Attention is currently required from: Varshit B Pandya, Subrata Banik, Maulik V Vaghela, Paul Menzel, Sugnan Prabhu S, Tim Wawrzynczak. Hello build bot (Jenkins), Subrata Banik, Maulik V Vaghela, Tim Wawrzynczak, Rizwan Qureshi, Sugnan Prabhu S, Tim Wawrzynczak,
https://review.coreboot.org/c/coreboot/+/61020
to look at the new patch set (#21).
Change subject: src/driver/wifi: Add _DSM method for DDRRFIM ......................................................................
coreboot needs to propagate the CnviDdrRfim value info of the feature enable/disable state into the CNVi via the WiFi DSM ACPI object. This patch adds _DSM method for that.
Add support for following 2 function in _DSM method
- Function 0: Function Support Query Returns a bitmask of functions supported. - Function 3: RFI enablement 0 Feature Enable 1 Feature Disable
BUG=b:201724512 TEST=Build, boot brya0 and dump SSDT entries
Method (_DSM, 4, Serialized) // _DSM: Device-Specific Method { ToBuffer (Arg0, Local0) If ((Local0 == ToUUID ("7266172c-220b-4b29-814f-75e4dd26b5fd"))) { ToInteger (Arg2, Local1) If ((Local1 == Zero)) { Return (Buffer (One) { 0x09 }) }
If ((Local1 == One)){} If ((Local1 == 0x02)){} If ((Local1 == 0x03)) { Return (Zero) }
Return (Buffer (One) { 0x00 }) }
Signed-off-by: Varshit B Pandya varshit.b.pandya@intel.com Change-Id: I217b736df3d4224a6732d1941a160abcddbd8f37 --- M src/drivers/wifi/generic/acpi.c 1 file changed, 67 insertions(+), 5 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/20/61020/21
