Isaac Christensen (isaac.christensen@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6610
commit 1146d68f4ad9eb583d49e08cdd41fe74c91336ab Author: David Hendricks dhendrix@chromium.org Date: Fri Aug 23 15:47:06 2013 -0700
Exynos5420: Remove code for enabling read leveling
This patch intends to remove all code which enables hardware read leveling. We need to disable h/w read leveling because new ASV table is merged in kernel (which is based on the new characterization condition) and new characterization environment has h/w read leveling disabled, so we should also disable this. Also, disabling h/w read leveling improves the MIF LVcc value (LVcc value is the value at which DDR will fail to work properly), improve LVcc means we have enough voltage margin for MIF. When h/w leveling is enabled, we have almost zero volatge margin.
This was ported from: https://gerrit.chromium.org/gerrit/66070 Signed-off-by: David Hendricks dhendrix@chromium.org
Change-Id: Id0a2d77e6214325f226d51ae08464b39424cea83 Reviewed-on: https://chromium-review.googlesource.com/66994 Reviewed-by: Gabe Black gabeblack@chromium.org Commit-Queue: David Hendricks dhendrix@chromium.org Tested-by: David Hendricks dhendrix@chromium.org (cherry picked from commit d29add98f52876aaed4fee2b76edf6b4591e66e8) Signed-off-by: Isaac Christensen isaac.christensen@se-eng.com --- src/cpu/samsung/exynos5420/dmc_init_ddr3.c | 64 ------------------------------ 1 file changed, 64 deletions(-)
diff --git a/src/cpu/samsung/exynos5420/dmc_init_ddr3.c b/src/cpu/samsung/exynos5420/dmc_init_ddr3.c index 6c774a0..e236e99 100644 --- a/src/cpu/samsung/exynos5420/dmc_init_ddr3.c +++ b/src/cpu/samsung/exynos5420/dmc_init_ddr3.c @@ -323,67 +323,6 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int interleave_size, int reset) writel(val, &drex1->directcmd); writel(val | (0x1 << DIRECT_CMD_CHIP_SHIFT), &drex1->directcmd);
- /* Set Read DQ Calibration */ - val = (0x3 << DIRECT_CMD_BANK_SHIFT) | 0x4; - writel(val, &drex0->directcmd); - writel(val | (0x1 << DIRECT_CMD_CHIP_SHIFT), &drex0->directcmd); - writel(val, &drex1->directcmd); - writel(val | (0x1 << DIRECT_CMD_CHIP_SHIFT), &drex1->directcmd); - - - val = readl(&phy0_ctrl->phy_con1); - val |= READ_LEVELLING_DDR3; - writel(val, &phy0_ctrl->phy_con1); - val = readl(&phy1_ctrl->phy_con1); - val |= READ_LEVELLING_DDR3; - writel(val, &phy1_ctrl->phy_con1); - - val = readl(&phy0_ctrl->phy_con2); - val |= (RDLVL_EN | RDLVL_INCR_ADJ); - writel(val, &phy0_ctrl->phy_con2); - val = readl(&phy1_ctrl->phy_con2); - val |= (RDLVL_EN | RDLVL_INCR_ADJ); - writel(val, &phy1_ctrl->phy_con2); - - setbits_le32(&drex0->rdlvl_config, CTRL_RDLVL_DATA_ENABLE); - i = TIMEOUT; - while (((readl(&drex0->phystatus) & RDLVL_COMPLETE_CHO) != - RDLVL_COMPLETE_CHO) && (i > 0)) { - /* - * TODO(waihong): Comment on how long this take to - * timeout - */ - udelay(1); - i--; - } - if (!i) - return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; - clrbits_le32(&drex0->rdlvl_config, CTRL_RDLVL_DATA_ENABLE); - - setbits_le32(&drex1->rdlvl_config, CTRL_RDLVL_DATA_ENABLE); - i = TIMEOUT; - while (((readl(&drex1->phystatus) & RDLVL_COMPLETE_CHO) != - RDLVL_COMPLETE_CHO) && (i > 0)) { - /* - * TODO(waihong): Comment on how long this take to - * timeout - */ - udelay(1); - i--; - } - if (!i) - return SETUP_ERR_RDLV_COMPLETE_TIMEOUT; - clrbits_le32(&drex1->rdlvl_config, CTRL_RDLVL_DATA_ENABLE); - - val = (0x3 << DIRECT_CMD_BANK_SHIFT); - writel(val, &drex0->directcmd); - writel(val | (0x1 << DIRECT_CMD_CHIP_SHIFT), &drex0->directcmd); - writel(val, &drex1->directcmd); - writel(val | (0x1 << DIRECT_CMD_CHIP_SHIFT), &drex1->directcmd); - - update_reset_dll(drex0, DDR_MODE_DDR3); - update_reset_dll(drex1, DDR_MODE_DDR3); - /* Common Settings for Leveling */ val = PHY_CON12_RESET_VAL; writel((val + nLockW_phy0), &phy0_ctrl->phy_con12); @@ -391,9 +330,6 @@ int ddr3_mem_ctrl_init(struct mem_timings *mem, int interleave_size, int reset)
setbits_le32(&phy0_ctrl->phy_con2, DLL_DESKEW_EN); setbits_le32(&phy1_ctrl->phy_con2, DLL_DESKEW_EN); - - update_reset_dll(drex0, DDR_MODE_DDR3); - update_reset_dll(drex1, DDR_MODE_DDR3); }
/* Send PALL command */
