Wonkyu Kim has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/84229?usp=email )
Change subject: libpayload: add more condition to check valid PCI device id ......................................................................
Checking more conditions to check valid PCI device id to avoid device stuck issue.
Below are invalid PCI device id cases VID: 0x0 or 0xffff DID: 0x0 or 0xffff
Signed-off-by: Wonkyu Kim wonkyu.kim@intel.com Change-Id: I772c4199c7a6c13a25590a36f1bfee17c1a44daf --- M payloads/libpayload/drivers/usb/usbinit.c 1 file changed, 29 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/29/84229/1
diff --git a/payloads/libpayload/drivers/usb/usbinit.c b/payloads/libpayload/drivers/usb/usbinit.c index a234b00..dfcdae9 100644 --- a/payloads/libpayload/drivers/usb/usbinit.c +++ b/payloads/libpayload/drivers/usb/usbinit.c @@ -116,15 +116,36 @@ return 0; }
+static bool is_valid_pci_dev(int bus, int dev, int fun) +{ + u32 id; + u16 vid, did; + pcidev_t pci_device = PCI_DEV(bus, dev, fun); + + id = pci_read_config32(pci_device, REG_VENDOR_ID); + vid = id & 0xffff; + did = (id >> 16) & 0xffff; + + if ((vid == 0x0000) || (vid == 0xffff) || + (did == 0xffff) || (did== 0x0000)) { + usb_debug("PCI dev %02x:%02x:%02x [0x%04x|0x%04x] is not valid\n", + bus, dev, fun, vid, did); + return false; + } + return true; +} + static void usb_scan_pci_bus(int bus) { int dev, func; + + usb_debug("usb_scan_pci_bus start\n"); for (dev = 0; dev < 32; dev++) { u8 header_type; pcidev_t pci_device = PCI_DEV(bus, dev, 0);
- /* Check if there's a device here at all. */ - if (pci_read_config32(pci_device, REG_VENDOR_ID) == 0xffffffff) + /* Check valid pci device*/ + if ( is_valid_pci_dev(bus, dev, 0) == false ) continue;
/* @@ -143,6 +164,11 @@
for (; func >= 0; func--) { pci_device = PCI_DEV(bus, dev, func); + + /* Check valid pci device*/ + if ( is_valid_pci_dev(bus, dev, func) == false ) + continue; + header_type = pci_read_config8(pci_device, REG_HEADER_TYPE); /* If this is a bridge, scan the other side. */ if ((header_type & ~HEADER_TYPE_MULTIFUNCTION) == @@ -157,6 +183,7 @@ usb_controller_initialize(bus, dev, func); } } + usb_debug("usb_scan_pci_bus end\n"); } #endif
