Attention is currently required from: Jamie Ryu, Subrata Banik, Eric Lai, Usha P.
Hello build bot (Jenkins), Jamie Ryu, Subrata Banik, Sridhar Siricilla, Eric Lai, Usha P,
https://review.coreboot.org/c/coreboot/+/71168
Change subject: mb/intel/mtlrvp: Configure USB devices for MTL-RVP ......................................................................
This patch adds OC configuration of USB devices for MTL-RVP as per MTL-RVP design specification,
USB 2.0 usb2_ports0 -> OC0 usb2_ports1 -> OC0 usb2_ports2 -> OC0 usb2_ports3 -> OC0 usb2_ports4 -> OC0 usb2_ports5 -> OC0 usb2_ports6 -> OC_SKIP usb2_ports7 -> OC_SKIP usb2_ports8 -> OC_SKIP usb2_ports9 -> OC_SKIP
USB 3.2 Gen 2x1 usb3_ports0 -> OC0 usb3_ports1 -> OC0
TCPx tcss_ports0 -> OC0 tcss_ports1 -> OC0 tcss_ports2 -> OC0 tcss_ports3 -> OC0
BUG=b:224325352 TEST=Able to build with the patch and boot the mtlrvp to chromeOS (on top of CB: 66190).
Signed-off-by: Harsha B R harsha.b.r@intel.com Change-Id: If1a0c31b7bf0f3fc06f039ad76b0cdd41f7cdd90 Signed-off-by: Jamie Ryu jamie.m.ryu@intel.com --- M src/mainboard/intel/mtlrvp/variants/baseboard/mtlrvp_p/devicetree.cb 1 file changed, 61 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/71168/5
