Attention is currently required from: Angel Pons, Martin L Roth.
Hello Angel Pons, Martin L Roth, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81785?usp=email
Change subject: Makefile.inc: Decrease minimal pagesize from 4 kB to 1 kB ......................................................................
GCC 12 incorrectly warns about an array out of bounds issue:
``` $ make V=1 # emulation/qemu-i440fx […] CC ramstage/arch/x86/ebda.o x86_64-linux-gnu-gcc-12 -MMD -Isrc -Isrc/include -Isrc/commonlib/include -Isrc/commonlib/bsd/include -Ibuild -I3rdparty/vboot/firmware/include -include src/include/kconfig.h -include src/include/rules.h -include src/commonlib/bsd/include/commonlib/bsd/compiler.h -I3rdparty -D__BUILD_DIR__="build" -Isrc/arch/x86/include -D__ARCH_x86_32__ -pipe -g -nostdinc -std=gnu11 -nostdlib -Wall -Wundef -Wstrict-prototypes -Wmissing-prototypes -Wwrite-strings -Wredundant-decls -Wno-trigraphs -Wimplicit-fallthrough -Wshadow -Wdate-time -Wtype-limits -Wvla -Wdangling-else -fno-common -ffreestanding -fno-builtin -fomit-frame-pointer -fstrict-aliasing -ffunction-sections -fdata-sections -fno-pie -Wno-packed-not-aligned -fconserve-stack -Wnull-dereference -Wreturn-type -Wlogical-op -Wduplicated-cond -Wno-unused-but-set-variable -Werror -Os -Wno-address-of-packed-member -m32 -Wl,-b,elf32-i386 -Wl,-melf_i386 -m32 -fuse-ld=bfd -fno-stack-protector -Wl,--build-id=none -fno-delete-null-pointer-checks -Wlogical-op -march=i686 -mno-mmx -MT build/ramstage/arch/x86/ebda.o -D__RAMSTAGE__ -c -o build/ramstage/arch/x86/ebda.o src/arch/x86/ebda.c In file included from src/arch/x86/ebda.c:6: In function 'write_ble8', inlined from 'write_le8' at src/commonlib/include/commonlib/endian.h:155:2, inlined from 'write_le16' at src/commonlib/include/commonlib/endian.h:178:2, inlined from 'setup_ebda' at src/arch/x86/ebda.c:35:2, inlined from 'setup_default_ebda' at src/arch/x86/ebda.c:48:2: src/commonlib/include/commonlib/endian.h:27:26: error: array subscript 0 is outside array bounds of 'void[0]' [-Werror=array-bounds] 27 | *(uint8_t *)dest = val; | ~~~~~~~~~~~~~~~~~^~~~~ […] ```
[In GCC 12 the new parameter `min-pagesize` is added and defaults 4 kB.][1] It treats INTEGER_CST addresses smaller than that as assumed results of pointer arithmetics from NULL while addresses equal or larger than that as expected user constant addresses. For GCC 13 we can represent results from pointer arithmetics on NULL using &MEM[(void*)0 + offset] instead of (void*)offset INTEGER_CSTs.
[1]: https://web.archive.org/web/20220711061810/https://gcc.gnu.org/bugzilla/show...
TEST=No compile error with gcc (Debian 12.2.0-3) 12.2.0 Change-Id: I6e36633f42cb4dc5af53212c10c919a86e451ee0 Original-Signed-off-by: Paul Menzel pmenzel@molgen.mpg.de Original-Reviewed-on: https://review.coreboot.org/c/coreboot/+/62830 Original-Tested-by: build bot (Jenkins) no-reply@coreboot.org Original-Reviewed-by: Angel Pons th3fanbus@gmail.com --- M util/xcompile/xcompile 1 file changed, 2 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/85/81785/2
