Felix Singer has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83253?usp=email )
Change subject: tgl mainboards: Move PCIe root port settings into their device scope ......................................................................
Change-Id: I110cc95d536cb0fd3b5db85b84cca7a96e31401c Signed-off-by: Felix Singer felixsinger@posteo.net Reviewed-on: https://review.coreboot.org/c/coreboot/+/83253 Reviewed-by: Matt DeVillier matt.devillier@gmail.com Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/volteer/variants/baseboard/devicetree.cb M src/mainboard/google/volteer/variants/chronicler/overridetree.cb M src/mainboard/google/volteer/variants/elemi/overridetree.cb M src/mainboard/google/volteer/variants/voema/overridetree.cb M src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb M src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb 6 files changed, 92 insertions(+), 95 deletions(-)
Approvals: Matt DeVillier: Looks good to me, approved build bot (Jenkins): Verified
diff --git a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb index 4775b0f..5dfc69c 100644 --- a/src/mainboard/google/volteer/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/volteer/variants/baseboard/devicetree.cb @@ -93,29 +93,6 @@ register "tcss_ports[0]" = "TCSS_PORT_DEFAULT(OC3)" register "tcss_ports[1]" = "TCSS_PORT_DEFAULT(OC0)"
- # NVMe PCIE 9 using clk 0 - register "PcieRpLtrEnable[8]" = "1" - register "PcieClkSrcUsage[0]" = "8" - register "PcieClkSrcClkReq[0]" = "0" - register "PcieRpSlotImplemented[8]" = "1" - - # Optane PCIE 11 using clk 0 - register "PcieRpLtrEnable[10]" = "1" - register "HybridStorageMode" = "0" - register "PcieRpSlotImplemented[10]" = "1" - - # SD Card PCIE 8 using clk 3 - register "PcieRpLtrEnable[7]" = "1" - register "PcieRpHotPlug[7]" = "1" - register "PcieClkSrcUsage[3]" = "7" - register "PcieClkSrcClkReq[3]" = "3" - - # WLAN PCIE 7 using clk 1 - register "PcieRpLtrEnable[6]" = "1" - register "PcieClkSrcUsage[1]" = "6" - register "PcieClkSrcClkReq[1]" = "1" - register "PcieRpSlotImplemented[6]" = "1" - # Mark SRCCLKREQ pins as unused that are routed for a Non-Clkreq functionality register "PcieClkSrcUsage[2]" = "PCIE_CLK_NOTUSED" register "PcieClkSrcUsage[4]" = "PCIE_CLK_NOTUSED" @@ -450,8 +427,20 @@ register "SataPortsDevSlp[1]" = "1" register "SataPortsEnableDitoConfig[1]" = "1" end - device ref pcie_rp7 on end + device ref pcie_rp7 on + # WLAN PCIE 7 using clk 1 + register "PcieRpLtrEnable[6]" = "1" + register "PcieClkSrcUsage[1]" = "6" + register "PcieClkSrcClkReq[1]" = "1" + register "PcieRpSlotImplemented[6]" = "1" + end device ref pcie_rp8 on + # SD Card PCIE 8 using clk 3 + register "PcieRpLtrEnable[7]" = "1" + register "PcieRpHotPlug[7]" = "1" + register "PcieClkSrcUsage[3]" = "7" + register "PcieClkSrcClkReq[3]" = "3" + probe DB_SD SD_GL9755S probe DB_SD SD_RTS5261 probe DB_SD SD_RTS5227S @@ -477,8 +466,19 @@ end end end - device ref pcie_rp9 on end - device ref pcie_rp11 on end + device ref pcie_rp9 on + # NVMe PCIE 9 using clk 0 + register "PcieRpLtrEnable[8]" = "1" + register "PcieClkSrcUsage[0]" = "8" + register "PcieClkSrcClkReq[0]" = "0" + register "PcieRpSlotImplemented[8]" = "1" + end + device ref pcie_rp11 on + # Optane PCIE 11 using clk 0 + register "PcieRpLtrEnable[10]" = "1" + register "HybridStorageMode" = "0" + register "PcieRpSlotImplemented[10]" = "1" + end device ref uart0 on end device ref gspi0 on chip drivers/spi/acpi diff --git a/src/mainboard/google/volteer/variants/chronicler/overridetree.cb b/src/mainboard/google/volteer/variants/chronicler/overridetree.cb index fc5d6ab..09fc980 100644 --- a/src/mainboard/google/volteer/variants/chronicler/overridetree.cb +++ b/src/mainboard/google/volteer/variants/chronicler/overridetree.cb @@ -5,12 +5,6 @@ register "DdiPort2Hpd" = "0" register "typec_aux_bias_pads[0]" = "{.pad_auxp_dc = GPP_E10, .pad_auxn_dc = GPP_E13}"
- # EMMC PCIE 5 using clk 5 - register "PcieRpLtrEnable[4]" = "1" - register "PcieRpHotPlug[4]" = "1" - register "PcieClkSrcUsage[5]" = "4" - register "PcieClkSrcClkReq[5]" = "5" - #+-------------------+---------------------------+ #| Field | Value | #+-------------------+---------------------------+ @@ -274,7 +268,13 @@ device generic 0 on end end end - device ref pcie_rp5 on end + device ref pcie_rp5 on + # EMMC PCIE 5 using clk 5 + register "PcieRpLtrEnable[4]" = "1" + register "PcieRpHotPlug[4]" = "1" + register "PcieClkSrcUsage[5]" = "4" + register "PcieClkSrcClkReq[5]" = "5" + end device ref pmc hidden # The pmc_mux chip driver is a placeholder for the # PMC.MUX device in the ACPI hierarchy. diff --git a/src/mainboard/google/volteer/variants/elemi/overridetree.cb b/src/mainboard/google/volteer/variants/elemi/overridetree.cb index 5eef9ef..7fa38bf 100644 --- a/src/mainboard/google/volteer/variants/elemi/overridetree.cb +++ b/src/mainboard/google/volteer/variants/elemi/overridetree.cb @@ -5,12 +5,6 @@ register "DdiPort2Hpd" = "0" register "typec_aux_bias_pads[0]" = "{.pad_auxp_dc = GPP_E10, .pad_auxn_dc = GPP_E13}"
- # EMMC PCIE 5 using clk 5 - register "PcieRpLtrEnable[4]" = "1" - register "PcieRpHotPlug[4]" = "1" - register "PcieClkSrcUsage[5]" = "4" - register "PcieClkSrcClkReq[5]" = "5" - #+-------------------+---------------------------+ #| Field | Value | #+-------------------+---------------------------+ @@ -275,7 +269,13 @@ device generic 0 on end end end - device ref pcie_rp5 on end + device ref pcie_rp5 on + # EMMC PCIE 5 using clk 5 + register "PcieRpLtrEnable[4]" = "1" + register "PcieRpHotPlug[4]" = "1" + register "PcieClkSrcUsage[5]" = "4" + register "PcieClkSrcClkReq[5]" = "5" + end device ref pmc hidden # The pmc_mux chip driver is a placeholder for the # PMC.MUX device in the ACPI hierarchy. diff --git a/src/mainboard/google/volteer/variants/voema/overridetree.cb b/src/mainboard/google/volteer/variants/voema/overridetree.cb index 97160ee..d895b1a 100644 --- a/src/mainboard/google/volteer/variants/voema/overridetree.cb +++ b/src/mainboard/google/volteer/variants/voema/overridetree.cb @@ -8,16 +8,6 @@ register "TcssAuxOri" = "1" register "typec_aux_bias_pads[0]" = "{.pad_auxp_dc = GPP_E10, .pad_auxn_dc = GPP_E13}"
- # Disable WLAN PCIE 7 - register "PcieRpLtrEnable[6]" = "0" - register "PcieClkSrcUsage[1]" = "PCIE_CLK_NOTUSED" - register "PcieRpSlotImplemented[6]" = "1" - - # Disable SD Card PCIE 8 - register "PcieRpLtrEnable[7]" = "0" - register "PcieRpHotPlug[7]" = "0" - register "PcieClkSrcUsage[3]" = "PCIE_CLK_NOTUSED" - device domain 0 on device ref ipu on end # IPU device ref i2c0 on @@ -97,8 +87,18 @@ probe AUDIO MAX98360_ALC5682I_I2S probe AUDIO RT1011_ALC5682I_I2S end - device ref pcie_rp7 off end + + device ref pcie_rp7 off + # Disable WLAN PCIE 7 + register "PcieRpLtrEnable[6]" = "0" + register "PcieClkSrcUsage[1]" = "PCIE_CLK_NOTUSED" + register "PcieRpSlotImplemented[6]" = "1" + end device ref pcie_rp8 off + # Disable SD Card PCIE 8 + register "PcieRpLtrEnable[7]" = "0" + register "PcieRpHotPlug[7]" = "0" + register "PcieClkSrcUsage[3]" = "PCIE_CLK_NOTUSED" # override-devicetree rules say it's only # the same device if it has the same probes: probe DB_SD SD_GL9755S diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb index 9c5fa6d..b82f583 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up3/devicetree.cb @@ -17,28 +17,9 @@ # CPU replacement check register "CpuReplacementCheck" = "1"
- register "PcieRpSlotImplemented[2]" = "1" - register "PcieRpSlotImplemented[3]" = "1" - register "PcieRpSlotImplemented[8]" = "1" - register "PcieRpSlotImplemented[10]" = "1" - - # Enable RP LTR - register "PcieRpLtrEnable[2]" = "1" - register "PcieRpLtrEnable[3]" = "1" - register "PcieRpLtrEnable[8]" = "1" - register "PcieRpLtrEnable[10]" = "1" - # Hybrid storage mode register "HybridStorageMode" = "1"
- register "PcieClkSrcClkReq[1]" = "1" - register "PcieClkSrcClkReq[2]" = "2" - register "PcieClkSrcClkReq[3]" = "3" - - register "PcieClkSrcUsage[1]" = "0x2" - register "PcieClkSrcUsage[2]" = "0x3" - register "PcieClkSrcUsage[3]" = "0x8" - # enabling EDP in PortA register "DdiPortAConfig" = "DDI_PORT_CFG_EDP"
@@ -260,8 +241,17 @@ device ref uart2 on end device ref pcie_rp1 off end device ref pcie_rp2 off end - device ref pcie_rp3 on end + device ref pcie_rp3 on + register "PcieRpSlotImplemented[2]" = "1" + register "PcieRpLtrEnable[2]" = "1" + register "PcieClkSrcUsage[1]" = "0x2" + register "PcieClkSrcClkReq[1]" = "1" + end device ref pcie_rp4 on + register "PcieRpSlotImplemented[3]" = "1" + register "PcieRpLtrEnable[3]" = "1" + register "PcieClkSrcUsage[2]" = "0x3" + register "PcieClkSrcClkReq[2]" = "2" chip soc/intel/common/block/pcie/rtd3 register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B17)" register "srcclk_pin" = "2" @@ -272,9 +262,17 @@ device ref pcie_rp6 off end device ref pcie_rp7 off end device ref pcie_rp8 off end - device ref pcie_rp9 on end + device ref pcie_rp9 on + register "PcieRpSlotImplemented[8]" = "1" + register "PcieRpLtrEnable[8]" = "1" + register "PcieClkSrcUsage[3]" = "0x8" + register "PcieClkSrcClkReq[3]" = "3" + end device ref pcie_rp10 off end - device ref pcie_rp11 on end + device ref pcie_rp11 on + register "PcieRpSlotImplemented[10]" = "1" + register "PcieRpLtrEnable[10]" = "1" + end device ref pcie_rp12 off end device ref uart0 off end device ref uart1 off end diff --git a/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb b/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb index 578eb98..51895b2 100644 --- a/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb +++ b/src/mainboard/intel/tglrvp/variants/tglrvp_up4/devicetree.cb @@ -17,28 +17,9 @@ # CPU replacement check register "CpuReplacementCheck" = "1"
- register "PcieRpSlotImplemented[2]" = "1" - register "PcieRpSlotImplemented[3]" = "1" - register "PcieRpSlotImplemented[8]" = "1" - register "PcieRpSlotImplemented[10]" = "1" - - # Enable PR LTR - register "PcieRpLtrEnable[2]" = "1" - register "PcieRpLtrEnable[3]" = "1" - register "PcieRpLtrEnable[8]" = "1" - register "PcieRpLtrEnable[10]" = "1" - # Hybrid storage mode register "HybridStorageMode" = "1"
@@ -262,8 +243,18 @@ device ref uart2 on end device ref pcie_rp1 off end device ref pcie_rp2 off end - device ref pcie_rp3 on end + device ref pcie_rp3 on + register "PcieRpSlotImplemented[2]" = "1" + register "PcieRpLtrEnable[2]" = "1" + register "PcieClkSrcUsage[1]" = "0x2" + register "PcieClkSrcClkReq[1]" = "1" + end + device ref pcie_rp4 on + register "PcieRpSlotImplemented[3]" = "1" + register "PcieRpLtrEnable[3]" = "1" + register "PcieClkSrcUsage[2]" = "0x3" + register "PcieClkSrcClkReq[2]" = "2" chip soc/intel/common/block/pcie/rtd3 register "reset_gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_LOW(GPP_B17)" register "srcclk_pin" = "2" @@ -274,9 +265,17 @@ device ref pcie_rp6 off end device ref pcie_rp7 off end device ref pcie_rp8 off end - device ref pcie_rp9 on end + device ref pcie_rp9 on + register "PcieRpSlotImplemented[8]" = "1" + register "PcieRpLtrEnable[8]" = "1" + register "PcieClkSrcUsage[3]" = "0x8" + register "PcieClkSrcClkReq[3]" = "3" + end device ref pcie_rp10 off end - device ref pcie_rp11 on end + device ref pcie_rp11 on + register "PcieRpSlotImplemented[10]" = "1" + register "PcieRpLtrEnable[10]" = "1" + end device ref pcie_rp12 off end device ref uart0 off end device ref uart1 off end
