff --git a/src/soc/intel/tigerlake/cpu.c b/src/soc/intel/tigerlake/cpu.c index 925bddb..7bb9e61 100644 --- a/src/soc/intel/tigerlake/cpu.c +++ b/src/soc/intel/tigerlake/cpu.c @@ -99,10 +99,12 @@ cpu_set_max_ratio();
static const struct mp_ops mp_ops = { diff --git a/src/soc/intel/tigerlake/pmc.c b/src/soc/intel/tigerlake/pmc.c index c5a4ae5..190f3ff 100644 --- a/src/soc/intel/tigerlake/pmc.c +++ b/src/soc/intel/tigerlake/pmc.c @@ -18,6 +18,7 @@ #include <soc/pci_devs.h> #include <soc/pm.h> #include <soc/soc_chip.h> +#include <bootstate.h>
@@ -145,6 +146,14 @@ pmc_set_acpi_mode(); }
