Hello Doug Anderson, Philip Chen, Wai-Hong Tam, mturney mturney,
https://review.coreboot.org/c/coreboot/+/43471
Change subject: google/trogdor: Remove GPIO_AP_SUSPEND_L ......................................................................
This pin has been removed from recent revisions (or at least moved to a pin that's not controlled like a normal GPIO). It has also never been used on older ones (I think?). The same GPIO is now used as a SKU ID pin, so make sure we're not incorrectly configuring it as an output (although sku_id() overrides that later anyway, but it's still incorrect).
BUG=b:160754995
Signed-off-by: Julius Werner jwerner@chromium.org Change-Id: I6e0d56e230d0bef172d7b78cc48263e9b6f059de --- M src/mainboard/google/trogdor/board.h M src/mainboard/google/trogdor/chromeos.c 2 files changed, 0 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/71/43471/1
diff --git a/src/mainboard/google/trogdor/board.h b/src/mainboard/google/trogdor/board.h index 63d03db..cab4403 100644 --- a/src/mainboard/google/trogdor/board.h +++ b/src/mainboard/google/trogdor/board.h @@ -9,7 +9,6 @@
#define GPIO_EC_IN_RW GPIO(118) #define GPIO_AP_EC_INT GPIO(94) -#define GPIO_AP_SUSPEND GPIO(20) #define GPIO_WP_STATE GPIO(42) #define GPIO_H1_AP_INT (CONFIG(TROGDOR_REV0) ? GPIO(21) : GPIO(42)) #define GPIO_SD_CD_L GPIO(69) diff --git a/src/mainboard/google/trogdor/chromeos.c b/src/mainboard/google/trogdor/chromeos.c index 9360928..9c45dfe 100644 --- a/src/mainboard/google/trogdor/chromeos.c +++ b/src/mainboard/google/trogdor/chromeos.c @@ -14,7 +14,6 @@ { gpio_input_pullup(GPIO_EC_IN_RW); gpio_input_pullup(GPIO_AP_EC_INT); - gpio_output(GPIO_AP_SUSPEND, 1); gpio_input(GPIO_WP_STATE); gpio_input_pullup(GPIO_SD_CD_L); gpio_input_irq(GPIO_H1_AP_INT, IRQ_TYPE_RISING_EDGE, GPIO_PULL_UP);
EricR Lai has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43471 )
Patch Set 1: Code-Review+2
Douglas Anderson has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43471 )
Patch Set 2: Code-Review+1
Philip Chen has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43471 )
Patch Set 2: Code-Review+2
Bob Moragues has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43471 )
Julius Werner has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43471 )
BUG=b:160754995
Signed-off-by: Julius Werner jwerner@chromium.org Change-Id: I6e0d56e230d0bef172d7b78cc48263e9b6f059de Reviewed-on: https://review.coreboot.org/c/coreboot/+/43471 Reviewed-by: Douglas Anderson dianders@chromium.org Reviewed-by: Philip Chen philipchen@google.com Reviewed-by: Bob Moragues moragues@google.com Reviewed-by: EricR Lai ericr_lai@compal.corp-partner.google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/trogdor/board.h M src/mainboard/google/trogdor/chromeos.c 2 files changed, 0 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Philip Chen: Looks good to me, approved Douglas Anderson: Looks good to me, but someone else must approve EricR Lai: Looks good to me, approved Bob Moragues: Looks good to me, but someone else must approve
