Venkateswarlu V Vinjamuri (venkateswarlu.v.vinjamuri@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15776
commit 3ff6bae8b28d675e41776002367d7a128d09bdd2 Author: Shankar, Vaibhav vaibhav.shankar@intel.com Date: Wed Jul 13 14:00:08 2016 -0700
soc/intel/apollolake: Add iosstate macros for GPIO
IO Standby State (IOSSTATE): The I/O Standby State defines which state the pad should be parked in when the I/O is in a standby state. Iosstate set to 15 means IO-Standby is ignored for this pin (same as functional mode), So that pin keeps on functioning in S3/S0iX.
Change-Id: Ie51ff86a2ea63fa6535407fcc2df7a137ee43e8b Signed-off-by: Venkateswarlu Vinjamuri venkateswarlu.v.vinjamuri@intel.com Signed-off-by: Shankar, Vaibhav vaibhav.shankar@intel.com --- src/soc/intel/apollolake/gpio.c | 11 ++++++++++- src/soc/intel/apollolake/include/soc/gpio.h | 6 ++++++ src/soc/intel/apollolake/include/soc/gpio_defs.h | 22 ++++++++++++++++++++++ 3 files changed, 38 insertions(+), 1 deletion(-)
diff --git a/src/soc/intel/apollolake/gpio.c b/src/soc/intel/apollolake/gpio.c index a3ffb3d..2d32525 100644 --- a/src/soc/intel/apollolake/gpio.c +++ b/src/soc/intel/apollolake/gpio.c @@ -85,10 +85,19 @@ static void gpio_configure_itss(const struct pad_config *cfg,
void gpio_configure_pad(const struct pad_config *cfg) { + uint32_t dw1; const struct pad_community *comm = gpio_get_community(cfg->pad); uint16_t config_offset = PAD_CFG_OFFSET(cfg->pad - comm->first_pad); + + /* Iostandby bits are tentatively stored in [3:0] bits (RO) of config1. + * dw1 is used to extract the bits of Iostandby. + * This is done to preserve config1 size as unit16 in gpio.h. + */ + dw1 = cfg->config1 & ~PAD_CFG1_IOSSTATE_MASK; + dw1 |= (cfg->config1 & PAD_CFG1_IOSSTATE_MASK) << PAD_CFG1_IOSSTATE_SHIFT; + iosf_write(comm->port, config_offset, cfg->config0); - iosf_write(comm->port, config_offset + sizeof(uint32_t), cfg->config1); + iosf_write(comm->port, config_offset + sizeof(uint32_t), dw1);
gpio_configure_itss(cfg, comm->port, config_offset); } diff --git a/src/soc/intel/apollolake/include/soc/gpio.h b/src/soc/intel/apollolake/include/soc/gpio.h index 1ebac2d..56c2407 100644 --- a/src/soc/intel/apollolake/include/soc/gpio.h +++ b/src/soc/intel/apollolake/include/soc/gpio.h @@ -28,6 +28,7 @@ typedef uint32_t gpio_t; #define PAD_FUNC(value) PAD_CFG0_MODE_##value #define PAD_RESET(value) PAD_CFG0_RESET_##value #define PAD_PULL(value) PAD_CFG1_PULL_##value +#define PAD_IOSSTATE(value) PAD_CFG1_IOSSTATE_##value #define PAD_IRQ_CFG(route, trig, inv) \ (PAD_CFG0_ROUTE_##route | \ PAD_CFG0_TRIG_##trig | \ @@ -44,6 +45,11 @@ typedef uint32_t gpio_t; #define PAD_CFG_NF(pad, pull, rst, func) \ _PAD_CFG_STRUCT(pad, PAD_RESET(rst) | PAD_FUNC(func), PAD_PULL(pull))
+/* Native function configuration for standby state */ +#define PAD_CFG_NF_IOSSTATE(pad, pull, rst, func, iosstate) \ + _PAD_CFG_STRUCT(pad, PAD_RESET(rst) | PAD_FUNC(func), (PAD_PULL(pull) | \ + PAD_IOSSTATE(iosstate))) + /* General purpose output, no pullup/down. */ #define PAD_CFG_GPO(pad, val, rst) \ _PAD_CFG_STRUCT(pad, \ diff --git a/src/soc/intel/apollolake/include/soc/gpio_defs.h b/src/soc/intel/apollolake/include/soc/gpio_defs.h index 48e08e7..c46f24a 100644 --- a/src/soc/intel/apollolake/include/soc/gpio_defs.h +++ b/src/soc/intel/apollolake/include/soc/gpio_defs.h @@ -86,6 +86,28 @@ #define PAD_CFG1_PULL_UP_20K (0xc << 10) #define PAD_CFG1_PULL_UP_667 (0xd << 10) #define PAD_CFG1_PULL_NATIVE (0xf << 10) +#define PAD_CFG1_IOSSTATE_IOSS0 (0x0 << 0) /* Tx enabled driving last value + driven, Rx enabled */ +#define PAD_CFG1_IOSSTATE_IOSS1 (0x1 << 0) /* Tx enabled driving 0, Rx disabled + and Rx driving 0 back to its controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS2 (0x2 << 0) /* Tx enabled driving 0, Rx disabled + and Rx driving 1 back to its controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS3 (0x3 << 0) /* Tx enabled driving 1, Rx disabled + and Rx driving 0 back to its controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS4 (0x4 << 0) /* Tx enabled driving 1, Rx disabled + and Rx driving 1 back to its controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS5 (0x5 << 0) /* Tx enabled driving 0, + Rx enabled */ +#define PAD_CFG1_IOSSTATE_IOSS6 (0x6 << 0) /* Tx enabled driving 1, + Rx enabled */ +#define PAD_CFG1_IOSSTATE_IOSS7 (0x7 << 0) /* Hi-Z, Rx driving 0 back to its + controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS8 (0x8 << 0) /* Hi-Z, Rx driving 1 back to its + controller internally */ +#define PAD_CFG1_IOSSTATE_IOSS9 (0x9 << 0) /* Tx disabled, Rx enabled */ +#define PAD_CFG1_IOSSTATE_IGNORE (0xf << 0) /* Ignore Iostandby */ +#define PAD_CFG1_IOSSTATE_MASK 0xf /* mask to extract Iostandby bits */ +#define PAD_CFG1_IOSSTATE_SHIFT 14 /* set Iostandby bits [17:14] */
#define PAD_CFG_BASE 0x500 #define PAD_CFG_OFFSET(pad) (PAD_CFG_BASE + ((pad) * 8))
