Dave Frodin (dave.frodin@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/8251
commit dad3bcf986d5c6da9d7e6c99d83e1f67e78ac345 Author: Dave Frodin dave.frodin@se-eng.com Date: Mon Jan 19 11:40:38 2015 -0700
southbridge/amd/pi: Rename Avalon to Hudson
To maintain consistancy with southbridge/amd/agesa/hudson rename pi/avalon to pi/hudson in advance of adding support for the base hudson southbridge.
Change-Id: Icff8c4c06aae2d40cbd9e90903754735ac3510c3 Signed-off-by: Dave Frodin dave.frodin@se-eng.com --- src/mainboard/amd/olivehillplus/devicetree.cb | 4 +- src/mainboard/amd/olivehillplus/dsdt.asl | 10 +- src/mainboard/amd/olivehillplus/mptable.c | 2 +- src/mainboard/amd/olivehillplus/romstage.c | 2 +- src/southbridge/amd/pi/Kconfig | 2 +- src/southbridge/amd/pi/Makefile.inc | 2 +- src/southbridge/amd/pi/avalon/Kconfig | 219 ---------- src/southbridge/amd/pi/avalon/Makefile.inc | 310 -------------- src/southbridge/amd/pi/avalon/acpi/audio.asl | 57 --- src/southbridge/amd/pi/avalon/acpi/fch.asl | 188 -------- src/southbridge/amd/pi/avalon/acpi/lpc.asl | 108 ----- src/southbridge/amd/pi/avalon/acpi/pci_int.asl | 473 --------------------- src/southbridge/amd/pi/avalon/acpi/pcie.asl | 95 ----- src/southbridge/amd/pi/avalon/acpi/sleepstates.asl | 40 -- src/southbridge/amd/pi/avalon/acpi/smbus.asl | 20 - src/southbridge/amd/pi/avalon/acpi/usb.asl | 78 ---- src/southbridge/amd/pi/avalon/amd_pci_int_defs.h | 72 ---- src/southbridge/amd/pi/avalon/amd_pci_int_types.h | 33 -- src/southbridge/amd/pi/avalon/bootblock.c | 67 --- src/southbridge/amd/pi/avalon/chip.h | 35 -- src/southbridge/amd/pi/avalon/early_setup.c | 126 ------ src/southbridge/amd/pi/avalon/enable_usbdebug.c | 63 --- src/southbridge/amd/pi/avalon/fadt.c | 211 --------- src/southbridge/amd/pi/avalon/hda.c | 51 --- src/southbridge/amd/pi/avalon/hudson.c | 140 ------ src/southbridge/amd/pi/avalon/hudson.h | 92 ---- src/southbridge/amd/pi/avalon/ide.c | 48 --- src/southbridge/amd/pi/avalon/lpc.c | 342 --------------- src/southbridge/amd/pi/avalon/pci.c | 74 ---- src/southbridge/amd/pi/avalon/pci_devs.h | 96 ----- src/southbridge/amd/pi/avalon/pcie.c | 65 --- src/southbridge/amd/pi/avalon/reset.c | 35 -- src/southbridge/amd/pi/avalon/sata.c | 85 ---- src/southbridge/amd/pi/avalon/sd.c | 69 --- src/southbridge/amd/pi/avalon/sm.c | 174 -------- src/southbridge/amd/pi/avalon/smbus.c | 250 ----------- src/southbridge/amd/pi/avalon/smbus.h | 76 ---- src/southbridge/amd/pi/avalon/smbus_spd.c | 152 ------- src/southbridge/amd/pi/avalon/smi.c | 25 -- src/southbridge/amd/pi/avalon/smi.h | 65 --- src/southbridge/amd/pi/avalon/smi_util.c | 79 ---- src/southbridge/amd/pi/avalon/smihandler.c | 136 ------ src/southbridge/amd/pi/avalon/usb.c | 100 ----- src/southbridge/amd/pi/hudson/Kconfig | 219 ++++++++++ src/southbridge/amd/pi/hudson/Makefile.inc | 310 ++++++++++++++ src/southbridge/amd/pi/hudson/acpi/audio.asl | 57 +++ src/southbridge/amd/pi/hudson/acpi/fch.asl | 188 ++++++++ src/southbridge/amd/pi/hudson/acpi/lpc.asl | 108 +++++ src/southbridge/amd/pi/hudson/acpi/pci_int.asl | 473 +++++++++++++++++++++ src/southbridge/amd/pi/hudson/acpi/pcie.asl | 95 +++++ src/southbridge/amd/pi/hudson/acpi/sleepstates.asl | 40 ++ src/southbridge/amd/pi/hudson/acpi/smbus.asl | 20 + src/southbridge/amd/pi/hudson/acpi/usb.asl | 78 ++++ src/southbridge/amd/pi/hudson/amd_pci_int_defs.h | 72 ++++ src/southbridge/amd/pi/hudson/amd_pci_int_types.h | 33 ++ src/southbridge/amd/pi/hudson/bootblock.c | 67 +++ src/southbridge/amd/pi/hudson/chip.h | 35 ++ src/southbridge/amd/pi/hudson/early_setup.c | 126 ++++++ src/southbridge/amd/pi/hudson/enable_usbdebug.c | 63 +++ src/southbridge/amd/pi/hudson/fadt.c | 211 +++++++++ src/southbridge/amd/pi/hudson/hda.c | 51 +++ src/southbridge/amd/pi/hudson/hudson.c | 140 ++++++ src/southbridge/amd/pi/hudson/hudson.h | 92 ++++ src/southbridge/amd/pi/hudson/ide.c | 48 +++ src/southbridge/amd/pi/hudson/lpc.c | 342 +++++++++++++++ src/southbridge/amd/pi/hudson/pci.c | 74 ++++ src/southbridge/amd/pi/hudson/pci_devs.h | 96 +++++ src/southbridge/amd/pi/hudson/pcie.c | 65 +++ src/southbridge/amd/pi/hudson/reset.c | 35 ++ src/southbridge/amd/pi/hudson/sata.c | 85 ++++ src/southbridge/amd/pi/hudson/sd.c | 69 +++ src/southbridge/amd/pi/hudson/sm.c | 174 ++++++++ src/southbridge/amd/pi/hudson/smbus.c | 250 +++++++++++ src/southbridge/amd/pi/hudson/smbus.h | 76 ++++ src/southbridge/amd/pi/hudson/smbus_spd.c | 152 +++++++ src/southbridge/amd/pi/hudson/smi.c | 25 ++ src/southbridge/amd/pi/hudson/smi.h | 65 +++ src/southbridge/amd/pi/hudson/smi_util.c | 79 ++++ src/southbridge/amd/pi/hudson/smihandler.c | 136 ++++++ src/southbridge/amd/pi/hudson/usb.c | 100 +++++ src/vendorcode/amd/pi/00730F01/Makefile.inc | 2 +- 81 files changed, 4361 insertions(+), 4361 deletions(-)
diff --git a/src/mainboard/amd/olivehillplus/devicetree.cb b/src/mainboard/amd/olivehillplus/devicetree.cb index 65f7ee4..8dd0671 100644 --- a/src/mainboard/amd/olivehillplus/devicetree.cb +++ b/src/mainboard/amd/olivehillplus/devicetree.cb @@ -41,7 +41,7 @@ chip northbridge/amd/pi/00730F01/root_complex device pci 8.0 on end # Platform Security Processor end #chip northbridge/amd/pi/00730F01
- chip southbridge/amd/pi/avalon # it is under NB/SB Link, but on the same pci bus + chip southbridge/amd/pi/hudson # it is under NB/SB Link, but on the same pci bus device pci 10.0 on end # XHCI HC0 device pci 11.0 on end # SATA device pci 12.0 on end # USB @@ -60,7 +60,7 @@ chip northbridge/amd/pi/00730F01/root_complex device pci 14.3 on end # LPC 0x439d device pci 14.7 on end # SD device pci 16.0 on end # USB - end #chip southbridge/amd/pi/avalon + end #chip southbridge/amd/pi/hudson
device pci 18.0 on end device pci 18.1 on end diff --git a/src/mainboard/amd/olivehillplus/dsdt.asl b/src/mainboard/amd/olivehillplus/dsdt.asl index 56381e1..68ed74e 100644 --- a/src/mainboard/amd/olivehillplus/dsdt.asl +++ b/src/mainboard/amd/olivehillplus/dsdt.asl @@ -37,13 +37,13 @@ DefinitionBlock ( #include "acpi/usb_oc.asl"
/* PCI IRQ mapping for the Southbridge */ - #include <southbridge/amd/pi/avalon/acpi/pcie.asl> + #include <southbridge/amd/pi/hudson/acpi/pcie.asl>
/* Describe the processor tree (_PR) */ #include <cpu/amd/pi/00730F01/acpi/cpu.asl>
/* Contains the supported sleep states for this chipset */ - #include <southbridge/amd/pi/avalon/acpi/sleepstates.asl> + #include <southbridge/amd/pi/hudson/acpi/sleepstates.asl>
/* Contains the Sleep methods (WAK, PTS, GTS, etc.) */ #include "acpi/sleep.asl" @@ -68,16 +68,16 @@ DefinitionBlock ( #include <northbridge/amd/pi/00730F01/acpi/northbridge.asl>
/* Describe the AMD Fusion Controller Hub Southbridge */ - #include <southbridge/amd/pi/avalon/acpi/fch.asl> + #include <southbridge/amd/pi/hudson/acpi/fch.asl> }
/* Describe PCI INT[A-H] for the Southbridge */ - #include <southbridge/amd/pi/avalon/acpi/pci_int.asl> + #include <southbridge/amd/pi/hudson/acpi/pci_int.asl>
} /* End _SB scope */
/* Describe SMBUS for the Southbridge */ - #include <southbridge/amd/pi/avalon/acpi/smbus.asl> + #include <southbridge/amd/pi/hudson/acpi/smbus.asl>
/* Define the General Purpose Events for the platform */ #include "acpi/gpe.asl" diff --git a/src/mainboard/amd/olivehillplus/mptable.c b/src/mainboard/amd/olivehillplus/mptable.c index 80ba5b5..d49c998 100644 --- a/src/mainboard/amd/olivehillplus/mptable.c +++ b/src/mainboard/amd/olivehillplus/mptable.c @@ -27,7 +27,7 @@ #include <cpu/amd/amdfam15.h> #include <arch/cpu.h> #include <cpu/x86/lapic.h> -#include <southbridge/amd/pi/avalon/hudson.h> /* pm_ioread() */ +#include <southbridge/amd/pi/hudson/hudson.h> /* pm_ioread() */
u8 picr_data[0x54] = { 0x03,0x04,0x05,0x07,0x0B,0x0A,0x1F,0x1F,0xFA,0xF1,0x00,0x00,0x1F,0x1F,0x1F,0x1F, diff --git a/src/mainboard/amd/olivehillplus/romstage.c b/src/mainboard/amd/olivehillplus/romstage.c index 63044ed..6b081c6 100644 --- a/src/mainboard/amd/olivehillplus/romstage.c +++ b/src/mainboard/amd/olivehillplus/romstage.c @@ -34,7 +34,7 @@ #include <northbridge/amd/pi/agesawrapper_call.h> #include <cpu/x86/bist.h> #include <cpu/x86/lapic.h> -#include <southbridge/amd/pi/avalon/hudson.h> +#include <southbridge/amd/pi/hudson/hudson.h> #include <cpu/amd/pi/s3_resume.h>
void cache_as_ram_main(unsigned long bist, unsigned long cpu_init_detectedx) diff --git a/src/southbridge/amd/pi/Kconfig b/src/southbridge/amd/pi/Kconfig index a0438c8..2cbf748 100644 --- a/src/southbridge/amd/pi/Kconfig +++ b/src/southbridge/amd/pi/Kconfig @@ -17,4 +17,4 @@ # Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA #
-source src/southbridge/amd/pi/avalon/Kconfig +source src/southbridge/amd/pi/hudson/Kconfig diff --git a/src/southbridge/amd/pi/Makefile.inc b/src/southbridge/amd/pi/Makefile.inc index b7bcc7a..d8e492a 100644 --- a/src/southbridge/amd/pi/Makefile.inc +++ b/src/southbridge/amd/pi/Makefile.inc @@ -16,4 +16,4 @@ # along with this program; if not, write to the Free Software # Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA # -subdirs-$(CONFIG_SOUTHBRIDGE_AMD_PI_AVALON) += avalon +subdirs-$(CONFIG_SOUTHBRIDGE_AMD_PI_AVALON) += hudson diff --git a/src/southbridge/amd/pi/avalon/Kconfig b/src/southbridge/amd/pi/avalon/Kconfig deleted file mode 100644 index c54138c..0000000 --- a/src/southbridge/amd/pi/avalon/Kconfig +++ /dev/null @@ -1,219 +0,0 @@ -## -## This file is part of the coreboot project. -## -## Copyright (C) 2010 Advanced Micro Devices, Inc. -## -## This program is free software; you can redistribute it and/or modify -## it under the terms of the GNU General Public License as published by -## the Free Software Foundation; version 2 of the License. -## -## This program is distributed in the hope that it will be useful, -## but WITHOUT ANY WARRANTY; without even the implied warranty of -## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -## GNU General Public License for more details. -## -## You should have received a copy of the GNU General Public License -## along with this program; if not, write to the Free Software -## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA -## - -config SOUTHBRIDGE_AMD_PI_AVALON - bool - select IOAPIC - select HAVE_USBDEBUG_OPTIONS - select HAVE_HARD_RESET - -if SOUTHBRIDGE_AMD_PI_AVALON - -config BOOTBLOCK_SOUTHBRIDGE_INIT - string - default "southbridge/amd/pi/avalon/bootblock.c" - -config SOUTHBRIDGE_AMD_HUDSON_SKIP_ISA_DMA_INIT - bool - default n - -config EHCI_BAR - hex - default 0xfef00000 - -config HUDSON_XHCI_ENABLE - bool "Enable Hudson XHCI Controller" - default y - help - The XHCI controller must be enabled and the XHCI firmware - must be added in order to have USB 3.0 support configured - by coreboot. The OS will be responsible for enabling the XHCI - controller if the the XHCI firmware is available but the - XHCI controller is not enabled by coreboot. - -config HUDSON_XHCI_FWM - bool "Add xhci firmware" - default y - help - Add Hudson 2/3/4 XHCI Firmware to support the onboard USB 3.0 - -config HUDSON_DISABLE_IMC - bool - default n - -config HUDSON_IMC_FWM - bool "Add IMC firmware" - depends on !HUDSON_DISABLE_IMC - default y - help - Add Hudson 2/3/4 IMC Firmware to support the onboard fan control - -config HUDSON_GEC_FWM - bool - default n - help - Add Hudson 2/3/4 GEC Firmware to support the onboard gigabit Ethernet MAC. - Must be connected to a Broadcom B50610 or B50610M PHY on the motherboard. - -config HUDSON_PSP - bool - default y if CPU_AMD_PI_00730F01 - -config HUDSON_XHCI_FWM_FILE - string "XHCI firmware path and filename" - default "3rdparty/southbridge/amd/avalon/xhci.bin" if SOUTHBRIDGE_AMD_PI_AVALON - depends on HUDSON_XHCI_FWM - -config HUDSON_IMC_FWM_FILE - string "IMC firmware path and filename" - default "3rdparty/southbridge/amd/avalon/imc.bin" if SOUTHBRIDGE_AMD_PI_AVALON - depends on HUDSON_IMC_FWM - -config HUDSON_GEC_FWM_FILE - string "GEC firmware path and filename" - depends on HUDSON_GEC_FWM - -config HUDSON_FWM - bool - default y if HUDSON_XHCI_FWM || HUDSON_IMC_FWM || HUDSON_GEC_FWM || HUDSON_PSP - default n - -if HUDSON_FWM - -config HUDSON_FWM_POSITION - hex "Hudson Firmware ROM Position" - default 0xFFF20000 if BOARD_ROMSIZE_KB_1024 - default 0xFFE20000 if BOARD_ROMSIZE_KB_2048 - default 0xFFC20000 if BOARD_ROMSIZE_KB_4096 - default 0xFF820000 if BOARD_ROMSIZE_KB_8192 - default 0xFF020000 if BOARD_ROMSIZE_KB_16384 - help - Hudson requires the firmware MUST be located at - a specific address (ROM start address + 0x20000), otherwise - xhci host Controller can not find or load the xhci firmware. - - The firmware start address is dependent on the ROM chip size. - The default offset is 0x20000 from the ROM start address, namely - 0xFFF20000 if flash chip size is 1M - 0xFFE20000 if flash chip size is 2M - 0xFFC20000 if flash chip size is 4M - 0xFF820000 if flash chip size is 8M - 0xFF020000 if flash chip size is 16M -endif # HUDSON_FWM - -config AMD_PUBKEY_FILE - depends on HUDSON_PSP - string "AMD public Key" - default "3rdparty/southbridge/amd/avalon/PSP/AmdPubKey.bin" if CPU_AMD_PI_00730F01 - -config HUDSON_SATA_MODE - int "SATA Mode" - default 0 - range 0 6 - help - Select the mode in which SATA should be driven. NATIVE AHCI, or RAID. - The default is NATIVE. - 0: NATIVE mode does not require a ROM. - 1: RAID mode must have the two ROM files. - 2: AHCI may work with or without AHCI ROM. It depends on the payload support. - For example, seabios does not require the AHCI ROM. - 3: LEGACY IDE - 4: IDE to AHCI - 5: AHCI7804: ROM Required, and AMD driver required in the OS. - 6: IDE to AHCI7804: ROM Required, and AMD driver required in the OS. - -comment "NATIVE" - depends on HUDSON_SATA_MODE = 0 - -comment "RAID" - depends on HUDSON_SATA_MODE = 1 - -comment "AHCI" - depends on HUDSON_SATA_MODE = 2 - -comment "LEGACY IDE" - depends on HUDSON_SATA_MODE = 3 - -comment "IDE to AHCI" - depends on HUDSON_SATA_MODE = 4 - -comment "AHCI7804" - depends on HUDSON_SATA_MODE = 5 - -comment "IDE to AHCI7804" - depends on HUDSON_SATA_MODE = 6 - -if HUDSON_SATA_MODE = 2 || HUDSON_SATA_MODE = 5 - -config AHCI_ROM_ID - string "AHCI device PCI IDs" - default "1022,7801" if HUDSON_SATA_MODE = 2 - default "1022,7804" if HUDSON_SATA_MODE = 5 - -config HUDSON_AHCI_ROM - bool "Add a AHCI ROM" - -config AHCI_ROM_FILE - string "AHCI ROM path and filename" - depends on HUDSON_AHCI_ROM - default "src/southbridge/amd/pi/avalon/ahci.bin" - -endif - -if HUDSON_SATA_MODE = 1 - -config RAID_ROM_ID - string "RAID device PCI IDs" - default "1022,7802" - help - 1022,7802 for SATA NON-RAID5 module, 1022,7803 for SATA RAID5 mode - -config RAID_ROM_FILE - string "RAID ROM path and filename" - default "src/southbridge/amd/pi/avalon/raid.bin" - -config RAID_MISC_ROM_FILE - string "RAID Misc ROM path and filename" - default "src/southbridge/amd/pi/avalon/misc.bin" - -config RAID_MISC_ROM_POSITION - hex "RAID Misc ROM Position" - default 0xFFF00000 - help - The RAID ROM requires that the MISC ROM is located between the range - 0xFFF0_0000 to 0xFFF0_FFFF. Also, it must 1K bytes aligned. - The CONFIG_ROM_SIZE must be larger than 0x100000. - -endif - -config HUDSON_LEGACY_FREE - bool "System is legacy free" - help - Select y if there is no keyboard controller in the system. - This sets variables in AGESA and ACPI. - -config AZ_PIN - hex - default 0xaa - help - bit 1,0 - pin 0 - bit 3,2 - pin 1 - bit 5,4 - pin 2 - bit 7,6 - pin 3 -endif diff --git a/src/southbridge/amd/pi/avalon/Makefile.inc b/src/southbridge/amd/pi/avalon/Makefile.inc deleted file mode 100644 index 06e95a6..0000000 --- a/src/southbridge/amd/pi/avalon/Makefile.inc +++ /dev/null @@ -1,310 +0,0 @@ -#***************************************************************************** -# -# Copyright (c) 2012, Advanced Micro Devices, Inc. -# 2013 - 2014, Sage Electronic Engineering, LLC -# All rights reserved. -# -# Redistribution and use in source and binary forms, with or without -# modification, are permitted provided that the following conditions are met: -# * Redistributions of source code must retain the above copyright -# notice, this list of conditions and the following disclaimer. -# * Redistributions in binary form must reproduce the above copyright -# notice, this list of conditions and the following disclaimer in the -# documentation and/or other materials provided with the distribution. -# * Neither the name of Advanced Micro Devices, Inc. nor the names of -# its contributors may be used to endorse or promote products derived -# from this software without specific prior written permission. -# -# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND -# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED -# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE -# DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY -# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES -# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; -# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND -# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT -# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS -# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. -# -#***************************************************************************** - -INCLUDES += -Isrc/southbridge/amd/pi/avalon - -romstage-y += smbus.c smbus_spd.c -ramstage-y += hudson.c -ramstage-y += usb.c -ramstage-y += lpc.c -ramstage-y += sm.c -ramstage-y += ide.c -ramstage-y += sata.c -ramstage-y += hda.c -ramstage-y += pci.c -ramstage-y += pcie.c -ramstage-y += sd.c - -ramstage-$(CONFIG_HAVE_ACPI_TABLES) += fadt.c -ramstage-y += reset.c -romstage-$(CONFIG_USBDEBUG_IN_ROMSTAGE) += enable_usbdebug.c -ramstage-$(CONFIG_USBDEBUG) += enable_usbdebug.c -romstage-y += early_setup.c - -smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c smi_util.c -ramstage-$(CONFIG_HAVE_SMI_HANDLER) += smi.c smi_util.c - -# ROMSIG At ROMBASE + 0x20000: -# +-----------+---------------+----------------+------------+ -# |0x55AA55AA |EC ROM Address |GEC ROM Address |USB3 ROM | -# +-----------+---------------+----------------+------------+ -# |PSPDIR ADDR| -# +-----------+ -# -# EC ROM should be 64K aligned. - -HUDSON_FWM_POSITION=$(shell printf %u $(CONFIG_HUDSON_FWM_POSITION)) -CBFS_HEADER_SIZE=0x40 - -#assume the cbfs header is less than $(CBFS_HEADER_SIZE) bytes. -ROMSIG_SIZE=4096 -ifeq ($(CONFIG_HUDSON_XHCI_FWM), y) -HUDSON_XHCI_POSITION=$(call int-add,$(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE)) -XHCI_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_XHCI_FWM_FILE)) -else -HUDSON_XHCI_POSITION=0 -XHCI_FWM_SIZE=0 -endif - -ifeq ($(CONFIG_HUDSON_GEC_FWM), y) -HUDSON_GEC_POSITION=$(call int-add,$(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) \ - $(XHCI_FWM_SIZE) $(CBFS_HEADER_SIZE)) -GEC_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_GEC_FWM_FILE)) -else -HUDSON_GEC_POSITION=0 -GEC_FWM_SIZE=0 -endif - -ifeq ($(CONFIG_HUDSON_IMC_FWM), y) -HUDSON_IMC_POSITION=$(call int-align,\ - $(call int-add,\ - $(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) $(XHCI_FWM_SIZE)\ - $(CBFS_HEADER_SIZE) $(GEC_FWM_SIZE) $(CBFS_HEADER_SIZE)),\ - 65536) -IMC_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_IMC_FWM_FILE)) -else -HUDSON_IMC_POSITION=0 -IMC_FWM_SIZE=0 -endif - -ifeq ($(CONFIG_CPU_AMD_PI_00730F01), y) -HUDSON_PSP_DIRECTORY_POSITION=$(call int-align,\ - $(call int-add,\ - $(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) $(XHCI_FWM_SIZE)\ - $(CBFS_HEADER_SIZE) $(GEC_FWM_SIZE) $(CBFS_HEADER_SIZE) $(IMC_FWM_SIZE) $(CBFS_HEADER_SIZE)),\ - 65536) -HUDSON_PSP_DIRECTORY_SIZE=256 -else -HUDSON_PSP_DIRECTORY_POSITION=0 -HUDSON_PSP_DIRECTORY_SIZE=0 -endif - -$(obj)/coreboot_hudson_romsig.bin: $(call strip_quotes, $(CONFIG_HUDSON_XHCI_FWM_FILE)) \ - $(call strip_quotes, $(CONFIG_HUDSON_IMC_FWM_FILE)) \ - $(call strip_quotes, $(CONFIG_HUDSON_GEC_FWM_FILE)) \ - $(obj)/config.h - echo " Hudson FW $@" - dd if=/dev/zero of=$@ count=$(ROMSIG_SIZE) ibs=1 status=noxfer 2>/dev/null; \ - for fwm in 1437226410 \ - $(HUDSON_IMC_POSITION) \ - $(HUDSON_GEC_POSITION) \ - $(HUDSON_XHCI_POSITION) \ - $(HUDSON_PSP_DIRECTORY_POSITION); do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done > $@.tmp; \ - dd if=$@.tmp of=$@ conv=notrunc status=noxfer 2>/dev/null; \ - rm $@.tmp - -ifeq ($(CONFIG_HUDSON_FWM), y) -cbfs-files-y += fch/fwm -fch/fwm-file := $(obj)/coreboot_hudson_romsig.bin -fch/fwm-position := $(HUDSON_FWM_POSITION) -fch/fwm-size := $(ROMSIZE_SIG) -fch/fwm-type := raw -endif - -ifeq ($(CONFIG_HUDSON_XHCI_FWM), y) -cbfs-files-y += fch/xhci -fch/xhci-file := $(call strip_quotes, $(CONFIG_HUDSON_XHCI_FWM_FILE)) -fch/xhci-position := $(HUDSON_XHCI_POSITION) -fch/xhci-type := raw -fch/xhci-required := Hudson XHCI firmware (available in coreboot/3rdparty if enabled) -endif - -ifeq ($(CONFIG_HUDSON_IMC_FWM), y) -cbfs-files-y += fch/imc -fch/imc-file := $(call strip_quotes, $(CONFIG_HUDSON_IMC_FWM_FILE)) -fch/imc-position := $(HUDSON_IMC_POSITION) -fch/imc-type := raw -fch/imc-required := Hudson IMC Firmware (available in coreboot/3rdparty if enabled) -endif - -ifeq ($(CONFIG_HUDSON_GEC_FWM), y) -cbfs-files-y += fch/gec -fch/gec-file := $(call strip_quotes, $(CONFIG_HUDSON_GEC_FWM_FILE)) -fch/gec-position := $(HUDSON_GEC_POSITION) -fch/gec-type := raw -fch/gec-required := Hudson Gigabit Ethernet Controller Firmware (Contact your AMD representative) -endif - -ifdef CONFIG_HUDSON_AHCI_ROM -stripped_ahci_rom_id = $(call strip_quotes,$(CONFIG_AHCI_ROM_ID)) -cbfs-files-y += pci$(stripped_ahci_rom_id).rom -pci$(stripped_ahci_rom_id).rom-file := $(call strip_quotes,$(CONFIG_AHCI_ROM_FILE)) -pci$(stripped_ahci_rom_id).rom-type := optionrom -pci$(stripped_ahci_rom_id).rom-required := Hudson AHCI Option ROM (Contact your AMD representative) -endif - -ifeq ($(CONFIG_HUDSON_PSP), y) - -# 0 -# catenate the pubkey and pspdir together to save some space. -AMDPUBKEY_POS=$(call int-add,$(HUDSON_PSP_DIRECTORY_POSITION) $(HUDSON_PSP_DIRECTORY_SIZE)) -AMDPUBKEY_SIZE=$(call file-size,$(CONFIG_AMD_PUBKEY_FILE)) - -ifeq ($(CONFIG_CPU_AMD_PI_00730F01), y) -FIRMWARE_LOCATE=$(dir $(call strip_quotes, $(CONFIG_AMD_PUBKEY_FILE))) -FIRMWARE_TYPE= -endif - -CONFIG_PUBSIGNEDKEY_FILE=$(top)/$(FIRMWARE_LOCATE)/RtmPubSigned$(FIRMWARE_TYPE).key -PUBSIGNEDKEY_POS=$(call int-align, \ - $(call int-add,$(AMDPUBKEY_POS) $(AMDPUBKEY_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -PUBSIGNEDKEY_SIZE=$(call file-size,$(CONFIG_PUBSIGNEDKEY_FILE)) - -CONFIG_PSPBTLDR_FILE=$(top)/$(FIRMWARE_LOCATE)/PspBootLoader$(FIRMWARE_TYPE).Bypass.sbin -PSPBTLDR_POS=$(call int-align, \ - $(call int-add,$(PUBSIGNEDKEY_POS) $(PUBSIGNEDKEY_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -PSPBTLDR_SIZE=$(call file-size,$(CONFIG_PSPBTLDR_FILE)) - -CONFIG_PSPRCVR_FILE=$(top)/$(FIRMWARE_LOCATE)/PspRecovery$(FIRMWARE_TYPE).sbin -PSPRCVR_POS=$(call int-align, \ - $(call int-add,$(PSPBTLDR_POS) $(PSPBTLDR_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -PSPRCVR_SIZE=$(call file-size,$(CONFIG_PSPRCVR_FILE)) - -CONFIG_PSPSCUREOS_FILE=$(top)/$(FIRMWARE_LOCATE)/PspSecureOs$(FIRMWARE_TYPE).sbin -PSPSECUREOS_POS=$(call int-align, \ - $(call int-add,$(PSPRCVR_POS) $(PSPRCVR_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -PSPSECUREOS_SIZE=$(call file-size,$(CONFIG_PSPSCUREOS_FILE)) - -CONFIG_PSPNVRAM_FILE=$(top)/$(FIRMWARE_LOCATE)/PspNvram$(FIRMWARE_TYPE).bin -PSPNVRAM_POS=$(call int-align, \ - $(call int-add,$(PSPSECUREOS_POS) $(PSPSECUREOS_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -PSPNVRAM_SIZE=$(call file-size,$(CONFIG_PSPNVRAM_FILE)) - -CONFIG_SMUFWM_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuFirmware$(FIRMWARE_TYPE).sbin -SMUFWM_POS=$(call int-align, \ - $(call int-add,$(PSPNVRAM_POS) $(PSPNVRAM_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -SMUFWM_SIZE=$(call file-size,$(CONFIG_SMUFWM_FILE)) - -CONFIG_SMUSCS_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuScs$(FIRMWARE_TYPE).bin -SMUSCS_POS=$(call int-align, \ - $(call int-add,$(SMUFWM_POS) $(SMUFWM_SIZE) $(CBFS_HEADER_SIZE)), \ - $(CBFS_HEADER_SIZE)) -SMUSCS_SIZE=$(call file-size,$(CONFIG_SMUSCS_FILE)) - -define output_hex -echo $(1) | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}' -endef - -$(obj)/coreboot_psp_directory.bin: $(obj)/config.h $(FLETCHER) $(RTM_FILE) - echo " PSPDir $@" - for fwm in 0 $(AMDPUBKEY_SIZE) $(AMDPUBKEY_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done > $@_tail.tmp - for fwm in 1 $(PSPBTLDR_SIZE) $(PSPBTLDR_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 8 $(SMUFWM_SIZE) $(SMUFWM_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 3 $(PSPRCVR_SIZE) $(PSPRCVR_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 5 $(PUBSIGNEDKEY_SIZE) $(PUBSIGNEDKEY_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 2 $(PSPSECUREOS_SIZE) $(PSPSECUREOS_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 4 $(PSPNVRAM_SIZE) $(PSPNVRAM_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 95 $(SMUSCS_SIZE) $(SMUSCS_POS) 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 11 4294967295 0 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done >> $@_tail.tmp - for fwm in 1347637284 0 `ls -l $@_tail.tmp | awk '{printf("%d", $$5/16);}'` 0; do \ - echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ - done > $@_head.tmp - cat $@_head.tmp $@_tail.tmp > $@.tmp - $(FLETCHER) < $@.tmp > $@ - rm $@_head.tmp $@_tail.tmp $@.tmp - -$(obj)/coreboot_psp_directory_combine_pubkey.bin: $(obj)/coreboot_psp_directory.bin - cat $(obj)/coreboot_psp_directory.bin > $@ - ls -l $(obj)/coreboot_psp_directory.bin | LC_ALL=C awk '{for (i=0; i<256-$$5; i++) {printf "%c", 255}}' >> $@ - cat $(top)/$(FIRMWARE_LOCATE)/AmdPubKey$(FIRMWARE_TYPE).bin >> $@ - -cbfs-files-y += apu/pspdir -apu/pspdir-file := $(obj)/coreboot_psp_directory_combine_pubkey.bin -apu/pspdir-position := $(HUDSON_PSP_DIRECTORY_POSITION) -apu/pspdir-type := raw - -# 5 -cbfs-files-y += apu/pubsignedkey -apu/pubsignedkey-file := $(CONFIG_PUBSIGNEDKEY_FILE) -apu/pubsignedkey-position := $(PUBSIGNEDKEY_POS) -apu/pubsignedkey-type := raw - -# 1 -cbfs-files-y += apu/pspbtldr -apu/pspbtldr-file := $(CONFIG_PSPBTLDR_FILE) -apu/pspbtldr-position := $(PSPBTLDR_POS) -apu/pspbtldr-type := raw - -#3 -cbfs-files-y += apu/psprcvr -apu/psprcvr-file := $(CONFIG_PSPRCVR_FILE) -apu/psprcvr-position := $(PSPRCVR_POS) -apu/psprcvr-type := raw - -# 2 -cbfs-files-y += apu/pspsecureos -apu/pspsecureos-file := $(CONFIG_PSPSCUREOS_FILE) -apu/pspsecureos-position := $(PSPSECUREOS_POS) -apu/pspsecureos-type := raw - -# 4 -cbfs-files-y += apu/pspnvram -apu/pspnvram-file := $(CONFIG_PSPNVRAM_FILE) -apu/pspnvram-position := $(PSPNVRAM_POS) -apu/pspnvram-type := raw - -#8 -cbfs-files-y += apu/smufwm -apu/smufwm-file := $(CONFIG_SMUFWM_FILE) -apu/smufwm-position := $(SMUFWM_POS) -apu/smufwm-type := raw - -cbfs-files-y += apu/smuscs -apu/smuscs-file := $(CONFIG_SMUSCS_FILE) -apu/smuscs-position := $(SMUSCS_POS) -apu/smuscs-type := raw - -endif diff --git a/src/southbridge/amd/pi/avalon/acpi/audio.asl b/src/southbridge/amd/pi/avalon/acpi/audio.asl deleted file mode 100644 index 2c25ab5..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/audio.asl +++ /dev/null @@ -1,57 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -Device(AZHD) { /* 0:14.2 - HD Audio */ - Name(_ADR, 0x00140002) - OperationRegion(AZPD, PCI_Config, 0x00, 0x100) - Field(AZPD, AnyAcc, NoLock, Preserve) { - offset (0x42), - NSDI, 1, - NSDO, 1, - NSEN, 1, - offset (0x44), - IPCR, 4, - offset (0x54), - PWST, 2, - , 6, - PMEB, 1, - , 6, - PMST, 1, - offset (0x62), - MMCR, 1, - offset (0x64), - MMLA, 32, - offset (0x68), - MMHA, 32, - offset (0x6C), - MMDT, 16, - } - - Method (_INI, 0, NotSerialized) - { - If (LEqual (OSVR, 0x03)) - { - Store (Zero, NSEN) - Store (One, NSDO) - Store (One, NSDI) - } - } -} /* end AZHD */ diff --git a/src/southbridge/amd/pi/avalon/acpi/fch.asl b/src/southbridge/amd/pi/avalon/acpi/fch.asl deleted file mode 100644 index f2764aa..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/fch.asl +++ /dev/null @@ -1,188 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2011 Advanced Micro Devices, Inc. - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* South Bridge */ -/* _SB.PCI0 */ - -/* Operating System Capabilities Method */ -Method(_OSC,4) -{ - // Create DWord-addressable fields from the Capabilities Buffer - CreateDWordField(Arg3,0,CDW1) - CreateDWordField(Arg3,4,CDW2) - CreateDWordField(Arg3,8,CDW3) - - /* Check for proper PCI/PCIe UUID */ - If(LEqual(Arg0,ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) - { - /* Let OS control everything */ - Return (Arg3) - } Else { - Or(CDW1,4,CDW1) // Unrecognized UUID - Return(Arg3) - } -} - -/* Describe the Southbridge devices */ - -/* 0:11.0 - SATA */ -Device(STCR) { - Name(_ADR, 0x00110000) - #include "acpi/sata.asl" -} /* end STCR */ - -/* 0:14.0 - SMBUS */ -Device(SBUS) { - Name(_ADR, 0x00140000) -} /* end SBUS */ - -#include "usb.asl" - -/* 0:14.2 - HD Audio */ -#include "audio.asl" - -/* 0:14.3 - LPC */ -#include "lpc.asl" - -/* 0:14.7 - SD Controller */ -Device(SDCN) { - Name(_ADR, 0x00140007) -} /* end SDCN */ - -Name(CRES, ResourceTemplate() { - /* Set the Bus number and Secondary Bus number for the PCI0 device - * The Secondary bus range for PCI0 lets the system - * know what bus values are allowed on the downstream - * side of this PCI bus if there is a PCI-PCI bridge. - * PCI busses can have 256 secondary busses which - * range from [0-0xFF] but they do not need to be - * sequential. - */ - WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, - 0x0000, /* address granularity */ - 0x0000, /* range minimum */ - 0x00FF, /* range maximum */ - 0x0000, /* translation */ - 0x0100, /* length */ - ,, PSB0) /* ResourceSourceIndex, ResourceSource, DescriptorName */ - - IO(Decode16, 0x0CF8, 0x0CF8, 1, 8) - - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x0000, /* range minimum */ - 0x0CF7, /* range maximum */ - 0x0000, /* translation */ - 0x0CF8 /* length */ - ) - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x03B0, /* range minimum */ - 0x03DF, /* range maximum */ - 0x0000, /* translation */ - 0x0030 /* length */ - ) - - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x0D00, /* range minimum */ - 0xFFFF, /* range maximum */ - 0x0000, /* translation */ - 0xF300 /* length */ - ) - - Memory32Fixed(READONLY, 0x000A0000, 0x00020000, VGAM) /* VGA memory space */ - Memory32Fixed(READONLY, 0x000C0000, 0x00020000, EMM1) /* Assume C0000-E0000 empty */ - - /* memory space for PCI BARs below 4GB */ - Memory32Fixed(ReadOnly, 0x00000000, 0x00000000, MMIO) -}) /* End Name(_SB.PCI0.CRES) */ - -Method(_CRS, 0) { - /* DBGO("\_SB\PCI0\_CRS\n") */ - CreateDWordField(CRES, ^MMIO._BAS, MM1B) - CreateDWordField(CRES, ^MMIO._LEN, MM1L) - - /* - * Declare memory between TOM1 and 4GB as available - * for PCI MMIO. - * Use ShiftLeft to avoid 64bit constant (for XP). - * This will work even if the OS does 32bit arithmetic, as - * 32bit (0x00000000 - TOM1) will wrap and give the same - * result as 64bit (0x100000000 - TOM1). - */ - Store(TOM1, MM1B) - ShiftLeft(0x10000000, 4, Local0) - Subtract(Local0, TOM1, Local0) - Store(Local0, MM1L) - - Return(CRES) /* note to change the Name buffer */ -} /* end of Method(_SB.PCI0._CRS) */ - -/* - * - * FIRST METHOD CALLED UPON BOOT - * - * 1. If debugging, print current OS and ACPI interpreter. - * 2. Get PCI Interrupt routing from ACPI VSM, this - * value is based on user choice in BIOS setup. - */ -Method(_INI, 0) { - /* DBGO("\_SB\_INI\n") */ - /* DBGO(" DSDT.ASL code from ") */ - /* DBGO(__DATE__) */ - /* DBGO(" ") */ - /* DBGO(__TIME__) */ - /* DBGO("\n Sleep states supported: ") */ - /* DBGO("\n") */ - /* DBGO(" \_OS=") */ - /* DBGO(_OS) */ - /* DBGO("\n \_REV=") */ - /* DBGO(_REV) */ - /* DBGO("\n") */ - - /* Determine the OS we're running on */ - OSFL() - - /* TODO: It is unstable. */ - //#include "acpi/AmdImc.asl" /* Hudson IMC function */ - //ITZE() /* enable IMC Fan Control*/ -} /* End Method(_SB._INI) */ - -Method(OSFL, 0){ - - if(LNotEqual(OSVR, Ones)) {Return(OSVR)} /* OS version was already detected */ - - if(CondRefOf(_OSI,Local1)) - { - Store(1, OSVR) /* Assume some form of XP */ - if (_OSI("Windows 2006")) /* Vista */ - { - Store(2, OSVR) - } - } else { - If(WCMP(_OS,"Linux")) { - Store(3, OSVR) /* Linux */ - } Else { - Store(4, OSVR) /* Gotta be WinCE */ - } - } - Return(OSVR) -} diff --git a/src/southbridge/amd/pi/avalon/acpi/lpc.asl b/src/southbridge/amd/pi/avalon/acpi/lpc.asl deleted file mode 100644 index 3383ac8..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/lpc.asl +++ /dev/null @@ -1,108 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* 0:14.3 - LPC */ -Device(LIBR) { - Name(_ADR, 0x00140003) - /* Method(_INI) { - * DBGO("\_SB\PCI0\LpcIsaBr\_INI\n") - } */ /* End Method(_SB.SBRDG._INI) */ - - OperationRegion(CFG,PCI_Config,0x0,0x100) // Map PCI Configuration Space - Field(CFG,DWordAcc,NoLock,Preserve){ - Offset(0xA0), - BAR,32} // SPI Controller Base Address Register (Index 0xA0) - - Device(LDRC) // LPC device: Resource consumption - { - Name (_HID, EISAID("PNP0C02")) // ID for Motherboard resources - Name (CRS, ResourceTemplate () // Current Motherboard resources - { - Memory32Fixed(ReadWrite, // Setup for fixed resource location for SPI base address - 0x00000000, // Address Base - 0x00000000, // Address Length - BAR0 // Descriptor Name - ) - }) - - Method(_CRS,0,NotSerialized) - { - CreateDwordField(^CRS,^BAR0._BAS,SPIB) // Field to hold SPI base address - CreateDwordField(^CRS,^BAR0._LEN,SPIL) // Field to hold SPI address length - Store(BAR,SPIB) // SPI base address mapped - Store(0x1000,SPIL) // 4k space mapped - Return(CRS) - } - } - - /* Real Time Clock Device */ - Device(RTC0) { - Name(_HID, EISAID("PNP0B00")) /* AT Real Time Clock (not PIIX4 compatible) */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){8} - IO(Decode16,0x0070, 0x0070, 0, 2) - }) - } /* End Device(_SB.PCI0.LpcIsaBr.RTC0) */ - - Device(TMR) { /* Timer */ - Name(_HID,EISAID("PNP0100")) /* System Timer */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){0} - IO(Decode16, 0x0040, 0x0040, 0, 4) - }) - } /* End Device(_SB.PCI0.LpcIsaBr.TMR) */ - - Device(SPKR) { /* Speaker */ - Name(_HID,EISAID("PNP0800")) /* AT style speaker */ - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x0061, 0x0061, 0, 1) - }) - } /* End Device(_SB.PCI0.LpcIsaBr.SPKR) */ - - Device(PIC) { - Name(_HID,EISAID("PNP0000")) /* AT Interrupt Controller */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){2} - IO(Decode16,0x0020, 0x0020, 0, 2) - IO(Decode16,0x00A0, 0x00A0, 0, 2) - }) - } /* End Device(_SB.PCI0.LpcIsaBr.PIC) */ - - Device(MAD) { /* 8257 DMA */ - Name(_HID,EISAID("PNP0200")) /* Hardware Device ID */ - Name(_CRS, ResourceTemplate() { - DMA(Compatibility,BusMaster,Transfer8){4} - IO(Decode16, 0x0000, 0x0000, 0x10, 0x10) - IO(Decode16, 0x0081, 0x0081, 0x01, 0x03) - IO(Decode16, 0x0087, 0x0087, 0x01, 0x01) - IO(Decode16, 0x0089, 0x0089, 0x01, 0x03) - IO(Decode16, 0x008F, 0x008F, 0x01, 0x01) - IO(Decode16, 0x00C0, 0x00C0, 0x10, 0x20) - }) /* End Name(_SB.PCI0.LpcIsaBr.MAD._CRS) */ - } /* End Device(_SB.PCI0.LpcIsaBr.MAD) */ - - Device(COPR) { - Name(_HID,EISAID("PNP0C04")) /* Math Coprocessor */ - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x00F0, 0x00F0, 0, 0x10) - IRQNoFlags(){13} - }) - } /* End Device(_SB.PCI0.LpcIsaBr.COPR) */ - #include "acpi/superio.asl" -} /* end LIBR */ diff --git a/src/southbridge/amd/pi/avalon/acpi/pci_int.asl b/src/southbridge/amd/pi/avalon/acpi/pci_int.asl deleted file mode 100644 index 384ed61..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/pci_int.asl +++ /dev/null @@ -1,473 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - - /* PCIe Configuration Space for CONFIG_MMCONF_BUS_NUMBER busses */ - OperationRegion(PCFG, SystemMemory, PCBA, PCLN) /* Each bus consumes 1MB */ - Field(PCFG, ByteAcc, NoLock, Preserve) { - /* Byte offsets are computed using the following technique: - * ((bus number + 1) * ((device number * 8) * 4096)) + register offset - * The 8 comes from 8 functions per device, and 4096 bytes per function config space - */ - Offset(0x00088024), /* Byte offset to SATA register 24h - Bus 0, Device 17, Function 0 */ - STB5, 32, - Offset(0x00098042), /* Byte offset to OHCI0 register 42h - Bus 0, Device 19, Function 0 */ - PT0D, 1, - PT1D, 1, - PT2D, 1, - PT3D, 1, - PT4D, 1, - PT5D, 1, - PT6D, 1, - PT7D, 1, - PT8D, 1, - PT9D, 1, - Offset(0x000A0004), /* Byte offset to SMBUS register 4h - Bus 0, Device 20, Function 0 */ - SBIE, 1, - SBME, 1, - Offset(0x000A0008), /* Byte offset to SMBUS register 8h - Bus 0, Device 20, Function 0 */ - SBRI, 8, - Offset(0x000A0014), /* Byte offset to SMBUS register 14h - Bus 0, Device 20, Function 0 */ - SBB1, 32, - Offset(0x000A0078), /* Byte offset to SMBUS register 78h - Bus 0, Device 20, Function 0 */ - ,14, - P92E, 1, /* Port92 decode enable */ - } - - OperationRegion(SB5, SystemMemory, STB5, 0x1000) - Field(SB5, AnyAcc, NoLock, Preserve){ - /* Port 0 */ - Offset(0x120), /* Port 0 Task file status */ - P0ER, 1, - , 2, - P0DQ, 1, - , 3, - P0BY, 1, - Offset(0x128), /* Port 0 Serial ATA status */ - P0DD, 4, - , 4, - P0IS, 4, - Offset(0x12C), /* Port 0 Serial ATA control */ - P0DI, 4, - Offset(0x130), /* Port 0 Serial ATA error */ - , 16, - P0PR, 1, - - /* Port 1 */ - offset(0x1A0), /* Port 1 Task file status */ - P1ER, 1, - , 2, - P1DQ, 1, - , 3, - P1BY, 1, - Offset(0x1A8), /* Port 1 Serial ATA status */ - P1DD, 4, - , 4, - P1IS, 4, - Offset(0x1AC), /* Port 1 Serial ATA control */ - P1DI, 4, - Offset(0x1B0), /* Port 1 Serial ATA error */ - , 16, - P1PR, 1, - - /* Port 2 */ - Offset(0x220), /* Port 2 Task file status */ - P2ER, 1, - , 2, - P2DQ, 1, - , 3, - P2BY, 1, - Offset(0x228), /* Port 2 Serial ATA status */ - P2DD, 4, - , 4, - P2IS, 4, - Offset(0x22C), /* Port 2 Serial ATA control */ - P2DI, 4, - Offset(0x230), /* Port 2 Serial ATA error */ - , 16, - P2PR, 1, - - /* Port 3 */ - Offset(0x2A0), /* Port 3 Task file status */ - P3ER, 1, - , 2, - P3DQ, 1, - , 3, - P3BY, 1, - Offset(0x2A8), /* Port 3 Serial ATA status */ - P3DD, 4, - , 4, - P3IS, 4, - Offset(0x2AC), /* Port 3 Serial ATA control */ - P3DI, 4, - Offset(0x2B0), /* Port 3 Serial ATA error */ - , 16, - P3PR, 1, - } - - Method(_PIC, 0x01, NotSerialized) - { - If (Arg0) - { - _SB.CIRQ() - } - Store(Arg0, PMOD) - } - - Method(CIRQ, 0x00, NotSerialized){ - } - - Name(IRQB, ResourceTemplate(){ - IRQ(Level,ActiveLow,Shared){15} - }) - - Name(IRQP, ResourceTemplate(){ - IRQ(Level,ActiveLow,Exclusive){3, 4, 5, 7, 10, 11, 12, 15} - }) - - Name(PITF, ResourceTemplate(){ - IRQ(Level,ActiveLow,Exclusive){9} - }) - - Device(INTA) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 1) - - Method(_STA, 0) { - if (PIRA) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTA._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKA\_DIS\n") */ - } /* End Method(_SB.INTA._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKA\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTA._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKA\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRA, IRQN) - Return(IRQB) - } /* Method(_SB.INTA._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKA\_SRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRA) - } /* End Method(_SB.INTA._SRS) */ - } /* End Device(INTA) */ - - Device(INTB) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 2) - - Method(_STA, 0) { - if (PIRB) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTB._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKB\_DIS\n") */ - } /* End Method(_SB.INTB._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKB\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTB._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKB\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRB, IRQN) - Return(IRQB) - } /* Method(_SB.INTB._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKB\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRB) - } /* End Method(_SB.INTB._SRS) */ - } /* End Device(INTB) */ - - Device(INTC) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 3) - - Method(_STA, 0) { - if (PIRC) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTC._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKC\_DIS\n") */ - } /* End Method(_SB.INTC._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKC\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTC._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKC\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRC, IRQN) - Return(IRQB) - } /* Method(_SB.INTC._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKC\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRC) - } /* End Method(_SB.INTC._SRS) */ - } /* End Device(INTC) */ - - Device(INTD) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 4) - - Method(_STA, 0) { - if (PIRD) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTD._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKD\_DIS\n") */ - } /* End Method(_SB.INTD._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKD\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTD._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKD\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRD, IRQN) - Return(IRQB) - } /* Method(_SB.INTD._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKD\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRD) - } /* End Method(_SB.INTD._SRS) */ - } /* End Device(INTD) */ - - Device(INTE) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 5) - - Method(_STA, 0) { - if (PIRE) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTE._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKE\_DIS\n") */ - } /* End Method(_SB.INTE._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKE\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTE._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKE\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRE, IRQN) - Return(IRQB) - } /* Method(_SB.INTE._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKE\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRE) - } /* End Method(_SB.INTE._SRS) */ - } /* End Device(INTE) */ - - Device(INTF) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 6) - - Method(_STA, 0) { - if (PIRF) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTF._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKF\_DIS\n") */ - } /* End Method(_SB.INTF._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKF\_PRS\n") */ - Return(PITF) - } /* Method(_SB.INTF._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKF\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRF, IRQN) - Return(IRQB) - } /* Method(_SB.INTF._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKF\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRF) - } /* End Method(_SB.INTF._SRS) */ - } /* End Device(INTF) */ - - Device(INTG) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 7) - - Method(_STA, 0) { - if (PIRG) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTG._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKG\_DIS\n") */ - } /* End Method(_SB.INTG._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKG\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTG._CRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKG\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRG, IRQN) - Return(IRQB) - } /* Method(_SB.INTG._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKG\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRG) - } /* End Method(_SB.INTG._SRS) */ - } /* End Device(INTG) */ - - Device(INTH) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 8) - - Method(_STA, 0) { - if (PIRH) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTH._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKH\_DIS\n") */ - } /* End Method(_SB.INTH._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKH\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTH._CRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKH\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRH, IRQN) - Return(IRQB) - } /* Method(_SB.INTH._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKH\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRH) - } /* End Method(_SB.INTH._SRS) */ - } /* End Device(INTH) */ diff --git a/src/southbridge/amd/pi/avalon/acpi/pcie.asl b/src/southbridge/amd/pi/avalon/acpi/pcie.asl deleted file mode 100644 index f130fb4..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/pcie.asl +++ /dev/null @@ -1,95 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - - /* PCI IRQ mapping registers, C00h-C01h. */ - OperationRegion(PRQM, SystemIO, 0x00000C00, 0x00000002) - Field(PRQM, ByteAcc, NoLock, Preserve) { - PRQI, 0x00000008, - PRQD, 0x00000008, /* Offset: 1h */ - } - IndexField(PRQI, PRQD, ByteAcc, NoLock, Preserve) { - PIRA, 0x00000008, /* Index 0 */ - PIRB, 0x00000008, /* Index 1 */ - PIRC, 0x00000008, /* Index 2 */ - PIRD, 0x00000008, /* Index 3 */ - PIRE, 0x00000008, /* Index 4 */ - PIRF, 0x00000008, /* Index 5 */ - PIRG, 0x00000008, /* Index 6 */ - PIRH, 0x00000008, /* Index 7 */ - } - - /* PCI Error control register */ - OperationRegion(PERC, SystemIO, 0x00000C14, 0x00000001) - Field(PERC, ByteAcc, NoLock, Preserve) { - SENS, 0x00000001, - PENS, 0x00000001, - SENE, 0x00000001, - PENE, 0x00000001, - } - - /* Client Management index/data registers */ - OperationRegion(CMT, SystemIO, 0x00000C50, 0x00000002) - Field(CMT, ByteAcc, NoLock, Preserve) { - CMTI, 8, - /* Client Management Data register */ - G64E, 1, - G64O, 1, - G32O, 2, - , 2, - GPSL, 2, - } - - /* GPM Port register */ - OperationRegion(GPT, SystemIO, 0x00000C52, 0x00000001) - Field(GPT, ByteAcc, NoLock, Preserve) { - GPB0,1, - GPB1,1, - GPB2,1, - GPB3,1, - GPB4,1, - GPB5,1, - GPB6,1, - GPB7,1, - } - - /* Flash ROM program enable register */ - OperationRegion(FRE, SystemIO, 0x00000C6F, 0x00000001) - Field(FRE, ByteAcc, NoLock, Preserve) { - , 0x00000006, - FLRE, 0x00000001, - } - - /* PM2 index/data registers */ - OperationRegion(PM2R, SystemIO, 0x00000CD0, 0x00000002) - Field(PM2R, ByteAcc, NoLock, Preserve) { - PM2I, 0x00000008, - PM2D, 0x00000008, - } - - /* Power Management I/O registers, TODO:PMIO is quite different in SB800. */ - OperationRegion(PIOR, SystemIO, 0x00000CD6, 0x00000002) - Field(PIOR, ByteAcc, NoLock, Preserve) { - PIOI, 0x00000008, - PIOD, 0x00000008, - } - - IndexField (PIOI, PIOD, ByteAcc, NoLock, Preserve) { - Offset(0xEE), - UPWS, 3, - } diff --git a/src/southbridge/amd/pi/avalon/acpi/sleepstates.asl b/src/southbridge/amd/pi/avalon/acpi/sleepstates.asl deleted file mode 100644 index f8d0bb0..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/sleepstates.asl +++ /dev/null @@ -1,40 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* Supported sleep states: */ -Name(_S0, Package () {0x00, 0x00, 0x00, 0x00} ) /* (S0) - working state */ - -If (LAnd(SSFG, 0x01)) { - Name(_S1, Package () {0x01, 0x01, 0x00, 0x00} ) /* (S1) - sleeping w/CPU context */ -} -If (LAnd(SSFG, 0x02)) { - Name(_S2, Package () {0x02, 0x02, 0x00, 0x00} ) /* (S2) - "light" Suspend to RAM */ -} -If (LAnd(SSFG, 0x04)) { - Name(_S3, Package () {0x03, 0x03, 0x00, 0x00} ) /* (S3) - Suspend to RAM */ -} -If (LAnd(SSFG, 0x08)) { - Name(_S4, Package () {0x04, 0x04, 0x00, 0x00} ) /* (S4) - Suspend to Disk */ -} - -Name(_S5, Package () {0x05, 0x05, 0x00, 0x00} ) /* (S5) - Soft Off */ - -Name(_SB.CSPS ,0) /* Current Sleep State (S0, S1, S2, S3, S4, S5) */ -Name(CSMS, 0) /* Current System State */ diff --git a/src/southbridge/amd/pi/avalon/acpi/smbus.asl b/src/southbridge/amd/pi/avalon/acpi/smbus.asl deleted file mode 100644 index 11aff4a..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/smbus.asl +++ /dev/null @@ -1,20 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* SMBus Support */ diff --git a/src/southbridge/amd/pi/avalon/acpi/usb.asl b/src/southbridge/amd/pi/avalon/acpi/usb.asl deleted file mode 100644 index 4ec338e..0000000 --- a/src/southbridge/amd/pi/avalon/acpi/usb.asl +++ /dev/null @@ -1,78 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2007-2009 coresystems GmbH - * - * This program is free software; you can redistribute it and/or - * modify it under the terms of the GNU General Public License as - * published by the Free Software Foundation; version 2 of - * the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, - * MA 02110-1301 USA - */ - -/* 0:12.0 - OHCI */ -Device(UOH1) { - Name(_ADR, 0x00120000) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH1 */ - -/* 0:12.2 - EHCI */ -Device(UOH2) { - Name(_ADR, 0x00120002) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH2 */ - -/* 0:13.0 - OHCI */ -Device(UOH3) { - Name(_ADR, 0x00130000) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH3 */ - -/* 0:13.2 - EHCI */ -Device(UOH4) { - Name(_ADR, 0x00130002) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH4 */ - -/* 0:16.0 - OHCI */ -Device(UOH5) { - Name(_ADR, 0x00160000) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH5 */ - -/* 0:16.2 - EHCI */ -Device(UOH6) { - Name(_ADR, 0x00160002) - Name(_PRW, Package() {0x0B, 3}) -} /* end UOH5 */ - -#if !CONFIG_SOUTHBRIDGE_AMD_PI_AVALON -/* 0:14.5 - OHCI */ -Device(UEH1) { - Name(_ADR, 0x00140005) - Name(_PRW, Package() {0x0B, 3}) -} /* end UEH1 */ -#endif - -/* 0:10.0 - XHCI 0*/ -Device(XHC0) { - Name(_ADR, 0x00100000) - Name(_PRW, Package() {0x0B, 4}) -} /* end XHC0 */ - -#if !CONFIG_SOUTHBRIDGE_AMD_PI_AVALON -/* 0:10.1 - XHCI 1*/ -Device(XHC1) { - Name(_ADR, 0x00100001) - Name(_PRW, Package() {0x0B, 4}) -} /* end XHC1 */ -#endif diff --git a/src/southbridge/amd/pi/avalon/amd_pci_int_defs.h b/src/southbridge/amd/pi/avalon/amd_pci_int_defs.h deleted file mode 100644 index e6bd2da..0000000 --- a/src/southbridge/amd/pi/avalon/amd_pci_int_defs.h +++ /dev/null @@ -1,72 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef AMD_PCI_INT_DEFS_H -#define AMD_PCI_INT_DEFS_H - -/* - * PIRQ and device routing - these define the index - * into the FCH PCI_INTR 0xC00/0xC01 interrupt - * routing table - */ -#define FCH_INT_TABLE_SIZE 0x63 - -#define PIRQ_NC 0x1F /* Not Used */ -#define PIRQ_A 0x00 /* INT A */ -#define PIRQ_B 0x01 /* INT B */ -#define PIRQ_C 0x02 /* INT C */ -#define PIRQ_D 0x03 /* INT D */ -#define PIRQ_E 0x04 /* INT E */ -#define PIRQ_F 0x05 /* INT F */ -#define PIRQ_G 0x06 /* INT G */ -#define PIRQ_H 0x07 /* INT H */ -#define PIRQ_MISC 0x08 /* Miscellaneous IRQ Settings - See FCH Spec */ -#define PIRQ_MISC0 0x09 /* Miscellaneous0 IRQ Settings */ -#define PIRQ_MISC1 0x0A /* Miscellaneous1 IRQ Settings */ -#define PIRQ_MISC2 0x0B /* Miscellaneous2 IRQ Settings */ -#define PIRQ_SIRQA 0x0C /* Serial IRQ INTA */ -#define PIRQ_SIRQB 0x0D /* Serial IRQ INTA */ -#define PIRQ_SIRQC 0x0E /* Serial IRQ INTA */ -#define PIRQ_SIRQD 0x0F /* Serial IRQ INTA */ -#define PIRQ_SCI 0x10 /* SCI IRQ */ -#define PIRQ_SMBUS 0x11 /* SMBUS 14h.0 */ -#define PIRQ_ASF 0x12 /* ASF */ -#define PIRQ_HDA 0x13 /* HDA 14h.2 */ -#define PIRQ_FC 0x14 /* FC */ -#define PIRQ_GEC 0x15 /* GEC */ -#define PIRQ_PMON 0x16 /* Performance Monitor */ -#define PIRQ_SD 0x17 /* SD */ -#define PIRQ_IMC0 0x20 /* IMC INT0 */ -#define PIRQ_IMC1 0x21 /* IMC INT1 */ -#define PIRQ_IMC2 0x22 /* IMC INT2 */ -#define PIRQ_IMC3 0x23 /* IMC INT3 */ -#define PIRQ_IMC4 0x24 /* IMC INT4 */ -#define PIRQ_IMC5 0x25 /* IMC INT5 */ -#define PIRQ_OHCI1 0x30 /* USB OHCI 12h.0 */ -#define PIRQ_EHCI1 0x31 /* USB EHCI 12h.2 */ -#define PIRQ_OHCI2 0x32 /* USB OHCI 13h.0 */ -#define PIRQ_EHCI2 0x33 /* USB EHCI 13h.2 */ -#define PIRQ_OHCI3 0x34 /* USB OHCI 16h.0 */ -#define PIRQ_EHCI3 0x35 /* USB EHCI 16h.2 */ -#define PIRQ_OHCI4 0x36 /* USB OHCI 14h.5 */ -#define PIRQ_IDE 0x40 /* IDE 14h.1 */ -#define PIRQ_SATA 0x41 /* SATA 11h.0 */ -#define PIRQ_GPIO 0x62 /* GPIO Controller Interrupt */ - -#endif /* AMD_PCI_INT_DEFS_H */ diff --git a/src/southbridge/amd/pi/avalon/amd_pci_int_types.h b/src/southbridge/amd/pi/avalon/amd_pci_int_types.h deleted file mode 100644 index d0fe9c8..0000000 --- a/src/southbridge/amd/pi/avalon/amd_pci_int_types.h +++ /dev/null @@ -1,33 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef AMD_PCI_INT_TYPES_H -#define AMD_PCI_INT_TYPES_H - -const char * intr_types[] = { - [0x00] = "INTA#\t", "INTB#\t", "INTC#\t", "INTD#\t", "INTE#\t", "INTF#\t", "INTG#\t", "INTH#\t", - [0x08] = "Misc\t", "Misc0\t", "Misc1\t", "Misc2\t", "Ser IRQ INTA", "Ser IRQ INTB", "Ser IRQ INTC", "Ser IRQ INTD", - [0x10] = "SCI\t", "SMBUS0\t", "ASF\t", "HDA\t", "FC\t\t", "GEC\t", "PerMon\t", "SD\t", - [0x20] = "IMC INT0\t", "IMC INT1\t", "IMC INT2\t", "IMC INT3\t", "IMC INT4\t", "IMC INT5\t", - [0x30] = "Dev18.0 INTA", "Dev18.2 INTB", "Dev19.0 INTA", "Dev19.2 INTB", "Dev22.0 INTA", "Dev22.2 INTB", - [0x40] = "RSVD\t", "SATA\t", - [0x60] = "RSVD\t", "RSVD\t", "GPIO\t", -}; - -#endif /* AMD_PCI_INT_TYPES_H */ diff --git a/src/southbridge/amd/pi/avalon/bootblock.c b/src/southbridge/amd/pi/avalon/bootblock.c deleted file mode 100644 index 3cdba8b..0000000 --- a/src/southbridge/amd/pi/avalon/bootblock.c +++ /dev/null @@ -1,67 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <stdint.h> -#include <arch/io.h> -#include <device/pci_ids.h> - -/* - * Enable 4MB (LPC) ROM access at 0xFFC00000 - 0xFFFFFFFF. - * - * Hardware should enable LPC ROM by pin straps. This function does not - * handle the theoretically possible PCI ROM, FWH, or SPI ROM configurations. - * - * The HUDSON power-on default is to map 512K ROM space. - * - */ -static void hudson_enable_rom(void) -{ - u8 reg8; - pci_devfn_t dev; - - dev = PCI_DEV(0, 0x14, 3); - - /* Decode variable LPC ROM address ranges 1 and 2. */ - reg8 = pci_read_config8(dev, 0x48); - reg8 |= (1 << 3) | (1 << 4); - pci_write_config8(dev, 0x48, reg8); - - /* LPC ROM address range 1: */ - /* Enable LPC ROM range mirroring start at 0x000e(0000). */ - pci_write_config16(dev, 0x68, 0x000e); - /* Enable LPC ROM range mirroring end at 0x000f(ffff). */ - pci_write_config16(dev, 0x6a, 0x000f); - - /* LPC ROM address range 2: */ - /* - * Enable LPC ROM range start at: - * 0xfff8(0000): 512KB - * 0xfff0(0000): 1MB - * 0xffe0(0000): 2MB - * 0xffc0(0000): 4MB - */ - pci_write_config16(dev, 0x6c, 0x10000 - (CONFIG_COREBOOT_ROMSIZE_KB >> 6)); - /* Enable LPC ROM range end at 0xffff(ffff). */ - pci_write_config16(dev, 0x6e, 0xffff); -} - -static void bootblock_southbridge_init(void) -{ - hudson_enable_rom(); -} diff --git a/src/southbridge/amd/pi/avalon/chip.h b/src/southbridge/amd/pi/avalon/chip.h deleted file mode 100644 index 40b2480..0000000 --- a/src/southbridge/amd/pi/avalon/chip.h +++ /dev/null @@ -1,35 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef AVALON_CHIP_H -#define AVALON_CHIP_H - -struct southbridge_amd_pi_avalon_config -{ - #if 1 - u32 ide0_enable : 1; - u32 sata0_enable : 1; - u32 boot_switch_sata_ide : 1; - u32 hda_viddid; - u8 gpp_configuration; - u8 sd_mode; - #endif -}; - -#endif /* AVALON_CHIP_H */ diff --git a/src/southbridge/amd/pi/avalon/early_setup.c b/src/southbridge/amd/pi/avalon/early_setup.c deleted file mode 100644 index 9500d0e..0000000 --- a/src/southbridge/amd/pi/avalon/early_setup.c +++ /dev/null @@ -1,126 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef _HUDSON_EARLY_SETUP_C_ -#define _HUDSON_EARLY_SETUP_C_ - -#include <stdint.h> -#include <arch/io.h> -#include <arch/acpi.h> -#include <console/console.h> -#include <reset.h> -#include <arch/cpu.h> -#include <cbmem.h> -#include "hudson.h" - -void hudson_pci_port80(void) -{ - u8 byte; - device_t dev; - - /* P2P Bridge */ - dev = PCI_DEV(0, 0x14, 4); - - /* Chip Control: Enable subtractive decoding */ - byte = pci_read_config8(dev, 0x40); - byte |= 1 << 5; - pci_write_config8(dev, 0x40, byte); - - /* Misc Control: Enable subtractive decoding if 0x40 bit 5 is set */ - byte = pci_read_config8(dev, 0x4B); - byte |= 1 << 7; - pci_write_config8(dev, 0x4B, byte); - - /* The same IO Base and IO Limit here is meaningful because we set the - * bridge to be subtractive. During early setup stage, we have to make - * sure that data can go through port 0x80. - */ - /* IO Base: 0xf000 */ - byte = pci_read_config8(dev, 0x1C); - byte |= 0xF << 4; - pci_write_config8(dev, 0x1C, byte); - - /* IO Limit: 0xf000 */ - byte = pci_read_config8(dev, 0x1D); - byte |= 0xF << 4; - pci_write_config8(dev, 0x1D, byte); - - /* PCI Command: Enable IO response */ - byte = pci_read_config8(dev, 0x04); - byte |= 1 << 0; - pci_write_config8(dev, 0x04, byte); - - /* LPC controller */ - dev = PCI_DEV(0, 0x14, 3); - - byte = pci_read_config8(dev, 0x4A); - byte &= ~(1 << 5); /* disable lpc port 80 */ - pci_write_config8(dev, 0x4A, byte); -} - -void hudson_lpc_port80(void) -{ - u8 byte; - device_t dev; - - /* Enable LPC controller */ - outb(0xEC, 0xCD6); - byte = inb(0xCD7); - byte |= 1; - outb(0xEC, 0xCD6); - outb(byte, 0xCD7); - - /* Enable port 80 LPC decode in pci function 3 configuration space. */ - dev = PCI_DEV(0, 0x14, 3); - byte = pci_read_config8(dev, 0x4a); - byte |= 1 << 5; /* enable port 80 */ - pci_write_config8(dev, 0x4a, byte); -} - -int s3_save_nvram_early(u32 dword, int size, int nvram_pos) -{ - int i; - printk(BIOS_DEBUG, "Writing %x of size %d to nvram pos: %d\n", dword, size, nvram_pos); - - for (i = 0; i<size; i++) { - outb(nvram_pos, BIOSRAM_INDEX); - outb((dword >>(8 * i)) & 0xff , BIOSRAM_DATA); - nvram_pos++; - } - - return nvram_pos; -} - -int s3_load_nvram_early(int size, u32 *old_dword, int nvram_pos) -{ - u32 data = *old_dword; - int i; - for (i = 0; i<size; i++) { - outb(nvram_pos, BIOSRAM_INDEX); - data &= ~(0xff << (i * 8)); - data |= inb(BIOSRAM_DATA) << (i *8); - nvram_pos++; - } - *old_dword = data; - printk(BIOS_DEBUG, "Loading %x of size %d to nvram pos:%d\n", *old_dword, size, - nvram_pos-size); - return nvram_pos; -} - -#endif diff --git a/src/southbridge/amd/pi/avalon/enable_usbdebug.c b/src/southbridge/amd/pi/avalon/enable_usbdebug.c deleted file mode 100644 index 258267e..0000000 --- a/src/southbridge/amd/pi/avalon/enable_usbdebug.c +++ /dev/null @@ -1,63 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -// Use simple device model for this file even in ramstage -#define __SIMPLE_DEVICE__ - -#include <stdint.h> -#include <arch/io.h> -#include <device/pci_ehci.h> -#include <device/pci_def.h> -#include "hudson.h" - -#define DEBUGPORT_MISC_CONTROL 0x80 - -pci_devfn_t pci_ehci_dbg_dev(unsigned int hcd_idx) -{ - if (hcd_idx==3) - return PCI_DEV(0, 0x16, 2); - else if (hcd_idx==2) - return PCI_DEV(0, 0x13, 2); - else - return PCI_DEV(0, 0x12, 2); -} - -void pci_ehci_dbg_set_port(pci_devfn_t dev, unsigned int port) -{ - u32 base_regs = pci_ehci_base_regs(dev); - u32 reg32; - - /* Write the port number to DEBUGPORT_MISC_CONTROL[31:28]. */ - reg32 = read32(base_regs + DEBUGPORT_MISC_CONTROL); - reg32 &= ~(0xf << 28); - reg32 |= (port << 28); - reg32 |= (1 << 27); /* Enable Debug Port port number remapping. */ - write32(base_regs + DEBUGPORT_MISC_CONTROL, reg32); -} - - -void pci_ehci_dbg_enable(pci_devfn_t dev, unsigned long base) -{ - /* Enable all of the USB controllers */ - outb(0xEF, PM_INDEX); - outb(0x7F, PM_DATA); - - pci_write_config32(dev, EHCI_BAR_INDEX, base); - pci_write_config8(dev, PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); -} diff --git a/src/southbridge/amd/pi/avalon/fadt.c b/src/southbridge/amd/pi/avalon/fadt.c deleted file mode 100644 index f86016a..0000000 --- a/src/southbridge/amd/pi/avalon/fadt.c +++ /dev/null @@ -1,211 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2012 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -/* - * ACPI - create the Fixed ACPI Description Tables (FADT) - */ - -#include <string.h> -#include <console/console.h> -#include <arch/acpi.h> -#include <arch/io.h> -#include <device/device.h> -#include "hudson.h" -#include "smi.h" - -#if CONFIG_HUDSON_LEGACY_FREE - #define FADT_BOOT_ARCH ACPI_FADT_LEGACY_FREE -#else - #define FADT_BOOT_ARCH (ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042) -#endif - -#ifndef FADT_PM_PROFILE - #define FADT_PM_PROFILE PM_UNSPECIFIED -#endif - -/* - * Reference section 5.2.9 Fixed ACPI Description Table (FADT) - * in the ACPI 3.0b specification. - */ -void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) -{ - acpi_header_t *header = &(fadt->header); - - printk(BIOS_DEBUG, "pm_base: 0x%04x\n", HUDSON_ACPI_IO_BASE); - - /* Prepare the header */ - memset((void *)fadt, 0, sizeof(acpi_fadt_t)); - memcpy(header->signature, "FACP", 4); - header->length = sizeof(acpi_fadt_t); - header->revision = ACPI_FADT_REV_ACPI_3_0; - memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); - memcpy(header->asl_compiler_id, ASLC, 4); - header->asl_compiler_revision = 0; - - fadt->firmware_ctrl = (u32) facs; - fadt->dsdt = (u32) dsdt; - fadt->model = 0; /* reserved, should be 0 ACPI 3.0 */ - fadt->preferred_pm_profile = FADT_PM_PROFILE; - fadt->sci_int = 9; /* HUDSON - IRQ 09 – ACPI SCI */ - - if (IS_ENABLED(CONFIG_HAVE_SMI_HANDLER)) { - fadt->smi_cmd = ACPI_SMI_CTL_PORT; - fadt->acpi_enable = ACPI_SMI_CMD_ENABLE; - fadt->acpi_disable = ACPI_SMI_CMD_DISABLE; - fadt->s4bios_req = 0; /* Not supported */ - fadt->pstate_cnt = 0; /* Not supported */ - fadt->cst_cnt = 0; /* Not supported */ - outl(0x0, ACPI_PM1_CNT_BLK); /* clear SCI_EN */ - } else { - fadt->smi_cmd = 0; /* disable system management mode */ - fadt->acpi_enable = 0; /* unused if SMI_CMD = 0 */ - fadt->acpi_disable = 0; /* unused if SMI_CMD = 0 */ - fadt->s4bios_req = 0; /* unused if SMI_CMD = 0 */ - fadt->pstate_cnt = 0; /* unused if SMI_CMD = 0 */ - fadt->cst_cnt = 0x00; /* unused if SMI_CMD = 0 */ - outl(0x1, ACPI_PM1_CNT_BLK); /* set SCI_EN */ - } - - fadt->pm1a_evt_blk = ACPI_PM_EVT_BLK; - fadt->pm1b_evt_blk = 0x0000; - fadt->pm1a_cnt_blk = ACPI_PM1_CNT_BLK; - fadt->pm1b_cnt_blk = 0x0000; - fadt->pm2_cnt_blk = 0x0000; - fadt->pm_tmr_blk = ACPI_PM_TMR_BLK; - fadt->gpe0_blk = ACPI_GPE0_BLK; - fadt->gpe1_blk = 0x0000; /* No gpe1 block in hudson */ - - fadt->pm1_evt_len = 4; /* 32 bits */ - fadt->pm1_cnt_len = 2; /* 16 bits */ - fadt->pm2_cnt_len = 0; - fadt->pm_tmr_len = 4; /* 32 bits */ - fadt->gpe0_blk_len = 8; /* 64 bits */ - fadt->gpe1_blk_len = 0; - fadt->gpe1_base = 0; - - fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; - fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; - fadt->flush_size = 0; /* set to 0 if WBINVD is 1 in flags */ - fadt->flush_stride = 0; /* set to 0 if WBINVD is 1 in flags */ - fadt->duty_offset = 1; /* CLK_VAL bits 3:1 */ - fadt->duty_width = 3; /* CLK_VAL bits 3:1 */ - fadt->day_alrm = 0; /* 0x7d these have to be */ - fadt->mon_alrm = 0; /* 0x7e added to cmos.layout */ - fadt->century = 0; /* 0x7f to make rtc alarm work */ - fadt->iapc_boot_arch = FADT_BOOT_ARCH; /* See table 5-10 */ - fadt->res2 = 0; /* reserved, MUST be 0 ACPI 3.0 */ - fadt->flags = ACPI_FADT_WBINVD | /* See table 5-10 ACPI 3.0a spec */ - ACPI_FADT_C1_SUPPORTED | - ACPI_FADT_SLEEP_BUTTON | - ACPI_FADT_S4_RTC_WAKE | - ACPI_FADT_32BIT_TIMER | - ACPI_FADT_RESET_REGISTER | - ACPI_FADT_PCI_EXPRESS_WAKE | - ACPI_FADT_PLATFORM_CLOCK | - ACPI_FADT_S4_RTC_VALID | - ACPI_FADT_REMOTE_POWER_ON; - - /* Format is from 5.2.3.1: Generic Address Structure */ - /* reset_reg: see section 4.7.3.6 ACPI 3.0a spec */ - /* 8 bit write of value 0x06 to 0xCF9 in IO space */ - fadt->reset_reg.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->reset_reg.bit_width = 8; - fadt->reset_reg.bit_offset = 0; - fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->reset_reg.addrl = 0xcf9; - fadt->reset_reg.addrh = 0x0; - - fadt->reset_value = 6; - - fadt->res3 = 0; /* reserved, MUST be 0 ACPI 3.0 */ - fadt->res4 = 0; /* reserved, MUST be 0 ACPI 3.0 */ - fadt->res5 = 0; /* reserved, MUST be 0 ACPI 3.0 */ - - fadt->x_firmware_ctl_l = 0; /* set to 0 if firmware_ctrl is used */ - fadt->x_firmware_ctl_h = 0; - fadt->x_dsdt_l = (u32) dsdt; - fadt->x_dsdt_h = 0; - - fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm1a_evt_blk.bit_width = 32; - fadt->x_pm1a_evt_blk.bit_offset = 0; - fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; - fadt->x_pm1a_evt_blk.addrl = ACPI_PM_EVT_BLK; - fadt->x_pm1a_evt_blk.addrh = 0x0; - - fadt->x_pm1b_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm1b_evt_blk.bit_width = 0; - fadt->x_pm1b_evt_blk.bit_offset = 0; - fadt->x_pm1b_evt_blk.access_size = 0; - fadt->x_pm1b_evt_blk.addrl = 0x0; - fadt->x_pm1b_evt_blk.addrh = 0x0; - - - fadt->x_pm1a_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm1a_cnt_blk.bit_width = 16; - fadt->x_pm1a_cnt_blk.bit_offset = 0; - fadt->x_pm1a_cnt_blk.access_size = 0; - fadt->x_pm1a_cnt_blk.addrl = ACPI_PM1_CNT_BLK; - fadt->x_pm1a_cnt_blk.addrh = 0x0; - - fadt->x_pm1b_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm1b_cnt_blk.bit_width = 0; - fadt->x_pm1b_cnt_blk.bit_offset = 0; - fadt->x_pm1b_cnt_blk.access_size = 0; - fadt->x_pm1b_cnt_blk.addrl = 0x0; - fadt->x_pm1b_cnt_blk.addrh = 0x0; - - /* - * Note: Under this current AMD C state implementation, this is no longer - * used and should not be reported to OS. - */ - fadt->x_pm2_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm2_cnt_blk.bit_width = 0; - fadt->x_pm2_cnt_blk.bit_offset = 0; - fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; - fadt->x_pm2_cnt_blk.addrl = 0; - fadt->x_pm2_cnt_blk.addrh = 0x0; - - - fadt->x_pm_tmr_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_pm_tmr_blk.bit_width = 32; - fadt->x_pm_tmr_blk.bit_offset = 0; - fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_pm_tmr_blk.addrl = ACPI_PM_TMR_BLK; - fadt->x_pm_tmr_blk.addrh = 0x0; - - - fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_gpe0_blk.bit_width = 64; /* EventStatus + Event Enable */ - fadt->x_gpe0_blk.bit_offset = 0; - fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; - fadt->x_gpe0_blk.addrl = ACPI_GPE0_BLK; - fadt->x_gpe0_blk.addrh = 0x0; - - - fadt->x_gpe1_blk.space_id = ACPI_ADDRESS_SPACE_IO; - fadt->x_gpe1_blk.bit_width = 0; - fadt->x_gpe1_blk.bit_offset = 0; - fadt->x_gpe1_blk.access_size = 0; - fadt->x_gpe1_blk.addrl = 0; - fadt->x_gpe1_blk.addrh = 0x0; - - header->checksum = acpi_checksum((void *)fadt, sizeof(acpi_fadt_t)); -} diff --git a/src/southbridge/amd/pi/avalon/hda.c b/src/southbridge/amd/pi/avalon/hda.c deleted file mode 100644 index 2e648b7..0000000 --- a/src/southbridge/amd/pi/avalon/hda.c +++ /dev/null @@ -1,51 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <arch/io.h> -#include <delay.h> -#include "hudson.h" - - -static void hda_init(struct device *dev) -{ -} - -static struct pci_operations lops_pci = { - .set_subsystem = pci_dev_set_subsystem, -}; - -static struct device_operations hda_audio_ops = { - .read_resources = pci_dev_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = hda_init, - .scan_bus = 0, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver hdaaudio_driver __pci_driver = { - .ops = &hda_audio_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_HDA, -}; diff --git a/src/southbridge/amd/pi/avalon/hudson.c b/src/southbridge/amd/pi/avalon/hudson.c deleted file mode 100644 index 3c07ed2..0000000 --- a/src/southbridge/amd/pi/avalon/hudson.c +++ /dev/null @@ -1,140 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> - -#include <arch/io.h> -#include <arch/acpi.h> - -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <cbmem.h> -#include "hudson.h" -#include "smbus.h" -#include "smi.h" - -/* Offsets from ACPI_MMIO_BASE - * This is defined by AGESA, but we don't include AGESA headers to avoid - * polluting the namesace. - */ -#define PM_MMIO_BASE 0xfed80300 - - -int acpi_get_sleep_type(void) -{ - u16 tmp = inw(ACPI_PM1_CNT_BLK); - tmp = ((tmp & (7 << 10)) >> 10); - return (int)tmp; -} - -void pm_write8(u8 reg, u8 value) -{ - write8(PM_MMIO_BASE + reg, value); -} - -u8 pm_read8(u8 reg) -{ - return read8(PM_MMIO_BASE + reg); -} - -void pm_write16(u8 reg, u16 value) -{ - write16(PM_MMIO_BASE + reg, value); -} - -u16 pm_read16(u16 reg) -{ - return read16(PM_MMIO_BASE + reg); -} - -void hudson_enable(device_t dev) -{ - printk(BIOS_DEBUG, "hudson_enable()\n"); - switch (dev->path.pci.devfn) { - case (0x14 << 3) | 7: /* 0:14.7 SD */ - if (dev->enabled == 0) { - // read the VENDEV ID - device_t sd_dev = dev_find_slot( 0, PCI_DEVFN( 0x14, 7)); - u32 sd_device_id = pci_read_config32( sd_dev, 0) >> 16; - /* turn off the SDHC controller in the PM reg */ - u8 reg8; - if (sd_device_id == PCI_DEVICE_ID_AMD_HUDSON_SD) { - reg8 = pm_read8(0xe7); - reg8 &= ~(1 << 0); - pm_write8(0xe7, reg8); - } - else if (sd_device_id == PCI_DEVICE_ID_AMD_YANGTZE_SD) { - reg8 = pm_read8(0xe8); - reg8 &= ~(1 << 0); - pm_write8(0xe8, reg8); - } - /* remove device 0:14.7 from PCI space */ - reg8 = pm_read8(0xd3); - reg8 &= ~(1 << 6); - pm_write8(0xd3, reg8); - } - break; - default: - break; - } -} - -static void hudson_init_acpi_ports(void) -{ - /* We use some of these ports in SMM regardless of whether or not - * ACPI tables are generated. Enable these ports indiscriminately. - */ - - pm_write16(0x60, ACPI_PM_EVT_BLK); - pm_write16(0x62, ACPI_PM1_CNT_BLK); - pm_write16(0x64, ACPI_PM_TMR_BLK); - pm_write16(0x68, ACPI_GPE0_BLK); - /* CpuControl is in _PR.CPU0, 6 bytes */ - pm_write16(0x66, ACPI_CPU_CONTROL); - - if (IS_ENABLED(CONFIG_HAVE_SMI_HANDLER)) { - pm_write16(0x6a, ACPI_SMI_CTL_PORT); - hudson_enable_acpi_cmd_smi(); - } else { - pm_write16(0x6a, 0); - } - - /* AcpiDecodeEnable, When set, SB uses the contents of the PM registers - * at index 60-6B to decode ACPI I/O address. AcpiSmiEn & SmiCmdEn - */ - pm_write8(0x74, 1<<0 | 1<<1 | 1<<4 | 1<<2); -} - -static void hudson_init(void *chip_info) -{ - hudson_init_acpi_ports(); -} - -static void hudson_final(void *chip_info) -{ -} - -struct chip_operations southbridge_amd_pi_avalon_ops = { - CHIP_NAME("ATI HUDSON") - .enable_dev = hudson_enable, - .init = hudson_init, - .final = hudson_final -}; diff --git a/src/southbridge/amd/pi/avalon/hudson.h b/src/southbridge/amd/pi/avalon/hudson.h deleted file mode 100644 index 90c3205..0000000 --- a/src/southbridge/amd/pi/avalon/hudson.h +++ /dev/null @@ -1,92 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * Copyright (C) 2014 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef HUDSON_H -#define HUDSON_H - -#include <device/pci_ids.h> -#include <device/device.h> -#include "chip.h" - -/* Power management index/data registers */ -#define BIOSRAM_INDEX 0xcd4 -#define BIOSRAM_DATA 0xcd5 -#define PM_INDEX 0xcd6 -#define PM_DATA 0xcd7 -#define PM2_INDEX 0xcd0 -#define PM2_DATA 0xcd1 - -#define HUDSON_ACPI_IO_BASE 0x800 - -#define ACPI_PM_EVT_BLK (HUDSON_ACPI_IO_BASE + 0x00) /* 4 bytes */ -#define ACPI_PM1_CNT_BLK (HUDSON_ACPI_IO_BASE + 0x04) /* 2 bytes */ -#define ACPI_PM_TMR_BLK (HUDSON_ACPI_IO_BASE + 0x18) /* 4 bytes */ -#define ACPI_GPE0_BLK (HUDSON_ACPI_IO_BASE + 0x10) /* 8 bytes */ -#define ACPI_CPU_CONTROL (HUDSON_ACPI_IO_BASE + 0x08) /* 6 bytes */ - -#define ACPI_SMI_CTL_PORT 0xb2 -#define ACPI_SMI_CMD_CST_CONTROL 0xde -#define ACPI_SMI_CMD_PST_CONTROL 0xad -#define ACPI_SMI_CMD_DISABLE 0xbe -#define ACPI_SMI_CMD_ENABLE 0xef -#define ACPI_SMI_CMD_S4_REQ 0xc0 - -#define REV_HUDSON_A11 0x11 -#define REV_HUDSON_A12 0x12 - -#define SPIROM_BASE_ADDRESS_REGISTER 0xA0 -#define SPI_ROM_ENABLE 0x02 -#define SPI_BASE_ADDRESS 0xFEC10000 - -static inline int hudson_sata_enable(void) -{ - /* True if IDE or AHCI. */ - return (CONFIG_HUDSON_SATA_MODE == 0) || (CONFIG_HUDSON_SATA_MODE == 2); -} - -static inline int hudson_ide_enable(void) -{ - /* True if IDE or LEGACY IDE. */ - return (CONFIG_HUDSON_SATA_MODE == 0) || (CONFIG_HUDSON_SATA_MODE == 3); -} - -#ifndef __SMM__ - -void pm_write8(u8 reg, u8 value); -u8 pm_read8(u8 reg); -void pm_write16(u8 reg, u16 value); -u16 pm_read16(u16 reg); - -#ifdef __PRE_RAM__ -void hudson_lpc_port80(void); -void hudson_pci_port80(void); -void hudson_clk_output_48Mhz(void); - -int s3_save_nvram_early(u32 dword, int size, int nvram_pos); -int s3_load_nvram_early(int size, u32 *old_dword, int nvram_pos); - -#else -void hudson_enable(device_t dev); -void s3_resume_init_data(void *FchParams); - -#endif /* __PRE_RAM__ */ -#endif /* __SMM__ */ - -#endif /* HUDSON_H */ diff --git a/src/southbridge/amd/pi/avalon/ide.c b/src/southbridge/amd/pi/avalon/ide.c deleted file mode 100644 index cd80f99..0000000 --- a/src/southbridge/amd/pi/avalon/ide.c +++ /dev/null @@ -1,48 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include "hudson.h" - -static void ide_init(struct device *dev) -{ -} - -static struct pci_operations lops_pci = { - .set_subsystem = pci_dev_set_subsystem, -}; - -static struct device_operations ide_ops = { - .read_resources = pci_dev_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = ide_init, - .scan_bus = 0, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver ide_driver __pci_driver = { - .ops = &ide_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_IDE, -}; diff --git a/src/southbridge/amd/pi/avalon/lpc.c b/src/southbridge/amd/pi/avalon/lpc.c deleted file mode 100644 index d15a6d1..0000000 --- a/src/southbridge/amd/pi/avalon/lpc.c +++ /dev/null @@ -1,342 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * Copyright (C) 2014 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pnp.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <device/pci_def.h> -#include <pc80/mc146818rtc.h> -#include <pc80/isa-dma.h> -#include <arch/io.h> -#include <arch/acpi.h> -#include <arch/ioapic.h> -#include "hudson.h" - -static void lpc_init(device_t dev) -{ - u8 byte; - u32 dword; - device_t sm_dev; - - /* Enable the LPC Controller */ - sm_dev = dev_find_slot(0, PCI_DEVFN(0x14, 0)); - dword = pci_read_config32(sm_dev, 0x64); - dword |= 1 << 20; - pci_write_config32(sm_dev, 0x64, dword); - - /* Initialize isa dma */ - isa_dma_init(); - - /* Enable DMA transaction on the LPC bus */ - byte = pci_read_config8(dev, 0x40); - byte |= (1 << 2); - pci_write_config8(dev, 0x40, byte); - - /* Disable the timeout mechanism on LPC */ - byte = pci_read_config8(dev, 0x48); - byte &= ~(1 << 7); - pci_write_config8(dev, 0x48, byte); - - /* Disable LPC MSI Capability */ - byte = pci_read_config8(dev, 0x78); - byte &= ~(1 << 1); - byte &= ~(1 << 0); /* Keep the old way. i.e., when bus master/DMA cycle is going - on on LPC, it holds PCI grant, so no LPC slave cycle can - interrupt and visit LPC. */ - pci_write_config8(dev, 0x78, byte); - - /* bit0: Enable prefetch a cacheline (64 bytes) when Host reads code from SPI rom */ - /* bit3: Fix SPI_CS# timing issue when running at 66M. TODO:A12. */ - byte = pci_read_config8(dev, 0xBB); - byte |= 1 << 0 | 1 << 3; - pci_write_config8(dev, 0xBB, byte); - - cmos_check_update_date(); - - /* Initialize the real time clock. - * The 0 argument tells cmos_init not to - * update CMOS unless it is invalid. - * 1 tells cmos_init to always initialize the CMOS. - */ - cmos_init(0); -} - -static void hudson_lpc_read_resources(device_t dev) -{ - struct resource *res; - - /* Get the normal pci resources of this device */ - pci_dev_read_resources(dev); /* We got one for APIC, or one more for TRAP */ - - /* Add an extra subtractive resource for both memory and I/O. */ - res = new_resource(dev, IOINDEX_SUBTRACTIVE(0, 0)); - res->base = 0; - res->size = 0x1000; - res->flags = IORESOURCE_IO | IORESOURCE_SUBTRACTIVE | - IORESOURCE_ASSIGNED | IORESOURCE_FIXED; - - res = new_resource(dev, IOINDEX_SUBTRACTIVE(1, 0)); - res->base = 0xff800000; - res->size = 0x00800000; /* 8 MB for flash */ - res->flags = IORESOURCE_MEM | IORESOURCE_SUBTRACTIVE | - IORESOURCE_ASSIGNED | IORESOURCE_FIXED; - - /* Add a memory resource for the SPI BAR. */ - fixed_mem_resource(dev, 2, SPI_BASE_ADDRESS / 1024, 1, IORESOURCE_SUBTRACTIVE); - - res = new_resource(dev, 3); /* IOAPIC */ - res->base = IO_APIC_ADDR; - res->size = 0x00001000; - res->flags = IORESOURCE_MEM | IORESOURCE_ASSIGNED | IORESOURCE_FIXED; - - compact_resources(dev); -} - -static void hudson_lpc_set_resources(struct device *dev) -{ - struct resource *res; - - /* Special case. SPI Base Address. The SpiRomEnable should STAY set. */ - res = find_resource(dev, 2); - pci_write_config32(dev, SPIROM_BASE_ADDRESS_REGISTER, res->base | SPI_ROM_ENABLE); - - pci_dev_set_resources(dev); -} - -/** - * @brief Enable resources for children devices - * - * @param dev the device whos children's resources are to be enabled - * - */ -static void hudson_lpc_enable_childrens_resources(device_t dev) -{ - struct bus *link; - u32 reg, reg_x; - int var_num = 0; - u16 reg_var[3]; - u16 reg_size[1] = {512}; - u8 wiosize = pci_read_config8(dev, 0x74); - - /* Be bit relaxed, tolerate that LPC region might be bigger than resource we try to fit, - * do it like this for all regions < 16 bytes. If there is a resource > 16 bytes - * it must be 512 bytes to be able to allocate the fresh LPC window. - * - * AGESA likes to enable already one LPC region in wide port base 0x64-0x65, - * using DFLT_SIO_PME_BASE_ADDRESS, 512 bytes size - * The code tries to check if resource can fit into this region - */ - - reg = pci_read_config32(dev, 0x44); - reg_x = pci_read_config32(dev, 0x48); - - /* check if ranges are free and not use them if entry is just already taken */ - if (reg_x & (1 << 2)) - var_num = 1; - /* just in case check if someone did not manually set other ranges too */ - if (reg_x & (1 << 24)) - var_num = 2; - - if (reg_x & (1 << 25)) - var_num = 3; - - /* check AGESA region size */ - if (wiosize & (1 << 0)) - reg_size[0] = 16; - - reg_var[2] = pci_read_config16(dev, 0x90); - reg_var[1] = pci_read_config16(dev, 0x66); - reg_var[0] = pci_read_config16(dev, 0x64); - - for (link = dev->link_list; link; link = link->next) { - device_t child; - for (child = link->children; child; - child = child->sibling) { - if (child->enabled - && (child->path.type == DEVICE_PATH_PNP)) { - struct resource *res; - for (res = child->resource_list; res; res = res->next) { - u32 base, end; /* don't need long long */ - u32 rsize, set = 0, set_x = 0; - if (!(res->flags & IORESOURCE_IO)) - continue; - base = res->base; - end = resource_end(res); - /* find a resource size */ - printk(BIOS_DEBUG, "hudson lpc decode:%s, base=0x%08x, end=0x%08x\n", - dev_path(child), base, end); - switch (base) { - case 0x60: /* KB */ - case 0x64: /* MS */ - set |= (1 << 29); - rsize = 1; - break; - case 0x3f8: /* COM1 */ - set |= (1 << 6); - rsize = 8; - break; - case 0x2f8: /* COM2 */ - set |= (1 << 7); - rsize = 8; - break; - case 0x378: /* Parallel 1 */ - set |= (1 << 0); - set |= (1 << 1); /* + 0x778 for ECP */ - rsize = 8; - break; - case 0x3f0: /* FD0 */ - set |= (1 << 26); - rsize = 8; - break; - case 0x220: /* 0x220 - 0x227 */ - set |= (1 << 8); - rsize = 8; - break; - case 0x228: /* 0x228 - 0x22f */ - set |= (1 << 9); - rsize = 8; - break; - case 0x238: /* 0x238 - 0x23f */ - set |= (1 << 10); - rsize = 8; - break; - case 0x300: /* 0x300 -0x301 */ - set |= (1 << 18); - rsize = 2; - break; - case 0x400: - set_x |= (1 << 16); - rsize = 0x40; - break; - case 0x480: - set_x |= (1 << 17); - rsize = 0x40; - break; - case 0x500: - set_x |= (1 << 18); - rsize = 0x40; - break; - case 0x580: - set_x |= (1 << 19); - rsize = 0x40; - break; - case 0x4700: - set_x |= (1 << 22); - rsize = 0xc; - break; - case 0xfd60: - set_x |= (1 << 23); - rsize = 16; - break; - default: - rsize = 0; - /* try AGESA allocated region in region 0 */ - if ((var_num > 0) && ((base >=reg_var[0]) && - ((base + res->size) <= (reg_var[0] + reg_size[0])))) - rsize = reg_size[0]; - } - /* check if region found and matches the enable */ - if (res->size <= rsize) { - reg |= set; - reg_x |= set_x; - /* check if we can fit resource in variable range */ - } else if ((var_num < 3) && - ((res->size <= 16) || (res->size == 512))) { - /* use variable ranges if pre-defined do not match */ - switch (var_num) { - case 0: - reg_x |= (1 << 2); - if (res->size <= 16) { - wiosize |= (1 << 0); - } - break; - case 1: - reg_x |= (1 << 24); - if (res->size <= 16) - wiosize |= (1 << 2); - break; - case 2: - reg_x |= (1 << 25); - if (res->size <= 16) - wiosize |= (1 << 3); - break; - } - reg_var[var_num++] = - base & 0xffff; - } else { - printk(BIOS_ERR, "cannot fit LPC decode region:%s, base=0x%08x, end=0x%08x\n", - dev_path(child), base, end); - } - } - } - } - } - pci_write_config32(dev, 0x44, reg); - pci_write_config32(dev, 0x48, reg_x); - /* Set WideIO for as many IOs found (fall through is on purpose) */ - switch (var_num) { - case 3: - pci_write_config16(dev, 0x90, reg_var[2]); - /* fall through */ - case 2: - pci_write_config16(dev, 0x66, reg_var[1]); - /* fall through */ - case 1: - pci_write_config16(dev, 0x64, reg_var[0]); - break; - } - pci_write_config8(dev, 0x74, wiosize); -} - -unsigned long acpi_fill_mcfg(unsigned long current) -{ - /* Just a dummy */ - return current; -} - -static void hudson_lpc_enable_resources(device_t dev) -{ - pci_dev_enable_resources(dev); - hudson_lpc_enable_childrens_resources(dev); -} - -static struct pci_operations lops_pci = { - .set_subsystem = pci_dev_set_subsystem, -}; - -static struct device_operations lpc_ops = { - .read_resources = hudson_lpc_read_resources, - .set_resources = hudson_lpc_set_resources, - .enable_resources = hudson_lpc_enable_resources, -#if IS_ENABLED(CONFIG_HAVE_ACPI_TABLES) - .write_acpi_tables = acpi_write_hpet, -#endif - .init = lpc_init, - .scan_bus = scan_static_bus, - .ops_pci = &lops_pci, -}; -static const struct pci_driver lpc_driver __pci_driver = { - .ops = &lpc_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_LPC, -}; diff --git a/src/southbridge/amd/pi/avalon/pci.c b/src/southbridge/amd/pi/avalon/pci.c deleted file mode 100644 index e8836e4..0000000 --- a/src/southbridge/amd/pi/avalon/pci.c +++ /dev/null @@ -1,74 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include "hudson.h" -#include <southbridge/amd/amd_pci_util.h> -#include <bootstate.h> - -static void pci_init(struct device *dev) -{ -} - -/* - * Update the PCI devices with a valid IRQ number - * that is set in the mainboard PCI_IRQ structures. - */ -static void set_pci_irqs(void *unused) -{ - /* Write PCI_INTR regs 0xC00/0xC01 */ - write_pci_int_table(); - - /* Write IRQs for all devicetree enabled devices */ - write_pci_cfg_irqs(); -} - -/* - * Hook this function into the PCI state machine - * on entry into BS_DEV_ENABLE. - */ -BOOT_STATE_INIT_ENTRIES(pci_irq_update) = { - BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, - set_pci_irqs, NULL), -}; - -static struct pci_operations lops_pci = { - .set_subsystem = 0, -}; - -static struct device_operations pci_ops = { - .read_resources = pci_bus_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_bus_enable_resources, - .init = pci_init, - .scan_bus = pci_scan_bridge, - .reset_bus = pci_bus_reset, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver pci_driver __pci_driver = { - .ops = &pci_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_PCI, -}; diff --git a/src/southbridge/amd/pi/avalon/pci_devs.h b/src/southbridge/amd/pi/avalon/pci_devs.h deleted file mode 100644 index d2549d4..0000000 --- a/src/southbridge/amd/pi/avalon/pci_devs.h +++ /dev/null @@ -1,96 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2014 Sage Electronic Engineering, LLC. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef _PI_HUDSON_PCI_DEVS_H_ -#define _PI_HUDSON_PCI_DEVS_H_ - -#define BUS0 0 - -/* XHCI */ -#define XHCI_DEV 0x10 -#define XHCI_FUNC 0 -#define XHCI_DEVID 0x7814 -#define XHCI_DEVFN PCI_DEVFN(XHCI_DEV,XHCI_FUNC) - -/* SATA */ -#define SATA_DEV 0x11 -#define SATA_FUNC 0 -#define SATA_IDE_DEVID 0x7800 -#define AHCI_DEVID_MS 0x7801 -#define AHCI_DEVID_AMD 0x7804 -#define SATA_DEVFN PCI_DEVFN(SATA_DEV,SATA_FUNC) - -/* OHCI */ -#define OHCI1_DEV 0x12 -#define OHCI1_FUNC 0 -#define OHCI2_DEV 0x13 -#define OHCI2_FUNC 0 -#define OHCI3_DEV 0x16 -#define OHCI3_FUNC 0 -#define OHCI4_DEV 0x14 -#define OHCI4_FUNC 5 -#define OHCI_DEVID 0x7807 -#define OHCI1_DEVFN PCI_DEVFN(OHCI1_DEV,OHCI1_FUNC) -#define OHCI2_DEVFN PCI_DEVFN(OHCI2_DEV,OHCI2_FUNC) -#define OHCI3_DEVFN PCI_DEVFN(OHCI3_DEV,OHCI3_FUNC) -#define OHCI4_DEVFN PCI_DEVFN(OHCI4_DEV,OHCI4_FUNC) - -/* EHCI */ -#define EHCI1_DEV 0x12 -#define EHCI1_FUNC 2 -#define EHCI2_DEV 0x13 -#define EHCI2_FUNC 2 -#define EHCI3_DEV 0x16 -#define EHCI3_FUNC 2 -#define EHCI_DEVID 0x7808 -#define EHCI1_DEVFN PCI_DEVFN(EHCI1_DEV,EHCI1_FUNC) -#define EHCI2_DEVFN PCI_DEVFN(EHCI2_DEV,EHCI2_FUNC) -#define EHCI3_DEVFN PCI_DEVFN(EHCI3_DEV,EHCI3_FUNC) - -/* SMBUS */ -#define SMBUS_DEV 0x14 -#define SMBUS_FUNC 0 -#define SMBUS_DEVID 0x780B -#define SMBUS_DEVFN PCI_DEVFN(SMBUS_DEV,SMBUS_FUNC) - -/* HD Audio */ -#define HDA_DEV 0x14 -#define HDA_FUNC 2 -#define HDA_DEVID 0x780D -#define HDA_DEVFN PCI_DEVFN(HDA_DEV,HDA_FUNC) - -/* LPC BUS */ -#define PCU_DEV 0x14 -#define LPC_FUNC 3 -#define LPC_DEVID 0x780E -#define LPC_DEVFN PCI_DEVFN(LPC_DEV,LPC_FUNC) - -/* PCI Ports */ -#define SB_PCI_PORT_DEV 0x14 -#define SB_PCI_PORT_FUNC 4 -# define SB_PCI_PORT_DEVID 0x780F -# define SB_PCI_PORT_DEVFN PCI_DEVFN(SB_PCI_PORT_DEV,SB_PCI_PORT_FUNC) - -/* SD Controller */ -#define SD_DEV 0x14 -#define SD_FUNC 7 -#define SD_DEVID 0x7806 -#define SD_DEVFN PCI_DEVFN(SD_DEV,SD_FUNC) - -#endif /* _PI_HUDSON_PCI_DEVS_H_ */ diff --git a/src/southbridge/amd/pi/avalon/pcie.c b/src/southbridge/amd/pi/avalon/pcie.c deleted file mode 100644 index ec686fc..0000000 --- a/src/southbridge/amd/pi/avalon/pcie.c +++ /dev/null @@ -1,65 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include "hudson.h" - -static void pcie_init(struct device *dev) -{ -} - -static struct pci_operations lops_pci = { - .set_subsystem = 0, -}; - -static struct device_operations pci_ops = { - .read_resources = pci_bus_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_bus_enable_resources, - .init = pcie_init, - .scan_bus = pci_scan_bridge, - .reset_bus = pci_bus_reset, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver pciea_driver __pci_driver = { - .ops = &pci_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_PCIEA, -}; - -static const struct pci_driver pcieb_driver __pci_driver = { - .ops = &pci_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_PCIEB, -}; -static const struct pci_driver pciec_driver __pci_driver = { - .ops = &pci_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_PCIEC, -}; -static const struct pci_driver pcied_driver __pci_driver = { - .ops = &pci_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_PCIED, -}; diff --git a/src/southbridge/amd/pi/avalon/reset.c b/src/southbridge/amd/pi/avalon/reset.c deleted file mode 100644 index 79fd79e..0000000 --- a/src/southbridge/amd/pi/avalon/reset.c +++ /dev/null @@ -1,35 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -// Use simple device model for this file even in ramstage -#define __SIMPLE_DEVICE__ - -#include <arch/io.h> -#include <reset.h> - -#include <northbridge/amd/amdk8/reset_test.c> - -void hard_reset(void) -{ - set_bios_reset(); - /* Try rebooting through port 0xcf9 */ - /* Actually it is not a real hard_reset --- it only reset coherent link table, but not reset link freq and width */ - outb((0 << 3) | (0 << 2) | (1 << 1), 0xcf9); - outb((0 << 3) | (1 << 2) | (1 << 1), 0xcf9); -} diff --git a/src/southbridge/amd/pi/avalon/sata.c b/src/southbridge/amd/pi/avalon/sata.c deleted file mode 100644 index c02a5b1..0000000 --- a/src/southbridge/amd/pi/avalon/sata.c +++ /dev/null @@ -1,85 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <delay.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <arch/io.h> -#include "hudson.h" - - -static void sata_init(struct device *dev) -{ -#if IS_ENABLED(CONFIG_SOUTHBRIDGE_AMD_PI_AVALON) - /************************************** - * Configure the SATA port multiplier * - **************************************/ - #define BYTE_TO_DWORD_OFFSET(x) (x/4) - #define AHCI_BASE_ADDRESS_REG 0x24 - #define MISC_CONTROL_REG 0x40 - #define UNLOCK_BIT (1<<0) - #define SATA_CAPABILITIES_REG 0xFC - #define CFG_CAP_SPM (1<<12) - - volatile u32 *ahci_ptr = - (u32*)(pci_read_config32(dev, AHCI_BASE_ADDRESS_REG) & 0xFFFFFF00); - u32 temp; - - /* unlock the write-protect */ - temp = pci_read_config32(dev, MISC_CONTROL_REG); - temp |= UNLOCK_BIT; - pci_write_config32(dev, MISC_CONTROL_REG, temp); - - /* set the SATA AHCI mode to allow port expanders */ - *(ahci_ptr + BYTE_TO_DWORD_OFFSET(SATA_CAPABILITIES_REG)) |= CFG_CAP_SPM; - - /* lock the write-protect */ - temp = pci_read_config32(dev, MISC_CONTROL_REG); - temp &= ~UNLOCK_BIT; - pci_write_config32(dev, MISC_CONTROL_REG, temp); -#endif -}; - -static struct pci_operations lops_pci = { - /* .set_subsystem = pci_dev_set_subsystem, */ -}; - -static struct device_operations sata_ops = { - .read_resources = pci_dev_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = sata_init, - .scan_bus = 0, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver sata0_driver __pci_driver = { - .ops = &sata_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_SATA, -}; - -static const struct pci_driver sata0_driver_ahci __pci_driver = { - .ops = &sata_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_SATA_AHCI, -}; diff --git a/src/southbridge/amd/pi/avalon/sd.c b/src/southbridge/amd/pi/avalon/sd.c deleted file mode 100644 index 4367f7a..0000000 --- a/src/southbridge/amd/pi/avalon/sd.c +++ /dev/null @@ -1,69 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2013 Sage Electronic Engineering, LLC - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <device/device.h> -#include <delay.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <arch/io.h> -#include "hudson.h" - -static void sd_init(struct device *dev) -{ - u32 stepping; - - stepping = pci_read_config32(dev_find_slot(0, PCI_DEVFN(0x18, 3)), 0xFC); - - struct southbridge_amd_pi_avalon_config *sd_chip = - (struct southbridge_amd_pi_avalon_config *)(dev->chip_info); - - if (sd_chip->sd_mode == 3) { /* SD 3.0 mode */ - pci_write_config32(dev, 0xA4, 0x31FEC8B2); - pci_write_config32(dev, 0xA8, 0x00002503); - pci_write_config32(dev, 0xB0, 0x02180C19); - pci_write_config32(dev, 0xD0, 0x0000078B); - } - else { /* SD 2.0 mode */ - if ((stepping & 0x0000000F) == 0) { /* Stepping A0 */ - pci_write_config32(dev, 0xA4, 0x31DE32B2); - pci_write_config32(dev, 0xB0, 0x01180C19); - pci_write_config32(dev, 0xD0, 0x0000058B); - } - else { /* Stepping >= A1 */ - pci_write_config32(dev, 0xA4, 0x31FE3FB2); - pci_write_config32(dev, 0xB0, 0x01180C19); - pci_write_config32(dev, 0xD0, 0x0000078B); - } - } -} - -static struct device_operations sd_ops = { - .read_resources = pci_dev_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = sd_init, - .scan_bus = 0, -}; - -static const struct pci_driver sd_driver __pci_driver = { - .ops = &sd_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_AMD_YANGTZE_SD, -}; diff --git a/src/southbridge/amd/pi/avalon/sm.c b/src/southbridge/amd/pi/avalon/sm.c deleted file mode 100644 index d6ca215..0000000 --- a/src/southbridge/amd/pi/avalon/sm.c +++ /dev/null @@ -1,174 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <device/smbus.h> -#include <pc80/mc146818rtc.h> -#include <arch/io.h> -#include <cpu/x86/lapic.h> -#include <arch/ioapic.h> -#include <stdlib.h> -#include "hudson.h" -#include "smbus.c" - -#define NMI_OFF 0 - -#define MAINBOARD_POWER_OFF 0 -#define MAINBOARD_POWER_ON 1 - -#ifndef CONFIG_MAINBOARD_POWER_ON_AFTER_POWER_FAIL -#define CONFIG_MAINBOARD_POWER_ON_AFTER_POWER_FAIL MAINBOARD_POWER_ON -#endif - -#define BIT0 (1 << 0) -#define BIT1 (1 << 1) -#define BIT2 (1 << 2) -#define BIT3 (1 << 3) -#define BIT4 (1 << 4) -#define BIT5 (1 << 5) -#define BIT6 (1 << 6) -#define BIT7 (1 << 7) - -#define BIT8 (1 << 8 ) -#define BIT9 (1 << 9 ) -#define BIT10 (1 << 10) -#define BIT11 (1 << 11) -#define BIT12 (1 << 12) -#define BIT13 (1 << 13) -#define BIT14 (1 << 14) -#define BIT15 (1 << 15) - -#define BIT16 (1 << 16) -#define BIT17 (1 << 17) -#define BIT18 (1 << 18) -#define BIT19 (1 << 19) -#define BIT20 (1 << 20) -#define BIT21 (1 << 21) -#define BIT22 (1 << 22) -#define BIT23 (1 << 23) -#define BIT24 (1 << 24) -#define BIT25 (1 << 25) -#define BIT26 (1 << 26) -#define BIT27 (1 << 27) -#define BIT28 (1 << 28) -#define BIT29 (1 << 29) -#define BIT30 (1 << 30) -#define BIT31 (1 << 31) - -/* -* HUDSON enables all USB controllers by default in SMBUS Control. -* HUDSON enables SATA by default in SMBUS Control. -*/ - -static void sm_init(device_t dev) -{ - setup_ioapic(IO_APIC_ADDR, CONFIG_MAX_CPUS); -} - -static int lsmbus_recv_byte(device_t dev) -{ - u32 device; - struct resource *res; - struct bus *pbus; - - device = dev->path.i2c.device; - pbus = get_pbus_smbus(dev); - - res = find_resource(pbus->dev, 0x90); - - return do_smbus_recv_byte(res->base, device); -} - -static int lsmbus_send_byte(device_t dev, u8 val) -{ - u32 device; - struct resource *res; - struct bus *pbus; - - device = dev->path.i2c.device; - pbus = get_pbus_smbus(dev); - - res = find_resource(pbus->dev, 0x90); - - return do_smbus_send_byte(res->base, device, val); -} - -static int lsmbus_read_byte(device_t dev, u8 address) -{ - u32 device; - struct resource *res; - struct bus *pbus; - - device = dev->path.i2c.device; - pbus = get_pbus_smbus(dev); - - res = find_resource(pbus->dev, 0x90); - - return do_smbus_read_byte(res->base, device, address); -} - -static int lsmbus_write_byte(device_t dev, u8 address, u8 val) -{ - u32 device; - struct resource *res; - struct bus *pbus; - - device = dev->path.i2c.device; - pbus = get_pbus_smbus(dev); - - res = find_resource(pbus->dev, 0x90); - - return do_smbus_write_byte(res->base, device, address, val); -} -static struct smbus_bus_operations lops_smbus_bus = { - .recv_byte = lsmbus_recv_byte, - .send_byte = lsmbus_send_byte, - .read_byte = lsmbus_read_byte, - .write_byte = lsmbus_write_byte, -}; - -static void hudson_sm_read_resources(device_t dev) -{ -} - -static void hudson_sm_set_resources(struct device *dev) -{ -} - -static struct pci_operations lops_pci = { - .set_subsystem = pci_dev_set_subsystem, -}; -static struct device_operations smbus_ops = { - .read_resources = hudson_sm_read_resources, - .set_resources = hudson_sm_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = sm_init, - .scan_bus = scan_static_bus, - .ops_pci = &lops_pci, - .ops_smbus_bus = &lops_smbus_bus, -}; -static const struct pci_driver smbus_driver __pci_driver = { - .ops = &smbus_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_SM, -}; diff --git a/src/southbridge/amd/pi/avalon/smbus.c b/src/southbridge/amd/pi/avalon/smbus.c deleted file mode 100644 index 519c85d..0000000 --- a/src/southbridge/amd/pi/avalon/smbus.c +++ /dev/null @@ -1,250 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef _HUDSON_SMBUS_C_ -#define _HUDSON_SMBUS_C_ - -#include <io.h> -#include <stdint.h> -#include "smbus.h" - -static int smbus_wait_until_ready(u32 smbus_io_base) -{ - u32 loops; - loops = SMBUS_TIMEOUT; - do { - u8 val; - val = inb(smbus_io_base + SMBHSTSTAT); - val &= 0x1f; - if (val == 0) { /* ready now */ - return 0; - } - outb(val, smbus_io_base + SMBHSTSTAT); - } while (--loops); - return -2; /* time out */ -} - -static int smbus_wait_until_done(u32 smbus_io_base) -{ - u32 loops; - loops = SMBUS_TIMEOUT; - do { - u8 val; - - val = inb(smbus_io_base + SMBHSTSTAT); - val &= 0x1f; /* mask off reserved bits */ - if (val & 0x1c) { - return -5; /* error */ - } - if (val == 0x02) { - outb(val, smbus_io_base + SMBHSTSTAT); /* clear status */ - return 0; - } - } while (--loops); - return -3; /* timeout */ -} - -int do_smbus_recv_byte(u32 smbus_io_base, u32 device) -{ - u8 byte; - - if (smbus_wait_until_ready(smbus_io_base) < 0) { - return -2; /* not ready */ - } - - /* set the device I'm talking too */ - outb(((device & 0x7f) << 1) | 1, smbus_io_base + SMBHSTADDR); - - byte = inb(smbus_io_base + SMBHSTCTRL); - byte &= 0xe3; /* Clear [4:2] */ - byte |= (1 << 2) | (1 << 6); /* Byte data read/write command, start the command */ - outb(byte, smbus_io_base + SMBHSTCTRL); - - /* poll for transaction completion */ - if (smbus_wait_until_done(smbus_io_base) < 0) { - return -3; /* timeout or error */ - } - - /* read results of transaction */ - byte = inb(smbus_io_base + SMBHSTCMD); - - return byte; -} - -int do_smbus_send_byte(u32 smbus_io_base, u32 device, u8 val) -{ - u8 byte; - - if (smbus_wait_until_ready(smbus_io_base) < 0) { - return -2; /* not ready */ - } - - /* set the command... */ - outb(val, smbus_io_base + SMBHSTCMD); - - /* set the device I'm talking too */ - outb(((device & 0x7f) << 1) | 0, smbus_io_base + SMBHSTADDR); - - byte = inb(smbus_io_base + SMBHSTCTRL); - byte &= 0xe3; /* Clear [4:2] */ - byte |= (1 << 2) | (1 << 6); /* Byte data read/write command, start the command */ - outb(byte, smbus_io_base + SMBHSTCTRL); - - /* poll for transaction completion */ - if (smbus_wait_until_done(smbus_io_base) < 0) { - return -3; /* timeout or error */ - } - - return 0; -} - -int do_smbus_read_byte(u32 smbus_io_base, u32 device, - u32 address) -{ - u8 byte; - - if (smbus_wait_until_ready(smbus_io_base) < 0) { - return -2; /* not ready */ - } - - /* set the command/address... */ - outb(address & 0xff, smbus_io_base + SMBHSTCMD); - - /* set the device I'm talking too */ - outb(((device & 0x7f) << 1) | 1, smbus_io_base + SMBHSTADDR); - - byte = inb(smbus_io_base + SMBHSTCTRL); - byte &= 0xe3; /* Clear [4:2] */ - byte |= (1 << 3) | (1 << 6); /* Byte data read/write command, start the command */ - outb(byte, smbus_io_base + SMBHSTCTRL); - - /* poll for transaction completion */ - if (smbus_wait_until_done(smbus_io_base) < 0) { - return -3; /* timeout or error */ - } - - /* read results of transaction */ - byte = inb(smbus_io_base + SMBHSTDAT0); - - return byte; -} - -int do_smbus_write_byte(u32 smbus_io_base, u32 device, - u32 address, u8 val) -{ - u8 byte; - - if (smbus_wait_until_ready(smbus_io_base) < 0) { - return -2; /* not ready */ - } - - /* set the command/address... */ - outb(address & 0xff, smbus_io_base + SMBHSTCMD); - - /* set the device I'm talking too */ - outb(((device & 0x7f) << 1) | 0, smbus_io_base + SMBHSTADDR); - - /* output value */ - outb(val, smbus_io_base + SMBHSTDAT0); - - byte = inb(smbus_io_base + SMBHSTCTRL); - byte &= 0xe3; /* Clear [4:2] */ - byte |= (1 << 3) | (1 << 6); /* Byte data read/write command, start the command */ - outb(byte, smbus_io_base + SMBHSTCTRL); - - /* poll for transaction completion */ - if (smbus_wait_until_done(smbus_io_base) < 0) { - return -3; /* timeout or error */ - } - - return 0; -} - -void alink_ab_indx(u32 reg_space, u32 reg_addr, - u32 mask, u32 val) -{ - u32 tmp; - - outl((reg_space & 0x7) << 29 | reg_addr, AB_INDX); - tmp = inl(AB_DATA); - /* rpr 4.2 - * For certain revisions of the chip, the ABCFG registers, - * with an address of 0x100NN (where 'N' is any hexadecimal - * number), require an extra programming step.*/ - outl(0, AB_INDX); - - tmp &= ~mask; - tmp |= val; - - /* printk(BIOS_DEBUG, "about write %x, index=%x", tmp, (reg_space&0x3)<<29 | reg_addr); */ - outl((reg_space & 0x7) << 29 | reg_addr, AB_INDX); /* probably we dont have to do it again. */ - outl(tmp, AB_DATA); - outl(0, AB_INDX); -} - -void alink_rc_indx(u32 reg_space, u32 reg_addr, u32 port, - u32 mask, u32 val) -{ - u32 tmp; - - outl((reg_space & 0x7) << 29 | (port & 3) << 24 | reg_addr, AB_INDX); - tmp = inl(AB_DATA); - /* rpr 4.2 - * For certain revisions of the chip, the ABCFG registers, - * with an address of 0x100NN (where 'N' is any hexadecimal - * number), require an extra programming step.*/ - outl(0, AB_INDX); - - tmp &= ~mask; - tmp |= val; - - //printk(BIOS_DEBUG, "about write %x, index=%x", tmp, (reg_space&0x3)<<29 | (port&3) << 24 | reg_addr); - outl((reg_space & 0x7) << 29 | (port & 3) << 24 | reg_addr, AB_INDX); /* probably we dont have to do it again. */ - outl(tmp, AB_DATA); - outl(0, AB_INDX); -} - -/* space = 0: AX_INDXC, AX_DATAC - * space = 1: AX_INDXP, AX_DATAP - */ -void alink_ax_indx(u32 space /*c or p? */ , u32 axindc, - u32 mask, u32 val) -{ - u32 tmp; - - /* read axindc to tmp */ - outl(space << 29 | space << 3 | 0x30, AB_INDX); - outl(axindc, AB_DATA); - outl(0, AB_INDX); - outl(space << 29 | space << 3 | 0x34, AB_INDX); - tmp = inl(AB_DATA); - outl(0, AB_INDX); - - tmp &= ~mask; - tmp |= val; - - /* write tmp */ - outl(space << 29 | space << 3 | 0x30, AB_INDX); - outl(axindc, AB_DATA); - outl(0, AB_INDX); - outl(space << 29 | space << 3 | 0x34, AB_INDX); - outl(tmp, AB_DATA); - outl(0, AB_INDX); -} -#endif diff --git a/src/southbridge/amd/pi/avalon/smbus.h b/src/southbridge/amd/pi/avalon/smbus.h deleted file mode 100644 index 53cc0e6..0000000 --- a/src/southbridge/amd/pi/avalon/smbus.h +++ /dev/null @@ -1,76 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#ifndef HUDSON_SMBUS_H -#define HUDSON_SMBUS_H - -#include <stdint.h> - -#define SMBHSTSTAT 0x0 -#define SMBSLVSTAT 0x1 -#define SMBHSTCTRL 0x2 -#define SMBHSTCMD 0x3 -#define SMBHSTADDR 0x4 -#define SMBHSTDAT0 0x5 -#define SMBHSTDAT1 0x6 -#define SMBHSTBLKDAT 0x7 - -#define SMBSLVCTRL 0x8 -#define SMBSLVCMD_SHADOW 0x9 -#define SMBSLVEVT 0xa -#define SMBSLVDAT 0xc - -#define AX_INDXC 0 -#define AX_INDXP 2 -#define AXCFG 4 -#define ABCFG 6 -#define RC_INDXC 1 -#define RC_INDXP 3 - -#define AB_INDX 0xCD8 -#define AB_DATA (AB_INDX+4) - -/* Between 1-10 seconds, We should never timeout normally - * Longer than this is just painful when a timeout condition occurs. - */ -#define SMBUS_TIMEOUT (100*1000*10) - -#define abcfg_reg(reg, mask, val) \ - alink_ab_indx((ABCFG), (reg), (mask), (val)) -#define axcfg_reg(reg, mask, val) \ - alink_ab_indx((AXCFG), (reg), (mask), (val)) -#define axindxc_reg(reg, mask, val) \ - alink_ax_indx((AX_INDXC), (reg), (mask), (val)) -#define axindxp_reg(reg, mask, val) \ - alink_ax_indx((AX_INDXP), (reg), (mask), (val)) -#define rcindxc_reg(reg, port, mask, val) \ - alink_rc_indx((RC_INDXC), (reg), (port), (mask), (val)) -#define rcindxp_reg(reg, port, mask, val) \ - alink_rc_indx((RC_INDXP), (reg), (port), (mask), (val)) - -int do_smbus_read_byte(u32 smbus_io_base, u32 device, u32 address); -int do_smbus_write_byte(u32 smbus_io_base, u32 device, u32 address, u8 val); -int do_smbus_recv_byte(u32 smbus_io_base, u32 device); -int do_smbus_send_byte(u32 smbus_io_base, u32 device, u8 val); -void alink_rc_indx(u32 reg_space, u32 reg_addr, u32 port, u32 mask, u32 val); -void alink_ab_indx(u32 reg_space, u32 reg_addr, u32 mask, u32 val); -void alink_ax_indx(u32 space /*c or p? */ , u32 axindc, u32 mask, u32 val); - - -#endif diff --git a/src/southbridge/amd/pi/avalon/smbus_spd.c b/src/southbridge/amd/pi/avalon/smbus_spd.c deleted file mode 100644 index 9dfd0b5..0000000 --- a/src/southbridge/amd/pi/avalon/smbus_spd.c +++ /dev/null @@ -1,152 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2012 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <device/pci_def.h> -#include <device/device.h> - -/* warning: Porting.h includes an open #pragma pack(1) */ -#include "Porting.h" -#include "AGESA.h" -#include "amdlib.h" - -#include <northbridge/amd/pi/dimmSpd.h> - -/*----------------------------------------------------------------------------- - * - * readSmbusByteData - read a single SPD byte from any offset - */ - -static int readSmbusByteData (int iobase, int address, char *buffer, int offset) -{ - unsigned int status; - UINT64 limit; - - address |= 1; // set read bit - - __outbyte (iobase + 0, 0xFF); // clear error status - __outbyte (iobase + 1, 0x1F); // clear error status - __outbyte (iobase + 3, offset); // offset in eeprom - __outbyte (iobase + 4, address); // slave address and read bit - __outbyte (iobase + 2, 0x48); // read byte command - - // time limit to avoid hanging for unexpected error status (should never happen) - limit = __rdtsc () + 2000000000 / 10; - for (;;) - { - status = __inbyte (iobase); - if (__rdtsc () > limit) break; - if ((status & 2) == 0) continue; // SMBusInterrupt not set, keep waiting - if ((status & 1) == 1) continue; // HostBusy set, keep waiting - break; - } - - buffer [0] = __inbyte (iobase + 5); - if (status == 2) status = 0; // check for done with no errors - return status; -} - -/*----------------------------------------------------------------------------- - * - * readSmbusByte - read a single SPD byte from the default offset - * this function is faster function readSmbusByteData - */ - -static int readSmbusByte (int iobase, int address, char *buffer) -{ - unsigned int status; - UINT64 limit; - - __outbyte (iobase + 0, 0xFF); // clear error status - __outbyte (iobase + 2, 0x44); // read command - - // time limit to avoid hanging for unexpected error status - limit = __rdtsc () + 2000000000 / 10; - for (;;) - { - status = __inbyte (iobase); - if (__rdtsc () > limit) break; - if ((status & 2) == 0) continue; // SMBusInterrupt not set, keep waiting - if ((status & 1) == 1) continue; // HostBusy set, keep waiting - break; - } - - buffer [0] = __inbyte (iobase + 5); - if (status == 2) status = 0; // check for done with no errors - return status; -} - -/*--------------------------------------------------------------------------- - * - * readspd - Read one or more SPD bytes from a DIMM. - * Start with offset zero and read sequentially. - * Optimization relies on autoincrement to avoid - * sending offset for every byte. - * Reads 128 bytes in 7-8 ms at 400 KHz. - */ - -static int readspd (int iobase, int SmbusSlaveAddress, char *buffer, int count) -{ - int index, error; - - printk(BIOS_SPEW, "-------------READING SPD-----------\n"); - printk(BIOS_SPEW, "iobase: 0x%08X, SmbusSlave: 0x%08X, count: %d\n", - iobase, SmbusSlaveAddress, count); - - /* read the first byte using offset zero */ - error = readSmbusByteData (iobase, SmbusSlaveAddress, buffer, 0); - - if (error) { - printk(BIOS_ERR, "-------------SPD READ ERROR-----------\n"); - return error; - } - - /* read the remaining bytes using auto-increment for speed */ - for (index = 1; index < count; index++) - { - error = readSmbusByte (iobase, SmbusSlaveAddress, &buffer [index]); - if (error) { - printk(BIOS_ERR, "-------------SPD READ ERROR-----------\n"); - return error; - } - } - printk(BIOS_SPEW, "\n"); - printk(BIOS_SPEW, "-------------FINISHED READING SPD-----------\n"); - - return 0; -} - -static void writePmReg (int reg, int data) -{ - __outbyte (0xCD6, reg); - __outbyte (0xCD7, data); -} - -static void setupFch (int ioBase) -{ - writePmReg (0x2D, ioBase >> 8); - writePmReg (0x2C, ioBase | 1); - __outbyte (ioBase + 0x0E, 66000000 / 400000 / 4); // set SMBus clock to 400 KHz -} - -int hudson_readSpd(int spdAddress, char *buf, size_t len) -{ - int ioBase = 0xB00; - setupFch (ioBase); - return readspd (ioBase, spdAddress, buf, len); -} diff --git a/src/southbridge/amd/pi/avalon/smi.c b/src/southbridge/amd/pi/avalon/smi.c deleted file mode 100644 index 1d58afe..0000000 --- a/src/southbridge/amd/pi/avalon/smi.c +++ /dev/null @@ -1,25 +0,0 @@ -/* - * Utilities for SMM setup - * - * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com - * Subject to the GNU GPL v2, or (at your option) any later version. - */ - -#include "smi.h" - -#include <console/console.h> -#include <cpu/cpu.h> - -void smm_setup_structures(void *gnvs, void *tcg, void *smi1) -{ - printk(BIOS_DEBUG, "smm_setup_structures STUB!!!\n"); -} - -/** Set the EOS bit and enable SMI generation from southbridge */ -void hudson_enable_smi_generation(void) -{ - uint32_t reg = smi_read32(SMI_REG_SMITRIG0); - reg &= ~SMITRG0_SMIENB; /* Enable SMI generation */ - reg |= SMITRG0_EOS; /* Set EOS bit */ - smi_write32(SMI_REG_SMITRIG0, reg); -} diff --git a/src/southbridge/amd/pi/avalon/smi.h b/src/southbridge/amd/pi/avalon/smi.h deleted file mode 100644 index de987a9..0000000 --- a/src/southbridge/amd/pi/avalon/smi.h +++ /dev/null @@ -1,65 +0,0 @@ -/* - * Utilities for SMI handlers and SMM setup - * - * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com - * Subject to the GNU GPL v2, or (at your option) any later version. - */ - -#ifndef _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H -#define _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H - -#include <arch/io.h> - -/* ACPI_MMIO_BASE + 0x200 -- leave this string here so grep catches it. - * This is defined by AGESA, but we dpn't include AGESA headers to avoid - * polluting the namesace. - */ -#define SMI_BASE 0xfed80200 - -#define SMI_REG_SMITRIG0 0x98 -#define SMITRG0_EOS (1 << 28) -#define SMITRG0_SMIENB (1 << 31) - -#define SMI_REG_CONTROL0 0xa0 - -enum smi_mode { - SMI_MODE_DISABLE = 0, - SMI_MODE_SMI = 1, - SMI_MODE_NMI = 2, - SMI_MODE_IRQ13 = 3, -}; - -enum smi_lvl { - SMI_LVL_LOW = 0, - SMI_LVL_HIGH = 1, -}; - -static inline uint32_t smi_read32(uint8_t offset) -{ - return read32(SMI_BASE + offset); -} - -static inline void smi_write32(uint8_t offset, uint32_t value) -{ - write32(SMI_BASE + offset, value); -} - -static inline uint16_t smi_read16(uint8_t offset) -{ - return read16(SMI_BASE + offset); -} - -static inline void smi_write16(uint8_t offset, uint16_t value) -{ - write16(SMI_BASE + offset, value); -} - -void hudson_configure_gevent_smi(uint8_t gevent, uint8_t mode, uint8_t level); -void hudson_disable_gevent_smi(uint8_t gevent); -void hudson_enable_acpi_cmd_smi(void); - -#ifndef __SMM__ -void hudson_enable_smi_generation(void); -#endif - -#endif /* _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H */ diff --git a/src/southbridge/amd/pi/avalon/smi_util.c b/src/southbridge/amd/pi/avalon/smi_util.c deleted file mode 100644 index 6076cd4..0000000 --- a/src/southbridge/amd/pi/avalon/smi_util.c +++ /dev/null @@ -1,79 +0,0 @@ -/* - * SMM utilities used in both SMM and normal mode - * - * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com - * Subject to the GNU GPL v2, or (at your option) any later version. - */ - -#include "smi.h" - -#include <console/console.h> - -#define HUDSON_SMI_ACPI_COMMAND 75 - -static void configure_smi(uint8_t smi_num, uint8_t mode) -{ - uint8_t reg32_offset, bit_offset; - uint32_t reg32; - - /* SMI sources range from [0:149] */ - if (smi_num > 149) { - printk(BIOS_WARNING, "BUG: Invalid SMI: %u\n", smi_num); - return; - } - - /* 16 sources per register, 2 bits per source; registers are 4 bytes */ - reg32_offset = (smi_num / 16) * 4; - bit_offset = (smi_num % 16) * 2; - - reg32 = smi_read32(SMI_REG_CONTROL0 + reg32_offset); - reg32 &= ~(0x3 << (bit_offset)); - reg32 |= (mode & 0x3) << bit_offset; - smi_write32(SMI_REG_CONTROL0 + reg32_offset, reg32); -} - -/** - * Configure generation of interrupts for given GEVENT pin - * - * @param gevent The GEVENT pin number. Valid values are 0 thru 23 - * @param mode The type of event this pin should generate. Note that only - * SMI_MODE_SMI generates an SMI. SMI_MODE_DISABLE disables events. - * @param level SMI_LVL_LOW or SMI_LVL_HIGH - */ -void hudson_configure_gevent_smi(uint8_t gevent, uint8_t mode, uint8_t level) -{ - uint32_t reg32; - /* GEVENT pins range from [0:23] */ - if (gevent > 23) { - printk(BIOS_WARNING, "BUG: Invalid GEVENT: %u\n", gevent); - return; - } - - /* SMI0 source is GEVENT0 and so on */ - configure_smi(gevent, mode); - - /* And set set the trigger level */ - reg32 = smi_read32(SMI_REG_SMITRIG0); - reg32 &= ~(1 << gevent); - reg32 |= (level & 0x1) << gevent; - smi_write32(SMI_REG_SMITRIG0, reg32); -} - -/** Disable events from given GEVENT pin */ -void hudson_disable_gevent_smi(uint8_t gevent) -{ - /* GEVENT pins range from [0:23] */ - if (gevent > 23) { - printk(BIOS_WARNING, "BUG: Invalid GEVENT: %u\n", gevent); - return; - } - - /* SMI0 source is GEVENT0 and so on */ - configure_smi(gevent, SMI_MODE_DISABLE); -} - -/** Enable SMIs on writes to ACPI SMI command port */ -void hudson_enable_acpi_cmd_smi(void) -{ - configure_smi(HUDSON_SMI_ACPI_COMMAND, SMI_MODE_SMI); -} diff --git a/src/southbridge/amd/pi/avalon/smihandler.c b/src/southbridge/amd/pi/avalon/smihandler.c deleted file mode 100644 index e762d0b..0000000 --- a/src/southbridge/amd/pi/avalon/smihandler.c +++ /dev/null @@ -1,136 +0,0 @@ -/* - * SMI handler for Hudson southbridges - * - * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com - * Subject to the GNU GPL v2, or (at your option) any later version. - */ - -#include "hudson.h" -#include "smi.h" - -#include <console/console.h> -#include <cpu/x86/smm.h> -#include <delay.h> - -#define SMI_0x88_ACPI_COMMAND (1 << 11) - -enum smi_source { - SMI_SOURCE_SCI = (1 << 0), - SMI_SOURCE_GPE = (1 << 1), - SMI_SOURCE_0x84 = (1 << 2), - SMI_SOURCE_0x88 = (1 << 3), - SMI_SOURCE_IRQ_TRAP = (1 << 4), - SMI_SOURCE_0x90 = (1 << 5) -}; - -static void hudson_apmc_smi_handler(void) -{ - u32 reg32; - const uint8_t cmd = inb(ACPI_SMI_CTL_PORT); - - switch (cmd) { - case ACPI_SMI_CMD_ENABLE: - reg32 = inl(ACPI_PM1_CNT_BLK); - reg32 |= (1 << 0); /* SCI_EN */ - outl(reg32, ACPI_PM1_CNT_BLK); - break; - case ACPI_SMI_CMD_DISABLE: - reg32 = inl(ACPI_PM1_CNT_BLK); - reg32 &= ~(1 << 0); /* clear SCI_EN */ - outl(ACPI_PM1_CNT_BLK, reg32); - break; - } - - if (mainboard_smi_apmc) - mainboard_smi_apmc(cmd); -} - -int southbridge_io_trap_handler(int smif) -{ - return 0; -} - -static void process_smi_sci(void) -{ - const uint32_t status = smi_read32(0x10); - - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x10, status); -} - -static void process_gpe_smi(void) -{ - const uint32_t status = smi_read32(0x80); - const uint32_t gevent_mask = (1 << 24) - 1; - - /* Only Bits [23:0] indicate GEVENT SMIs. */ - if (status & gevent_mask) { - /* A GEVENT SMI occured */ - if (mainboard_smi_gpi) - mainboard_smi_gpi(status & gevent_mask); - } - - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x80, status); -} - -static void process_smi_0x84(void) -{ - const uint32_t status = smi_read32(0x84); - - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x84, status); -} - -static void process_smi_0x88(void) -{ - const uint32_t status = smi_read32(0x88); - - if (status & SMI_0x88_ACPI_COMMAND) { - /* Command received via ACPI SMI command port */ - hudson_apmc_smi_handler(); - } - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x88, status); -} - -static void process_smi_0x8c(void) -{ - const uint32_t status = smi_read32(0x8c); - - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x8c, status); -} - -static void process_smi_0x90(void) -{ - const uint32_t status = smi_read32(0x90); - - /* Clear events to prevent re-entering SMI if event isn't handled */ - smi_write32(0x90, status); -} - -void southbridge_smi_handler(unsigned int node, smm_state_save_area_t *state_save) -{ - const uint16_t smi_src = smi_read16(0x94); - - if (smi_src & SMI_SOURCE_SCI) - process_smi_sci(); - if (smi_src & SMI_SOURCE_GPE) - process_gpe_smi(); - if (smi_src & SMI_SOURCE_0x84) - process_smi_0x84(); - if (smi_src & SMI_SOURCE_0x88) - process_smi_0x88(); - if (smi_src & SMI_SOURCE_IRQ_TRAP) - process_smi_0x8c(); - if (smi_src & SMI_SOURCE_0x90) - process_smi_0x90(); -} - -void southbridge_smi_set_eos(void) -{ - uint32_t reg = smi_read32(SMI_REG_SMITRIG0); - reg |= SMITRG0_EOS; - smi_write32(SMI_REG_SMITRIG0, reg); -} diff --git a/src/southbridge/amd/pi/avalon/usb.c b/src/southbridge/amd/pi/avalon/usb.c deleted file mode 100644 index 36eff6e..0000000 --- a/src/southbridge/amd/pi/avalon/usb.c +++ /dev/null @@ -1,100 +0,0 @@ -/* - * This file is part of the coreboot project. - * - * Copyright (C) 2010 Advanced Micro Devices, Inc. - * - * This program is free software; you can redistribute it and/or modify - * it under the terms of the GNU General Public License as published by - * the Free Software Foundation; version 2 of the License. - * - * This program is distributed in the hope that it will be useful, - * but WITHOUT ANY WARRANTY; without even the implied warranty of - * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the - * GNU General Public License for more details. - * - * You should have received a copy of the GNU General Public License - * along with this program; if not, write to the Free Software - * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA - */ - -#include <console/console.h> -#include <device/device.h> -#include <device/pci.h> -#include <device/pci_ids.h> -#include <device/pci_ops.h> -#include <device/pci_ehci.h> -#include <arch/io.h> -#include "hudson.h" - -static struct pci_operations lops_pci = { - .set_subsystem = pci_dev_set_subsystem, -}; - -static void usb_init(struct device *dev) -{ -} - -static struct device_operations usb_ops = { - .read_resources = pci_ehci_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = usb_init, - .scan_bus = 0, - .ops_pci = &lops_pci, -}; - -static const struct pci_driver usb_0_driver __pci_driver = { - .ops = &usb_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_USB_18_0, -}; -static const struct pci_driver usb_1_driver __pci_driver = { - .ops = &usb_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_USB_18_2, -}; - -/* the pci id of usb ctrl 0 and 1 are the same. */ -/* - * static const struct pci_driver usb_3_driver __pci_driver = { - * .ops = &usb_ops, - * .vendor = PCI_VENDOR_ID_AMD, - * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_0, - * }; - * static const struct pci_driver usb_4_driver __pci_driver = { - * .ops = &usb_ops, - * .vendor = PCI_VENDOR_ID_AMD, - * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_1, - * }; - */ - -static const struct pci_driver usb_4_driver __pci_driver = { - .ops = &usb_ops, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_SB900_USB_20_5, -}; - -/* -static struct device_operations usb_ops2 = { - .read_resources = pci_ehci_read_resources, - .set_resources = pci_dev_set_resources, - .enable_resources = pci_dev_enable_resources, - .init = usb_init2, - .scan_bus = 0, - .ops_pci = &lops_pci, -}; -*/ -/* -static const struct pci_driver usb_5_driver __pci_driver = { - .ops = &usb_ops2, - .vendor = PCI_VENDOR_ID_AMD, - .device = PCI_DEVICE_ID_ATI_HUDSON_USB_18_2, -}; -*/ -/* - * static const struct pci_driver usb_5_driver __pci_driver = { - * .ops = &usb_ops2, - * .vendor = PCI_VENDOR_ID_AMD, - * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_2, - * }; - */ diff --git a/src/southbridge/amd/pi/hudson/Kconfig b/src/southbridge/amd/pi/hudson/Kconfig new file mode 100644 index 0000000..a924ace --- /dev/null +++ b/src/southbridge/amd/pi/hudson/Kconfig @@ -0,0 +1,219 @@ +## +## This file is part of the coreboot project. +## +## Copyright (C) 2010 Advanced Micro Devices, Inc. +## +## This program is free software; you can redistribute it and/or modify +## it under the terms of the GNU General Public License as published by +## the Free Software Foundation; version 2 of the License. +## +## This program is distributed in the hope that it will be useful, +## but WITHOUT ANY WARRANTY; without even the implied warranty of +## MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +## GNU General Public License for more details. +## +## You should have received a copy of the GNU General Public License +## along with this program; if not, write to the Free Software +## Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA +## + +config SOUTHBRIDGE_AMD_PI_AVALON + bool + select IOAPIC + select HAVE_USBDEBUG_OPTIONS + select HAVE_HARD_RESET + +if SOUTHBRIDGE_AMD_PI_AVALON + +config BOOTBLOCK_SOUTHBRIDGE_INIT + string + default "southbridge/amd/pi/hudson/bootblock.c" + +config SOUTHBRIDGE_AMD_HUDSON_SKIP_ISA_DMA_INIT + bool + default n + +config EHCI_BAR + hex + default 0xfef00000 + +config HUDSON_XHCI_ENABLE + bool "Enable Hudson XHCI Controller" + default y + help + The XHCI controller must be enabled and the XHCI firmware + must be added in order to have USB 3.0 support configured + by coreboot. The OS will be responsible for enabling the XHCI + controller if the the XHCI firmware is available but the + XHCI controller is not enabled by coreboot. + +config HUDSON_XHCI_FWM + bool "Add xhci firmware" + default y + help + Add Hudson 2/3/4 XHCI Firmware to support the onboard USB 3.0 + +config HUDSON_DISABLE_IMC + bool + default n + +config HUDSON_IMC_FWM + bool "Add IMC firmware" + depends on !HUDSON_DISABLE_IMC + default y + help + Add Hudson 2/3/4 IMC Firmware to support the onboard fan control + +config HUDSON_GEC_FWM + bool + default n + help + Add Hudson 2/3/4 GEC Firmware to support the onboard gigabit Ethernet MAC. + Must be connected to a Broadcom B50610 or B50610M PHY on the motherboard. + +config HUDSON_PSP + bool + default y if CPU_AMD_PI_00730F01 + +config HUDSON_XHCI_FWM_FILE + string "XHCI firmware path and filename" + default "3rdparty/southbridge/amd/avalon/xhci.bin" if SOUTHBRIDGE_AMD_PI_AVALON + depends on HUDSON_XHCI_FWM + +config HUDSON_IMC_FWM_FILE + string "IMC firmware path and filename" + default "3rdparty/southbridge/amd/avalon/imc.bin" if SOUTHBRIDGE_AMD_PI_AVALON + depends on HUDSON_IMC_FWM + +config HUDSON_GEC_FWM_FILE + string "GEC firmware path and filename" + depends on HUDSON_GEC_FWM + +config HUDSON_FWM + bool + default y if HUDSON_XHCI_FWM || HUDSON_IMC_FWM || HUDSON_GEC_FWM || HUDSON_PSP + default n + +if HUDSON_FWM + +config HUDSON_FWM_POSITION + hex "Hudson Firmware ROM Position" + default 0xFFF20000 if BOARD_ROMSIZE_KB_1024 + default 0xFFE20000 if BOARD_ROMSIZE_KB_2048 + default 0xFFC20000 if BOARD_ROMSIZE_KB_4096 + default 0xFF820000 if BOARD_ROMSIZE_KB_8192 + default 0xFF020000 if BOARD_ROMSIZE_KB_16384 + help + Hudson requires the firmware MUST be located at + a specific address (ROM start address + 0x20000), otherwise + xhci host Controller can not find or load the xhci firmware. + + The firmware start address is dependent on the ROM chip size. + The default offset is 0x20000 from the ROM start address, namely + 0xFFF20000 if flash chip size is 1M + 0xFFE20000 if flash chip size is 2M + 0xFFC20000 if flash chip size is 4M + 0xFF820000 if flash chip size is 8M + 0xFF020000 if flash chip size is 16M +endif # HUDSON_FWM + +config AMD_PUBKEY_FILE + depends on HUDSON_PSP + string "AMD public Key" + default "3rdparty/southbridge/amd/avalon/PSP/AmdPubKey.bin" if CPU_AMD_PI_00730F01 + +config HUDSON_SATA_MODE + int "SATA Mode" + default 0 + range 0 6 + help + Select the mode in which SATA should be driven. NATIVE AHCI, or RAID. + The default is NATIVE. + 0: NATIVE mode does not require a ROM. + 1: RAID mode must have the two ROM files. + 2: AHCI may work with or without AHCI ROM. It depends on the payload support. + For example, seabios does not require the AHCI ROM. + 3: LEGACY IDE + 4: IDE to AHCI + 5: AHCI7804: ROM Required, and AMD driver required in the OS. + 6: IDE to AHCI7804: ROM Required, and AMD driver required in the OS. + +comment "NATIVE" + depends on HUDSON_SATA_MODE = 0 + +comment "RAID" + depends on HUDSON_SATA_MODE = 1 + +comment "AHCI" + depends on HUDSON_SATA_MODE = 2 + +comment "LEGACY IDE" + depends on HUDSON_SATA_MODE = 3 + +comment "IDE to AHCI" + depends on HUDSON_SATA_MODE = 4 + +comment "AHCI7804" + depends on HUDSON_SATA_MODE = 5 + +comment "IDE to AHCI7804" + depends on HUDSON_SATA_MODE = 6 + +if HUDSON_SATA_MODE = 2 || HUDSON_SATA_MODE = 5 + +config AHCI_ROM_ID + string "AHCI device PCI IDs" + default "1022,7801" if HUDSON_SATA_MODE = 2 + default "1022,7804" if HUDSON_SATA_MODE = 5 + +config HUDSON_AHCI_ROM + bool "Add a AHCI ROM" + +config AHCI_ROM_FILE + string "AHCI ROM path and filename" + depends on HUDSON_AHCI_ROM + default "src/southbridge/amd/pi/hudson/ahci.bin" + +endif + +if HUDSON_SATA_MODE = 1 + +config RAID_ROM_ID + string "RAID device PCI IDs" + default "1022,7802" + help + 1022,7802 for SATA NON-RAID5 module, 1022,7803 for SATA RAID5 mode + +config RAID_ROM_FILE + string "RAID ROM path and filename" + default "src/southbridge/amd/pi/hudson/raid.bin" + +config RAID_MISC_ROM_FILE + string "RAID Misc ROM path and filename" + default "src/southbridge/amd/pi/hudson/misc.bin" + +config RAID_MISC_ROM_POSITION + hex "RAID Misc ROM Position" + default 0xFFF00000 + help + The RAID ROM requires that the MISC ROM is located between the range + 0xFFF0_0000 to 0xFFF0_FFFF. Also, it must 1K bytes aligned. + The CONFIG_ROM_SIZE must be larger than 0x100000. + +endif + +config HUDSON_LEGACY_FREE + bool "System is legacy free" + help + Select y if there is no keyboard controller in the system. + This sets variables in AGESA and ACPI. + +config AZ_PIN + hex + default 0xaa + help + bit 1,0 - pin 0 + bit 3,2 - pin 1 + bit 5,4 - pin 2 + bit 7,6 - pin 3 +endif diff --git a/src/southbridge/amd/pi/hudson/Makefile.inc b/src/southbridge/amd/pi/hudson/Makefile.inc new file mode 100644 index 0000000..e0b26f8 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/Makefile.inc @@ -0,0 +1,310 @@ +#***************************************************************************** +# +# Copyright (c) 2012, Advanced Micro Devices, Inc. +# 2013 - 2014, Sage Electronic Engineering, LLC +# All rights reserved. +# +# Redistribution and use in source and binary forms, with or without +# modification, are permitted provided that the following conditions are met: +# * Redistributions of source code must retain the above copyright +# notice, this list of conditions and the following disclaimer. +# * Redistributions in binary form must reproduce the above copyright +# notice, this list of conditions and the following disclaimer in the +# documentation and/or other materials provided with the distribution. +# * Neither the name of Advanced Micro Devices, Inc. nor the names of +# its contributors may be used to endorse or promote products derived +# from this software without specific prior written permission. +# +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND +# ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED +# WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE +# DISCLAIMED. IN NO EVENT SHALL ADVANCED MICRO DEVICES, INC. BE LIABLE FOR ANY +# DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES +# (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; +# LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND +# ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT +# (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS +# SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. +# +#***************************************************************************** + +INCLUDES += -Isrc/southbridge/amd/pi/hudson + +romstage-y += smbus.c smbus_spd.c +ramstage-y += hudson.c +ramstage-y += usb.c +ramstage-y += lpc.c +ramstage-y += sm.c +ramstage-y += ide.c +ramstage-y += sata.c +ramstage-y += hda.c +ramstage-y += pci.c +ramstage-y += pcie.c +ramstage-y += sd.c + +ramstage-$(CONFIG_HAVE_ACPI_TABLES) += fadt.c +ramstage-y += reset.c +romstage-$(CONFIG_USBDEBUG_IN_ROMSTAGE) += enable_usbdebug.c +ramstage-$(CONFIG_USBDEBUG) += enable_usbdebug.c +romstage-y += early_setup.c + +smm-$(CONFIG_HAVE_SMI_HANDLER) += smihandler.c smi_util.c +ramstage-$(CONFIG_HAVE_SMI_HANDLER) += smi.c smi_util.c + +# ROMSIG At ROMBASE + 0x20000: +# +-----------+---------------+----------------+------------+ +# |0x55AA55AA |EC ROM Address |GEC ROM Address |USB3 ROM | +# +-----------+---------------+----------------+------------+ +# |PSPDIR ADDR| +# +-----------+ +# +# EC ROM should be 64K aligned. + +HUDSON_FWM_POSITION=$(shell printf %u $(CONFIG_HUDSON_FWM_POSITION)) +CBFS_HEADER_SIZE=0x40 + +#assume the cbfs header is less than $(CBFS_HEADER_SIZE) bytes. +ROMSIG_SIZE=4096 +ifeq ($(CONFIG_HUDSON_XHCI_FWM), y) +HUDSON_XHCI_POSITION=$(call int-add,$(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE)) +XHCI_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_XHCI_FWM_FILE)) +else +HUDSON_XHCI_POSITION=0 +XHCI_FWM_SIZE=0 +endif + +ifeq ($(CONFIG_HUDSON_GEC_FWM), y) +HUDSON_GEC_POSITION=$(call int-add,$(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) \ + $(XHCI_FWM_SIZE) $(CBFS_HEADER_SIZE)) +GEC_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_GEC_FWM_FILE)) +else +HUDSON_GEC_POSITION=0 +GEC_FWM_SIZE=0 +endif + +ifeq ($(CONFIG_HUDSON_IMC_FWM), y) +HUDSON_IMC_POSITION=$(call int-align,\ + $(call int-add,\ + $(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) $(XHCI_FWM_SIZE)\ + $(CBFS_HEADER_SIZE) $(GEC_FWM_SIZE) $(CBFS_HEADER_SIZE)),\ + 65536) +IMC_FWM_SIZE=$(call file-size,$(CONFIG_HUDSON_IMC_FWM_FILE)) +else +HUDSON_IMC_POSITION=0 +IMC_FWM_SIZE=0 +endif + +ifeq ($(CONFIG_CPU_AMD_PI_00730F01), y) +HUDSON_PSP_DIRECTORY_POSITION=$(call int-align,\ + $(call int-add,\ + $(HUDSON_FWM_POSITION) $(ROMSIG_SIZE) $(CBFS_HEADER_SIZE) $(XHCI_FWM_SIZE)\ + $(CBFS_HEADER_SIZE) $(GEC_FWM_SIZE) $(CBFS_HEADER_SIZE) $(IMC_FWM_SIZE) $(CBFS_HEADER_SIZE)),\ + 65536) +HUDSON_PSP_DIRECTORY_SIZE=256 +else +HUDSON_PSP_DIRECTORY_POSITION=0 +HUDSON_PSP_DIRECTORY_SIZE=0 +endif + +$(obj)/coreboot_hudson_romsig.bin: $(call strip_quotes, $(CONFIG_HUDSON_XHCI_FWM_FILE)) \ + $(call strip_quotes, $(CONFIG_HUDSON_IMC_FWM_FILE)) \ + $(call strip_quotes, $(CONFIG_HUDSON_GEC_FWM_FILE)) \ + $(obj)/config.h + echo " Hudson FW $@" + dd if=/dev/zero of=$@ count=$(ROMSIG_SIZE) ibs=1 status=noxfer 2>/dev/null; \ + for fwm in 1437226410 \ + $(HUDSON_IMC_POSITION) \ + $(HUDSON_GEC_POSITION) \ + $(HUDSON_XHCI_POSITION) \ + $(HUDSON_PSP_DIRECTORY_POSITION); do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done > $@.tmp; \ + dd if=$@.tmp of=$@ conv=notrunc status=noxfer 2>/dev/null; \ + rm $@.tmp + +ifeq ($(CONFIG_HUDSON_FWM), y) +cbfs-files-y += fch/fwm +fch/fwm-file := $(obj)/coreboot_hudson_romsig.bin +fch/fwm-position := $(HUDSON_FWM_POSITION) +fch/fwm-size := $(ROMSIZE_SIG) +fch/fwm-type := raw +endif + +ifeq ($(CONFIG_HUDSON_XHCI_FWM), y) +cbfs-files-y += fch/xhci +fch/xhci-file := $(call strip_quotes, $(CONFIG_HUDSON_XHCI_FWM_FILE)) +fch/xhci-position := $(HUDSON_XHCI_POSITION) +fch/xhci-type := raw +fch/xhci-required := Hudson XHCI firmware (available in coreboot/3rdparty if enabled) +endif + +ifeq ($(CONFIG_HUDSON_IMC_FWM), y) +cbfs-files-y += fch/imc +fch/imc-file := $(call strip_quotes, $(CONFIG_HUDSON_IMC_FWM_FILE)) +fch/imc-position := $(HUDSON_IMC_POSITION) +fch/imc-type := raw +fch/imc-required := Hudson IMC Firmware (available in coreboot/3rdparty if enabled) +endif + +ifeq ($(CONFIG_HUDSON_GEC_FWM), y) +cbfs-files-y += fch/gec +fch/gec-file := $(call strip_quotes, $(CONFIG_HUDSON_GEC_FWM_FILE)) +fch/gec-position := $(HUDSON_GEC_POSITION) +fch/gec-type := raw +fch/gec-required := Hudson Gigabit Ethernet Controller Firmware (Contact your AMD representative) +endif + +ifdef CONFIG_HUDSON_AHCI_ROM +stripped_ahci_rom_id = $(call strip_quotes,$(CONFIG_AHCI_ROM_ID)) +cbfs-files-y += pci$(stripped_ahci_rom_id).rom +pci$(stripped_ahci_rom_id).rom-file := $(call strip_quotes,$(CONFIG_AHCI_ROM_FILE)) +pci$(stripped_ahci_rom_id).rom-type := optionrom +pci$(stripped_ahci_rom_id).rom-required := Hudson AHCI Option ROM (Contact your AMD representative) +endif + +ifeq ($(CONFIG_HUDSON_PSP), y) + +# 0 +# catenate the pubkey and pspdir together to save some space. +AMDPUBKEY_POS=$(call int-add,$(HUDSON_PSP_DIRECTORY_POSITION) $(HUDSON_PSP_DIRECTORY_SIZE)) +AMDPUBKEY_SIZE=$(call file-size,$(CONFIG_AMD_PUBKEY_FILE)) + +ifeq ($(CONFIG_CPU_AMD_PI_00730F01), y) +FIRMWARE_LOCATE=$(dir $(call strip_quotes, $(CONFIG_AMD_PUBKEY_FILE))) +FIRMWARE_TYPE= +endif + +CONFIG_PUBSIGNEDKEY_FILE=$(top)/$(FIRMWARE_LOCATE)/RtmPubSigned$(FIRMWARE_TYPE).key +PUBSIGNEDKEY_POS=$(call int-align, \ + $(call int-add,$(AMDPUBKEY_POS) $(AMDPUBKEY_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +PUBSIGNEDKEY_SIZE=$(call file-size,$(CONFIG_PUBSIGNEDKEY_FILE)) + +CONFIG_PSPBTLDR_FILE=$(top)/$(FIRMWARE_LOCATE)/PspBootLoader$(FIRMWARE_TYPE).Bypass.sbin +PSPBTLDR_POS=$(call int-align, \ + $(call int-add,$(PUBSIGNEDKEY_POS) $(PUBSIGNEDKEY_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +PSPBTLDR_SIZE=$(call file-size,$(CONFIG_PSPBTLDR_FILE)) + +CONFIG_PSPRCVR_FILE=$(top)/$(FIRMWARE_LOCATE)/PspRecovery$(FIRMWARE_TYPE).sbin +PSPRCVR_POS=$(call int-align, \ + $(call int-add,$(PSPBTLDR_POS) $(PSPBTLDR_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +PSPRCVR_SIZE=$(call file-size,$(CONFIG_PSPRCVR_FILE)) + +CONFIG_PSPSCUREOS_FILE=$(top)/$(FIRMWARE_LOCATE)/PspSecureOs$(FIRMWARE_TYPE).sbin +PSPSECUREOS_POS=$(call int-align, \ + $(call int-add,$(PSPRCVR_POS) $(PSPRCVR_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +PSPSECUREOS_SIZE=$(call file-size,$(CONFIG_PSPSCUREOS_FILE)) + +CONFIG_PSPNVRAM_FILE=$(top)/$(FIRMWARE_LOCATE)/PspNvram$(FIRMWARE_TYPE).bin +PSPNVRAM_POS=$(call int-align, \ + $(call int-add,$(PSPSECUREOS_POS) $(PSPSECUREOS_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +PSPNVRAM_SIZE=$(call file-size,$(CONFIG_PSPNVRAM_FILE)) + +CONFIG_SMUFWM_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuFirmware$(FIRMWARE_TYPE).sbin +SMUFWM_POS=$(call int-align, \ + $(call int-add,$(PSPNVRAM_POS) $(PSPNVRAM_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +SMUFWM_SIZE=$(call file-size,$(CONFIG_SMUFWM_FILE)) + +CONFIG_SMUSCS_FILE=$(top)/$(FIRMWARE_LOCATE)/SmuScs$(FIRMWARE_TYPE).bin +SMUSCS_POS=$(call int-align, \ + $(call int-add,$(SMUFWM_POS) $(SMUFWM_SIZE) $(CBFS_HEADER_SIZE)), \ + $(CBFS_HEADER_SIZE)) +SMUSCS_SIZE=$(call file-size,$(CONFIG_SMUSCS_FILE)) + +define output_hex +echo $(1) | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}' +endef + +$(obj)/coreboot_psp_directory.bin: $(obj)/config.h $(FLETCHER) $(RTM_FILE) + echo " PSPDir $@" + for fwm in 0 $(AMDPUBKEY_SIZE) $(AMDPUBKEY_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done > $@_tail.tmp + for fwm in 1 $(PSPBTLDR_SIZE) $(PSPBTLDR_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 8 $(SMUFWM_SIZE) $(SMUFWM_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 3 $(PSPRCVR_SIZE) $(PSPRCVR_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 5 $(PUBSIGNEDKEY_SIZE) $(PUBSIGNEDKEY_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 2 $(PSPSECUREOS_SIZE) $(PSPSECUREOS_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 4 $(PSPNVRAM_SIZE) $(PSPNVRAM_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 95 $(SMUSCS_SIZE) $(SMUSCS_POS) 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 11 4294967295 0 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done >> $@_tail.tmp + for fwm in 1347637284 0 `ls -l $@_tail.tmp | awk '{printf("%d", $$5/16);}'` 0; do \ + echo $$fwm | LC_ALL=C awk '{printf ("%c%c%c%c", $$1 % 256, int($$1/256) % 256, int($$1/65536) % 256, int($$1/16777216));}'; \ + done > $@_head.tmp + cat $@_head.tmp $@_tail.tmp > $@.tmp + $(FLETCHER) < $@.tmp > $@ + rm $@_head.tmp $@_tail.tmp $@.tmp + +$(obj)/coreboot_psp_directory_combine_pubkey.bin: $(obj)/coreboot_psp_directory.bin + cat $(obj)/coreboot_psp_directory.bin > $@ + ls -l $(obj)/coreboot_psp_directory.bin | LC_ALL=C awk '{for (i=0; i<256-$$5; i++) {printf "%c", 255}}' >> $@ + cat $(top)/$(FIRMWARE_LOCATE)/AmdPubKey$(FIRMWARE_TYPE).bin >> $@ + +cbfs-files-y += apu/pspdir +apu/pspdir-file := $(obj)/coreboot_psp_directory_combine_pubkey.bin +apu/pspdir-position := $(HUDSON_PSP_DIRECTORY_POSITION) +apu/pspdir-type := raw + +# 5 +cbfs-files-y += apu/pubsignedkey +apu/pubsignedkey-file := $(CONFIG_PUBSIGNEDKEY_FILE) +apu/pubsignedkey-position := $(PUBSIGNEDKEY_POS) +apu/pubsignedkey-type := raw + +# 1 +cbfs-files-y += apu/pspbtldr +apu/pspbtldr-file := $(CONFIG_PSPBTLDR_FILE) +apu/pspbtldr-position := $(PSPBTLDR_POS) +apu/pspbtldr-type := raw + +#3 +cbfs-files-y += apu/psprcvr +apu/psprcvr-file := $(CONFIG_PSPRCVR_FILE) +apu/psprcvr-position := $(PSPRCVR_POS) +apu/psprcvr-type := raw + +# 2 +cbfs-files-y += apu/pspsecureos +apu/pspsecureos-file := $(CONFIG_PSPSCUREOS_FILE) +apu/pspsecureos-position := $(PSPSECUREOS_POS) +apu/pspsecureos-type := raw + +# 4 +cbfs-files-y += apu/pspnvram +apu/pspnvram-file := $(CONFIG_PSPNVRAM_FILE) +apu/pspnvram-position := $(PSPNVRAM_POS) +apu/pspnvram-type := raw + +#8 +cbfs-files-y += apu/smufwm +apu/smufwm-file := $(CONFIG_SMUFWM_FILE) +apu/smufwm-position := $(SMUFWM_POS) +apu/smufwm-type := raw + +cbfs-files-y += apu/smuscs +apu/smuscs-file := $(CONFIG_SMUSCS_FILE) +apu/smuscs-position := $(SMUSCS_POS) +apu/smuscs-type := raw + +endif diff --git a/src/southbridge/amd/pi/hudson/acpi/audio.asl b/src/southbridge/amd/pi/hudson/acpi/audio.asl new file mode 100644 index 0000000..2c25ab5 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/audio.asl @@ -0,0 +1,57 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +Device(AZHD) { /* 0:14.2 - HD Audio */ + Name(_ADR, 0x00140002) + OperationRegion(AZPD, PCI_Config, 0x00, 0x100) + Field(AZPD, AnyAcc, NoLock, Preserve) { + offset (0x42), + NSDI, 1, + NSDO, 1, + NSEN, 1, + offset (0x44), + IPCR, 4, + offset (0x54), + PWST, 2, + , 6, + PMEB, 1, + , 6, + PMST, 1, + offset (0x62), + MMCR, 1, + offset (0x64), + MMLA, 32, + offset (0x68), + MMHA, 32, + offset (0x6C), + MMDT, 16, + } + + Method (_INI, 0, NotSerialized) + { + If (LEqual (OSVR, 0x03)) + { + Store (Zero, NSEN) + Store (One, NSDO) + Store (One, NSDI) + } + } +} /* end AZHD */ diff --git a/src/southbridge/amd/pi/hudson/acpi/fch.asl b/src/southbridge/amd/pi/hudson/acpi/fch.asl new file mode 100644 index 0000000..f2764aa --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/fch.asl @@ -0,0 +1,188 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2011 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* South Bridge */ +/* _SB.PCI0 */ + +/* Operating System Capabilities Method */ +Method(_OSC,4) +{ + // Create DWord-addressable fields from the Capabilities Buffer + CreateDWordField(Arg3,0,CDW1) + CreateDWordField(Arg3,4,CDW2) + CreateDWordField(Arg3,8,CDW3) + + /* Check for proper PCI/PCIe UUID */ + If(LEqual(Arg0,ToUUID("33DB4D5B-1FF7-401C-9657-7441C03DD766"))) + { + /* Let OS control everything */ + Return (Arg3) + } Else { + Or(CDW1,4,CDW1) // Unrecognized UUID + Return(Arg3) + } +} + +/* Describe the Southbridge devices */ + +/* 0:11.0 - SATA */ +Device(STCR) { + Name(_ADR, 0x00110000) + #include "acpi/sata.asl" +} /* end STCR */ + +/* 0:14.0 - SMBUS */ +Device(SBUS) { + Name(_ADR, 0x00140000) +} /* end SBUS */ + +#include "usb.asl" + +/* 0:14.2 - HD Audio */ +#include "audio.asl" + +/* 0:14.3 - LPC */ +#include "lpc.asl" + +/* 0:14.7 - SD Controller */ +Device(SDCN) { + Name(_ADR, 0x00140007) +} /* end SDCN */ + +Name(CRES, ResourceTemplate() { + /* Set the Bus number and Secondary Bus number for the PCI0 device + * The Secondary bus range for PCI0 lets the system + * know what bus values are allowed on the downstream + * side of this PCI bus if there is a PCI-PCI bridge. + * PCI busses can have 256 secondary busses which + * range from [0-0xFF] but they do not need to be + * sequential. + */ + WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, /* address granularity */ + 0x0000, /* range minimum */ + 0x00FF, /* range maximum */ + 0x0000, /* translation */ + 0x0100, /* length */ + ,, PSB0) /* ResourceSourceIndex, ResourceSource, DescriptorName */ + + IO(Decode16, 0x0CF8, 0x0CF8, 1, 8) + + WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, /* address granularity */ + 0x0000, /* range minimum */ + 0x0CF7, /* range maximum */ + 0x0000, /* translation */ + 0x0CF8 /* length */ + ) + WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, /* address granularity */ + 0x03B0, /* range minimum */ + 0x03DF, /* range maximum */ + 0x0000, /* translation */ + 0x0030 /* length */ + ) + + WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, + 0x0000, /* address granularity */ + 0x0D00, /* range minimum */ + 0xFFFF, /* range maximum */ + 0x0000, /* translation */ + 0xF300 /* length */ + ) + + Memory32Fixed(READONLY, 0x000A0000, 0x00020000, VGAM) /* VGA memory space */ + Memory32Fixed(READONLY, 0x000C0000, 0x00020000, EMM1) /* Assume C0000-E0000 empty */ + + /* memory space for PCI BARs below 4GB */ + Memory32Fixed(ReadOnly, 0x00000000, 0x00000000, MMIO) +}) /* End Name(_SB.PCI0.CRES) */ + +Method(_CRS, 0) { + /* DBGO("\_SB\PCI0\_CRS\n") */ + CreateDWordField(CRES, ^MMIO._BAS, MM1B) + CreateDWordField(CRES, ^MMIO._LEN, MM1L) + + /* + * Declare memory between TOM1 and 4GB as available + * for PCI MMIO. + * Use ShiftLeft to avoid 64bit constant (for XP). + * This will work even if the OS does 32bit arithmetic, as + * 32bit (0x00000000 - TOM1) will wrap and give the same + * result as 64bit (0x100000000 - TOM1). + */ + Store(TOM1, MM1B) + ShiftLeft(0x10000000, 4, Local0) + Subtract(Local0, TOM1, Local0) + Store(Local0, MM1L) + + Return(CRES) /* note to change the Name buffer */ +} /* end of Method(_SB.PCI0._CRS) */ + +/* + * + * FIRST METHOD CALLED UPON BOOT + * + * 1. If debugging, print current OS and ACPI interpreter. + * 2. Get PCI Interrupt routing from ACPI VSM, this + * value is based on user choice in BIOS setup. + */ +Method(_INI, 0) { + /* DBGO("\_SB\_INI\n") */ + /* DBGO(" DSDT.ASL code from ") */ + /* DBGO(__DATE__) */ + /* DBGO(" ") */ + /* DBGO(__TIME__) */ + /* DBGO("\n Sleep states supported: ") */ + /* DBGO("\n") */ + /* DBGO(" \_OS=") */ + /* DBGO(_OS) */ + /* DBGO("\n \_REV=") */ + /* DBGO(_REV) */ + /* DBGO("\n") */ + + /* Determine the OS we're running on */ + OSFL() + + /* TODO: It is unstable. */ + //#include "acpi/AmdImc.asl" /* Hudson IMC function */ + //ITZE() /* enable IMC Fan Control*/ +} /* End Method(_SB._INI) */ + +Method(OSFL, 0){ + + if(LNotEqual(OSVR, Ones)) {Return(OSVR)} /* OS version was already detected */ + + if(CondRefOf(_OSI,Local1)) + { + Store(1, OSVR) /* Assume some form of XP */ + if (_OSI("Windows 2006")) /* Vista */ + { + Store(2, OSVR) + } + } else { + If(WCMP(_OS,"Linux")) { + Store(3, OSVR) /* Linux */ + } Else { + Store(4, OSVR) /* Gotta be WinCE */ + } + } + Return(OSVR) +} diff --git a/src/southbridge/amd/pi/hudson/acpi/lpc.asl b/src/southbridge/amd/pi/hudson/acpi/lpc.asl new file mode 100644 index 0000000..3383ac8 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/lpc.asl @@ -0,0 +1,108 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* 0:14.3 - LPC */ +Device(LIBR) { + Name(_ADR, 0x00140003) + /* Method(_INI) { + * DBGO("\_SB\PCI0\LpcIsaBr\_INI\n") + } */ /* End Method(_SB.SBRDG._INI) */ + + OperationRegion(CFG,PCI_Config,0x0,0x100) // Map PCI Configuration Space + Field(CFG,DWordAcc,NoLock,Preserve){ + Offset(0xA0), + BAR,32} // SPI Controller Base Address Register (Index 0xA0) + + Device(LDRC) // LPC device: Resource consumption + { + Name (_HID, EISAID("PNP0C02")) // ID for Motherboard resources + Name (CRS, ResourceTemplate () // Current Motherboard resources + { + Memory32Fixed(ReadWrite, // Setup for fixed resource location for SPI base address + 0x00000000, // Address Base + 0x00000000, // Address Length + BAR0 // Descriptor Name + ) + }) + + Method(_CRS,0,NotSerialized) + { + CreateDwordField(^CRS,^BAR0._BAS,SPIB) // Field to hold SPI base address + CreateDwordField(^CRS,^BAR0._LEN,SPIL) // Field to hold SPI address length + Store(BAR,SPIB) // SPI base address mapped + Store(0x1000,SPIL) // 4k space mapped + Return(CRS) + } + } + + /* Real Time Clock Device */ + Device(RTC0) { + Name(_HID, EISAID("PNP0B00")) /* AT Real Time Clock (not PIIX4 compatible) */ + Name(_CRS, ResourceTemplate() { + IRQNoFlags(){8} + IO(Decode16,0x0070, 0x0070, 0, 2) + }) + } /* End Device(_SB.PCI0.LpcIsaBr.RTC0) */ + + Device(TMR) { /* Timer */ + Name(_HID,EISAID("PNP0100")) /* System Timer */ + Name(_CRS, ResourceTemplate() { + IRQNoFlags(){0} + IO(Decode16, 0x0040, 0x0040, 0, 4) + }) + } /* End Device(_SB.PCI0.LpcIsaBr.TMR) */ + + Device(SPKR) { /* Speaker */ + Name(_HID,EISAID("PNP0800")) /* AT style speaker */ + Name(_CRS, ResourceTemplate() { + IO(Decode16, 0x0061, 0x0061, 0, 1) + }) + } /* End Device(_SB.PCI0.LpcIsaBr.SPKR) */ + + Device(PIC) { + Name(_HID,EISAID("PNP0000")) /* AT Interrupt Controller */ + Name(_CRS, ResourceTemplate() { + IRQNoFlags(){2} + IO(Decode16,0x0020, 0x0020, 0, 2) + IO(Decode16,0x00A0, 0x00A0, 0, 2) + }) + } /* End Device(_SB.PCI0.LpcIsaBr.PIC) */ + + Device(MAD) { /* 8257 DMA */ + Name(_HID,EISAID("PNP0200")) /* Hardware Device ID */ + Name(_CRS, ResourceTemplate() { + DMA(Compatibility,BusMaster,Transfer8){4} + IO(Decode16, 0x0000, 0x0000, 0x10, 0x10) + IO(Decode16, 0x0081, 0x0081, 0x01, 0x03) + IO(Decode16, 0x0087, 0x0087, 0x01, 0x01) + IO(Decode16, 0x0089, 0x0089, 0x01, 0x03) + IO(Decode16, 0x008F, 0x008F, 0x01, 0x01) + IO(Decode16, 0x00C0, 0x00C0, 0x10, 0x20) + }) /* End Name(_SB.PCI0.LpcIsaBr.MAD._CRS) */ + } /* End Device(_SB.PCI0.LpcIsaBr.MAD) */ + + Device(COPR) { + Name(_HID,EISAID("PNP0C04")) /* Math Coprocessor */ + Name(_CRS, ResourceTemplate() { + IO(Decode16, 0x00F0, 0x00F0, 0, 0x10) + IRQNoFlags(){13} + }) + } /* End Device(_SB.PCI0.LpcIsaBr.COPR) */ + #include "acpi/superio.asl" +} /* end LIBR */ diff --git a/src/southbridge/amd/pi/hudson/acpi/pci_int.asl b/src/southbridge/amd/pi/hudson/acpi/pci_int.asl new file mode 100644 index 0000000..384ed61 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/pci_int.asl @@ -0,0 +1,473 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + + /* PCIe Configuration Space for CONFIG_MMCONF_BUS_NUMBER busses */ + OperationRegion(PCFG, SystemMemory, PCBA, PCLN) /* Each bus consumes 1MB */ + Field(PCFG, ByteAcc, NoLock, Preserve) { + /* Byte offsets are computed using the following technique: + * ((bus number + 1) * ((device number * 8) * 4096)) + register offset + * The 8 comes from 8 functions per device, and 4096 bytes per function config space + */ + Offset(0x00088024), /* Byte offset to SATA register 24h - Bus 0, Device 17, Function 0 */ + STB5, 32, + Offset(0x00098042), /* Byte offset to OHCI0 register 42h - Bus 0, Device 19, Function 0 */ + PT0D, 1, + PT1D, 1, + PT2D, 1, + PT3D, 1, + PT4D, 1, + PT5D, 1, + PT6D, 1, + PT7D, 1, + PT8D, 1, + PT9D, 1, + Offset(0x000A0004), /* Byte offset to SMBUS register 4h - Bus 0, Device 20, Function 0 */ + SBIE, 1, + SBME, 1, + Offset(0x000A0008), /* Byte offset to SMBUS register 8h - Bus 0, Device 20, Function 0 */ + SBRI, 8, + Offset(0x000A0014), /* Byte offset to SMBUS register 14h - Bus 0, Device 20, Function 0 */ + SBB1, 32, + Offset(0x000A0078), /* Byte offset to SMBUS register 78h - Bus 0, Device 20, Function 0 */ + ,14, + P92E, 1, /* Port92 decode enable */ + } + + OperationRegion(SB5, SystemMemory, STB5, 0x1000) + Field(SB5, AnyAcc, NoLock, Preserve){ + /* Port 0 */ + Offset(0x120), /* Port 0 Task file status */ + P0ER, 1, + , 2, + P0DQ, 1, + , 3, + P0BY, 1, + Offset(0x128), /* Port 0 Serial ATA status */ + P0DD, 4, + , 4, + P0IS, 4, + Offset(0x12C), /* Port 0 Serial ATA control */ + P0DI, 4, + Offset(0x130), /* Port 0 Serial ATA error */ + , 16, + P0PR, 1, + + /* Port 1 */ + offset(0x1A0), /* Port 1 Task file status */ + P1ER, 1, + , 2, + P1DQ, 1, + , 3, + P1BY, 1, + Offset(0x1A8), /* Port 1 Serial ATA status */ + P1DD, 4, + , 4, + P1IS, 4, + Offset(0x1AC), /* Port 1 Serial ATA control */ + P1DI, 4, + Offset(0x1B0), /* Port 1 Serial ATA error */ + , 16, + P1PR, 1, + + /* Port 2 */ + Offset(0x220), /* Port 2 Task file status */ + P2ER, 1, + , 2, + P2DQ, 1, + , 3, + P2BY, 1, + Offset(0x228), /* Port 2 Serial ATA status */ + P2DD, 4, + , 4, + P2IS, 4, + Offset(0x22C), /* Port 2 Serial ATA control */ + P2DI, 4, + Offset(0x230), /* Port 2 Serial ATA error */ + , 16, + P2PR, 1, + + /* Port 3 */ + Offset(0x2A0), /* Port 3 Task file status */ + P3ER, 1, + , 2, + P3DQ, 1, + , 3, + P3BY, 1, + Offset(0x2A8), /* Port 3 Serial ATA status */ + P3DD, 4, + , 4, + P3IS, 4, + Offset(0x2AC), /* Port 3 Serial ATA control */ + P3DI, 4, + Offset(0x2B0), /* Port 3 Serial ATA error */ + , 16, + P3PR, 1, + } + + Method(_PIC, 0x01, NotSerialized) + { + If (Arg0) + { + _SB.CIRQ() + } + Store(Arg0, PMOD) + } + + Method(CIRQ, 0x00, NotSerialized){ + } + + Name(IRQB, ResourceTemplate(){ + IRQ(Level,ActiveLow,Shared){15} + }) + + Name(IRQP, ResourceTemplate(){ + IRQ(Level,ActiveLow,Exclusive){3, 4, 5, 7, 10, 11, 12, 15} + }) + + Name(PITF, ResourceTemplate(){ + IRQ(Level,ActiveLow,Exclusive){9} + }) + + Device(INTA) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 1) + + Method(_STA, 0) { + if (PIRA) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTA._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKA\_DIS\n") */ + } /* End Method(_SB.INTA._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKA\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTA._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKA\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRA, IRQN) + Return(IRQB) + } /* Method(_SB.INTA._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKA\_SRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRA) + } /* End Method(_SB.INTA._SRS) */ + } /* End Device(INTA) */ + + Device(INTB) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 2) + + Method(_STA, 0) { + if (PIRB) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTB._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKB\_DIS\n") */ + } /* End Method(_SB.INTB._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKB\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTB._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKB\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRB, IRQN) + Return(IRQB) + } /* Method(_SB.INTB._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKB\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRB) + } /* End Method(_SB.INTB._SRS) */ + } /* End Device(INTB) */ + + Device(INTC) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 3) + + Method(_STA, 0) { + if (PIRC) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTC._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKC\_DIS\n") */ + } /* End Method(_SB.INTC._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKC\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTC._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKC\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRC, IRQN) + Return(IRQB) + } /* Method(_SB.INTC._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKC\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRC) + } /* End Method(_SB.INTC._SRS) */ + } /* End Device(INTC) */ + + Device(INTD) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 4) + + Method(_STA, 0) { + if (PIRD) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTD._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKD\_DIS\n") */ + } /* End Method(_SB.INTD._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKD\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTD._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKD\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRD, IRQN) + Return(IRQB) + } /* Method(_SB.INTD._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKD\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRD) + } /* End Method(_SB.INTD._SRS) */ + } /* End Device(INTD) */ + + Device(INTE) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 5) + + Method(_STA, 0) { + if (PIRE) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTE._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKE\_DIS\n") */ + } /* End Method(_SB.INTE._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKE\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTE._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKE\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRE, IRQN) + Return(IRQB) + } /* Method(_SB.INTE._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKE\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRE) + } /* End Method(_SB.INTE._SRS) */ + } /* End Device(INTE) */ + + Device(INTF) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 6) + + Method(_STA, 0) { + if (PIRF) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTF._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKF\_DIS\n") */ + } /* End Method(_SB.INTF._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKF\_PRS\n") */ + Return(PITF) + } /* Method(_SB.INTF._PRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKF\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRF, IRQN) + Return(IRQB) + } /* Method(_SB.INTF._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKF\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRF) + } /* End Method(_SB.INTF._SRS) */ + } /* End Device(INTF) */ + + Device(INTG) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 7) + + Method(_STA, 0) { + if (PIRG) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTG._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKG\_DIS\n") */ + } /* End Method(_SB.INTG._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKG\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTG._CRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKG\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRG, IRQN) + Return(IRQB) + } /* Method(_SB.INTG._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKG\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRG) + } /* End Method(_SB.INTG._SRS) */ + } /* End Device(INTG) */ + + Device(INTH) { + Name(_HID, EISAID("PNP0C0F")) + Name(_UID, 8) + + Method(_STA, 0) { + if (PIRH) { + Return(0x0B) /* sata is invisible */ + } else { + Return(0x09) /* sata is disabled */ + } + } /* End Method(_SB.INTH._STA) */ + + Method(_DIS ,0) { + /* DBGO("\_SB\LNKH\_DIS\n") */ + } /* End Method(_SB.INTH._DIS) */ + + Method(_PRS ,0) { + /* DBGO("\_SB\LNKH\_PRS\n") */ + Return(IRQP) + } /* Method(_SB.INTH._CRS) */ + + Method(_CRS ,0) { + /* DBGO("\_SB\LNKH\_CRS\n") */ + CreateWordField(IRQB, 0x1, IRQN) + ShiftLeft(1, PIRH, IRQN) + Return(IRQB) + } /* Method(_SB.INTH._CRS) */ + + Method(_SRS, 1) { + /* DBGO("\_SB\LNKH\_CRS\n") */ + CreateWordField(ARG0, 1, IRQM) + + /* Use lowest available IRQ */ + FindSetRightBit(IRQM, Local0) + if (Local0) { + Decrement(Local0) + } + Store(Local0, PIRH) + } /* End Method(_SB.INTH._SRS) */ + } /* End Device(INTH) */ diff --git a/src/southbridge/amd/pi/hudson/acpi/pcie.asl b/src/southbridge/amd/pi/hudson/acpi/pcie.asl new file mode 100644 index 0000000..f130fb4 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/pcie.asl @@ -0,0 +1,95 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + + /* PCI IRQ mapping registers, C00h-C01h. */ + OperationRegion(PRQM, SystemIO, 0x00000C00, 0x00000002) + Field(PRQM, ByteAcc, NoLock, Preserve) { + PRQI, 0x00000008, + PRQD, 0x00000008, /* Offset: 1h */ + } + IndexField(PRQI, PRQD, ByteAcc, NoLock, Preserve) { + PIRA, 0x00000008, /* Index 0 */ + PIRB, 0x00000008, /* Index 1 */ + PIRC, 0x00000008, /* Index 2 */ + PIRD, 0x00000008, /* Index 3 */ + PIRE, 0x00000008, /* Index 4 */ + PIRF, 0x00000008, /* Index 5 */ + PIRG, 0x00000008, /* Index 6 */ + PIRH, 0x00000008, /* Index 7 */ + } + + /* PCI Error control register */ + OperationRegion(PERC, SystemIO, 0x00000C14, 0x00000001) + Field(PERC, ByteAcc, NoLock, Preserve) { + SENS, 0x00000001, + PENS, 0x00000001, + SENE, 0x00000001, + PENE, 0x00000001, + } + + /* Client Management index/data registers */ + OperationRegion(CMT, SystemIO, 0x00000C50, 0x00000002) + Field(CMT, ByteAcc, NoLock, Preserve) { + CMTI, 8, + /* Client Management Data register */ + G64E, 1, + G64O, 1, + G32O, 2, + , 2, + GPSL, 2, + } + + /* GPM Port register */ + OperationRegion(GPT, SystemIO, 0x00000C52, 0x00000001) + Field(GPT, ByteAcc, NoLock, Preserve) { + GPB0,1, + GPB1,1, + GPB2,1, + GPB3,1, + GPB4,1, + GPB5,1, + GPB6,1, + GPB7,1, + } + + /* Flash ROM program enable register */ + OperationRegion(FRE, SystemIO, 0x00000C6F, 0x00000001) + Field(FRE, ByteAcc, NoLock, Preserve) { + , 0x00000006, + FLRE, 0x00000001, + } + + /* PM2 index/data registers */ + OperationRegion(PM2R, SystemIO, 0x00000CD0, 0x00000002) + Field(PM2R, ByteAcc, NoLock, Preserve) { + PM2I, 0x00000008, + PM2D, 0x00000008, + } + + /* Power Management I/O registers, TODO:PMIO is quite different in SB800. */ + OperationRegion(PIOR, SystemIO, 0x00000CD6, 0x00000002) + Field(PIOR, ByteAcc, NoLock, Preserve) { + PIOI, 0x00000008, + PIOD, 0x00000008, + } + + IndexField (PIOI, PIOD, ByteAcc, NoLock, Preserve) { + Offset(0xEE), + UPWS, 3, + } diff --git a/src/southbridge/amd/pi/hudson/acpi/sleepstates.asl b/src/southbridge/amd/pi/hudson/acpi/sleepstates.asl new file mode 100644 index 0000000..f8d0bb0 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/sleepstates.asl @@ -0,0 +1,40 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * Copyright (C) 2011 The ChromiumOS Authors. All rights reserved. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* Supported sleep states: */ +Name(_S0, Package () {0x00, 0x00, 0x00, 0x00} ) /* (S0) - working state */ + +If (LAnd(SSFG, 0x01)) { + Name(_S1, Package () {0x01, 0x01, 0x00, 0x00} ) /* (S1) - sleeping w/CPU context */ +} +If (LAnd(SSFG, 0x02)) { + Name(_S2, Package () {0x02, 0x02, 0x00, 0x00} ) /* (S2) - "light" Suspend to RAM */ +} +If (LAnd(SSFG, 0x04)) { + Name(_S3, Package () {0x03, 0x03, 0x00, 0x00} ) /* (S3) - Suspend to RAM */ +} +If (LAnd(SSFG, 0x08)) { + Name(_S4, Package () {0x04, 0x04, 0x00, 0x00} ) /* (S4) - Suspend to Disk */ +} + +Name(_S5, Package () {0x05, 0x05, 0x00, 0x00} ) /* (S5) - Soft Off */ + +Name(_SB.CSPS ,0) /* Current Sleep State (S0, S1, S2, S3, S4, S5) */ +Name(CSMS, 0) /* Current System State */ diff --git a/src/southbridge/amd/pi/hudson/acpi/smbus.asl b/src/southbridge/amd/pi/hudson/acpi/smbus.asl new file mode 100644 index 0000000..11aff4a --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/smbus.asl @@ -0,0 +1,20 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* SMBus Support */ diff --git a/src/southbridge/amd/pi/hudson/acpi/usb.asl b/src/southbridge/amd/pi/hudson/acpi/usb.asl new file mode 100644 index 0000000..4ec338e --- /dev/null +++ b/src/southbridge/amd/pi/hudson/acpi/usb.asl @@ -0,0 +1,78 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2007-2009 coresystems GmbH + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, + * MA 02110-1301 USA + */ + +/* 0:12.0 - OHCI */ +Device(UOH1) { + Name(_ADR, 0x00120000) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH1 */ + +/* 0:12.2 - EHCI */ +Device(UOH2) { + Name(_ADR, 0x00120002) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH2 */ + +/* 0:13.0 - OHCI */ +Device(UOH3) { + Name(_ADR, 0x00130000) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH3 */ + +/* 0:13.2 - EHCI */ +Device(UOH4) { + Name(_ADR, 0x00130002) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH4 */ + +/* 0:16.0 - OHCI */ +Device(UOH5) { + Name(_ADR, 0x00160000) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH5 */ + +/* 0:16.2 - EHCI */ +Device(UOH6) { + Name(_ADR, 0x00160002) + Name(_PRW, Package() {0x0B, 3}) +} /* end UOH5 */ + +#if !CONFIG_SOUTHBRIDGE_AMD_PI_AVALON +/* 0:14.5 - OHCI */ +Device(UEH1) { + Name(_ADR, 0x00140005) + Name(_PRW, Package() {0x0B, 3}) +} /* end UEH1 */ +#endif + +/* 0:10.0 - XHCI 0*/ +Device(XHC0) { + Name(_ADR, 0x00100000) + Name(_PRW, Package() {0x0B, 4}) +} /* end XHC0 */ + +#if !CONFIG_SOUTHBRIDGE_AMD_PI_AVALON +/* 0:10.1 - XHCI 1*/ +Device(XHC1) { + Name(_ADR, 0x00100001) + Name(_PRW, Package() {0x0B, 4}) +} /* end XHC1 */ +#endif diff --git a/src/southbridge/amd/pi/hudson/amd_pci_int_defs.h b/src/southbridge/amd/pi/hudson/amd_pci_int_defs.h new file mode 100644 index 0000000..e6bd2da --- /dev/null +++ b/src/southbridge/amd/pi/hudson/amd_pci_int_defs.h @@ -0,0 +1,72 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Sage Electronic Engineering, LLC. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef AMD_PCI_INT_DEFS_H +#define AMD_PCI_INT_DEFS_H + +/* + * PIRQ and device routing - these define the index + * into the FCH PCI_INTR 0xC00/0xC01 interrupt + * routing table + */ +#define FCH_INT_TABLE_SIZE 0x63 + +#define PIRQ_NC 0x1F /* Not Used */ +#define PIRQ_A 0x00 /* INT A */ +#define PIRQ_B 0x01 /* INT B */ +#define PIRQ_C 0x02 /* INT C */ +#define PIRQ_D 0x03 /* INT D */ +#define PIRQ_E 0x04 /* INT E */ +#define PIRQ_F 0x05 /* INT F */ +#define PIRQ_G 0x06 /* INT G */ +#define PIRQ_H 0x07 /* INT H */ +#define PIRQ_MISC 0x08 /* Miscellaneous IRQ Settings - See FCH Spec */ +#define PIRQ_MISC0 0x09 /* Miscellaneous0 IRQ Settings */ +#define PIRQ_MISC1 0x0A /* Miscellaneous1 IRQ Settings */ +#define PIRQ_MISC2 0x0B /* Miscellaneous2 IRQ Settings */ +#define PIRQ_SIRQA 0x0C /* Serial IRQ INTA */ +#define PIRQ_SIRQB 0x0D /* Serial IRQ INTA */ +#define PIRQ_SIRQC 0x0E /* Serial IRQ INTA */ +#define PIRQ_SIRQD 0x0F /* Serial IRQ INTA */ +#define PIRQ_SCI 0x10 /* SCI IRQ */ +#define PIRQ_SMBUS 0x11 /* SMBUS 14h.0 */ +#define PIRQ_ASF 0x12 /* ASF */ +#define PIRQ_HDA 0x13 /* HDA 14h.2 */ +#define PIRQ_FC 0x14 /* FC */ +#define PIRQ_GEC 0x15 /* GEC */ +#define PIRQ_PMON 0x16 /* Performance Monitor */ +#define PIRQ_SD 0x17 /* SD */ +#define PIRQ_IMC0 0x20 /* IMC INT0 */ +#define PIRQ_IMC1 0x21 /* IMC INT1 */ +#define PIRQ_IMC2 0x22 /* IMC INT2 */ +#define PIRQ_IMC3 0x23 /* IMC INT3 */ +#define PIRQ_IMC4 0x24 /* IMC INT4 */ +#define PIRQ_IMC5 0x25 /* IMC INT5 */ +#define PIRQ_OHCI1 0x30 /* USB OHCI 12h.0 */ +#define PIRQ_EHCI1 0x31 /* USB EHCI 12h.2 */ +#define PIRQ_OHCI2 0x32 /* USB OHCI 13h.0 */ +#define PIRQ_EHCI2 0x33 /* USB EHCI 13h.2 */ +#define PIRQ_OHCI3 0x34 /* USB OHCI 16h.0 */ +#define PIRQ_EHCI3 0x35 /* USB EHCI 16h.2 */ +#define PIRQ_OHCI4 0x36 /* USB OHCI 14h.5 */ +#define PIRQ_IDE 0x40 /* IDE 14h.1 */ +#define PIRQ_SATA 0x41 /* SATA 11h.0 */ +#define PIRQ_GPIO 0x62 /* GPIO Controller Interrupt */ + +#endif /* AMD_PCI_INT_DEFS_H */ diff --git a/src/southbridge/amd/pi/hudson/amd_pci_int_types.h b/src/southbridge/amd/pi/hudson/amd_pci_int_types.h new file mode 100644 index 0000000..d0fe9c8 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/amd_pci_int_types.h @@ -0,0 +1,33 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Sage Electronic Engineering, LLC. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef AMD_PCI_INT_TYPES_H +#define AMD_PCI_INT_TYPES_H + +const char * intr_types[] = { + [0x00] = "INTA#\t", "INTB#\t", "INTC#\t", "INTD#\t", "INTE#\t", "INTF#\t", "INTG#\t", "INTH#\t", + [0x08] = "Misc\t", "Misc0\t", "Misc1\t", "Misc2\t", "Ser IRQ INTA", "Ser IRQ INTB", "Ser IRQ INTC", "Ser IRQ INTD", + [0x10] = "SCI\t", "SMBUS0\t", "ASF\t", "HDA\t", "FC\t\t", "GEC\t", "PerMon\t", "SD\t", + [0x20] = "IMC INT0\t", "IMC INT1\t", "IMC INT2\t", "IMC INT3\t", "IMC INT4\t", "IMC INT5\t", + [0x30] = "Dev18.0 INTA", "Dev18.2 INTB", "Dev19.0 INTA", "Dev19.2 INTB", "Dev22.0 INTA", "Dev22.2 INTB", + [0x40] = "RSVD\t", "SATA\t", + [0x60] = "RSVD\t", "RSVD\t", "GPIO\t", +}; + +#endif /* AMD_PCI_INT_TYPES_H */ diff --git a/src/southbridge/amd/pi/hudson/bootblock.c b/src/southbridge/amd/pi/hudson/bootblock.c new file mode 100644 index 0000000..3cdba8b --- /dev/null +++ b/src/southbridge/amd/pi/hudson/bootblock.c @@ -0,0 +1,67 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <stdint.h> +#include <arch/io.h> +#include <device/pci_ids.h> + +/* + * Enable 4MB (LPC) ROM access at 0xFFC00000 - 0xFFFFFFFF. + * + * Hardware should enable LPC ROM by pin straps. This function does not + * handle the theoretically possible PCI ROM, FWH, or SPI ROM configurations. + * + * The HUDSON power-on default is to map 512K ROM space. + * + */ +static void hudson_enable_rom(void) +{ + u8 reg8; + pci_devfn_t dev; + + dev = PCI_DEV(0, 0x14, 3); + + /* Decode variable LPC ROM address ranges 1 and 2. */ + reg8 = pci_read_config8(dev, 0x48); + reg8 |= (1 << 3) | (1 << 4); + pci_write_config8(dev, 0x48, reg8); + + /* LPC ROM address range 1: */ + /* Enable LPC ROM range mirroring start at 0x000e(0000). */ + pci_write_config16(dev, 0x68, 0x000e); + /* Enable LPC ROM range mirroring end at 0x000f(ffff). */ + pci_write_config16(dev, 0x6a, 0x000f); + + /* LPC ROM address range 2: */ + /* + * Enable LPC ROM range start at: + * 0xfff8(0000): 512KB + * 0xfff0(0000): 1MB + * 0xffe0(0000): 2MB + * 0xffc0(0000): 4MB + */ + pci_write_config16(dev, 0x6c, 0x10000 - (CONFIG_COREBOOT_ROMSIZE_KB >> 6)); + /* Enable LPC ROM range end at 0xffff(ffff). */ + pci_write_config16(dev, 0x6e, 0xffff); +} + +static void bootblock_southbridge_init(void) +{ + hudson_enable_rom(); +} diff --git a/src/southbridge/amd/pi/hudson/chip.h b/src/southbridge/amd/pi/hudson/chip.h new file mode 100644 index 0000000..001ba7b --- /dev/null +++ b/src/southbridge/amd/pi/hudson/chip.h @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef HUDSON_CHIP_H +#define HUDSON_CHIP_H + +struct southbridge_amd_pi_hudson_config +{ + #if 1 + u32 ide0_enable : 1; + u32 sata0_enable : 1; + u32 boot_switch_sata_ide : 1; + u32 hda_viddid; + u8 gpp_configuration; + u8 sd_mode; + #endif +}; + +#endif /* HUDSON_CHIP_H */ diff --git a/src/southbridge/amd/pi/hudson/early_setup.c b/src/southbridge/amd/pi/hudson/early_setup.c new file mode 100644 index 0000000..9500d0e --- /dev/null +++ b/src/southbridge/amd/pi/hudson/early_setup.c @@ -0,0 +1,126 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef _HUDSON_EARLY_SETUP_C_ +#define _HUDSON_EARLY_SETUP_C_ + +#include <stdint.h> +#include <arch/io.h> +#include <arch/acpi.h> +#include <console/console.h> +#include <reset.h> +#include <arch/cpu.h> +#include <cbmem.h> +#include "hudson.h" + +void hudson_pci_port80(void) +{ + u8 byte; + device_t dev; + + /* P2P Bridge */ + dev = PCI_DEV(0, 0x14, 4); + + /* Chip Control: Enable subtractive decoding */ + byte = pci_read_config8(dev, 0x40); + byte |= 1 << 5; + pci_write_config8(dev, 0x40, byte); + + /* Misc Control: Enable subtractive decoding if 0x40 bit 5 is set */ + byte = pci_read_config8(dev, 0x4B); + byte |= 1 << 7; + pci_write_config8(dev, 0x4B, byte); + + /* The same IO Base and IO Limit here is meaningful because we set the + * bridge to be subtractive. During early setup stage, we have to make + * sure that data can go through port 0x80. + */ + /* IO Base: 0xf000 */ + byte = pci_read_config8(dev, 0x1C); + byte |= 0xF << 4; + pci_write_config8(dev, 0x1C, byte); + + /* IO Limit: 0xf000 */ + byte = pci_read_config8(dev, 0x1D); + byte |= 0xF << 4; + pci_write_config8(dev, 0x1D, byte); + + /* PCI Command: Enable IO response */ + byte = pci_read_config8(dev, 0x04); + byte |= 1 << 0; + pci_write_config8(dev, 0x04, byte); + + /* LPC controller */ + dev = PCI_DEV(0, 0x14, 3); + + byte = pci_read_config8(dev, 0x4A); + byte &= ~(1 << 5); /* disable lpc port 80 */ + pci_write_config8(dev, 0x4A, byte); +} + +void hudson_lpc_port80(void) +{ + u8 byte; + device_t dev; + + /* Enable LPC controller */ + outb(0xEC, 0xCD6); + byte = inb(0xCD7); + byte |= 1; + outb(0xEC, 0xCD6); + outb(byte, 0xCD7); + + /* Enable port 80 LPC decode in pci function 3 configuration space. */ + dev = PCI_DEV(0, 0x14, 3); + byte = pci_read_config8(dev, 0x4a); + byte |= 1 << 5; /* enable port 80 */ + pci_write_config8(dev, 0x4a, byte); +} + +int s3_save_nvram_early(u32 dword, int size, int nvram_pos) +{ + int i; + printk(BIOS_DEBUG, "Writing %x of size %d to nvram pos: %d\n", dword, size, nvram_pos); + + for (i = 0; i<size; i++) { + outb(nvram_pos, BIOSRAM_INDEX); + outb((dword >>(8 * i)) & 0xff , BIOSRAM_DATA); + nvram_pos++; + } + + return nvram_pos; +} + +int s3_load_nvram_early(int size, u32 *old_dword, int nvram_pos) +{ + u32 data = *old_dword; + int i; + for (i = 0; i<size; i++) { + outb(nvram_pos, BIOSRAM_INDEX); + data &= ~(0xff << (i * 8)); + data |= inb(BIOSRAM_DATA) << (i *8); + nvram_pos++; + } + *old_dword = data; + printk(BIOS_DEBUG, "Loading %x of size %d to nvram pos:%d\n", *old_dword, size, + nvram_pos-size); + return nvram_pos; +} + +#endif diff --git a/src/southbridge/amd/pi/hudson/enable_usbdebug.c b/src/southbridge/amd/pi/hudson/enable_usbdebug.c new file mode 100644 index 0000000..258267e --- /dev/null +++ b/src/southbridge/amd/pi/hudson/enable_usbdebug.c @@ -0,0 +1,63 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +// Use simple device model for this file even in ramstage +#define __SIMPLE_DEVICE__ + +#include <stdint.h> +#include <arch/io.h> +#include <device/pci_ehci.h> +#include <device/pci_def.h> +#include "hudson.h" + +#define DEBUGPORT_MISC_CONTROL 0x80 + +pci_devfn_t pci_ehci_dbg_dev(unsigned int hcd_idx) +{ + if (hcd_idx==3) + return PCI_DEV(0, 0x16, 2); + else if (hcd_idx==2) + return PCI_DEV(0, 0x13, 2); + else + return PCI_DEV(0, 0x12, 2); +} + +void pci_ehci_dbg_set_port(pci_devfn_t dev, unsigned int port) +{ + u32 base_regs = pci_ehci_base_regs(dev); + u32 reg32; + + /* Write the port number to DEBUGPORT_MISC_CONTROL[31:28]. */ + reg32 = read32(base_regs + DEBUGPORT_MISC_CONTROL); + reg32 &= ~(0xf << 28); + reg32 |= (port << 28); + reg32 |= (1 << 27); /* Enable Debug Port port number remapping. */ + write32(base_regs + DEBUGPORT_MISC_CONTROL, reg32); +} + + +void pci_ehci_dbg_enable(pci_devfn_t dev, unsigned long base) +{ + /* Enable all of the USB controllers */ + outb(0xEF, PM_INDEX); + outb(0x7F, PM_DATA); + + pci_write_config32(dev, EHCI_BAR_INDEX, base); + pci_write_config8(dev, PCI_COMMAND, PCI_COMMAND_MEMORY | PCI_COMMAND_MASTER); +} diff --git a/src/southbridge/amd/pi/hudson/fadt.c b/src/southbridge/amd/pi/hudson/fadt.c new file mode 100644 index 0000000..f86016a --- /dev/null +++ b/src/southbridge/amd/pi/hudson/fadt.c @@ -0,0 +1,211 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* + * ACPI - create the Fixed ACPI Description Tables (FADT) + */ + +#include <string.h> +#include <console/console.h> +#include <arch/acpi.h> +#include <arch/io.h> +#include <device/device.h> +#include "hudson.h" +#include "smi.h" + +#if CONFIG_HUDSON_LEGACY_FREE + #define FADT_BOOT_ARCH ACPI_FADT_LEGACY_FREE +#else + #define FADT_BOOT_ARCH (ACPI_FADT_LEGACY_DEVICES | ACPI_FADT_8042) +#endif + +#ifndef FADT_PM_PROFILE + #define FADT_PM_PROFILE PM_UNSPECIFIED +#endif + +/* + * Reference section 5.2.9 Fixed ACPI Description Table (FADT) + * in the ACPI 3.0b specification. + */ +void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) +{ + acpi_header_t *header = &(fadt->header); + + printk(BIOS_DEBUG, "pm_base: 0x%04x\n", HUDSON_ACPI_IO_BASE); + + /* Prepare the header */ + memset((void *)fadt, 0, sizeof(acpi_fadt_t)); + memcpy(header->signature, "FACP", 4); + header->length = sizeof(acpi_fadt_t); + header->revision = ACPI_FADT_REV_ACPI_3_0; + memcpy(header->oem_id, OEM_ID, 6); + memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); + memcpy(header->asl_compiler_id, ASLC, 4); + header->asl_compiler_revision = 0; + + fadt->firmware_ctrl = (u32) facs; + fadt->dsdt = (u32) dsdt; + fadt->model = 0; /* reserved, should be 0 ACPI 3.0 */ + fadt->preferred_pm_profile = FADT_PM_PROFILE; + fadt->sci_int = 9; /* HUDSON - IRQ 09 – ACPI SCI */ + + if (IS_ENABLED(CONFIG_HAVE_SMI_HANDLER)) { + fadt->smi_cmd = ACPI_SMI_CTL_PORT; + fadt->acpi_enable = ACPI_SMI_CMD_ENABLE; + fadt->acpi_disable = ACPI_SMI_CMD_DISABLE; + fadt->s4bios_req = 0; /* Not supported */ + fadt->pstate_cnt = 0; /* Not supported */ + fadt->cst_cnt = 0; /* Not supported */ + outl(0x0, ACPI_PM1_CNT_BLK); /* clear SCI_EN */ + } else { + fadt->smi_cmd = 0; /* disable system management mode */ + fadt->acpi_enable = 0; /* unused if SMI_CMD = 0 */ + fadt->acpi_disable = 0; /* unused if SMI_CMD = 0 */ + fadt->s4bios_req = 0; /* unused if SMI_CMD = 0 */ + fadt->pstate_cnt = 0; /* unused if SMI_CMD = 0 */ + fadt->cst_cnt = 0x00; /* unused if SMI_CMD = 0 */ + outl(0x1, ACPI_PM1_CNT_BLK); /* set SCI_EN */ + } + + fadt->pm1a_evt_blk = ACPI_PM_EVT_BLK; + fadt->pm1b_evt_blk = 0x0000; + fadt->pm1a_cnt_blk = ACPI_PM1_CNT_BLK; + fadt->pm1b_cnt_blk = 0x0000; + fadt->pm2_cnt_blk = 0x0000; + fadt->pm_tmr_blk = ACPI_PM_TMR_BLK; + fadt->gpe0_blk = ACPI_GPE0_BLK; + fadt->gpe1_blk = 0x0000; /* No gpe1 block in hudson */ + + fadt->pm1_evt_len = 4; /* 32 bits */ + fadt->pm1_cnt_len = 2; /* 16 bits */ + fadt->pm2_cnt_len = 0; + fadt->pm_tmr_len = 4; /* 32 bits */ + fadt->gpe0_blk_len = 8; /* 64 bits */ + fadt->gpe1_blk_len = 0; + fadt->gpe1_base = 0; + + fadt->p_lvl2_lat = ACPI_FADT_C2_NOT_SUPPORTED; + fadt->p_lvl3_lat = ACPI_FADT_C3_NOT_SUPPORTED; + fadt->flush_size = 0; /* set to 0 if WBINVD is 1 in flags */ + fadt->flush_stride = 0; /* set to 0 if WBINVD is 1 in flags */ + fadt->duty_offset = 1; /* CLK_VAL bits 3:1 */ + fadt->duty_width = 3; /* CLK_VAL bits 3:1 */ + fadt->day_alrm = 0; /* 0x7d these have to be */ + fadt->mon_alrm = 0; /* 0x7e added to cmos.layout */ + fadt->century = 0; /* 0x7f to make rtc alarm work */ + fadt->iapc_boot_arch = FADT_BOOT_ARCH; /* See table 5-10 */ + fadt->res2 = 0; /* reserved, MUST be 0 ACPI 3.0 */ + fadt->flags = ACPI_FADT_WBINVD | /* See table 5-10 ACPI 3.0a spec */ + ACPI_FADT_C1_SUPPORTED | + ACPI_FADT_SLEEP_BUTTON | + ACPI_FADT_S4_RTC_WAKE | + ACPI_FADT_32BIT_TIMER | + ACPI_FADT_RESET_REGISTER | + ACPI_FADT_PCI_EXPRESS_WAKE | + ACPI_FADT_PLATFORM_CLOCK | + ACPI_FADT_S4_RTC_VALID | + ACPI_FADT_REMOTE_POWER_ON; + + /* Format is from 5.2.3.1: Generic Address Structure */ + /* reset_reg: see section 4.7.3.6 ACPI 3.0a spec */ + /* 8 bit write of value 0x06 to 0xCF9 in IO space */ + fadt->reset_reg.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->reset_reg.bit_width = 8; + fadt->reset_reg.bit_offset = 0; + fadt->reset_reg.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->reset_reg.addrl = 0xcf9; + fadt->reset_reg.addrh = 0x0; + + fadt->reset_value = 6; + + fadt->res3 = 0; /* reserved, MUST be 0 ACPI 3.0 */ + fadt->res4 = 0; /* reserved, MUST be 0 ACPI 3.0 */ + fadt->res5 = 0; /* reserved, MUST be 0 ACPI 3.0 */ + + fadt->x_firmware_ctl_l = 0; /* set to 0 if firmware_ctrl is used */ + fadt->x_firmware_ctl_h = 0; + fadt->x_dsdt_l = (u32) dsdt; + fadt->x_dsdt_h = 0; + + fadt->x_pm1a_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_evt_blk.bit_width = 32; + fadt->x_pm1a_evt_blk.bit_offset = 0; + fadt->x_pm1a_evt_blk.access_size = ACPI_ACCESS_SIZE_WORD_ACCESS; + fadt->x_pm1a_evt_blk.addrl = ACPI_PM_EVT_BLK; + fadt->x_pm1a_evt_blk.addrh = 0x0; + + fadt->x_pm1b_evt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_evt_blk.bit_width = 0; + fadt->x_pm1b_evt_blk.bit_offset = 0; + fadt->x_pm1b_evt_blk.access_size = 0; + fadt->x_pm1b_evt_blk.addrl = 0x0; + fadt->x_pm1b_evt_blk.addrh = 0x0; + + + fadt->x_pm1a_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1a_cnt_blk.bit_width = 16; + fadt->x_pm1a_cnt_blk.bit_offset = 0; + fadt->x_pm1a_cnt_blk.access_size = 0; + fadt->x_pm1a_cnt_blk.addrl = ACPI_PM1_CNT_BLK; + fadt->x_pm1a_cnt_blk.addrh = 0x0; + + fadt->x_pm1b_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm1b_cnt_blk.bit_width = 0; + fadt->x_pm1b_cnt_blk.bit_offset = 0; + fadt->x_pm1b_cnt_blk.access_size = 0; + fadt->x_pm1b_cnt_blk.addrl = 0x0; + fadt->x_pm1b_cnt_blk.addrh = 0x0; + + /* + * Note: Under this current AMD C state implementation, this is no longer + * used and should not be reported to OS. + */ + fadt->x_pm2_cnt_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm2_cnt_blk.bit_width = 0; + fadt->x_pm2_cnt_blk.bit_offset = 0; + fadt->x_pm2_cnt_blk.access_size = ACPI_ACCESS_SIZE_BYTE_ACCESS; + fadt->x_pm2_cnt_blk.addrl = 0; + fadt->x_pm2_cnt_blk.addrh = 0x0; + + + fadt->x_pm_tmr_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_pm_tmr_blk.bit_width = 32; + fadt->x_pm_tmr_blk.bit_offset = 0; + fadt->x_pm_tmr_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_pm_tmr_blk.addrl = ACPI_PM_TMR_BLK; + fadt->x_pm_tmr_blk.addrh = 0x0; + + + fadt->x_gpe0_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe0_blk.bit_width = 64; /* EventStatus + Event Enable */ + fadt->x_gpe0_blk.bit_offset = 0; + fadt->x_gpe0_blk.access_size = ACPI_ACCESS_SIZE_DWORD_ACCESS; + fadt->x_gpe0_blk.addrl = ACPI_GPE0_BLK; + fadt->x_gpe0_blk.addrh = 0x0; + + + fadt->x_gpe1_blk.space_id = ACPI_ADDRESS_SPACE_IO; + fadt->x_gpe1_blk.bit_width = 0; + fadt->x_gpe1_blk.bit_offset = 0; + fadt->x_gpe1_blk.access_size = 0; + fadt->x_gpe1_blk.addrl = 0; + fadt->x_gpe1_blk.addrh = 0x0; + + header->checksum = acpi_checksum((void *)fadt, sizeof(acpi_fadt_t)); +} diff --git a/src/southbridge/amd/pi/hudson/hda.c b/src/southbridge/amd/pi/hudson/hda.c new file mode 100644 index 0000000..2e648b7 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/hda.c @@ -0,0 +1,51 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <arch/io.h> +#include <delay.h> +#include "hudson.h" + + +static void hda_init(struct device *dev) +{ +} + +static struct pci_operations lops_pci = { + .set_subsystem = pci_dev_set_subsystem, +}; + +static struct device_operations hda_audio_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = hda_init, + .scan_bus = 0, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver hdaaudio_driver __pci_driver = { + .ops = &hda_audio_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_HDA, +}; diff --git a/src/southbridge/amd/pi/hudson/hudson.c b/src/southbridge/amd/pi/hudson/hudson.c new file mode 100644 index 0000000..e5382b4 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/hudson.c @@ -0,0 +1,140 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> + +#include <arch/io.h> +#include <arch/acpi.h> + +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <cbmem.h> +#include "hudson.h" +#include "smbus.h" +#include "smi.h" + +/* Offsets from ACPI_MMIO_BASE + * This is defined by AGESA, but we don't include AGESA headers to avoid + * polluting the namespace. + */ +#define PM_MMIO_BASE 0xfed80300 + + +int acpi_get_sleep_type(void) +{ + u16 tmp = inw(ACPI_PM1_CNT_BLK); + tmp = ((tmp & (7 << 10)) >> 10); + return (int)tmp; +} + +void pm_write8(u8 reg, u8 value) +{ + write8(PM_MMIO_BASE + reg, value); +} + +u8 pm_read8(u8 reg) +{ + return read8(PM_MMIO_BASE + reg); +} + +void pm_write16(u8 reg, u16 value) +{ + write16(PM_MMIO_BASE + reg, value); +} + +u16 pm_read16(u16 reg) +{ + return read16(PM_MMIO_BASE + reg); +} + +void hudson_enable(device_t dev) +{ + printk(BIOS_DEBUG, "hudson_enable()\n"); + switch (dev->path.pci.devfn) { + case (0x14 << 3) | 7: /* 0:14.7 SD */ + if (dev->enabled == 0) { + // read the VENDEV ID + device_t sd_dev = dev_find_slot( 0, PCI_DEVFN( 0x14, 7)); + u32 sd_device_id = pci_read_config32( sd_dev, 0) >> 16; + /* turn off the SDHC controller in the PM reg */ + u8 reg8; + if (sd_device_id == PCI_DEVICE_ID_AMD_HUDSON_SD) { + reg8 = pm_read8(0xe7); + reg8 &= ~(1 << 0); + pm_write8(0xe7, reg8); + } + else if (sd_device_id == PCI_DEVICE_ID_AMD_YANGTZE_SD) { + reg8 = pm_read8(0xe8); + reg8 &= ~(1 << 0); + pm_write8(0xe8, reg8); + } + /* remove device 0:14.7 from PCI space */ + reg8 = pm_read8(0xd3); + reg8 &= ~(1 << 6); + pm_write8(0xd3, reg8); + } + break; + default: + break; + } +} + +static void hudson_init_acpi_ports(void) +{ + /* We use some of these ports in SMM regardless of whether or not + * ACPI tables are generated. Enable these ports indiscriminately. + */ + + pm_write16(0x60, ACPI_PM_EVT_BLK); + pm_write16(0x62, ACPI_PM1_CNT_BLK); + pm_write16(0x64, ACPI_PM_TMR_BLK); + pm_write16(0x68, ACPI_GPE0_BLK); + /* CpuControl is in _PR.CPU0, 6 bytes */ + pm_write16(0x66, ACPI_CPU_CONTROL); + + if (IS_ENABLED(CONFIG_HAVE_SMI_HANDLER)) { + pm_write16(0x6a, ACPI_SMI_CTL_PORT); + hudson_enable_acpi_cmd_smi(); + } else { + pm_write16(0x6a, 0); + } + + /* AcpiDecodeEnable, When set, SB uses the contents of the PM registers + * at index 60-6B to decode ACPI I/O address. AcpiSmiEn & SmiCmdEn + */ + pm_write8(0x74, 1<<0 | 1<<1 | 1<<4 | 1<<2); +} + +static void hudson_init(void *chip_info) +{ + hudson_init_acpi_ports(); +} + +static void hudson_final(void *chip_info) +{ +} + +struct chip_operations southbridge_amd_pi_hudson_ops = { + CHIP_NAME("ATI HUDSON") + .enable_dev = hudson_enable, + .init = hudson_init, + .final = hudson_final +}; diff --git a/src/southbridge/amd/pi/hudson/hudson.h b/src/southbridge/amd/pi/hudson/hudson.h new file mode 100644 index 0000000..90c3205 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/hudson.h @@ -0,0 +1,92 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef HUDSON_H +#define HUDSON_H + +#include <device/pci_ids.h> +#include <device/device.h> +#include "chip.h" + +/* Power management index/data registers */ +#define BIOSRAM_INDEX 0xcd4 +#define BIOSRAM_DATA 0xcd5 +#define PM_INDEX 0xcd6 +#define PM_DATA 0xcd7 +#define PM2_INDEX 0xcd0 +#define PM2_DATA 0xcd1 + +#define HUDSON_ACPI_IO_BASE 0x800 + +#define ACPI_PM_EVT_BLK (HUDSON_ACPI_IO_BASE + 0x00) /* 4 bytes */ +#define ACPI_PM1_CNT_BLK (HUDSON_ACPI_IO_BASE + 0x04) /* 2 bytes */ +#define ACPI_PM_TMR_BLK (HUDSON_ACPI_IO_BASE + 0x18) /* 4 bytes */ +#define ACPI_GPE0_BLK (HUDSON_ACPI_IO_BASE + 0x10) /* 8 bytes */ +#define ACPI_CPU_CONTROL (HUDSON_ACPI_IO_BASE + 0x08) /* 6 bytes */ + +#define ACPI_SMI_CTL_PORT 0xb2 +#define ACPI_SMI_CMD_CST_CONTROL 0xde +#define ACPI_SMI_CMD_PST_CONTROL 0xad +#define ACPI_SMI_CMD_DISABLE 0xbe +#define ACPI_SMI_CMD_ENABLE 0xef +#define ACPI_SMI_CMD_S4_REQ 0xc0 + +#define REV_HUDSON_A11 0x11 +#define REV_HUDSON_A12 0x12 + +#define SPIROM_BASE_ADDRESS_REGISTER 0xA0 +#define SPI_ROM_ENABLE 0x02 +#define SPI_BASE_ADDRESS 0xFEC10000 + +static inline int hudson_sata_enable(void) +{ + /* True if IDE or AHCI. */ + return (CONFIG_HUDSON_SATA_MODE == 0) || (CONFIG_HUDSON_SATA_MODE == 2); +} + +static inline int hudson_ide_enable(void) +{ + /* True if IDE or LEGACY IDE. */ + return (CONFIG_HUDSON_SATA_MODE == 0) || (CONFIG_HUDSON_SATA_MODE == 3); +} + +#ifndef __SMM__ + +void pm_write8(u8 reg, u8 value); +u8 pm_read8(u8 reg); +void pm_write16(u8 reg, u16 value); +u16 pm_read16(u16 reg); + +#ifdef __PRE_RAM__ +void hudson_lpc_port80(void); +void hudson_pci_port80(void); +void hudson_clk_output_48Mhz(void); + +int s3_save_nvram_early(u32 dword, int size, int nvram_pos); +int s3_load_nvram_early(int size, u32 *old_dword, int nvram_pos); + +#else +void hudson_enable(device_t dev); +void s3_resume_init_data(void *FchParams); + +#endif /* __PRE_RAM__ */ +#endif /* __SMM__ */ + +#endif /* HUDSON_H */ diff --git a/src/southbridge/amd/pi/hudson/ide.c b/src/southbridge/amd/pi/hudson/ide.c new file mode 100644 index 0000000..cd80f99 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/ide.c @@ -0,0 +1,48 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include "hudson.h" + +static void ide_init(struct device *dev) +{ +} + +static struct pci_operations lops_pci = { + .set_subsystem = pci_dev_set_subsystem, +}; + +static struct device_operations ide_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = ide_init, + .scan_bus = 0, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver ide_driver __pci_driver = { + .ops = &ide_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_IDE, +}; diff --git a/src/southbridge/amd/pi/hudson/lpc.c b/src/southbridge/amd/pi/hudson/lpc.c new file mode 100644 index 0000000..d15a6d1 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/lpc.c @@ -0,0 +1,342 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pnp.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <device/pci_def.h> +#include <pc80/mc146818rtc.h> +#include <pc80/isa-dma.h> +#include <arch/io.h> +#include <arch/acpi.h> +#include <arch/ioapic.h> +#include "hudson.h" + +static void lpc_init(device_t dev) +{ + u8 byte; + u32 dword; + device_t sm_dev; + + /* Enable the LPC Controller */ + sm_dev = dev_find_slot(0, PCI_DEVFN(0x14, 0)); + dword = pci_read_config32(sm_dev, 0x64); + dword |= 1 << 20; + pci_write_config32(sm_dev, 0x64, dword); + + /* Initialize isa dma */ + isa_dma_init(); + + /* Enable DMA transaction on the LPC bus */ + byte = pci_read_config8(dev, 0x40); + byte |= (1 << 2); + pci_write_config8(dev, 0x40, byte); + + /* Disable the timeout mechanism on LPC */ + byte = pci_read_config8(dev, 0x48); + byte &= ~(1 << 7); + pci_write_config8(dev, 0x48, byte); + + /* Disable LPC MSI Capability */ + byte = pci_read_config8(dev, 0x78); + byte &= ~(1 << 1); + byte &= ~(1 << 0); /* Keep the old way. i.e., when bus master/DMA cycle is going + on on LPC, it holds PCI grant, so no LPC slave cycle can + interrupt and visit LPC. */ + pci_write_config8(dev, 0x78, byte); + + /* bit0: Enable prefetch a cacheline (64 bytes) when Host reads code from SPI rom */ + /* bit3: Fix SPI_CS# timing issue when running at 66M. TODO:A12. */ + byte = pci_read_config8(dev, 0xBB); + byte |= 1 << 0 | 1 << 3; + pci_write_config8(dev, 0xBB, byte); + + cmos_check_update_date(); + + /* Initialize the real time clock. + * The 0 argument tells cmos_init not to + * update CMOS unless it is invalid. + * 1 tells cmos_init to always initialize the CMOS. + */ + cmos_init(0); +} + +static void hudson_lpc_read_resources(device_t dev) +{ + struct resource *res; + + /* Get the normal pci resources of this device */ + pci_dev_read_resources(dev); /* We got one for APIC, or one more for TRAP */ + + /* Add an extra subtractive resource for both memory and I/O. */ + res = new_resource(dev, IOINDEX_SUBTRACTIVE(0, 0)); + res->base = 0; + res->size = 0x1000; + res->flags = IORESOURCE_IO | IORESOURCE_SUBTRACTIVE | + IORESOURCE_ASSIGNED | IORESOURCE_FIXED; + + res = new_resource(dev, IOINDEX_SUBTRACTIVE(1, 0)); + res->base = 0xff800000; + res->size = 0x00800000; /* 8 MB for flash */ + res->flags = IORESOURCE_MEM | IORESOURCE_SUBTRACTIVE | + IORESOURCE_ASSIGNED | IORESOURCE_FIXED; + + /* Add a memory resource for the SPI BAR. */ + fixed_mem_resource(dev, 2, SPI_BASE_ADDRESS / 1024, 1, IORESOURCE_SUBTRACTIVE); + + res = new_resource(dev, 3); /* IOAPIC */ + res->base = IO_APIC_ADDR; + res->size = 0x00001000; + res->flags = IORESOURCE_MEM | IORESOURCE_ASSIGNED | IORESOURCE_FIXED; + + compact_resources(dev); +} + +static void hudson_lpc_set_resources(struct device *dev) +{ + struct resource *res; + + /* Special case. SPI Base Address. The SpiRomEnable should STAY set. */ + res = find_resource(dev, 2); + pci_write_config32(dev, SPIROM_BASE_ADDRESS_REGISTER, res->base | SPI_ROM_ENABLE); + + pci_dev_set_resources(dev); +} + +/** + * @brief Enable resources for children devices + * + * @param dev the device whos children's resources are to be enabled + * + */ +static void hudson_lpc_enable_childrens_resources(device_t dev) +{ + struct bus *link; + u32 reg, reg_x; + int var_num = 0; + u16 reg_var[3]; + u16 reg_size[1] = {512}; + u8 wiosize = pci_read_config8(dev, 0x74); + + /* Be bit relaxed, tolerate that LPC region might be bigger than resource we try to fit, + * do it like this for all regions < 16 bytes. If there is a resource > 16 bytes + * it must be 512 bytes to be able to allocate the fresh LPC window. + * + * AGESA likes to enable already one LPC region in wide port base 0x64-0x65, + * using DFLT_SIO_PME_BASE_ADDRESS, 512 bytes size + * The code tries to check if resource can fit into this region + */ + + reg = pci_read_config32(dev, 0x44); + reg_x = pci_read_config32(dev, 0x48); + + /* check if ranges are free and not use them if entry is just already taken */ + if (reg_x & (1 << 2)) + var_num = 1; + /* just in case check if someone did not manually set other ranges too */ + if (reg_x & (1 << 24)) + var_num = 2; + + if (reg_x & (1 << 25)) + var_num = 3; + + /* check AGESA region size */ + if (wiosize & (1 << 0)) + reg_size[0] = 16; + + reg_var[2] = pci_read_config16(dev, 0x90); + reg_var[1] = pci_read_config16(dev, 0x66); + reg_var[0] = pci_read_config16(dev, 0x64); + + for (link = dev->link_list; link; link = link->next) { + device_t child; + for (child = link->children; child; + child = child->sibling) { + if (child->enabled + && (child->path.type == DEVICE_PATH_PNP)) { + struct resource *res; + for (res = child->resource_list; res; res = res->next) { + u32 base, end; /* don't need long long */ + u32 rsize, set = 0, set_x = 0; + if (!(res->flags & IORESOURCE_IO)) + continue; + base = res->base; + end = resource_end(res); + /* find a resource size */ + printk(BIOS_DEBUG, "hudson lpc decode:%s, base=0x%08x, end=0x%08x\n", + dev_path(child), base, end); + switch (base) { + case 0x60: /* KB */ + case 0x64: /* MS */ + set |= (1 << 29); + rsize = 1; + break; + case 0x3f8: /* COM1 */ + set |= (1 << 6); + rsize = 8; + break; + case 0x2f8: /* COM2 */ + set |= (1 << 7); + rsize = 8; + break; + case 0x378: /* Parallel 1 */ + set |= (1 << 0); + set |= (1 << 1); /* + 0x778 for ECP */ + rsize = 8; + break; + case 0x3f0: /* FD0 */ + set |= (1 << 26); + rsize = 8; + break; + case 0x220: /* 0x220 - 0x227 */ + set |= (1 << 8); + rsize = 8; + break; + case 0x228: /* 0x228 - 0x22f */ + set |= (1 << 9); + rsize = 8; + break; + case 0x238: /* 0x238 - 0x23f */ + set |= (1 << 10); + rsize = 8; + break; + case 0x300: /* 0x300 -0x301 */ + set |= (1 << 18); + rsize = 2; + break; + case 0x400: + set_x |= (1 << 16); + rsize = 0x40; + break; + case 0x480: + set_x |= (1 << 17); + rsize = 0x40; + break; + case 0x500: + set_x |= (1 << 18); + rsize = 0x40; + break; + case 0x580: + set_x |= (1 << 19); + rsize = 0x40; + break; + case 0x4700: + set_x |= (1 << 22); + rsize = 0xc; + break; + case 0xfd60: + set_x |= (1 << 23); + rsize = 16; + break; + default: + rsize = 0; + /* try AGESA allocated region in region 0 */ + if ((var_num > 0) && ((base >=reg_var[0]) && + ((base + res->size) <= (reg_var[0] + reg_size[0])))) + rsize = reg_size[0]; + } + /* check if region found and matches the enable */ + if (res->size <= rsize) { + reg |= set; + reg_x |= set_x; + /* check if we can fit resource in variable range */ + } else if ((var_num < 3) && + ((res->size <= 16) || (res->size == 512))) { + /* use variable ranges if pre-defined do not match */ + switch (var_num) { + case 0: + reg_x |= (1 << 2); + if (res->size <= 16) { + wiosize |= (1 << 0); + } + break; + case 1: + reg_x |= (1 << 24); + if (res->size <= 16) + wiosize |= (1 << 2); + break; + case 2: + reg_x |= (1 << 25); + if (res->size <= 16) + wiosize |= (1 << 3); + break; + } + reg_var[var_num++] = + base & 0xffff; + } else { + printk(BIOS_ERR, "cannot fit LPC decode region:%s, base=0x%08x, end=0x%08x\n", + dev_path(child), base, end); + } + } + } + } + } + pci_write_config32(dev, 0x44, reg); + pci_write_config32(dev, 0x48, reg_x); + /* Set WideIO for as many IOs found (fall through is on purpose) */ + switch (var_num) { + case 3: + pci_write_config16(dev, 0x90, reg_var[2]); + /* fall through */ + case 2: + pci_write_config16(dev, 0x66, reg_var[1]); + /* fall through */ + case 1: + pci_write_config16(dev, 0x64, reg_var[0]); + break; + } + pci_write_config8(dev, 0x74, wiosize); +} + +unsigned long acpi_fill_mcfg(unsigned long current) +{ + /* Just a dummy */ + return current; +} + +static void hudson_lpc_enable_resources(device_t dev) +{ + pci_dev_enable_resources(dev); + hudson_lpc_enable_childrens_resources(dev); +} + +static struct pci_operations lops_pci = { + .set_subsystem = pci_dev_set_subsystem, +}; + +static struct device_operations lpc_ops = { + .read_resources = hudson_lpc_read_resources, + .set_resources = hudson_lpc_set_resources, + .enable_resources = hudson_lpc_enable_resources, +#if IS_ENABLED(CONFIG_HAVE_ACPI_TABLES) + .write_acpi_tables = acpi_write_hpet, +#endif + .init = lpc_init, + .scan_bus = scan_static_bus, + .ops_pci = &lops_pci, +}; +static const struct pci_driver lpc_driver __pci_driver = { + .ops = &lpc_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_LPC, +}; diff --git a/src/southbridge/amd/pi/hudson/pci.c b/src/southbridge/amd/pi/hudson/pci.c new file mode 100644 index 0000000..e8836e4 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/pci.c @@ -0,0 +1,74 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * Copyright (C) 2014 Sage Electronic Engineering, LLC. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include "hudson.h" +#include <southbridge/amd/amd_pci_util.h> +#include <bootstate.h> + +static void pci_init(struct device *dev) +{ +} + +/* + * Update the PCI devices with a valid IRQ number + * that is set in the mainboard PCI_IRQ structures. + */ +static void set_pci_irqs(void *unused) +{ + /* Write PCI_INTR regs 0xC00/0xC01 */ + write_pci_int_table(); + + /* Write IRQs for all devicetree enabled devices */ + write_pci_cfg_irqs(); +} + +/* + * Hook this function into the PCI state machine + * on entry into BS_DEV_ENABLE. + */ +BOOT_STATE_INIT_ENTRIES(pci_irq_update) = { + BOOT_STATE_INIT_ENTRY(BS_DEV_ENABLE, BS_ON_ENTRY, + set_pci_irqs, NULL), +}; + +static struct pci_operations lops_pci = { + .set_subsystem = 0, +}; + +static struct device_operations pci_ops = { + .read_resources = pci_bus_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_bus_enable_resources, + .init = pci_init, + .scan_bus = pci_scan_bridge, + .reset_bus = pci_bus_reset, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver pci_driver __pci_driver = { + .ops = &pci_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_PCI, +}; diff --git a/src/southbridge/amd/pi/hudson/pci_devs.h b/src/southbridge/amd/pi/hudson/pci_devs.h new file mode 100644 index 0000000..d2549d4 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/pci_devs.h @@ -0,0 +1,96 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2014 Sage Electronic Engineering, LLC. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef _PI_HUDSON_PCI_DEVS_H_ +#define _PI_HUDSON_PCI_DEVS_H_ + +#define BUS0 0 + +/* XHCI */ +#define XHCI_DEV 0x10 +#define XHCI_FUNC 0 +#define XHCI_DEVID 0x7814 +#define XHCI_DEVFN PCI_DEVFN(XHCI_DEV,XHCI_FUNC) + +/* SATA */ +#define SATA_DEV 0x11 +#define SATA_FUNC 0 +#define SATA_IDE_DEVID 0x7800 +#define AHCI_DEVID_MS 0x7801 +#define AHCI_DEVID_AMD 0x7804 +#define SATA_DEVFN PCI_DEVFN(SATA_DEV,SATA_FUNC) + +/* OHCI */ +#define OHCI1_DEV 0x12 +#define OHCI1_FUNC 0 +#define OHCI2_DEV 0x13 +#define OHCI2_FUNC 0 +#define OHCI3_DEV 0x16 +#define OHCI3_FUNC 0 +#define OHCI4_DEV 0x14 +#define OHCI4_FUNC 5 +#define OHCI_DEVID 0x7807 +#define OHCI1_DEVFN PCI_DEVFN(OHCI1_DEV,OHCI1_FUNC) +#define OHCI2_DEVFN PCI_DEVFN(OHCI2_DEV,OHCI2_FUNC) +#define OHCI3_DEVFN PCI_DEVFN(OHCI3_DEV,OHCI3_FUNC) +#define OHCI4_DEVFN PCI_DEVFN(OHCI4_DEV,OHCI4_FUNC) + +/* EHCI */ +#define EHCI1_DEV 0x12 +#define EHCI1_FUNC 2 +#define EHCI2_DEV 0x13 +#define EHCI2_FUNC 2 +#define EHCI3_DEV 0x16 +#define EHCI3_FUNC 2 +#define EHCI_DEVID 0x7808 +#define EHCI1_DEVFN PCI_DEVFN(EHCI1_DEV,EHCI1_FUNC) +#define EHCI2_DEVFN PCI_DEVFN(EHCI2_DEV,EHCI2_FUNC) +#define EHCI3_DEVFN PCI_DEVFN(EHCI3_DEV,EHCI3_FUNC) + +/* SMBUS */ +#define SMBUS_DEV 0x14 +#define SMBUS_FUNC 0 +#define SMBUS_DEVID 0x780B +#define SMBUS_DEVFN PCI_DEVFN(SMBUS_DEV,SMBUS_FUNC) + +/* HD Audio */ +#define HDA_DEV 0x14 +#define HDA_FUNC 2 +#define HDA_DEVID 0x780D +#define HDA_DEVFN PCI_DEVFN(HDA_DEV,HDA_FUNC) + +/* LPC BUS */ +#define PCU_DEV 0x14 +#define LPC_FUNC 3 +#define LPC_DEVID 0x780E +#define LPC_DEVFN PCI_DEVFN(LPC_DEV,LPC_FUNC) + +/* PCI Ports */ +#define SB_PCI_PORT_DEV 0x14 +#define SB_PCI_PORT_FUNC 4 +# define SB_PCI_PORT_DEVID 0x780F +# define SB_PCI_PORT_DEVFN PCI_DEVFN(SB_PCI_PORT_DEV,SB_PCI_PORT_FUNC) + +/* SD Controller */ +#define SD_DEV 0x14 +#define SD_FUNC 7 +#define SD_DEVID 0x7806 +#define SD_DEVFN PCI_DEVFN(SD_DEV,SD_FUNC) + +#endif /* _PI_HUDSON_PCI_DEVS_H_ */ diff --git a/src/southbridge/amd/pi/hudson/pcie.c b/src/southbridge/amd/pi/hudson/pcie.c new file mode 100644 index 0000000..ec686fc --- /dev/null +++ b/src/southbridge/amd/pi/hudson/pcie.c @@ -0,0 +1,65 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include "hudson.h" + +static void pcie_init(struct device *dev) +{ +} + +static struct pci_operations lops_pci = { + .set_subsystem = 0, +}; + +static struct device_operations pci_ops = { + .read_resources = pci_bus_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_bus_enable_resources, + .init = pcie_init, + .scan_bus = pci_scan_bridge, + .reset_bus = pci_bus_reset, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver pciea_driver __pci_driver = { + .ops = &pci_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_PCIEA, +}; + +static const struct pci_driver pcieb_driver __pci_driver = { + .ops = &pci_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_PCIEB, +}; +static const struct pci_driver pciec_driver __pci_driver = { + .ops = &pci_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_PCIEC, +}; +static const struct pci_driver pcied_driver __pci_driver = { + .ops = &pci_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_PCIED, +}; diff --git a/src/southbridge/amd/pi/hudson/reset.c b/src/southbridge/amd/pi/hudson/reset.c new file mode 100644 index 0000000..79fd79e --- /dev/null +++ b/src/southbridge/amd/pi/hudson/reset.c @@ -0,0 +1,35 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +// Use simple device model for this file even in ramstage +#define __SIMPLE_DEVICE__ + +#include <arch/io.h> +#include <reset.h> + +#include <northbridge/amd/amdk8/reset_test.c> + +void hard_reset(void) +{ + set_bios_reset(); + /* Try rebooting through port 0xcf9 */ + /* Actually it is not a real hard_reset --- it only reset coherent link table, but not reset link freq and width */ + outb((0 << 3) | (0 << 2) | (1 << 1), 0xcf9); + outb((0 << 3) | (1 << 2) | (1 << 1), 0xcf9); +} diff --git a/src/southbridge/amd/pi/hudson/sata.c b/src/southbridge/amd/pi/hudson/sata.c new file mode 100644 index 0000000..c02a5b1 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/sata.c @@ -0,0 +1,85 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <delay.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <arch/io.h> +#include "hudson.h" + + +static void sata_init(struct device *dev) +{ +#if IS_ENABLED(CONFIG_SOUTHBRIDGE_AMD_PI_AVALON) + /************************************** + * Configure the SATA port multiplier * + **************************************/ + #define BYTE_TO_DWORD_OFFSET(x) (x/4) + #define AHCI_BASE_ADDRESS_REG 0x24 + #define MISC_CONTROL_REG 0x40 + #define UNLOCK_BIT (1<<0) + #define SATA_CAPABILITIES_REG 0xFC + #define CFG_CAP_SPM (1<<12) + + volatile u32 *ahci_ptr = + (u32*)(pci_read_config32(dev, AHCI_BASE_ADDRESS_REG) & 0xFFFFFF00); + u32 temp; + + /* unlock the write-protect */ + temp = pci_read_config32(dev, MISC_CONTROL_REG); + temp |= UNLOCK_BIT; + pci_write_config32(dev, MISC_CONTROL_REG, temp); + + /* set the SATA AHCI mode to allow port expanders */ + *(ahci_ptr + BYTE_TO_DWORD_OFFSET(SATA_CAPABILITIES_REG)) |= CFG_CAP_SPM; + + /* lock the write-protect */ + temp = pci_read_config32(dev, MISC_CONTROL_REG); + temp &= ~UNLOCK_BIT; + pci_write_config32(dev, MISC_CONTROL_REG, temp); +#endif +}; + +static struct pci_operations lops_pci = { + /* .set_subsystem = pci_dev_set_subsystem, */ +}; + +static struct device_operations sata_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = sata_init, + .scan_bus = 0, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver sata0_driver __pci_driver = { + .ops = &sata_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_SATA, +}; + +static const struct pci_driver sata0_driver_ahci __pci_driver = { + .ops = &sata_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_SATA_AHCI, +}; diff --git a/src/southbridge/amd/pi/hudson/sd.c b/src/southbridge/amd/pi/hudson/sd.c new file mode 100644 index 0000000..03b097a --- /dev/null +++ b/src/southbridge/amd/pi/hudson/sd.c @@ -0,0 +1,69 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <device/device.h> +#include <delay.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <arch/io.h> +#include "hudson.h" + +static void sd_init(struct device *dev) +{ + u32 stepping; + + stepping = pci_read_config32(dev_find_slot(0, PCI_DEVFN(0x18, 3)), 0xFC); + + struct southbridge_amd_pi_hudson_config *sd_chip = + (struct southbridge_amd_pi_hudson_config *)(dev->chip_info); + + if (sd_chip->sd_mode == 3) { /* SD 3.0 mode */ + pci_write_config32(dev, 0xA4, 0x31FEC8B2); + pci_write_config32(dev, 0xA8, 0x00002503); + pci_write_config32(dev, 0xB0, 0x02180C19); + pci_write_config32(dev, 0xD0, 0x0000078B); + } + else { /* SD 2.0 mode */ + if ((stepping & 0x0000000F) == 0) { /* Stepping A0 */ + pci_write_config32(dev, 0xA4, 0x31DE32B2); + pci_write_config32(dev, 0xB0, 0x01180C19); + pci_write_config32(dev, 0xD0, 0x0000058B); + } + else { /* Stepping >= A1 */ + pci_write_config32(dev, 0xA4, 0x31FE3FB2); + pci_write_config32(dev, 0xB0, 0x01180C19); + pci_write_config32(dev, 0xD0, 0x0000078B); + } + } +} + +static struct device_operations sd_ops = { + .read_resources = pci_dev_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = sd_init, + .scan_bus = 0, +}; + +static const struct pci_driver sd_driver __pci_driver = { + .ops = &sd_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_AMD_YANGTZE_SD, +}; diff --git a/src/southbridge/amd/pi/hudson/sm.c b/src/southbridge/amd/pi/hudson/sm.c new file mode 100644 index 0000000..d6ca215 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/sm.c @@ -0,0 +1,174 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <device/smbus.h> +#include <pc80/mc146818rtc.h> +#include <arch/io.h> +#include <cpu/x86/lapic.h> +#include <arch/ioapic.h> +#include <stdlib.h> +#include "hudson.h" +#include "smbus.c" + +#define NMI_OFF 0 + +#define MAINBOARD_POWER_OFF 0 +#define MAINBOARD_POWER_ON 1 + +#ifndef CONFIG_MAINBOARD_POWER_ON_AFTER_POWER_FAIL +#define CONFIG_MAINBOARD_POWER_ON_AFTER_POWER_FAIL MAINBOARD_POWER_ON +#endif + +#define BIT0 (1 << 0) +#define BIT1 (1 << 1) +#define BIT2 (1 << 2) +#define BIT3 (1 << 3) +#define BIT4 (1 << 4) +#define BIT5 (1 << 5) +#define BIT6 (1 << 6) +#define BIT7 (1 << 7) + +#define BIT8 (1 << 8 ) +#define BIT9 (1 << 9 ) +#define BIT10 (1 << 10) +#define BIT11 (1 << 11) +#define BIT12 (1 << 12) +#define BIT13 (1 << 13) +#define BIT14 (1 << 14) +#define BIT15 (1 << 15) + +#define BIT16 (1 << 16) +#define BIT17 (1 << 17) +#define BIT18 (1 << 18) +#define BIT19 (1 << 19) +#define BIT20 (1 << 20) +#define BIT21 (1 << 21) +#define BIT22 (1 << 22) +#define BIT23 (1 << 23) +#define BIT24 (1 << 24) +#define BIT25 (1 << 25) +#define BIT26 (1 << 26) +#define BIT27 (1 << 27) +#define BIT28 (1 << 28) +#define BIT29 (1 << 29) +#define BIT30 (1 << 30) +#define BIT31 (1 << 31) + +/* +* HUDSON enables all USB controllers by default in SMBUS Control. +* HUDSON enables SATA by default in SMBUS Control. +*/ + +static void sm_init(device_t dev) +{ + setup_ioapic(IO_APIC_ADDR, CONFIG_MAX_CPUS); +} + +static int lsmbus_recv_byte(device_t dev) +{ + u32 device; + struct resource *res; + struct bus *pbus; + + device = dev->path.i2c.device; + pbus = get_pbus_smbus(dev); + + res = find_resource(pbus->dev, 0x90); + + return do_smbus_recv_byte(res->base, device); +} + +static int lsmbus_send_byte(device_t dev, u8 val) +{ + u32 device; + struct resource *res; + struct bus *pbus; + + device = dev->path.i2c.device; + pbus = get_pbus_smbus(dev); + + res = find_resource(pbus->dev, 0x90); + + return do_smbus_send_byte(res->base, device, val); +} + +static int lsmbus_read_byte(device_t dev, u8 address) +{ + u32 device; + struct resource *res; + struct bus *pbus; + + device = dev->path.i2c.device; + pbus = get_pbus_smbus(dev); + + res = find_resource(pbus->dev, 0x90); + + return do_smbus_read_byte(res->base, device, address); +} + +static int lsmbus_write_byte(device_t dev, u8 address, u8 val) +{ + u32 device; + struct resource *res; + struct bus *pbus; + + device = dev->path.i2c.device; + pbus = get_pbus_smbus(dev); + + res = find_resource(pbus->dev, 0x90); + + return do_smbus_write_byte(res->base, device, address, val); +} +static struct smbus_bus_operations lops_smbus_bus = { + .recv_byte = lsmbus_recv_byte, + .send_byte = lsmbus_send_byte, + .read_byte = lsmbus_read_byte, + .write_byte = lsmbus_write_byte, +}; + +static void hudson_sm_read_resources(device_t dev) +{ +} + +static void hudson_sm_set_resources(struct device *dev) +{ +} + +static struct pci_operations lops_pci = { + .set_subsystem = pci_dev_set_subsystem, +}; +static struct device_operations smbus_ops = { + .read_resources = hudson_sm_read_resources, + .set_resources = hudson_sm_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = sm_init, + .scan_bus = scan_static_bus, + .ops_pci = &lops_pci, + .ops_smbus_bus = &lops_smbus_bus, +}; +static const struct pci_driver smbus_driver __pci_driver = { + .ops = &smbus_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_SM, +}; diff --git a/src/southbridge/amd/pi/hudson/smbus.c b/src/southbridge/amd/pi/hudson/smbus.c new file mode 100644 index 0000000..519c85d --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smbus.c @@ -0,0 +1,250 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef _HUDSON_SMBUS_C_ +#define _HUDSON_SMBUS_C_ + +#include <io.h> +#include <stdint.h> +#include "smbus.h" + +static int smbus_wait_until_ready(u32 smbus_io_base) +{ + u32 loops; + loops = SMBUS_TIMEOUT; + do { + u8 val; + val = inb(smbus_io_base + SMBHSTSTAT); + val &= 0x1f; + if (val == 0) { /* ready now */ + return 0; + } + outb(val, smbus_io_base + SMBHSTSTAT); + } while (--loops); + return -2; /* time out */ +} + +static int smbus_wait_until_done(u32 smbus_io_base) +{ + u32 loops; + loops = SMBUS_TIMEOUT; + do { + u8 val; + + val = inb(smbus_io_base + SMBHSTSTAT); + val &= 0x1f; /* mask off reserved bits */ + if (val & 0x1c) { + return -5; /* error */ + } + if (val == 0x02) { + outb(val, smbus_io_base + SMBHSTSTAT); /* clear status */ + return 0; + } + } while (--loops); + return -3; /* timeout */ +} + +int do_smbus_recv_byte(u32 smbus_io_base, u32 device) +{ + u8 byte; + + if (smbus_wait_until_ready(smbus_io_base) < 0) { + return -2; /* not ready */ + } + + /* set the device I'm talking too */ + outb(((device & 0x7f) << 1) | 1, smbus_io_base + SMBHSTADDR); + + byte = inb(smbus_io_base + SMBHSTCTRL); + byte &= 0xe3; /* Clear [4:2] */ + byte |= (1 << 2) | (1 << 6); /* Byte data read/write command, start the command */ + outb(byte, smbus_io_base + SMBHSTCTRL); + + /* poll for transaction completion */ + if (smbus_wait_until_done(smbus_io_base) < 0) { + return -3; /* timeout or error */ + } + + /* read results of transaction */ + byte = inb(smbus_io_base + SMBHSTCMD); + + return byte; +} + +int do_smbus_send_byte(u32 smbus_io_base, u32 device, u8 val) +{ + u8 byte; + + if (smbus_wait_until_ready(smbus_io_base) < 0) { + return -2; /* not ready */ + } + + /* set the command... */ + outb(val, smbus_io_base + SMBHSTCMD); + + /* set the device I'm talking too */ + outb(((device & 0x7f) << 1) | 0, smbus_io_base + SMBHSTADDR); + + byte = inb(smbus_io_base + SMBHSTCTRL); + byte &= 0xe3; /* Clear [4:2] */ + byte |= (1 << 2) | (1 << 6); /* Byte data read/write command, start the command */ + outb(byte, smbus_io_base + SMBHSTCTRL); + + /* poll for transaction completion */ + if (smbus_wait_until_done(smbus_io_base) < 0) { + return -3; /* timeout or error */ + } + + return 0; +} + +int do_smbus_read_byte(u32 smbus_io_base, u32 device, + u32 address) +{ + u8 byte; + + if (smbus_wait_until_ready(smbus_io_base) < 0) { + return -2; /* not ready */ + } + + /* set the command/address... */ + outb(address & 0xff, smbus_io_base + SMBHSTCMD); + + /* set the device I'm talking too */ + outb(((device & 0x7f) << 1) | 1, smbus_io_base + SMBHSTADDR); + + byte = inb(smbus_io_base + SMBHSTCTRL); + byte &= 0xe3; /* Clear [4:2] */ + byte |= (1 << 3) | (1 << 6); /* Byte data read/write command, start the command */ + outb(byte, smbus_io_base + SMBHSTCTRL); + + /* poll for transaction completion */ + if (smbus_wait_until_done(smbus_io_base) < 0) { + return -3; /* timeout or error */ + } + + /* read results of transaction */ + byte = inb(smbus_io_base + SMBHSTDAT0); + + return byte; +} + +int do_smbus_write_byte(u32 smbus_io_base, u32 device, + u32 address, u8 val) +{ + u8 byte; + + if (smbus_wait_until_ready(smbus_io_base) < 0) { + return -2; /* not ready */ + } + + /* set the command/address... */ + outb(address & 0xff, smbus_io_base + SMBHSTCMD); + + /* set the device I'm talking too */ + outb(((device & 0x7f) << 1) | 0, smbus_io_base + SMBHSTADDR); + + /* output value */ + outb(val, smbus_io_base + SMBHSTDAT0); + + byte = inb(smbus_io_base + SMBHSTCTRL); + byte &= 0xe3; /* Clear [4:2] */ + byte |= (1 << 3) | (1 << 6); /* Byte data read/write command, start the command */ + outb(byte, smbus_io_base + SMBHSTCTRL); + + /* poll for transaction completion */ + if (smbus_wait_until_done(smbus_io_base) < 0) { + return -3; /* timeout or error */ + } + + return 0; +} + +void alink_ab_indx(u32 reg_space, u32 reg_addr, + u32 mask, u32 val) +{ + u32 tmp; + + outl((reg_space & 0x7) << 29 | reg_addr, AB_INDX); + tmp = inl(AB_DATA); + /* rpr 4.2 + * For certain revisions of the chip, the ABCFG registers, + * with an address of 0x100NN (where 'N' is any hexadecimal + * number), require an extra programming step.*/ + outl(0, AB_INDX); + + tmp &= ~mask; + tmp |= val; + + /* printk(BIOS_DEBUG, "about write %x, index=%x", tmp, (reg_space&0x3)<<29 | reg_addr); */ + outl((reg_space & 0x7) << 29 | reg_addr, AB_INDX); /* probably we dont have to do it again. */ + outl(tmp, AB_DATA); + outl(0, AB_INDX); +} + +void alink_rc_indx(u32 reg_space, u32 reg_addr, u32 port, + u32 mask, u32 val) +{ + u32 tmp; + + outl((reg_space & 0x7) << 29 | (port & 3) << 24 | reg_addr, AB_INDX); + tmp = inl(AB_DATA); + /* rpr 4.2 + * For certain revisions of the chip, the ABCFG registers, + * with an address of 0x100NN (where 'N' is any hexadecimal + * number), require an extra programming step.*/ + outl(0, AB_INDX); + + tmp &= ~mask; + tmp |= val; + + //printk(BIOS_DEBUG, "about write %x, index=%x", tmp, (reg_space&0x3)<<29 | (port&3) << 24 | reg_addr); + outl((reg_space & 0x7) << 29 | (port & 3) << 24 | reg_addr, AB_INDX); /* probably we dont have to do it again. */ + outl(tmp, AB_DATA); + outl(0, AB_INDX); +} + +/* space = 0: AX_INDXC, AX_DATAC + * space = 1: AX_INDXP, AX_DATAP + */ +void alink_ax_indx(u32 space /*c or p? */ , u32 axindc, + u32 mask, u32 val) +{ + u32 tmp; + + /* read axindc to tmp */ + outl(space << 29 | space << 3 | 0x30, AB_INDX); + outl(axindc, AB_DATA); + outl(0, AB_INDX); + outl(space << 29 | space << 3 | 0x34, AB_INDX); + tmp = inl(AB_DATA); + outl(0, AB_INDX); + + tmp &= ~mask; + tmp |= val; + + /* write tmp */ + outl(space << 29 | space << 3 | 0x30, AB_INDX); + outl(axindc, AB_DATA); + outl(0, AB_INDX); + outl(space << 29 | space << 3 | 0x34, AB_INDX); + outl(tmp, AB_DATA); + outl(0, AB_INDX); +} +#endif diff --git a/src/southbridge/amd/pi/hudson/smbus.h b/src/southbridge/amd/pi/hudson/smbus.h new file mode 100644 index 0000000..53cc0e6 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smbus.h @@ -0,0 +1,76 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#ifndef HUDSON_SMBUS_H +#define HUDSON_SMBUS_H + +#include <stdint.h> + +#define SMBHSTSTAT 0x0 +#define SMBSLVSTAT 0x1 +#define SMBHSTCTRL 0x2 +#define SMBHSTCMD 0x3 +#define SMBHSTADDR 0x4 +#define SMBHSTDAT0 0x5 +#define SMBHSTDAT1 0x6 +#define SMBHSTBLKDAT 0x7 + +#define SMBSLVCTRL 0x8 +#define SMBSLVCMD_SHADOW 0x9 +#define SMBSLVEVT 0xa +#define SMBSLVDAT 0xc + +#define AX_INDXC 0 +#define AX_INDXP 2 +#define AXCFG 4 +#define ABCFG 6 +#define RC_INDXC 1 +#define RC_INDXP 3 + +#define AB_INDX 0xCD8 +#define AB_DATA (AB_INDX+4) + +/* Between 1-10 seconds, We should never timeout normally + * Longer than this is just painful when a timeout condition occurs. + */ +#define SMBUS_TIMEOUT (100*1000*10) + +#define abcfg_reg(reg, mask, val) \ + alink_ab_indx((ABCFG), (reg), (mask), (val)) +#define axcfg_reg(reg, mask, val) \ + alink_ab_indx((AXCFG), (reg), (mask), (val)) +#define axindxc_reg(reg, mask, val) \ + alink_ax_indx((AX_INDXC), (reg), (mask), (val)) +#define axindxp_reg(reg, mask, val) \ + alink_ax_indx((AX_INDXP), (reg), (mask), (val)) +#define rcindxc_reg(reg, port, mask, val) \ + alink_rc_indx((RC_INDXC), (reg), (port), (mask), (val)) +#define rcindxp_reg(reg, port, mask, val) \ + alink_rc_indx((RC_INDXP), (reg), (port), (mask), (val)) + +int do_smbus_read_byte(u32 smbus_io_base, u32 device, u32 address); +int do_smbus_write_byte(u32 smbus_io_base, u32 device, u32 address, u8 val); +int do_smbus_recv_byte(u32 smbus_io_base, u32 device); +int do_smbus_send_byte(u32 smbus_io_base, u32 device, u8 val); +void alink_rc_indx(u32 reg_space, u32 reg_addr, u32 port, u32 mask, u32 val); +void alink_ab_indx(u32 reg_space, u32 reg_addr, u32 mask, u32 val); +void alink_ax_indx(u32 space /*c or p? */ , u32 axindc, u32 mask, u32 val); + + +#endif diff --git a/src/southbridge/amd/pi/hudson/smbus_spd.c b/src/southbridge/amd/pi/hudson/smbus_spd.c new file mode 100644 index 0000000..9dfd0b5 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smbus_spd.c @@ -0,0 +1,152 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <device/pci_def.h> +#include <device/device.h> + +/* warning: Porting.h includes an open #pragma pack(1) */ +#include "Porting.h" +#include "AGESA.h" +#include "amdlib.h" + +#include <northbridge/amd/pi/dimmSpd.h> + +/*----------------------------------------------------------------------------- + * + * readSmbusByteData - read a single SPD byte from any offset + */ + +static int readSmbusByteData (int iobase, int address, char *buffer, int offset) +{ + unsigned int status; + UINT64 limit; + + address |= 1; // set read bit + + __outbyte (iobase + 0, 0xFF); // clear error status + __outbyte (iobase + 1, 0x1F); // clear error status + __outbyte (iobase + 3, offset); // offset in eeprom + __outbyte (iobase + 4, address); // slave address and read bit + __outbyte (iobase + 2, 0x48); // read byte command + + // time limit to avoid hanging for unexpected error status (should never happen) + limit = __rdtsc () + 2000000000 / 10; + for (;;) + { + status = __inbyte (iobase); + if (__rdtsc () > limit) break; + if ((status & 2) == 0) continue; // SMBusInterrupt not set, keep waiting + if ((status & 1) == 1) continue; // HostBusy set, keep waiting + break; + } + + buffer [0] = __inbyte (iobase + 5); + if (status == 2) status = 0; // check for done with no errors + return status; +} + +/*----------------------------------------------------------------------------- + * + * readSmbusByte - read a single SPD byte from the default offset + * this function is faster function readSmbusByteData + */ + +static int readSmbusByte (int iobase, int address, char *buffer) +{ + unsigned int status; + UINT64 limit; + + __outbyte (iobase + 0, 0xFF); // clear error status + __outbyte (iobase + 2, 0x44); // read command + + // time limit to avoid hanging for unexpected error status + limit = __rdtsc () + 2000000000 / 10; + for (;;) + { + status = __inbyte (iobase); + if (__rdtsc () > limit) break; + if ((status & 2) == 0) continue; // SMBusInterrupt not set, keep waiting + if ((status & 1) == 1) continue; // HostBusy set, keep waiting + break; + } + + buffer [0] = __inbyte (iobase + 5); + if (status == 2) status = 0; // check for done with no errors + return status; +} + +/*--------------------------------------------------------------------------- + * + * readspd - Read one or more SPD bytes from a DIMM. + * Start with offset zero and read sequentially. + * Optimization relies on autoincrement to avoid + * sending offset for every byte. + * Reads 128 bytes in 7-8 ms at 400 KHz. + */ + +static int readspd (int iobase, int SmbusSlaveAddress, char *buffer, int count) +{ + int index, error; + + printk(BIOS_SPEW, "-------------READING SPD-----------\n"); + printk(BIOS_SPEW, "iobase: 0x%08X, SmbusSlave: 0x%08X, count: %d\n", + iobase, SmbusSlaveAddress, count); + + /* read the first byte using offset zero */ + error = readSmbusByteData (iobase, SmbusSlaveAddress, buffer, 0); + + if (error) { + printk(BIOS_ERR, "-------------SPD READ ERROR-----------\n"); + return error; + } + + /* read the remaining bytes using auto-increment for speed */ + for (index = 1; index < count; index++) + { + error = readSmbusByte (iobase, SmbusSlaveAddress, &buffer [index]); + if (error) { + printk(BIOS_ERR, "-------------SPD READ ERROR-----------\n"); + return error; + } + } + printk(BIOS_SPEW, "\n"); + printk(BIOS_SPEW, "-------------FINISHED READING SPD-----------\n"); + + return 0; +} + +static void writePmReg (int reg, int data) +{ + __outbyte (0xCD6, reg); + __outbyte (0xCD7, data); +} + +static void setupFch (int ioBase) +{ + writePmReg (0x2D, ioBase >> 8); + writePmReg (0x2C, ioBase | 1); + __outbyte (ioBase + 0x0E, 66000000 / 400000 / 4); // set SMBus clock to 400 KHz +} + +int hudson_readSpd(int spdAddress, char *buf, size_t len) +{ + int ioBase = 0xB00; + setupFch (ioBase); + return readspd (ioBase, spdAddress, buf, len); +} diff --git a/src/southbridge/amd/pi/hudson/smi.c b/src/southbridge/amd/pi/hudson/smi.c new file mode 100644 index 0000000..1d58afe --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smi.c @@ -0,0 +1,25 @@ +/* + * Utilities for SMM setup + * + * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com + * Subject to the GNU GPL v2, or (at your option) any later version. + */ + +#include "smi.h" + +#include <console/console.h> +#include <cpu/cpu.h> + +void smm_setup_structures(void *gnvs, void *tcg, void *smi1) +{ + printk(BIOS_DEBUG, "smm_setup_structures STUB!!!\n"); +} + +/** Set the EOS bit and enable SMI generation from southbridge */ +void hudson_enable_smi_generation(void) +{ + uint32_t reg = smi_read32(SMI_REG_SMITRIG0); + reg &= ~SMITRG0_SMIENB; /* Enable SMI generation */ + reg |= SMITRG0_EOS; /* Set EOS bit */ + smi_write32(SMI_REG_SMITRIG0, reg); +} diff --git a/src/southbridge/amd/pi/hudson/smi.h b/src/southbridge/amd/pi/hudson/smi.h new file mode 100644 index 0000000..de987a9 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smi.h @@ -0,0 +1,65 @@ +/* + * Utilities for SMI handlers and SMM setup + * + * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com + * Subject to the GNU GPL v2, or (at your option) any later version. + */ + +#ifndef _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H +#define _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H + +#include <arch/io.h> + +/* ACPI_MMIO_BASE + 0x200 -- leave this string here so grep catches it. + * This is defined by AGESA, but we dpn't include AGESA headers to avoid + * polluting the namesace. + */ +#define SMI_BASE 0xfed80200 + +#define SMI_REG_SMITRIG0 0x98 +#define SMITRG0_EOS (1 << 28) +#define SMITRG0_SMIENB (1 << 31) + +#define SMI_REG_CONTROL0 0xa0 + +enum smi_mode { + SMI_MODE_DISABLE = 0, + SMI_MODE_SMI = 1, + SMI_MODE_NMI = 2, + SMI_MODE_IRQ13 = 3, +}; + +enum smi_lvl { + SMI_LVL_LOW = 0, + SMI_LVL_HIGH = 1, +}; + +static inline uint32_t smi_read32(uint8_t offset) +{ + return read32(SMI_BASE + offset); +} + +static inline void smi_write32(uint8_t offset, uint32_t value) +{ + write32(SMI_BASE + offset, value); +} + +static inline uint16_t smi_read16(uint8_t offset) +{ + return read16(SMI_BASE + offset); +} + +static inline void smi_write16(uint8_t offset, uint16_t value) +{ + write16(SMI_BASE + offset, value); +} + +void hudson_configure_gevent_smi(uint8_t gevent, uint8_t mode, uint8_t level); +void hudson_disable_gevent_smi(uint8_t gevent); +void hudson_enable_acpi_cmd_smi(void); + +#ifndef __SMM__ +void hudson_enable_smi_generation(void); +#endif + +#endif /* _SOUTHBRIDGE_AMD_PI_HUDSON_SMI_H */ diff --git a/src/southbridge/amd/pi/hudson/smi_util.c b/src/southbridge/amd/pi/hudson/smi_util.c new file mode 100644 index 0000000..6076cd4 --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smi_util.c @@ -0,0 +1,79 @@ +/* + * SMM utilities used in both SMM and normal mode + * + * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com + * Subject to the GNU GPL v2, or (at your option) any later version. + */ + +#include "smi.h" + +#include <console/console.h> + +#define HUDSON_SMI_ACPI_COMMAND 75 + +static void configure_smi(uint8_t smi_num, uint8_t mode) +{ + uint8_t reg32_offset, bit_offset; + uint32_t reg32; + + /* SMI sources range from [0:149] */ + if (smi_num > 149) { + printk(BIOS_WARNING, "BUG: Invalid SMI: %u\n", smi_num); + return; + } + + /* 16 sources per register, 2 bits per source; registers are 4 bytes */ + reg32_offset = (smi_num / 16) * 4; + bit_offset = (smi_num % 16) * 2; + + reg32 = smi_read32(SMI_REG_CONTROL0 + reg32_offset); + reg32 &= ~(0x3 << (bit_offset)); + reg32 |= (mode & 0x3) << bit_offset; + smi_write32(SMI_REG_CONTROL0 + reg32_offset, reg32); +} + +/** + * Configure generation of interrupts for given GEVENT pin + * + * @param gevent The GEVENT pin number. Valid values are 0 thru 23 + * @param mode The type of event this pin should generate. Note that only + * SMI_MODE_SMI generates an SMI. SMI_MODE_DISABLE disables events. + * @param level SMI_LVL_LOW or SMI_LVL_HIGH + */ +void hudson_configure_gevent_smi(uint8_t gevent, uint8_t mode, uint8_t level) +{ + uint32_t reg32; + /* GEVENT pins range from [0:23] */ + if (gevent > 23) { + printk(BIOS_WARNING, "BUG: Invalid GEVENT: %u\n", gevent); + return; + } + + /* SMI0 source is GEVENT0 and so on */ + configure_smi(gevent, mode); + + /* And set set the trigger level */ + reg32 = smi_read32(SMI_REG_SMITRIG0); + reg32 &= ~(1 << gevent); + reg32 |= (level & 0x1) << gevent; + smi_write32(SMI_REG_SMITRIG0, reg32); +} + +/** Disable events from given GEVENT pin */ +void hudson_disable_gevent_smi(uint8_t gevent) +{ + /* GEVENT pins range from [0:23] */ + if (gevent > 23) { + printk(BIOS_WARNING, "BUG: Invalid GEVENT: %u\n", gevent); + return; + } + + /* SMI0 source is GEVENT0 and so on */ + configure_smi(gevent, SMI_MODE_DISABLE); +} + +/** Enable SMIs on writes to ACPI SMI command port */ +void hudson_enable_acpi_cmd_smi(void) +{ + configure_smi(HUDSON_SMI_ACPI_COMMAND, SMI_MODE_SMI); +} diff --git a/src/southbridge/amd/pi/hudson/smihandler.c b/src/southbridge/amd/pi/hudson/smihandler.c new file mode 100644 index 0000000..e762d0b --- /dev/null +++ b/src/southbridge/amd/pi/hudson/smihandler.c @@ -0,0 +1,136 @@ +/* + * SMI handler for Hudson southbridges + * + * Copyright (C) 2014 Alexandru Gagniuc mr.nuke.me@gmail.com + * Subject to the GNU GPL v2, or (at your option) any later version. + */ + +#include "hudson.h" +#include "smi.h" + +#include <console/console.h> +#include <cpu/x86/smm.h> +#include <delay.h> + +#define SMI_0x88_ACPI_COMMAND (1 << 11) + +enum smi_source { + SMI_SOURCE_SCI = (1 << 0), + SMI_SOURCE_GPE = (1 << 1), + SMI_SOURCE_0x84 = (1 << 2), + SMI_SOURCE_0x88 = (1 << 3), + SMI_SOURCE_IRQ_TRAP = (1 << 4), + SMI_SOURCE_0x90 = (1 << 5) +}; + +static void hudson_apmc_smi_handler(void) +{ + u32 reg32; + const uint8_t cmd = inb(ACPI_SMI_CTL_PORT); + + switch (cmd) { + case ACPI_SMI_CMD_ENABLE: + reg32 = inl(ACPI_PM1_CNT_BLK); + reg32 |= (1 << 0); /* SCI_EN */ + outl(reg32, ACPI_PM1_CNT_BLK); + break; + case ACPI_SMI_CMD_DISABLE: + reg32 = inl(ACPI_PM1_CNT_BLK); + reg32 &= ~(1 << 0); /* clear SCI_EN */ + outl(ACPI_PM1_CNT_BLK, reg32); + break; + } + + if (mainboard_smi_apmc) + mainboard_smi_apmc(cmd); +} + +int southbridge_io_trap_handler(int smif) +{ + return 0; +} + +static void process_smi_sci(void) +{ + const uint32_t status = smi_read32(0x10); + + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x10, status); +} + +static void process_gpe_smi(void) +{ + const uint32_t status = smi_read32(0x80); + const uint32_t gevent_mask = (1 << 24) - 1; + + /* Only Bits [23:0] indicate GEVENT SMIs. */ + if (status & gevent_mask) { + /* A GEVENT SMI occured */ + if (mainboard_smi_gpi) + mainboard_smi_gpi(status & gevent_mask); + } + + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x80, status); +} + +static void process_smi_0x84(void) +{ + const uint32_t status = smi_read32(0x84); + + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x84, status); +} + +static void process_smi_0x88(void) +{ + const uint32_t status = smi_read32(0x88); + + if (status & SMI_0x88_ACPI_COMMAND) { + /* Command received via ACPI SMI command port */ + hudson_apmc_smi_handler(); + } + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x88, status); +} + +static void process_smi_0x8c(void) +{ + const uint32_t status = smi_read32(0x8c); + + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x8c, status); +} + +static void process_smi_0x90(void) +{ + const uint32_t status = smi_read32(0x90); + + /* Clear events to prevent re-entering SMI if event isn't handled */ + smi_write32(0x90, status); +} + +void southbridge_smi_handler(unsigned int node, smm_state_save_area_t *state_save) +{ + const uint16_t smi_src = smi_read16(0x94); + + if (smi_src & SMI_SOURCE_SCI) + process_smi_sci(); + if (smi_src & SMI_SOURCE_GPE) + process_gpe_smi(); + if (smi_src & SMI_SOURCE_0x84) + process_smi_0x84(); + if (smi_src & SMI_SOURCE_0x88) + process_smi_0x88(); + if (smi_src & SMI_SOURCE_IRQ_TRAP) + process_smi_0x8c(); + if (smi_src & SMI_SOURCE_0x90) + process_smi_0x90(); +} + +void southbridge_smi_set_eos(void) +{ + uint32_t reg = smi_read32(SMI_REG_SMITRIG0); + reg |= SMITRG0_EOS; + smi_write32(SMI_REG_SMITRIG0, reg); +} diff --git a/src/southbridge/amd/pi/hudson/usb.c b/src/southbridge/amd/pi/hudson/usb.c new file mode 100644 index 0000000..36eff6e --- /dev/null +++ b/src/southbridge/amd/pi/hudson/usb.c @@ -0,0 +1,100 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2010 Advanced Micro Devices, Inc. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +#include <console/console.h> +#include <device/device.h> +#include <device/pci.h> +#include <device/pci_ids.h> +#include <device/pci_ops.h> +#include <device/pci_ehci.h> +#include <arch/io.h> +#include "hudson.h" + +static struct pci_operations lops_pci = { + .set_subsystem = pci_dev_set_subsystem, +}; + +static void usb_init(struct device *dev) +{ +} + +static struct device_operations usb_ops = { + .read_resources = pci_ehci_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = usb_init, + .scan_bus = 0, + .ops_pci = &lops_pci, +}; + +static const struct pci_driver usb_0_driver __pci_driver = { + .ops = &usb_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_USB_18_0, +}; +static const struct pci_driver usb_1_driver __pci_driver = { + .ops = &usb_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_USB_18_2, +}; + +/* the pci id of usb ctrl 0 and 1 are the same. */ +/* + * static const struct pci_driver usb_3_driver __pci_driver = { + * .ops = &usb_ops, + * .vendor = PCI_VENDOR_ID_AMD, + * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_0, + * }; + * static const struct pci_driver usb_4_driver __pci_driver = { + * .ops = &usb_ops, + * .vendor = PCI_VENDOR_ID_AMD, + * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_1, + * }; + */ + +static const struct pci_driver usb_4_driver __pci_driver = { + .ops = &usb_ops, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_SB900_USB_20_5, +}; + +/* +static struct device_operations usb_ops2 = { + .read_resources = pci_ehci_read_resources, + .set_resources = pci_dev_set_resources, + .enable_resources = pci_dev_enable_resources, + .init = usb_init2, + .scan_bus = 0, + .ops_pci = &lops_pci, +}; +*/ +/* +static const struct pci_driver usb_5_driver __pci_driver = { + .ops = &usb_ops2, + .vendor = PCI_VENDOR_ID_AMD, + .device = PCI_DEVICE_ID_ATI_HUDSON_USB_18_2, +}; +*/ +/* + * static const struct pci_driver usb_5_driver __pci_driver = { + * .ops = &usb_ops2, + * .vendor = PCI_VENDOR_ID_AMD, + * .device = PCI_DEVICE_ID_ATI_HUDSON_USB_19_2, + * }; + */ diff --git a/src/vendorcode/amd/pi/00730F01/Makefile.inc b/src/vendorcode/amd/pi/00730F01/Makefile.inc index 72c71d4..a302e33 100644 --- a/src/vendorcode/amd/pi/00730F01/Makefile.inc +++ b/src/vendorcode/amd/pi/00730F01/Makefile.inc @@ -47,7 +47,7 @@ AGESA_INC += -I$(AGESA_ROOT)/Proc/CPU/Feature AGESA_INC += -I$(AGESA_ROOT)/Proc/Fch AGESA_INC += -I$(AGESA_ROOT)/Proc/Fch/Common
-AGESA_INC += -I$(src)/southbridge/amd/pi/avalon +AGESA_INC += -I$(src)/southbridge/amd/pi/hudson
AGESA_INC += -I$(src)/arch/x86/include AGESA_INC += -I$(src)/include
