Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68524 )
Change subject: soc/amd/picasso/uart: separate data and code ......................................................................
The goal of this is to be able to move most of the code over to the common AMD blocks.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: Ia496a4b29b25d4438ed8fc09bfe6f83e3fb768d9 Reviewed-on: https://review.coreboot.org/c/coreboot/+/68524 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Fred Reitberger reitbergerfred@gmail.com Reviewed-by: Jason Glenesk jason.glenesk@amd.corp-partner.google.com --- M src/soc/amd/picasso/uart.c 1 file changed, 54 insertions(+), 33 deletions(-)
Approvals: build bot (Jenkins): Verified Jason Glenesk: Looks good to me, approved Fred Reitberger: Looks good to me, approved
diff --git a/src/soc/amd/picasso/uart.c b/src/soc/amd/picasso/uart.c index 4ae4c5c..2879ed1 100644 --- a/src/soc/amd/picasso/uart.c +++ b/src/soc/amd/picasso/uart.c @@ -15,24 +15,26 @@
static const struct { uintptr_t base; + unsigned int aoac_device; + const char *acpi_name; struct soc_amd_gpio mux[2]; } uart_info[] = { - [0] = { APU_UART0_BASE, { + [0] = { APU_UART0_BASE, FCH_AOAC_DEV_UART0, "FUR0", { PAD_NF(GPIO_138, UART0_TXD, PULL_NONE), PAD_NF(GPIO_136, UART0_RXD, PULL_NONE), - } }, - [1] = { APU_UART1_BASE, { + } }, + [1] = { APU_UART1_BASE, FCH_AOAC_DEV_UART1, "FUR1", { PAD_NF(GPIO_143, UART1_TXD, PULL_NONE), PAD_NF(GPIO_141, UART1_RXD, PULL_NONE), - } }, - [2] = { APU_UART2_BASE, { + } }, + [2] = { APU_UART2_BASE, FCH_AOAC_DEV_UART2, "FUR2", { PAD_NF(GPIO_137, UART2_TXD, PULL_NONE), PAD_NF(GPIO_135, UART2_RXD, PULL_NONE), - } }, - [3] = { APU_UART3_BASE, { + } }, + [3] = { APU_UART3_BASE, FCH_AOAC_DEV_UART3, "FUR3", { PAD_NF(GPIO_140, UART3_TXD, PULL_NONE), PAD_NF(GPIO_142, UART3_RXD, PULL_NONE), - } }, + } }, };
uintptr_t get_uart_base(unsigned int idx) @@ -43,6 +45,28 @@ return uart_info[idx].base; }
+static enum cb_err get_uart_idx(uintptr_t base, unsigned int *idx) +{ + unsigned int i; + for (i = 0; i < ARRAY_SIZE(uart_info); i++) { + if (base == uart_info[i].base) { + *idx = i; + return CB_SUCCESS; + } + } + return CB_ERR; +} + +static enum cb_err get_uart_aoac_device(uintptr_t base, unsigned int *aoac_dev) +{ + unsigned int idx; + if (get_uart_idx(base, &idx) == CB_ERR) + return CB_ERR; + + *aoac_dev = uart_info[idx].aoac_device; + return CB_SUCCESS; +} + void clear_uart_legacy_config(void) { write16p(FCH_LEGACY_UART_DECODE, 0); @@ -58,18 +82,11 @@
static const char *uart_acpi_name(const struct device *dev) { - switch (dev->path.mmio.addr) { - case APU_UART0_BASE: - return "FUR0"; - case APU_UART1_BASE: - return "FUR1"; - case APU_UART2_BASE: - return "FUR2"; - case APU_UART3_BASE: - return "FUR3"; - default: + unsigned int idx; + if (get_uart_idx(dev->path.mmio.addr, &idx) == CB_SUCCESS) + return uart_info[idx].acpi_name; + else return NULL; - } }
/* Even though this is called enable, it gets called for both enabled and disabled devices. */ @@ -77,20 +94,7 @@ { unsigned int dev_id;
- switch (dev->path.mmio.addr) { - case APU_UART0_BASE: - dev_id = FCH_AOAC_DEV_UART0; - break; - case APU_UART1_BASE: - dev_id = FCH_AOAC_DEV_UART1; - break; - case APU_UART2_BASE: - dev_id = FCH_AOAC_DEV_UART2; - break; - case APU_UART3_BASE: - dev_id = FCH_AOAC_DEV_UART3; - break; - default: + if (get_uart_aoac_device(dev->path.mmio.addr, &dev_id) == CB_ERR) { printk(BIOS_ERR, "%s: Unknown device: %s\n", __func__, dev_path(dev)); return; }
