Patrick Rudolph (siro@das-labor.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17609
commit be02eb3e0892515374a408049ed237f6617c2fdc Author: Patrick Rudolph siro@das-labor.org Date: Fri Nov 25 15:40:49 2016 +0100
[WIP]nb/intel/sandybridge/raminit: Add default values
Add 100 Mhz reflock default values for Ivybridge. Some values are extracted from MRC, those marked as guessed needs to be verified.
UNTESTED!
Change-Id: Ife7f899b5fea02827ad998e9e8ab10ecaef61191 Signed-off-by: Patrick Rudolph siro@das-labor.org --- src/northbridge/intel/sandybridge/raminit_ivy.c | 51 +++++++++++++++++++++++-- 1 file changed, 48 insertions(+), 3 deletions(-)
diff --git a/src/northbridge/intel/sandybridge/raminit_ivy.c b/src/northbridge/intel/sandybridge/raminit_ivy.c index 5026211..9719639 100644 --- a/src/northbridge/intel/sandybridge/raminit_ivy.c +++ b/src/northbridge/intel/sandybridge/raminit_ivy.c @@ -292,10 +292,28 @@ static void dram_timing(ramctr_timing * ctrl) u8 val; u32 val32;
- /* Maximum supported DDR3 frequency is 1066MHz (DDR3 2133) so make sure - * we cap it if we have faster DIMMs. + /* Maximum supported DDR3 frequency is 1400MHz (DDR3 2800). + * We cap it at 1200Mhz (DDR3 2400). * Then, align it to the closest JEDEC standard frequency */ - if (ctrl->tCK <= TCK_1066MHZ) { + if (ctrl->tCK <= TCK_1200MHZ) { + ctrl->tCK = TCK_1200MHZ; + ctrl->edge_offset[0] = 18; //XXX: guessed + ctrl->edge_offset[1] = 8; + ctrl->edge_offset[2] = 8; + ctrl->timC_offset[0] = 20; //XXX: guessed + ctrl->timC_offset[1] = 8; + ctrl->timC_offset[2] = 8; + ctrl->reg_320c_range_threshold = 10; + } else if (ctrl->tCK <= TCK_1100MHZ) { + ctrl->tCK = TCK_1100MHZ; + ctrl->edge_offset[0] = 17; //XXX: guessed + ctrl->edge_offset[1] = 7; + ctrl->edge_offset[2] = 7; + ctrl->timC_offset[0] = 19; //XXX: guessed + ctrl->timC_offset[1] = 7; + ctrl->timC_offset[2] = 7; + ctrl->reg_320c_range_threshold = 13; + } else if (ctrl->tCK <= TCK_1066MHZ) { ctrl->tCK = TCK_1066MHZ; ctrl->edge_offset[0] = 16; ctrl->edge_offset[1] = 7; @@ -304,6 +322,15 @@ static void dram_timing(ramctr_timing * ctrl) ctrl->timC_offset[1] = 7; ctrl->timC_offset[2] = 7; ctrl->reg_320c_range_threshold = 13; + } else if (ctrl->tCK <= TCK_1000MHZ) { + ctrl->tCK = TCK_1000MHZ; + ctrl->edge_offset[0] = 15; //XXX: guessed + ctrl->edge_offset[1] = 6; + ctrl->edge_offset[2] = 6; + ctrl->timC_offset[0] = 17; //XXX: guessed + ctrl->timC_offset[1] = 6; + ctrl->timC_offset[2] = 6; + ctrl->reg_320c_range_threshold = 13; } else if (ctrl->tCK <= TCK_933MHZ) { ctrl->tCK = TCK_933MHZ; ctrl->edge_offset[0] = 14; @@ -313,6 +340,15 @@ static void dram_timing(ramctr_timing * ctrl) ctrl->timC_offset[1] = 6; ctrl->timC_offset[2] = 6; ctrl->reg_320c_range_threshold = 15; + } else if (ctrl->tCK <= TCK_900MHZ) { + ctrl->tCK = TCK_900MHZ; + ctrl->edge_offset[0] = 14; //XXX: guessed + ctrl->edge_offset[1] = 6; + ctrl->edge_offset[2] = 6; + ctrl->timC_offset[0] = 15; //XXX: guessed + ctrl->timC_offset[1] = 6; + ctrl->timC_offset[2] = 6; + ctrl->reg_320c_range_threshold = 12; } else if (ctrl->tCK <= TCK_800MHZ) { ctrl->tCK = TCK_800MHZ; ctrl->edge_offset[0] = 13; @@ -322,6 +358,15 @@ static void dram_timing(ramctr_timing * ctrl) ctrl->timC_offset[1] = 5; ctrl->timC_offset[2] = 5; ctrl->reg_320c_range_threshold = 15; + } else if (ctrl->tCK <= TCK_700MHZ) { + ctrl->tCK = TCK_700MHZ; + ctrl->edge_offset[0] = 13; //XXX: guessed + ctrl->edge_offset[1] = 5; + ctrl->edge_offset[2] = 5; + ctrl->timC_offset[0] = 14; //XXX: guessed + ctrl->timC_offset[1] = 5; + ctrl->timC_offset[2] = 5; + ctrl->reg_320c_range_threshold = 16; } else if (ctrl->tCK <= TCK_666MHZ) { ctrl->tCK = TCK_666MHZ; ctrl->edge_offset[0] = 10;
