Venkateswarlu V Vinjamuri has uploaded this change for review. ( https://review.coreboot.org/25570
Change subject: soc/intel/apollolake: Configure PCIe for APL/GLK WiFi ......................................................................
Creates a common asl include file for PCIe power state methods. This allows ports to be enabled independently.
Configures PCIe device ID's for APL/GLK. APL uses root port 1 (PCIe ID 14.0) and GLK Octopus uses root port 3 (PCIe 13.0) for discrete PCIe wifi card.
BUG=None BRANCH=None TEST=use Stone Peak discrete wifi card and test s0ix.
Change-Id: Idd1e6d502f3e7ecc2050a6c19bfe7bf99b163985 Signed-off-by: Venkateswarlu Vinjamuri venkateswarlu.v.vinjamuri@intel.com --- M src/soc/intel/apollolake/acpi/pcie.asl A src/soc/intel/apollolake/acpi/pcie_port.asl M src/soc/intel/apollolake/chip.c 3 files changed, 136 insertions(+), 105 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/70/25570/1
diff --git a/src/soc/intel/apollolake/acpi/pcie.asl b/src/soc/intel/apollolake/acpi/pcie.asl index 050f2f0..03c0c63 100644 --- a/src/soc/intel/apollolake/acpi/pcie.asl +++ b/src/soc/intel/apollolake/acpi/pcie.asl @@ -13,114 +13,20 @@ * GNU General Public License for more details. */
+/* PCIe Ports */ + Device (RP01) { + Name (_ADR, 0x00130000) + Name (_DDN, "PCIe-A 0") + + #include "pcie_port.asl" +} + +Device (RP02) +{ Name (_ADR, 0x00140000) Name (_DDN, "PCIe-B 0") - Name (PDST, 0) /* present Detect status */
- /* lowest D-state supported by - * PCIe root port during S0 state - */ - Name (_S0W, 4) - - /* Dynamic Opregion needed to access registers - * when the controller is in D3 cold - */ - OperationRegion (PX01, PCI_Config, 0x00, 0xFF) - Field (PX01, AnyAcc, NoLock, Preserve) - { - Offset(0x5A), - , 6, - PDS, 1, /* 6, Presence detect Change */ - Offset(0xE2), /* RPPGEN - Root Port Power Gating Enable */ - , 2, - L23E, 1, /* 2, L23_Rdy Entry Request (L23ER) */ - L23R, 1, /* 3, L23_Rdy to Detect Transition (L23R2DT) */ - Offset(0xF4), /* BLKPLLEN */ - , 10, - BPLL, 1, - } - - OperationRegion (PX02, PCI_Config, 0x338, 0x4) - Field (PX02, AnyAcc, NoLock, Preserve) - { - , 26, - BDQA, 1 /* BLKDQDA */ - } - - PowerResource (PXP, 0, 0) - { - /* Define the PowerResource for PCIe slot */ - Method (_STA, 0, Serialized) - { - Store (PDS, PDST) - If (LEqual (PDS, 1)) { - Return (0xf) - } Else { - Return (0) - } - } - - Method (_ON, 0, Serialized) - { - If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { - /* Enter this condition if device - * is connected - */ - - /* De-assert PERST */ - _SB.PCI0.PRDA (\PRT0) - - Store (0, BDQA) /* Set BLKDQDA to 0 */ - Store (0, BPLL) /* Set BLKPLLEN to 0 */ - - /* Set L23_Rdy to Detect Transition - * (L23R2DT) - */ - Store (1, L23R) - Sleep (16) - Store (0, Local0) - - /* Delay for transition Detect - * and link to train - */ - While (L23R) { - If (Lgreater (Local0, 4)) { - Break - } - Sleep (16) - Increment (Local0) - } - } /* End PDS condition check */ - } - - Method (_OFF, 0, Serialized) - { - /* Set L23_Rdy Entry Request (L23ER) */ - If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { - /* enter this condition if device - * is connected - */ - Store (1, L23E) - Sleep (16) - Store (0, Local0) - While (L23E) { - If (Lgreater (Local0, 4)) { - Break - } - Sleep (16) - Increment (Local0) - } - Store (1, BDQA) /* Set BLKDQDA to 1 */ - Store (1, BPLL) /* Set BLKPLLEN to 1 */ - - /* Assert PERST */ - _SB.PCI0.PRAS (\PRT0) - } /* End PDS condition check */ - } /* End of Method_OFF */ - } /* End PXP */ - - Name(_PR0, Package() { PXP }) - Name(_PR3, Package() { PXP }) + #include "pcie_port.asl" } diff --git a/src/soc/intel/apollolake/acpi/pcie_port.asl b/src/soc/intel/apollolake/acpi/pcie_port.asl new file mode 100644 index 0000000..ea8bfe3 --- /dev/null +++ b/src/soc/intel/apollolake/acpi/pcie_port.asl @@ -0,0 +1,123 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2016 Intel Corporation. + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* Include in each PCIe Root Port device */ + +/* lowest D-state supported by + * PCIe root port during S0 state + */ +Name (_S0W, 4) + +Name (PDST, 0) /* present Detect status */ + +/* Dynamic Opregion needed to access registers + * when the controller is in D3 cold + */ +OperationRegion (PX01, PCI_Config, 0x00, 0xFF) +Field (PX01, AnyAcc, NoLock, Preserve) +{ + Offset(0x5A), + , 6, + PDS, 1, /* 6, Presence detect Change */ + Offset(0xE2), /* RPPGEN - Root Port Power Gating Enable */ + , 2, + L23E, 1, /* 2, L23_Rdy Entry Request (L23ER) */ + L23R, 1, /* 3, L23_Rdy to Detect Transition (L23R2DT) */ + Offset(0xF4), /* BLKPLLEN */ + , 10, + BPLL, 1, +} + +OperationRegion (PX02, PCI_Config, 0x338, 0x4) +Field (PX02, AnyAcc, NoLock, Preserve) +{ + , 26, + BDQA, 1 /* BLKDQDA */ +} + +PowerResource (PXP, 0, 0) +{ + /* Define the PowerResource for PCIe slot */ + Method (_STA, 0, Serialized) + { + Store (PDS, PDST) + If (LEqual (PDS, 1)) { + Return (0xf) + } Else { + Return (0) + } + } + + Method (_ON, 0, Serialized) + { + If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { + /* Enter this condition if device + * is connected + */ + + /* De-assert PERST */ + _SB.PCI0.PRDA (\PRT0) + + Store (0, BDQA) /* Set BLKDQDA to 0 */ + Store (0, BPLL) /* Set BLKPLLEN to 0 */ + + /* Set L23_Rdy to Detect Transition + * (L23R2DT) + */ + Store (1, L23R) + Sleep (16) + Store (0, Local0) + + /* Delay for transition Detect + * and link to train + */ + While (L23R) { + If (Lgreater (Local0, 4)) { + Break + } + Sleep (16) + Increment (Local0) + } + } /* End PDS condition check */ + } + + Method (_OFF, 0, Serialized) + { + /* Set L23_Rdy Entry Request (L23ER) */ + If (LAnd (LEqual (PDST, 1), LNotEqual (\PRT0, 0))) { + /* enter this condition if device + * is connected + */ + Store (1, L23E) + Sleep (16) + Store (0, Local0) + While (L23E) { + If (Lgreater (Local0, 4)) { + Break + } + Sleep (16) + Increment (Local0) + } + Store (1, BDQA) /* Set BLKDQDA to 1 */ + Store (1, BPLL) /* Set BLKPLLEN to 1 */ + + /* Assert PERST */ + _SB.PCI0.PRAS (\PRT0) + } /* End PDS condition check */ + } /* End of Method_OFF */ +} /* End PXP */ + +Name(_PR0, Package() { PXP }) +Name(_PR3, Package() { PXP }) diff --git a/src/soc/intel/apollolake/chip.c b/src/soc/intel/apollolake/chip.c index 1dd6daf..9f2cebb 100644 --- a/src/soc/intel/apollolake/chip.c +++ b/src/soc/intel/apollolake/chip.c @@ -113,6 +113,8 @@ /* PCIe */ case PCH_DEVFN_PCIE1: return "RP01"; + case PCH_DEVFN_PCIE5: + return "RP02"; }
return NULL;
