Patrick Georgi (pgeorgi@google.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/10996
commit 8af9115871047ea46e1644106db4a44b2a91dd0d Author: rsatapat rishavnath.satapathy@intel.com Date: Mon Jul 6 21:03:02 2015 +0530
intel/common: remove printk in pre_console_init()
printk called before console init causes sluggish execution because of Rx timeout.
BRANCH=None BUG=chrome-os-partner:40857 TEST=Built for sklrvp and tested LPSS logs on RVP3 and Kunimitsu.
Change-Id: I61d5c0f5a4e93695bcba90b7ac7d4f68e2d625be Signed-off-by: Patrick Georgi pgeorgi@chromium.org Original-Commit-Id: 77c58702c8279c6d9c6ae1c946bf1b76df20714d Original-Change-Id: Ib85029456059248cc2c88aaccba4fa12cc5a76be Original-Signed-off-by: rsatapat rishavnath.satapathy@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/284823 Original-Reviewed-by: Aaron Durbin adurbin@chromium.org Original-Commit-Queue: Wenkai Du wenkai.du@intel.com Original-Tested-by: Wenkai Du wenkai.du@intel.com --- src/soc/intel/common/romstage.c | 1 - 1 file changed, 1 deletion(-)
diff --git a/src/soc/intel/common/romstage.c b/src/soc/intel/common/romstage.c index 919de83..370d973 100644 --- a/src/soc/intel/common/romstage.c +++ b/src/soc/intel/common/romstage.c @@ -231,7 +231,6 @@ __attribute__((weak)) void mainboard_check_ec_image( __attribute__((weak)) void mainboard_pre_console_init( struct romstage_params *params) { - printk(BIOS_DEBUG, "WEAK: %s/%s called\n", __FILE__, __func__); }
/* Board initialization before and after RAM is enabled */
