Marc Jones has uploaded this change for review. ( https://review.coreboot.org/23547
Change subject: vendorcode/amd/pi/00670f00: Update headers to AGESA 1.3.0.9 ......................................................................
Update the shared AGESA headers to 1.3.0.9.
This depends on 3rdparty/blobs/pi/amd/00670F00/ binaries updated to the same version.
Change-Id: I783b7318e8273913f753b70f12bfe8b71274e27f Signed-off-by: Marc Jones marcj303@gmail.com --- M src/vendorcode/amd/pi/00670F00/AGESA.h M src/vendorcode/amd/pi/00670F00/AMD.h M src/vendorcode/amd/pi/00670F00/Proc/CPU/Table.h M src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuFamilyTranslation.h M src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuRegisters.h M src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchCommonCfg.h M src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchDef.h M src/vendorcode/amd/pi/00670F00/Proc/Fch/FchPlatform.h M src/vendorcode/amd/pi/00670F00/binaryPI/OptionsIds.h 9 files changed, 89 insertions(+), 77 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/23547/1
diff --git a/src/vendorcode/amd/pi/00670F00/AGESA.h b/src/vendorcode/amd/pi/00670F00/AGESA.h index 09a1680..17f6986 100644 --- a/src/vendorcode/amd/pi/00670F00/AGESA.h +++ b/src/vendorcode/amd/pi/00670F00/AGESA.h @@ -13,7 +13,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -1800,6 +1800,14 @@ } DEVICE_BLOCK_HEADER;
///=============================================================================== +/// CPU_VREF_OVERRIDE +/// +typedef struct _CPU_VREF_OVERRIDE{ + IN UINT8 VrefOp; ///< Operater to adjust VrefHspeed + IN UINT8 VrefOffset; ///< Offset to adjust VrefHspeed +} CPU_VREF_OVERRIDE; + +///=============================================================================== /// MEM_PARAMETER_STRUCT /// This data structure is used to pass wrapper parameters to the memory configuration code /// @@ -2116,6 +2124,8 @@ ///< @BldCfgItem{BLDCFG_DIMM_TYPE_DDR3_CAPABLE} IN UINT16 CustomVddioSupport; ///< CustomVddioSupport ///< @BldCfgItem{BLDCFG_CUSTOM_VDDIO_VOLTAGE} + IN CPU_VREF_OVERRIDE CpuVrefOverride[2][4]; ///< Structure to adjust VrefHspeed + ///< PerDct, Per MemPstate } MEM_PARAMETER_STRUCT;
@@ -2858,6 +2868,7 @@ IN GPIO_CONTROL *CfgFchGpioControl; ///< FCH GPIO Control IN BOOLEAN CfgFchRtcWorkAround; ///< FCH RTC Workaround IN BOOLEAN CfgFchUsbPortDisWorkAround; ///< FCH USB Workaround + IN BOOLEAN CfgFchAllowSpiInterfaceUpdate; ///< FchAllowSpiInterfaceUpdate - Fch Allow Spi Interface Update } FCH_PLATFORM_POLICY;
@@ -2993,7 +3004,7 @@ ///< Build-time customizable only - @BldCfgItem{BLDCFG_GFX_LVDS_SPREAD_SPECTRUM} IN UINT16 CfgLvdsSpreadSpectrumRate; ///< Lvds Spread Spectrum Rate ///< Build-time customizable only - @BldCfgItem{BLDCFG_GFX_LVDS_SPREAD_SPECTRUM_RATE} - IN FCH_PLATFORM_POLICY *FchBldCfg; ///< FCH platform build configuration policy + IN CONST FCH_PLATFORM_POLICY *FchBldCfg; ///< FCH platform build configuration policy
IN BOOLEAN CfgIommuSupport; ///< IOMMU support IN UINT8 CfgLvdsPowerOnSeqDigonToDe; ///< Panel initialization timing @@ -3087,6 +3098,7 @@ IN BOOLEAN CfgAcpPowerGating; ///< @BldCfgItem{BLDCFG_ACP_POWER_GATING} IN BOOLEAN CfgSmuOverclocking; ///< @BldCfgItem{BLDCFG_SMU_OVERCLOCKING} IN BOOLEAN CfgSmuCPUIdleActivityMonitorEnable; ///< @BldCfgItem{BLDCFG_CPU_IDLE_ACTIVITY_MONITOR} + IN UINT16 CfgBootUpDisplayDevice; ///< @BldCfgItem{BLDCFG_CFG_BOOT_UP_DISPLAY_DEVICE} IN BOOLEAN Reserved; ///< reserved... } BUILD_OPT_CFG;
@@ -3171,6 +3183,9 @@ IN BOOLEAN AcpPowerGating; ///< @BldCfgItem{BLDCFG_ACP_POWER_GATING} IN BOOLEAN SmuOverclocking; ///< @BldCfgItem{BLDCFG_SMU_OVERCLOCKING} IN BOOLEAN SmuCPUIdleActivityMonitorEnable; ///< @BldCfgItem{BLDCFG_CPU_IDLE_ACTIVITY_MONITOR} + IN UINT16 BootUpDisplayDevice; ///< The boot up display device selected. + ///< If equal to 0 default setting in VBIOS for boot up display devices + ///< @BldCfgItem{BLDCFG_CFG_BOOT_UP_DISPLAY_DEVICE} } PLATFORM_CONFIGURATION;
@@ -3404,6 +3419,7 @@ OUT UINT8 Channel:2; ///< Channel ID OUT UINT8 Dimm:2; ///< DIMM ID OUT UINT8 DimmPresent:1; ///< Dimm Present + OUT BOOLEAN Interleaved; ///< Interleaved; OUT UINT32 StartingAddr; ///< The physical address, in kilobytes, of a range ///< of memory mapped to the referenced Memory Device. OUT UINT32 EndingAddr; ///< The handle, or instance number, associated with diff --git a/src/vendorcode/amd/pi/00670F00/AMD.h b/src/vendorcode/amd/pi/00670F00/AMD.h index c4d56c9..483ee32 100644 --- a/src/vendorcode/amd/pi/00670F00/AMD.h +++ b/src/vendorcode/amd/pi/00670F00/AMD.h @@ -13,7 +13,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -45,12 +45,8 @@ #ifndef _AMD_H_ #define _AMD_H_
-#define Int16FromChar(a,b) (UINT16)((a) << 0 | (b) << 8) -#define Int32FromChar(a,b,c,d) (UINT32)((a) << 0 | (b) << 8 | (c) << 16 | (d) << 24) -#define Int64FromChar(a,b,c,d,e,f,g,h) ((UINT64)(Int32FromChar(a,b,c,d)<<32) | (UINT64)Int32FromChar(e,f,g,h)) - #define AGESA_REVISION "Arch2008" -#define AGESA_ID {'A', 'G', 'E', 'S', 'A', 0x00, 0x00, 0x00} +#define AGESA_ID "AGESA"
// // @@ -58,8 +54,11 @@ // // #define LAST_ENTRY 0xFFFFFFFFul +#define Int32FromChar(a,b,c,d) (UINT32)((a) << 0 | (b) << 8 | (c) << 16 | (d) << 24) #define IMAGE_SIGNATURE Int32FromChar ('$', 'A', 'M', 'D') +/* coreboot binaryPI - start */ #define MODULE_SIGNATURE Int32FromChar ('$', 'M', 'O', 'D') +/* coreboot binaryPI - end */ #define IOCF8 0xCF8 #define IOCFC 0xCFC
@@ -130,37 +129,27 @@ /// AGESA struct name typedef enum { // AGESA BASIC FUNCTIONS - AMD_INIT_RECOVERY = 0x00021000, ///< AmdInitRecovery entry point handle - AMD_CREATE_STRUCT = 0x00022000, ///< AmdCreateStruct handle - AMD_INIT_EARLY = 0x00023000, ///< AmdInitEarly entry point handle - AMD_INIT_ENV = 0x00024000, ///< AmdInitEnv entry point handle - AMD_INIT_LATE = 0x00025000, ///< AmdInitLate entry point handle - AMD_INIT_MID = 0x00026000, ///< AmdInitMid entry point handle - AMD_INIT_POST = 0x00027000, ///< AmdInitPost entry point handle - AMD_INIT_RESET = 0x00028000, ///< AmdInitReset entry point handle - AMD_INIT_RESUME = 0x00029000, ///< AmdInitResume entry point handle - AMD_RELEASE_STRUCT = 0x0002A000, ///< AmdReleaseStruct handle - AMD_S3LATE_RESTORE = 0x0002B000, ///< AmdS3LateRestore entry point handle - AMD_GET_APIC_ID = 0x0002C000, ///< AmdGetApicId entry point handle - AMD_GET_PCI_ADDRESS = 0x0002D000, ///< AmdGetPciAddress entry point handle - AMD_IDENTIFY_CORE = 0x0002E000, ///< AmdIdentifyCore general service handle - AMD_READ_EVENT_LOG = 0x0002F000, ///< AmdReadEventLog general service handle - AMD_GET_EXECACHE_SIZE = 0x00030000, ///< AmdGetAvailableExeCacheSize general service handle - AMD_LATE_RUN_AP_TASK = 0x00031000, ///< AmdLateRunApTask entry point handle - AMD_IDENTIFY_DIMMS = 0x00032000, ///< AmdIdentifyDimm general service handle - AMD_GET_2D_DATA_EYE = 0x00033000, ///< AmdGet2DDataEye general service handle - AMD_S3FINAL_RESTORE = 0x00034000, ///< AmdS3FinalRestore entry point handle - AMD_INIT_RTB = 0x00035000, ///< AmdInitRtb entry point handle - AMD_HEAP_ALLOCATE_BUFFER = 0x00038000, - AMD_HEAP_DEALLOCATE_BUFFER = 0x00039000, - FCH_INIT_RESET = 0x00040000, - FCH_INIT_ENV = 0x00041000, - FCH_INIT_MID = 0x00042000, - FCH_INIT_LATE = 0x00043000, - FCH_INIT_S3_EARLY_RESTORE = 0x00044000, - FCH_INIT_S3_LATE_RESTORE = 0x00045000, - AMD_SET_VALUE_invalid = 0x00081000, - AMD_GET_VALUE_invalid = 0x00082000 + AMD_INIT_RECOVERY = 0x00020000, ///< AmdInitRecovery entry point handle + AMD_CREATE_STRUCT, ///< AmdCreateStruct handle + AMD_INIT_EARLY, ///< AmdInitEarly entry point handle + AMD_INIT_ENV, ///< AmdInitEnv entry point handle + AMD_INIT_LATE, ///< AmdInitLate entry point handle + AMD_INIT_MID, ///< AmdInitMid entry point handle + AMD_INIT_POST, ///< AmdInitPost entry point handle + AMD_INIT_RESET, ///< AmdInitReset entry point handle + AMD_INIT_RESUME, ///< AmdInitResume entry point handle + AMD_RELEASE_STRUCT, ///< AmdReleaseStruct handle + AMD_S3LATE_RESTORE, ///< AmdS3LateRestore entry point handle + AMD_GET_APIC_ID, ///< AmdGetApicId entry point handle + AMD_GET_PCI_ADDRESS, ///< AmdGetPciAddress entry point handle + AMD_IDENTIFY_CORE, ///< AmdIdentifyCore general service handle + AMD_READ_EVENT_LOG, ///< AmdReadEventLog general service handle + AMD_GET_EXECACHE_SIZE, ///< AmdGetAvailableExeCacheSize general service handle + AMD_LATE_RUN_AP_TASK, ///< AmdLateRunApTask entry point handle + AMD_IDENTIFY_DIMMS, ///< AmdIdentifyDimm general service handle + AMD_GET_2D_DATA_EYE, ///< AmdGet2DDataEye general service handle + AMD_S3FINAL_RESTORE, ///< AmdS3FinalRestore entry point handle + AMD_INIT_RTB ///< AmdInitRtb entry point handle } AGESA_STRUCT_NAME;
/* ResetType constant values */ diff --git a/src/vendorcode/amd/pi/00670F00/Proc/CPU/Table.h b/src/vendorcode/amd/pi/00670F00/Proc/CPU/Table.h index 75169cb..1d53990 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/CPU/Table.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/CPU/Table.h @@ -14,7 +14,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -656,7 +656,7 @@ */ typedef struct { REGISTER_TABLE_TIME_POINT TimePoint; ///< Time point - CONST REGISTER_TABLE** TableList; ///< The table list. + CONST REGISTER_TABLE* CONST * CONST TableList; ///< The table list. } REGISTER_TABLE_AT_GIVEN_TP; /*------------------------------------------------------------------------------------------*/ /* diff --git a/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuFamilyTranslation.h b/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuFamilyTranslation.h index f4ffd49..9331cd1 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuFamilyTranslation.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuFamilyTranslation.h @@ -13,7 +13,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -164,7 +164,7 @@ * */ typedef AGESA_STATUS F_CPU_DISABLE_PSTATE ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN UINT8 StateNumber, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -185,7 +185,7 @@ * */ typedef AGESA_STATUS F_CPU_TRANSITION_PSTATE ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN UINT8 StateNumber, IN BOOLEAN WaitForChange, IN AMD_CONFIG_PARAMS *StdHeader @@ -210,7 +210,7 @@ * */ typedef BOOLEAN F_CPU_GET_IDD_MAX ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN UINT8 StateNumber, OUT UINT32 *ProcIddMax, IN AMD_CONFIG_PARAMS *StdHeader @@ -231,7 +231,7 @@ * */ typedef AGESA_STATUS F_CPU_GET_TSC_RATE ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES * FamilySpecificServices, OUT UINT32 *FreqInMHz, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -252,7 +252,7 @@ * @retval AGESA_SUCCESS FreqInMHz is valid. */ typedef AGESA_STATUS F_CPU_GET_NB_FREQ ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, OUT UINT32 *FreqInMHz, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -276,7 +276,7 @@ * @retval AGESA_STATUS Northbridge frequency is valid */ typedef AGESA_STATUS F_CPU_GET_MIN_MAX_NB_FREQ ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN PLATFORM_CONFIGURATION *PlatformConfig, IN PCI_ADDR *PciAddress, OUT UINT32 *MinFreqInMHz, @@ -306,7 +306,7 @@ * @retval FALSE NbPstate is disabled or invalid */ typedef BOOLEAN F_CPU_GET_NB_PSTATE_INFO ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN PLATFORM_CONFIGURATION *PlatformConfig, IN PCI_ADDR *PciAddress, IN UINT32 NbPstate, @@ -333,7 +333,7 @@ * */ typedef BOOLEAN F_CPU_IS_NBCOF_INIT_NEEDED ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN PCI_ADDR *PciAddress, OUT BOOLEAN *NbVidUpdateAll, IN AMD_CONFIG_PARAMS *StdHeader @@ -358,7 +358,7 @@ * */ typedef BOOLEAN F_CPU_GET_NB_IDD_MAX ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN UINT8 StateNumber, OUT UINT32 *NbIddMax, IN AMD_CONFIG_PARAMS *StdHeader @@ -381,7 +381,7 @@ * @retval FALSE The core was previously launched, or has a problem. */ typedef BOOLEAN F_CPU_AP_INITIAL_LAUNCH ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN UINT32 CoreNumber, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -401,7 +401,7 @@ * @return One-based number of physical cores on current processor */ typedef UINT8 F_CPU_NUMBER_OF_PHYSICAL_CORES ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN AMD_CONFIG_PARAMS *StdHeader );
@@ -420,7 +420,7 @@ * @return The AP's unique core number */ typedef UINT32 (F_CPU_GET_AP_CORE_NUMBER) ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN AMD_CONFIG_PARAMS *StdHeader );
@@ -449,7 +449,7 @@ * @retval CoreIdPositionOne Core Id is low */ typedef CORE_ID_POSITION F_CORE_ID_POSITION_IN_INITIAL_APIC_ID ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN AMD_CONFIG_PARAMS *StdHeader );
@@ -468,7 +468,7 @@ * */ typedef VOID (F_CPU_SET_WARM_RESET_FLAG) ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN AMD_CONFIG_PARAMS *StdHeader, IN WARM_RESET_REQUEST *Request ); @@ -488,7 +488,7 @@ * */ typedef VOID (F_CPU_GET_WARM_RESET_FLAG) ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN AMD_CONFIG_PARAMS *StdHeader, OUT WARM_RESET_REQUEST *Request ); @@ -509,7 +509,7 @@ * */ typedef VOID F_CPU_GET_FAMILY_SPECIFIC_ARRAY ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, OUT CONST VOID **FamilySpecificArray, OUT UINT8 *NumberOfElements, IN AMD_CONFIG_PARAMS *StdHeader @@ -530,7 +530,7 @@ * */ typedef AGESA_STATUS F_CPU_GET_PLATFORM_TYPE_SPECIFIC_INFO ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN OUT PLATFORM_FEATS *FeaturesUnion, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -552,7 +552,7 @@ * @retval FALSE The NB PState feature is not enabled. */ typedef BOOLEAN F_IS_NB_PSTATE_ENABLED ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, IN PLATFORM_CONFIGURATION *PlatformConfig, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -571,7 +571,7 @@ * */ typedef REGISTER_TABLE_AT_GIVEN_TP *F_GET_REGISTER_TABLE_LIST ( - IN CPU_SPECIFIC_SERVICES *FamilyServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilyServices, IN AMD_CONFIG_PARAMS *StdHeader ); /// Reference to a Method. @@ -590,7 +590,7 @@ * */ typedef F_FAM_SPECIFIC_WORKAROUND **F_GET_WORKAROUND_TABLE ( - IN CPU_SPECIFIC_SERVICES *FamilyServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilyServices, OUT UINT16 *NumberOfWorkaroundTableEntries, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -614,7 +614,7 @@ * */ typedef VOID F_PERFORM_EARLY_INIT_ON_CORE ( - IN CPU_SPECIFIC_SERVICES *FamilyServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilyServices, IN AMD_CPU_EARLY_PARAMS *EarlyParams, IN AMD_CONFIG_PARAMS *StdHeader ); @@ -644,7 +644,7 @@ * */ typedef VOID F_GET_EARLY_INIT_TABLE ( - IN CPU_SPECIFIC_SERVICES *FamilyServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilyServices, OUT CONST S_PERFORM_EARLY_INIT_ON_CORE **Table, IN AMD_CPU_EARLY_PARAMS *EarlyParams, IN AMD_CONFIG_PARAMS *StdHeader @@ -853,7 +853,7 @@ */ VOID GetEmptyArray ( - IN CPU_SPECIFIC_SERVICES *FamilySpecificServices, + IN CONST CPU_SPECIFIC_SERVICES *FamilySpecificServices, OUT CONST VOID **Empty, OUT UINT8 *NumberOfElements, IN AMD_CONFIG_PARAMS *StdHeader diff --git a/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuRegisters.h b/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuRegisters.h index 4d10b42..46906a8 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuRegisters.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/CPU/cpuRegisters.h @@ -14,7 +14,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -236,7 +236,7 @@ /// Logical CPU ID Table typedef struct { IN UINT32 Elements; ///< Number of Elements - IN CPU_LOGICAL_ID_XLAT *LogicalIdTable; ///< CPU Logical ID Transfer table Pointer + IN CONST CPU_LOGICAL_ID_XLAT *LogicalIdTable; ///< CPU Logical ID Transfer table Pointer } LOGICAL_ID_TABLE;
// MSRs diff --git a/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchCommonCfg.h b/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchCommonCfg.h index 46e5b17..21f73a3 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchCommonCfg.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchCommonCfg.h @@ -14,7 +14,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -937,6 +937,7 @@ UINT32 FchCpuId; ///< Saving CpuId for FCH Module. BOOLEAN NoneSioKbcSupport; ///< NoneSioKbcSupport - No KBC/SIO controller ( Turn on Inchip KBC emulation function ) FCH_CS FchCsSupport; ///< FCH Cs function structure + BOOLEAN FchAllowSpiInterfaceUpdate; ///< FchAllowSpiInterfaceUpdate - Fch Allow Spi Interface Update } FCH_MISC;
@@ -1405,7 +1406,7 @@ ///PTUSBTxStructure typedef struct { PT_USB31Tx USB31Tx[2]; ///< USB31Tx setting -PT_USB30Tx USB30Tx[3]; ///< USB30Tx setting +PT_USB30Tx USB30Tx[6]; ///< USB30Tx setting UINT8 USB20B2Tx00; ///< USB2.0 TX driving current, 7: largest By USB_HSDP/N[0] UINT8 USB20B2Tx05; ///< USB2.0 TX driving current, 7: largest By USB_HSDP/N[5] UINT8 USB20B3Tx1113; ///< USB2.0 TX driving current, 7: largest By USB_HSDP/N[13][11] diff --git a/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchDef.h b/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchDef.h index 45453a8..c80dc52 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchDef.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/Fch/Common/FchDef.h @@ -14,7 +14,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -81,6 +81,7 @@ BOOLEAN FchCheckCZ (IN AMD_CONFIG_PARAMS *StdHeader); BOOLEAN FchCheckPackageAM4 (IN AMD_CONFIG_PARAMS *StdHeader); UINT64 FchGetScratchFuse (IN AMD_CONFIG_PARAMS *StdHeader); +VOID FchInitResetRequest (IN AMD_CONFIG_PARAMS *StdHeader);
/// /// Fch Ab Routines diff --git a/src/vendorcode/amd/pi/00670F00/Proc/Fch/FchPlatform.h b/src/vendorcode/amd/pi/00670F00/Proc/Fch/FchPlatform.h index 304ed23..04784fe 100644 --- a/src/vendorcode/amd/pi/00670F00/Proc/Fch/FchPlatform.h +++ b/src/vendorcode/amd/pi/00670F00/Proc/Fch/FchPlatform.h @@ -14,7 +14,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2016, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -115,6 +115,6 @@ #include "FchBiosRamUsage.h" #include "AmdFch.h"
-extern BUILD_OPT_CFG UserOptions; +extern CONST BUILD_OPT_CFG UserOptions;
#endif // _FCH_PLATFORM_H_ diff --git a/src/vendorcode/amd/pi/00670F00/binaryPI/OptionsIds.h b/src/vendorcode/amd/pi/00670F00/binaryPI/OptionsIds.h index 016d822..5811eb0 100644 --- a/src/vendorcode/amd/pi/00670F00/binaryPI/OptionsIds.h +++ b/src/vendorcode/amd/pi/00670F00/binaryPI/OptionsIds.h @@ -13,7 +13,7 @@ */ /***************************************************************************** * - * Copyright (c) 2008 - 2015, Advanced Micro Devices, Inc. + * Copyright (c) 2008 - 2017, Advanced Micro Devices, Inc. * All rights reserved. * * Redistribution and use in source and binary forms, with or without @@ -87,6 +87,8 @@ * IDSOPT_PERF_ANALYSIS * IDSOPT_ASSERT_ENABLED * IDS_DEBUG_PORT + * IDS_DEBUG_PORT_SIZE_IN_BYTES + * IDS_DEBUG_TP_PREFIX * IDSOPT_CAR_CORRUPTION_CHECK_ENABLED * IDSOPT_DEBUG_CODE_ENABLED * IDSOPT_IDT_EXCEPTION_TRAP @@ -94,12 +96,10 @@ * **/
- - -//#include "Ids.h" - #define IDSOPT_ERROR_TRAP_ENABLED FALSE
+#define IDS_MMAP_SERIAL_PORT + #ifdef DEBUG #define IDSOPT_IDS_ENABLED TRUE //#define IDSOPT_CONTROL_ENABLED FALSE @@ -109,12 +109,17 @@ #undef IDS_DEBUG_PRINT_MASK #endif #define IDS_DEBUG_PRINT_MASK (GNB_TRACE_ALL | GFX_MISC | CPU_TRACE_ALL | MEM_STATUS | TOPO_TRACE_ALL | FCH_TRACE_ALL | MAIN_FLOW | IDS_TRACE_DEFAULT | TEST_POINT) +#ifdef IDS_MMAP_SERIAL_PORT +#define IDSOPT_SERIAL_PORT 0xfedc6000 +#else #define IDSOPT_SERIAL_PORT 0x3F8 +#endif #define IDSOPT_HEAP_CHECKING TRUE #define IDSOPT_TRACE_BLD_CFG TRUE #define IDSOPT_CAR_CORRUPTION_CHECK_ENABLED FALSE #define IDSOPT_DEBUG_CODE_ENABLED TRUE #define IDSOPT_C_OPTIMIZATION_DISABLED TRUE +//#define IDSOPT_ASSERT_ENABLED TRUE #else #define IDSOPT_IDS_ENABLED FALSE //#define IDSOPT_ERROR_TRAP_ENABLED FALSE
