Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/28007
Change subject: sb/intel/lynxpoint/Kconfig: Clean up redefined config options ......................................................................
HAVE_IFD_BIN and the likes are redefined in southbridge/intel/common/Kconfig which presents options under the 'Intel Firmware' section which gets sourced later than the 'southbridge' section therefore overriding this anyway.
Also all board using this target override HAVE_IFD_BIN to default n, so it is simpler to just use the defaults in southbridge/intel/common/firmware.
Change-Id: I9999440031b07006e2df11e00dfb9f3dbe04f832 Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/mainboard/google/beltino/Kconfig M src/mainboard/google/slippy/Kconfig M src/mainboard/intel/baskingridge/Kconfig M src/southbridge/intel/lynxpoint/Kconfig 4 files changed, 0 insertions(+), 42 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/28007/1
diff --git a/src/mainboard/google/beltino/Kconfig b/src/mainboard/google/beltino/Kconfig index 428db73..aaec9f7 100644 --- a/src/mainboard/google/beltino/Kconfig +++ b/src/mainboard/google/beltino/Kconfig @@ -65,12 +65,4 @@ string default "pci8086,0406.rom"
-config HAVE_IFD_BIN - bool - default n - -config HAVE_ME_BIN - bool - default n - endif # BOARD_GOOGLE_BASEBOARD_BELTINO diff --git a/src/mainboard/google/slippy/Kconfig b/src/mainboard/google/slippy/Kconfig index c43b713..6891c0b 100644 --- a/src/mainboard/google/slippy/Kconfig +++ b/src/mainboard/google/slippy/Kconfig @@ -73,12 +73,4 @@ string default "pci8086,0406.rom"
-config HAVE_IFD_BIN - bool - default n - -config HAVE_ME_BIN - bool - default n - endif # BOARD_GOOGLE_BASEBOARD_SLIPPY diff --git a/src/mainboard/intel/baskingridge/Kconfig b/src/mainboard/intel/baskingridge/Kconfig index 445dbcb..1fd07c2 100644 --- a/src/mainboard/intel/baskingridge/Kconfig +++ b/src/mainboard/intel/baskingridge/Kconfig @@ -37,12 +37,4 @@ string default "pci8086,0166.rom"
-config HAVE_IFD_BIN - bool - default n - -config HAVE_ME_BIN - bool - default n - endif # BOARD_INTEL_BASKING_RIDGE diff --git a/src/southbridge/intel/lynxpoint/Kconfig b/src/southbridge/intel/lynxpoint/Kconfig index 8d5cbbf..4e5527a 100644 --- a/src/southbridge/intel/lynxpoint/Kconfig +++ b/src/southbridge/intel/lynxpoint/Kconfig @@ -57,28 +57,10 @@ If you set this option to y, the serial IRQ machine will be operated in continuous mode.
-config HAVE_IFD_BIN - bool - default y - config BUILD_WITH_FAKE_IFD bool default y if !HAVE_IFD_BIN
-config IFD_BIN_PATH - string - depends on !BUILD_WITH_FAKE_IFD - default "3rdparty/blobs/mainboard/$(MAINBOARDDIR)/descriptor.bin" - -config HAVE_ME_BIN - bool - default y - -config ME_BIN_PATH - string - depends on HAVE_ME_BIN - default "3rdparty/blobs/mainboard/$(MAINBOARDDIR)/me.bin" - config ME_MBP_CLEAR_LATE bool "Defer wait for ME MBP Cleared" default y
