Jan Philipp Groß has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/85756?usp=email )
Change subject: mb/asrock: Add Z87 Pro4 (Haswell) ......................................................................
This port was done via autoport and subsequent manual tweaking.
Working: - Haswell MRC.bin - All four DDR3/DDR3L DIMM slots - HDMI-Out Port - DVI-D Port - D-Sub Port - RJ-45 Gigabit LAN Port - All four USB 2.0 Ports - All four USB 3.1 Gen1 Ports - Vertical Type A USB 3.1 Gen1 (located next to RAM slots) - All six SATA3 6.0 Gb/s connectors - PCI Express 3.0 x16 slots (tested with AMD RX 550 dGPU) - PCI Express 2.0 x16 slot (tested with AMD RX 550 dGPU) - Both PCI Express 2.0 x1 slots (tested with TL-WDN4800 WiFi adapter) - HD Audio Jack (Audio output tested only) - Front Audio Jack (Audio output tested only)
not working: - Both USB 3.1 Gen1 headers (also not working on vendor firmware, possible hardware defect)
not (yet) tested: - IR header - COM Port header - USB 2.0 headers - PS/2 Mouse/Keyboard Port - HDMI-In Port - PCI slots
not (yet) working: - Software fan control: While the Nuvoton chip is correctly discovered, the numbering of the fan connectors is faulty, resulting in the wrong fan being controlled.
Change-Id: I2f01f2f25e0a4bcec10b075b574757250a5e5256 Signed-off-by: Jan Philipp Groß jeangrande@mailbox.org --- A src/mainboard/asrock/z87_pro4/Kconfig A src/mainboard/asrock/z87_pro4/Kconfig.name A src/mainboard/asrock/z87_pro4/Makefile.mk A src/mainboard/asrock/z87_pro4/acpi/ec.asl A src/mainboard/asrock/z87_pro4/acpi/platform.asl A src/mainboard/asrock/z87_pro4/acpi/superio.asl A src/mainboard/asrock/z87_pro4/board_info.txt A src/mainboard/asrock/z87_pro4/bootblock.c A src/mainboard/asrock/z87_pro4/data.vbt A src/mainboard/asrock/z87_pro4/devicetree.cb A src/mainboard/asrock/z87_pro4/dsdt.asl A src/mainboard/asrock/z87_pro4/gma-mainboard.ads A src/mainboard/asrock/z87_pro4/gpio.c A src/mainboard/asrock/z87_pro4/hda_verb.c A src/mainboard/asrock/z87_pro4/romstage.c 15 files changed, 531 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/56/85756/2
