Hello build bot (Jenkins), Furquan Shaikh, Patrick Georgi, Sridhar Siricilla, Rizwan Qureshi, Subrata Banik, Balaji Manigandan, Aamir Bohra, Patrick Rudolph, V Sowmya, Andrey Petrov, Jamie Ryu, Martin Roth, Tim Wawrzynczak,
https://review.coreboot.org/c/coreboot/+/35403
to look at the new patch set (#90).
Change subject: soc/intel/common/basecode: Implement CSE update flow ......................................................................
The following changes have been done in this patch: 1. Get the CSE partition info containing version of CSE RW using GET_BOOT_PARTITION_INFO HECI command 2. Get the me_rw.version from the currently selected RW slot. 3. If the version from the above 2 locations don't match start the update - If CSE's current boot partition is not RO, then * Set the CSE's next boot partition to RO using SET_BOOT_PARTITION HECI command. * Send global reset command to reset the system. - Enable HMRFPO (Host ME Region Flash Protection Override) operation mode using HMRFPO_ENABLE HECI command - Erase and Copy the CBFS CSE RW to CSE RW partition - Set the CSE's next boot partition to RW using SET_BOOT_PARTITION HECI command - Trigger global reset - The system should boot with the updated CSE RW partition.
TEST=Verified basic update flows on hatch and helios. BUG=b:111330995
Change-Id: I12f6bba3324069d65edabaccd234006b0840e700 Signed-off-by: Rizwan Qureshi rizwan.qureshi@intel.com Signed-off-by: Sridhar Siricilla sridhar.siricilla@intel.com Signed-off-by: V Sowmya v.sowmya@intel.com --- A Documentation/soc/intel/cse_fw_update/Layout_after.svg A Documentation/soc/intel/cse_fw_update/Layout_before.svg A Documentation/soc/intel/cse_fw_update/cse_fw_update.md M Documentation/soc/intel/index.md M src/soc/intel/common/block/cse/Kconfig M src/soc/intel/common/block/cse/cse_lite.c 6 files changed, 700 insertions(+), 21 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/03/35403/90
