Elyes HAOUAS has uploaded this change for review. ( https://review.coreboot.org/25857
Change subject: drivers/ati/ragexl: Add whitespace around '==' ......................................................................
Change-Id: Ia7920c334f6c5e0ed67a6899715cee3552227014 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- M src/drivers/ati/ragexl/atyfb.h M src/drivers/ati/ragexl/mach64_ct.c M src/drivers/ati/ragexl/xlinit.c 3 files changed, 28 insertions(+), 28 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/25857/1
diff --git a/src/drivers/ati/ragexl/atyfb.h b/src/drivers/ati/ragexl/atyfb.h index df8dd3d..6ed6ac9 100644 --- a/src/drivers/ati/ragexl/atyfb.h +++ b/src/drivers/ati/ragexl/atyfb.h @@ -96,7 +96,7 @@ #endif struct fb_info_aty { #if CONFIG_CONSOLE_BTEXT -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 struct fb_info fb_info; #endif #endif @@ -119,7 +119,7 @@ struct { u8 red, green, blue, pad; } palette[256]; #endif struct atyfb_par default_par; -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 struct atyfb_par current_par; #endif
diff --git a/src/drivers/ati/ragexl/mach64_ct.c b/src/drivers/ati/ragexl/mach64_ct.c index 9b45f2a..b5fd65c 100644 --- a/src/drivers/ati/ragexl/mach64_ct.c +++ b/src/drivers/ati/ragexl/mach64_ct.c @@ -14,7 +14,7 @@ struct pll_ct *pll); static int aty_var_to_pll_ct(const struct fb_info_aty *info, u32 vclk_per, u8 bpp, union aty_pll *pll); -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static u32 aty_pll_ct_to_var(const struct fb_info_aty *info, const union aty_pll *pll); #endif @@ -31,7 +31,7 @@ u32 xclks_per_row, fifo_off, fifo_on, y, fifo_size; u32 memcntl, n, t_pfc, t_rp, t_ras, t_rcd, t_crd, t_rcc, t_lat;
-#if DEBUG_PLL==1 +#if DEBUG_PLL == 1 printk(BIOS_DEBUG, "aty_dsp_gt : mclk_fb_mult=%d\n", pll->mclk_fb_mult); #endif
@@ -121,7 +121,7 @@ static int aty_valid_pll_ct(const struct fb_info_aty *info, u32 vclk_per, struct pll_ct *pll) { -#if DEBUG_PLL==1 +#if DEBUG_PLL == 1 int pllmclk, pllsclk; #endif u32 q; @@ -145,7 +145,7 @@ pll->mclk_post_div_real = 1; pll->sclk_fb_div = q*pll->mclk_post_div_real/8;
-#if DEBUG_PLL==1 +#if DEBUG_PLL == 1 pllsclk = (1000000 * 2 * pll->sclk_fb_div) / (info->ref_clk_per * pll->pll_ref_div);
@@ -171,7 +171,7 @@ pll->xclk_post_div_real = 1; pll->mclk_fb_div = q*pll->xclk_post_div_real/8;
-#if DEBUG_PLL==1 +#if DEBUG_PLL == 1 pllmclk = (1000000 * pll->mclk_fb_mult * pll->mclk_fb_div) / (info->ref_clk_per * pll->pll_ref_div); printk(BIOS_DEBUG, "aty_valid_pll_ct: pllmclk=%d MHz, xclk=%d MHz\n", @@ -285,7 +285,7 @@ return 0; } #if CONFIG_CONSOLE_BTEXT -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 u32 aty_pll_ct_to_var(const struct fb_info_aty *info, const union aty_pll *pll) { @@ -299,7 +299,7 @@ #endif void aty_set_pll_ct(const struct fb_info_aty *info, const union aty_pll *pll) { -#if DEBUG_PLL==1 +#if DEBUG_PLL == 1 printk(BIOS_DEBUG, "aty_set_pll_ct: about to program:\n" "refdiv=%d, extcntl=0x%02x, mfbdiv=%d\n" "spllcntl2=0x%02x, sfbdiv=%d, gencntl=0x%02x\n" diff --git a/src/drivers/ati/ragexl/xlinit.c b/src/drivers/ati/ragexl/xlinit.c index c5d4404..67293be 100644 --- a/src/drivers/ati/ragexl/xlinit.c +++ b/src/drivers/ati/ragexl/xlinit.c @@ -60,7 +60,7 @@ #define HAS_VICTORIA 0
enum { -#if HAS_VICTORIA==1 +#if HAS_VICTORIA == 1 VICTORIA = 0, XPERT98, #else @@ -88,7 +88,7 @@ u8 dll2_cntl; u8 pll_yclk_cntl; } card_cfg[NUM_XL_CARDS] = { -#if HAS_VICTORIA==1 +#if HAS_VICTORIA == 1 // VICTORIA { 2700, SDRAM, 0x800000, 0x10757A3B, 0x64000C81, 0x00110202, 0x7b33A040, @@ -399,7 +399,7 @@ static int aty_var_to_crtc(const struct fb_info_aty *info, const struct fb_var_screeninfo *var, struct crtc *crtc); -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static int aty_crtc_to_var(const struct crtc *crtc, struct fb_var_screeninfo *var); #endif @@ -409,7 +409,7 @@ static int atyfb_decode_var(const struct fb_var_screeninfo *var, struct atyfb_par *par, const struct fb_info_aty *info); -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static int atyfb_encode_var(struct fb_var_screeninfo *var, const struct atyfb_par *par, const struct fb_info_aty *info); @@ -517,7 +517,7 @@ u8 pll_ref_div; #endif
-#endif /*CONFIG_CONSOLE_BTEXT==1 */ +#endif /*CONFIG_CONSOLE_BTEXT == 1 */
struct fb_info_aty *info; struct fb_info_aty info_t; @@ -536,7 +536,7 @@ info->frame_buffer = res->base; #endif /* CONFIG_CONSOLE_BTEXT */
-#if USE_AUX_REG==0 +#if USE_AUX_REG == 0 info->ati_regbase = res2mmio(res, 0x7ff000+0xc00, 0); #else /* Fix this to look for the correct index. */ @@ -752,7 +752,7 @@ } #endif
-#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 atyfb_set_var(&var, -1, &info->fb_info); #else atyfb_set_par(&info->default_par, info); @@ -760,7 +760,7 @@ do_install_cmap(-1, info); #endif
printk(BIOS_SPEW, "framebuffer=0x%08x, width=%d, height=%d, bpp=%d, pitch=%d\n",info->frame_buffer, (((info->current_par.crtc.h_tot_disp>>16) & 0xff)+1)*8, @@ -830,7 +830,7 @@
return 0; } -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static int atyfb_encode_var(struct fb_var_screeninfo *var, const struct atyfb_par *par, const struct fb_info_aty *info) @@ -934,7 +934,7 @@ dp_pix_width = HOST_8BPP | SRC_8BPP | DST_8BPP | BYTE_ORDER_LSB_TO_MSB; dp_chain_mask = 0x8080; } -#if SUPPORT_8_BPP_ABOVE==1 +#if SUPPORT_8_BPP_ABOVE == 1 else if (bpp <= 16) { bpp = 16; pix_width = CRTC_PIX_WIDTH_15BPP; @@ -986,7 +986,7 @@
return 0; } -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static int aty_crtc_to_var(const struct crtc *crtc, struct fb_var_screeninfo *var) { @@ -1049,7 +1049,7 @@ var->transp.offset = 0; var->transp.length = 0; break; -#if SUPPORT_8_BPP_ABOVE==1 +#if SUPPORT_8_BPP_ABOVE == 1 case CRTC_PIX_WIDTH_15BPP: /* RGB 555 */ bpp = 16; var->red.offset = 10; @@ -1168,7 +1168,7 @@ /* * Set the User Defined Part of the Display */ -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 static int atyfb_set_var(struct fb_var_screeninfo *var, int con, struct fb_info *fb) { @@ -1269,7 +1269,7 @@
accelmode = par->accel_flags; /* hack */
-#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 info->current_par = *par; #endif
@@ -1293,7 +1293,7 @@ case 8: i |= 0x02000000; break; -#if SUPPORT_8_BPP_ABOVE==1 +#if SUPPORT_8_BPP_ABOVE == 1 case 16: i |= 0x03000000; break; @@ -1309,12 +1309,12 @@ i |= info->mem_refresh_rate << 20; switch (par->crtc.bpp) { case 8: -#if SUPPORT_8_BPP_ABOVE==1 +#if SUPPORT_8_BPP_ABOVE == 1 case 24: #endif i |= 0x00000000; break; -#if SUPPORT_8_BPP_ABOVE==1 +#if SUPPORT_8_BPP_ABOVE == 1 case 16: i |= 0x04000000; break; @@ -1433,7 +1433,7 @@ i |= 0x2; /*DAC_CNTL|0x2 turns off the extra brightness for gt*/ aty_st_8(DAC_CNTL, i, info); aty_st_8(DAC_MASK, 0xff, info); -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 scale = (M64_HAS(INTEGRATED) && info->current_par.crtc.bpp == 16) ? 3 : 0; #else scale = (M64_HAS(INTEGRATED) && info->default_par.crtc.bpp == 16) ? 3 : 0; @@ -1493,7 +1493,7 @@
static void do_install_cmap(int con, struct fb_info_aty *info) { -#if PLL_CRTC_DECODE==1 +#if PLL_CRTC_DECODE == 1 int size = info->current_par.crtc.bpp == 16 ? 32 : 256; #else int size = 256;
