Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/28908
Change subject: LinuxBoot/arm64: Remove firmware from defconfig ......................................................................
The extra firmware is not part of upstream kernel. Fixes build error if the firmware is not present.
Change-Id: Ifbcb0bb0e2edf3aa260b40dfa339812019f9f0b3 Signed-off-by: Patrick Rudolph patrick.rudolph@9elements.com --- M payloads/external/LinuxBoot/arm64/defconfig 1 file changed, 0 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/08/28908/1
diff --git a/payloads/external/LinuxBoot/arm64/defconfig b/payloads/external/LinuxBoot/arm64/defconfig index 6f68019..ffb6702 100644 --- a/payloads/external/LinuxBoot/arm64/defconfig +++ b/payloads/external/LinuxBoot/arm64/defconfig @@ -114,7 +114,6 @@ CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" CONFIG_DEVTMPFS=y CONFIG_DEVTMPFS_MOUNT=y -CONFIG_EXTRA_FIRMWARE="cpt8x-mc-ae.out cpt8x-mc-se.out" CONFIG_DMA_CMA=y CONFIG_MTD=y CONFIG_MTD_NAND=y
