the following patch was just integrated into master: commit 8ba235e2acf2c15ca5484ed51001d6555b082a51 Author: Martin Roth martinroth@google.com Date: Sat Mar 12 20:15:18 2016 -0700
genbuild_h: Fix numeric comparison to remove error
Change the comparison of build_timeless from -eq to =
This was generating an error if BUILD_TIMELESS wasn't set: util/genbuild_h/genbuild_h.sh: line 27: [: : integer expression expected
This wasn't causing the script to fail, and won't even if 'set -e' is added to the script because the error happens inside an 'if' clause, which is specifically excluded from failue on 'set -e'.
Change-Id: I6a4e147ece23e83ee682d72db35be9e5d4088c78 Signed-off-by: Martin Roth martinroth@google.com Reviewed-on: https://review.coreboot.org/14080 Tested-by: build bot (Jenkins) Reviewed-by: Paul Menzel paulepanter@users.sourceforge.net Reviewed-by: Alexander Couzens lynxis@fe80.eu Reviewed-by: Patrick Georgi pgeorgi@google.com
See https://review.coreboot.org/14080 for details.
