Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/81891?usp=email )
Change subject: mb/google/nissa: Create pujjoga variant ......................................................................
Create the pujjoga variant of nissa reference board by copying the template files to a new directory named for the variant.
Due to new_variant.py limitation that repo can no longer be used in inside, created this CL manually following google suggestion.
BUG=b:333839287 TEST=util/abuild/abuild -p none -t google/brya -x -a make sure the build includes GOOGLE_PUJJOGA
Change-Id: Ia8eb11eb65f9013e83abd45eefe7705d05b8697e Signed-off-by: Leo Chou leo.chou@lcfc.corp-partner.google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/81891 Reviewed-by: Subrata Banik subratabanik@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Eric Lai ericllai@google.com --- M src/mainboard/google/brya/Kconfig M src/mainboard/google/brya/Kconfig.name A src/mainboard/google/brya/variants/pujjoga/include/variant/ec.h A src/mainboard/google/brya/variants/pujjoga/include/variant/gpio.h A src/mainboard/google/brya/variants/pujjoga/memory/Makefile.mk A src/mainboard/google/brya/variants/pujjoga/memory/dram_id.generated.txt A src/mainboard/google/brya/variants/pujjoga/memory/mem_parts_used.txt A src/mainboard/google/brya/variants/pujjoga/overridetree.cb 8 files changed, 47 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Eric Lai: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index 7f6f7c7..77263e4 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -402,6 +402,9 @@ select BOARD_GOOGLE_BASEBOARD_NISSA select DRIVERS_GENERIC_GPIO_KEYS
+config BOARD_GOOGLE_PUJJOGA + select BOARD_GOOGLE_BASEBOARD_NISSA + config BOARD_GOOGLE_QUANDISO select BOARD_GOOGLE_BASEBOARD_NISSA select CHROMEOS_WIFI_SAR if CHROMEOS @@ -740,6 +743,7 @@ default "Yavilla" if BOARD_GOOGLE_YAVILLA default "Yavista" if BOARD_GOOGLE_YAVISTA default "Zydron" if BOARD_GOOGLE_ZYDRON + default "Pujjoga" if BOARD_GOOGLE_PUJJOGA
config VARIANT_DIR default "agah" if BOARD_GOOGLE_AGAH @@ -801,6 +805,7 @@ default "yavilla" if BOARD_GOOGLE_YAVILLA default "zydron" if BOARD_GOOGLE_ZYDRON default "yavista" if BOARD_GOOGLE_YAVISTA + default "pujjoga" if BOARD_GOOGLE_PUJJOGA
config VBOOT select VBOOT_EARLY_EC_SYNC if !BOARD_GOOGLE_BASEBOARD_NISSA diff --git a/src/mainboard/google/brya/Kconfig.name b/src/mainboard/google/brya/Kconfig.name index 0a22cad..fe8fcc9 100644 --- a/src/mainboard/google/brya/Kconfig.name +++ b/src/mainboard/google/brya/Kconfig.name @@ -178,3 +178,6 @@
config BOARD_GOOGLE_SUNDANCE bool "-> Sundance" + +config BOARD_GOOGLE_PUJJOGA + bool "-> Pujjoga" diff --git a/src/mainboard/google/brya/variants/pujjoga/include/variant/ec.h b/src/mainboard/google/brya/variants/pujjoga/include/variant/ec.h new file mode 100644 index 0000000..7a2a6ff --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/include/variant/ec.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef __VARIANT_EC_H__ +#define __VARIANT_EC_H__ + +#include <baseboard/ec.h> + +#endif diff --git a/src/mainboard/google/brya/variants/pujjoga/include/variant/gpio.h b/src/mainboard/google/brya/variants/pujjoga/include/variant/gpio.h new file mode 100644 index 0000000..c4fe342 --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/include/variant/gpio.h @@ -0,0 +1,8 @@ +/* SPDX-License-Identifier: GPL-2.0-or-later */ + +#ifndef VARIANT_GPIO_H +#define VARIANT_GPIO_H + +#include <baseboard/gpio.h> + +#endif diff --git a/src/mainboard/google/brya/variants/pujjoga/memory/Makefile.mk b/src/mainboard/google/brya/variants/pujjoga/memory/Makefile.mk new file mode 100644 index 0000000..eace2e4 --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/memory/Makefile.mk @@ -0,0 +1,5 @@ +# SPDX-License-Identifier: GPL-2.0-or-later +# This is an auto-generated file. Do not edit!! +# Add memory parts in mem_parts_used.txt and run spd_tools to regenerate. + +SPD_SOURCES = placeholder diff --git a/src/mainboard/google/brya/variants/pujjoga/memory/dram_id.generated.txt b/src/mainboard/google/brya/variants/pujjoga/memory/dram_id.generated.txt new file mode 100644 index 0000000..fa24790 --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/memory/dram_id.generated.txt @@ -0,0 +1 @@ +DRAM Part Name ID to assign diff --git a/src/mainboard/google/brya/variants/pujjoga/memory/mem_parts_used.txt b/src/mainboard/google/brya/variants/pujjoga/memory/mem_parts_used.txt new file mode 100644 index 0000000..2499005 --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/memory/mem_parts_used.txt @@ -0,0 +1,11 @@ +# This is a CSV file containing a list of memory parts used by this variant. +# One part per line with an optional fixed ID in column 2. +# Only include a fixed ID if it is required for legacy reasons! +# Generated IDs are dependent on the order of parts in this file, +# so new parts must always be added at the end of the file! +# +# Generate an updated Makefile.mk and dram_id.generated.txt by running the +# part_id_gen tool from util/spd_tools. +# See util/spd_tools/README.md for more details and instructions. + +# Part Name diff --git a/src/mainboard/google/brya/variants/pujjoga/overridetree.cb b/src/mainboard/google/brya/variants/pujjoga/overridetree.cb new file mode 100644 index 0000000..4f2c04a --- /dev/null +++ b/src/mainboard/google/brya/variants/pujjoga/overridetree.cb @@ -0,0 +1,6 @@ +chip soc/intel/alderlake + + device domain 0 on + end + +end
