Attention is currently required from: David Wu, Krishna P Bhat D, Reka Norman, Reka Norman, Stefan Reinauer, Subrata Banik.
Hello David Wu, Krishna P Bhat D, Reka Norman, Stefan Reinauer, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/81928?usp=email
Change subject: util/ifdtool: Add support for checking GPR0 status ......................................................................
This patch adds support for the new command-line option `-c` to the ifdtool, which is able to check GPR0 status.
Developers can use ifdtool with '-c' option to check whether GPR0 is set to enabled or disabled in the binary file.
BUG=none TEST=(1) Run `ifdtool -p mtl -c image.bin` on a locked karis image, show "GPRO status: Enabled". (2) Run `ifdtool -p mtl -c unlock_image.bin` on a unlocked karis image, show "GPRO status: Disabled".
Change-Id: I6b3af973be784200b965a68e5f6b7737cba03ed7 Signed-off-by: Tyler Wang tyler.wang@quanta.corp-partner.google.com --- M util/ifdtool/ifdtool.c 1 file changed, 48 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/28/81928/7
