Bill XIE has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/74180 )
Change subject: nb/intel/gm45: Export EDID-reading routine as a function ......................................................................
It will cache decoded EDID string in a static array. If called more than once, a pointer to the static array is directly returned, without reading EDID again.
Signed-off-by: Bill XIE persmule@hardenedlinux.org Change-Id: Ibdbe4d76f9b59e7ae83b60cda042c2d1c39827ca --- M src/northbridge/intel/gm45/gm45.h M src/northbridge/intel/gm45/gma.c 2 files changed, 49 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/80/74180/1
diff --git a/src/northbridge/intel/gm45/gm45.h b/src/northbridge/intel/gm45/gm45.h index f28c6d1..089d19a 100644 --- a/src/northbridge/intel/gm45/gm45.h +++ b/src/northbridge/intel/gm45/gm45.h @@ -447,6 +447,9 @@ u16 get_blc_pwm_freq_value(const char *edid_ascii_string);
#include <device/device.h> +#include <edid.h> + +const char *get_edid_str(struct device *dev);
struct acpi_rsdp; unsigned long northbridge_write_acpi_tables(const struct device *device, unsigned long start, diff --git a/src/northbridge/intel/gm45/gma.c b/src/northbridge/intel/gm45/gma.c index 8043822..a59bcea 100644 --- a/src/northbridge/intel/gm45/gma.c +++ b/src/northbridge/intel/gm45/gma.c @@ -143,18 +143,19 @@ reg8)); }
-static void gma_func0_init(struct device *dev) +const char *get_edid_str(struct device *dev) { u8 *mmio; u8 edid_data_lvds[128]; struct edid edid_lvds; - const struct northbridge_intel_gm45_config *const conf = dev->chip_info; + static char edid_str[EDID_ASCII_STRING_LENGTH + 1];
- intel_gma_init_igd_opregion(); + if (edid_str[0]) + return edid_str;
gtt_res = probe_resource(dev, PCI_BASE_ADDRESS_0); if (!gtt_res) - return; + return NULL; mmio = res2mmio(gtt_res, 0, 0);
/* @@ -163,9 +164,33 @@ */ pci_or_config16(dev, PCI_COMMAND, PCI_COMMAND_MASTER); memset(mmio + 2 * MiB, 0, 2 * MiB); + pci_and_config16(dev, PCI_COMMAND, ~PCI_COMMAND_MASTER);
- if (CONFIG(NO_GFX_INIT)) - pci_and_config16(dev, PCI_COMMAND, ~PCI_COMMAND_MASTER); + printk(BIOS_DEBUG, "LVDS EDID\n"); + intel_gmbus_read_edid(mmio + GMBUS0, GMBUS_PORT_PANEL, 0x50, + edid_data_lvds, sizeof(edid_data_lvds)); + intel_gmbus_stop(mmio + GMBUS0); + + if (decode_edid(edid_data_lvds, sizeof(edid_data_lvds), &edid_lvds) + != EDID_CONFORMANT) + return NULL; + memcpy(edid_str, edid_lvds.ascii_string, sizeof(edid_str)); + return edid_str; +} + +static void gma_func0_init(struct device *dev) +{ + const struct northbridge_intel_gm45_config *const conf = dev->chip_info; + const char *edid_str; + + intel_gma_init_igd_opregion(); + + edid_str = get_edid_str(dev); + if (!edid_str) + printk(BIOS_ERR, "Failed to obtain LVDS EDID string!\n"); + + if (!CONFIG(NO_GFX_INIT)) + pci_or_config16(dev, PCI_COMMAND, PCI_COMMAND_MASTER);
if (!CONFIG(MAINBOARD_USE_LIBGFXINIT)) { /* PCI Init, will run VBIOS */ @@ -173,14 +198,8 @@ pci_dev_init(dev); }
- printk(BIOS_DEBUG, "LVDS EDID\n"); - intel_gmbus_read_edid(mmio + GMBUS0, GMBUS_PORT_PANEL, 0x50, - edid_data_lvds, sizeof(edid_data_lvds)); - intel_gmbus_stop(mmio + GMBUS0); - decode_edid(edid_data_lvds, sizeof(edid_data_lvds), &edid_lvds); - /* Post VBIOS init */ - gma_pm_init_post_vbios(dev, edid_lvds.ascii_string); + gma_pm_init_post_vbios(dev, edid_str);
if (CONFIG(MAINBOARD_USE_LIBGFXINIT) && !acpi_is_wakeup_s3()) { int vga_disable = (pci_read_config16(dev, D0F0_GGC) & 2) >> 1;
