Attention is currently required from: Nico Huber, Furquan Shaikh, Martin Roth, Duncan Laurie, Aamir Bohra, Srinidhi N Kaushik, Patrick Rudolph. Nico Huber has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/49408 )
Change subject: soc/intel/common: Add new IRQ block ......................................................................
Patch Set 3:
(9 comments)
File src/soc/intel/common/block/irq/irq.c:
https://review.coreboot.org/c/coreboot/+/49408/comment/474e39a4_871cf838 PS3, Line 69: return entries[i].irq; Put the for body in braces for consistency and balance?
https://review.coreboot.org/c/coreboot/+/49408/comment/971643fc_3ae193b8 PS3, Line 82: 1 PCI_INT_A
https://review.coreboot.org/c/coreboot/+/49408/comment/4f3b6e56_57421fe1 PS3, Line 87: return (enum pci_pin)(i + 1); Put the for body in braces for consistency and balance?
https://review.coreboot.org/c/coreboot/+/49408/comment/f7959c12_717f38aa PS3, Line 87: i + 1 PCI_INT_A + i
no need for cast
https://review.coreboot.org/c/coreboot/+/49408/comment/34e8ed7f_6276491d PS3, Line 102: while (next != curr_idx) { Assumes `current <= MAX_IRQ` to terminate.
https://review.coreboot.org/c/coreboot/+/49408/comment/7be0a03b_6329d140 PS3, Line 119: dev = pcidev_path_on_root(devfn); : if (!dev) { : dummy.bus = &bus; : dummy.path.type = DEVICE_PATH_PCI; : dummy.path.pci.devfn = devfn; : dev = &dummy; : } : : const uint8_t pin = pci_read_config8(dev, PCI_INTERRUPT_PIN); Looks like calling pci_s_read_config8() directly would be easier here.
https://review.coreboot.org/c/coreboot/+/49408/comment/5f7741b3_24b98498 PS3, Line 155: line = MIN_IRQ; Why?
https://review.coreboot.org/c/coreboot/+/49408/comment/c4ef88ff_695fd316 PS3, Line 186: int pin = get_pci_irq_pin(devfn); This seems a bit fragile, `UNIQUE_IRQ` would have the requirement that no other fn has the same pin set. Which is harder to verify. next_pin_for_slot() also does not take potential future get_pci_irq_pin() results into account and relies on the already set `entries` alone. It seems everything would be easier if we say `UNIQUE_IRQ` requires all pins of a `slot` configurable and all fn's should be set to `UNIQUE_IRQ`. That seems true for the TGL use-case at least.
https://review.coreboot.org/c/coreboot/+/49408/comment/ea6a1ead_400a569d PS3, Line 209: PIRQ PIRQA
