Nico Huber (nico.h@gmx.de) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11696
commit be9e6455f4b8d6b37af68ec663bd245f0e82af82 Author: Nico Huber nico.h@gmx.de Date: Mon Sep 21 20:11:47 2015 +0200
Revert "coreboot_table: don't add CMOS checksum twice."
This reverts commit e6606518243d9beda31693d40493b5f7a1a3e2e0.
After some discussion on IRC we decided to revert it as libpayload can only read the copy that was removed (and other users like nvramtool can only read the other copy). So we need both copies at this time.
Signed-off-by: Nico Huber nico.h@gmx.de Change-Id: I6cf6b2a1523d771bb52f3d5720b1b16ed4b348db --- src/lib/coreboot_table.c | 25 +++++++++++++++++++++++++ 1 file changed, 25 insertions(+)
diff --git a/src/lib/coreboot_table.c b/src/lib/coreboot_table.c index 6859bf2..35341ab 100644 --- a/src/lib/coreboot_table.c +++ b/src/lib/coreboot_table.c @@ -34,6 +34,9 @@ #include <cbmem.h> #include <bootmem.h> #include <spi_flash.h> +#if CONFIG_USE_OPTION_TABLE +#include <option_table.h> +#endif #if CONFIG_CHROMEOS #if CONFIG_HAVE_ACPI_TABLES #include <arch/acpi.h> @@ -333,6 +336,26 @@ static struct lb_mainboard *lb_mainboard(struct lb_header *header) return mainboard; }
+#if CONFIG_USE_OPTION_TABLE +static struct cmos_checksum *lb_cmos_checksum(struct lb_header *header) +{ + struct lb_record *rec; + struct cmos_checksum *cmos_checksum; + rec = lb_new_record(header); + cmos_checksum = (struct cmos_checksum *)rec; + cmos_checksum->tag = LB_TAG_OPTION_CHECKSUM; + + cmos_checksum->size = (sizeof(*cmos_checksum)); + + cmos_checksum->range_start = LB_CKS_RANGE_START * 8; + cmos_checksum->range_end = ( LB_CKS_RANGE_END * 8 ) + 7; + cmos_checksum->location = LB_CKS_LOC * 8; + cmos_checksum->type = CHECKSUM_PCBIOS; + + return cmos_checksum; +} +#endif + static void lb_strings(struct lb_header *header) { static const struct { @@ -435,6 +458,8 @@ unsigned long write_coreboot_table( struct lb_record *rec_dest = lb_new_record(head); /* Copy the option config table, it's already a lb_record... */ memcpy(rec_dest, option_table, option_table->size); + /* Create cmos checksum entry in coreboot table */ + lb_cmos_checksum(head); } else { printk(BIOS_ERR, "cmos_layout.bin could not be found!\n"); }
