Attention is currently required from: Anil Kumar K, Bora Guvendik, Cliff Huang, Hannah Williams.
Hello Anil Kumar K, Bora Guvendik, Subrata Banik, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84103?usp=email
Change subject: soc/intel/common/block/acpi: Add GPE1 blocks to ACPI FADT table ......................................................................
Use CONFIG_SOC_INTEL_COMMON_BLOCK_ACPI_GPE1 to enable GPE1 block. This will include GPE1 blocks to FADT with their info.
BUG=362310295 TEST=boot to OS and check that FADT table include GPE1. FADT should have: GPE1 Block Address : 00001810 GPE1 Block Length : 18 GPE1 Base Offset : 80
Signed-off-by: Cliff Huang cliff.huang@intel.com Change-Id: Ia6928c35b86f4a2243d58597b17b2a3a5f54271e --- M src/soc/intel/common/block/acpi/Kconfig M src/soc/intel/common/block/acpi/acpi.c 2 files changed, 24 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/84103/4
