Kimarie Hoot (kimarie.hoot@se-eng.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3805
commit 2bee734a352435ff39b4f6ca474c80f410c80924 Author: Kimarie Hoot kimarie.hoot@se-eng.com Date: Sat Jul 20 14:28:10 2013 -0600
ASUS F2A85-M: Split DSDT into common sections (as per Parmer)
Rearranged the F2A85-M DSDT file to match the functionality found on Parmer. As with the Parmer implementation, the F2A85-M dsdt.asl file in the mainboard directory contains only #include references to the appropriate files.
As with Parmer, some include files have no content but are left as a template for other platforms and as placeholders for completing the ACPI implementation for F2A85-M.
Change-Id: Ic72cb6004538ca9d9f79826b9b3c8d6aeb25017c Signed-off-by: Kimarie Hoot kimarie.hoot@se-eng.com --- src/mainboard/asus/f2a85-m/acpi/gpe.asl | 76 + src/mainboard/asus/f2a85-m/acpi/ide.asl | 14 +- src/mainboard/asus/f2a85-m/acpi/mainboard.asl | 36 + src/mainboard/asus/f2a85-m/acpi/routing.asl | 110 +- src/mainboard/asus/f2a85-m/acpi/sata.asl | 12 +- src/mainboard/asus/f2a85-m/acpi/si.asl | 28 + src/mainboard/asus/f2a85-m/acpi/sleep.asl | 100 ++ src/mainboard/asus/f2a85-m/acpi/superio.asl | 20 + src/mainboard/asus/f2a85-m/acpi/thermal.asl | 20 + src/mainboard/asus/f2a85-m/acpi/usb_oc.asl | 31 + src/mainboard/asus/f2a85-m/dsdt.asl | 1452 +------------------- .../amd/agesa/family15tn/acpi/northbridge.asl | 10 + src/southbridge/amd/agesa/hudson/acpi/fch.asl | 8 + 13 files changed, 462 insertions(+), 1455 deletions(-)
diff --git a/src/mainboard/asus/f2a85-m/acpi/gpe.asl b/src/mainboard/asus/f2a85-m/acpi/gpe.asl new file mode 100644 index 0000000..956d5d1 --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/gpe.asl @@ -0,0 +1,76 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +Scope(_GPE) { /* Start Scope GPE */ + + /* General event 3 */ + Method(_L03) { + /* DBGO("\_GPE\_L00\n") */ + Notify(_SB.PCI0.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* Legacy PM event */ + Method(_L08) { + /* DBGO("\_GPE\_L08\n") */ + } + + /* Temp warning (TWarn) event */ + Method(_L09) { + /* DBGO("\_GPE\_L09\n") */ + /* Notify (_TZ.TZ00, 0x80) */ + } + + /* USB controller PME# */ + Method(_L0B) { + /* DBGO("\_GPE\_L0B\n") */ + Notify(_SB.PCI0.UOH1, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH2, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH3, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH5, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UOH6, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.UEH1, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* ExtEvent0 SCI event */ + Method(_L10) { + /* DBGO("\_GPE\_L10\n") */ + } + + + /* ExtEvent1 SCI event */ + Method(_L11) { + /* DBGO("\_GPE\_L11\n") */ + } + + /* GPIO0 or GEvent8 event */ + Method(_L18) { + /* DBGO("\_GPE\_L18\n") */ + Notify(_SB.PCI0.PBR4, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } + + /* Azalia SCI event */ + Method(_L1B) { + /* DBGO("\_GPE\_L1B\n") */ + Notify(_SB.PCI0.AZHD, 0x02) /* NOTIFY_DEVICE_WAKE */ + Notify(_SB.PCI0.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ + } +} /* End Scope GPE */ diff --git a/src/mainboard/asus/f2a85-m/acpi/ide.asl b/src/mainboard/asus/f2a85-m/acpi/ide.asl index 1ff2e79..5689009 100644 --- a/src/mainboard/asus/f2a85-m/acpi/ide.asl +++ b/src/mainboard/asus/f2a85-m/acpi/ide.asl @@ -2,6 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -17,17 +18,6 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-/* -Scope (_SB) { - Device(PCI0) { - Device(IDEC) { - Name(_ADR, 0x00140001) - #include "ide.asl" - } - } -} -*/ - /* Some timing tables */ Name(UDTT, Package(){ /* Udma timing table */ 120, 90, 60, 45, 30, 20, 15, 0 /* UDMA modes 0 -> 6 */ @@ -240,5 +230,5 @@ Device(PRID) } Return(CMBF) } - } /* End Device(SLAV) */ + } /* End Device(SLAV) */ } diff --git a/src/mainboard/asus/f2a85-m/acpi/mainboard.asl b/src/mainboard/asus/f2a85-m/acpi/mainboard.asl new file mode 100644 index 0000000..f554bbd --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/mainboard.asl @@ -0,0 +1,36 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + + /* Data to be patched by the BIOS during POST */ + /* FIXME the patching is not done yet! */ + /* Memory related values */ + Name(LOMH, 0x0) /* Start of unused memory in C0000-E0000 range */ + Name(PBAD, 0x0) /* Address of BIOS area (If TOM2 != 0, Addr >> 16) */ + Name(PBLN, 0x0) /* Length of BIOS area */ + + Name(PCBA, CONFIG_MMCONF_BASE_ADDRESS) /* Base address of PCIe config space */ + Name(PCLN, Multiply(0x100000, CONFIG_MMCONF_BUS_NUMBER)) /* Length of PCIe config space, 1MB each bus */ + Name(HPBA, 0xFED00000) /* Base address of HPET table */ + + Name(SSFG, 0x0D) /* S1 support: bit 0, S2 Support: bit 1, etc. S0 & S5 assumed */ + + /* Some global data */ + Name(OSTP, 3) /* Assume nothing. WinXp = 1, Vista = 2, Linux = 3, WinCE = 4 */ + Name(OSV, Ones) /* Assume nothing */ + Name(PMOD, One) /* Assume APIC */ diff --git a/src/mainboard/asus/f2a85-m/acpi/routing.asl b/src/mainboard/asus/f2a85-m/acpi/routing.asl index b939b6a..0685f8d 100644 --- a/src/mainboard/asus/f2a85-m/acpi/routing.asl +++ b/src/mainboard/asus/f2a85-m/acpi/routing.asl @@ -2,6 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -17,16 +18,7 @@ * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */
-/* -DefinitionBlock ("DSDT.AML","DSDT",0x01,"XXXXXX","XXXXXXXX",0x00010001 - ) - { - #include "routing.asl" - } -*/ - -/* Routing is in System Bus scope */ -Scope(_SB) { + /* Routing is in System Bus scope */ Name(PR0, Package(){ /* NB devices */ /* Bus 0, Dev 0 - F15 Host Controller */ @@ -45,24 +37,27 @@ Scope(_SB) { Package(){0x0002FFFF, 2, INTA, 0 }, Package(){0x0002FFFF, 3, INTB, 0 },
+ /* Bus 0, Dev 3 - PCIe graphics port 1 bridge */ + /* Bus 0, Dev 4 - PCIe Bridge for 4x slot */ Package(){0x0004FFFF, 0, INTA, 0 }, Package(){0x0004FFFF, 1, INTB, 0 }, Package(){0x0004FFFF, 2, INTC, 0 }, Package(){0x0004FFFF, 3, INTD, 0 },
+ /* Bus 0, Dev 5 - General purpose PCIe bridge 5 */ + /* Bus 0, Dev 6 - PCIe Bridge for Ethernet Chip */ + /* Bus 0, Dev 7 - PCIe Bridge for x1 PCIe Slot */ + /* Bus 0, Dev 8 - Southbridge port (normally hidden) */
- /* Bus 0, Funct 8 - Southbridge port (normally hidden) */ - - /* SB devices */ /* Bus 0, Dev 20 - F0:SMBus/ACPI,F1:IDE;F2:HDAudio;F3:LPC;F4:PCIBridge;F5:USB */ Package(){0x0014FFFF, 0, INTA, 0 }, Package(){0x0014FFFF, 1, INTB, 0 }, Package(){0x0014FFFF, 2, INTC, 0 }, Package(){0x0014FFFF, 3, INTD, 0 },
- /* Bus 0, Dev 19 - USB: OHCI, dev 18,19 func 0-2, dev 20 func 5; - * EHCI, dev 18, 19 func 2 */ + /* Bus 0, Dev 18,19,22 - USB: OHCI @ func 0 + * EHCI @ func 2 */ Package(){0x0012FFFF, 0, INTC, 0 }, Package(){0x0012FFFF, 1, INTB, 0 },
@@ -72,7 +67,8 @@ Scope(_SB) { Package(){0x0016FFFF, 0, INTC, 0 }, Package(){0x0016FFFF, 1, INTB, 0 },
- /* Bus 0, Dev 10 - USB: XHCI func 0, 1 */ + /* SB devices */ + /* Bus 0, Dev 16 - USB: XHCI func 0, 1 */ Package(){0x0010FFFF, 0, INTC, 0 }, Package(){0x0010FFFF, 1, INTB, 0 },
@@ -104,23 +100,28 @@ Scope(_SB) { Package(){0x0002FFFF, 2, 0, 16 }, Package(){0x0002FFFF, 3, 0, 17 },
+ /* Bus 0, Dev 3 - PCIe graphics port 1 bridge */ + /* Bus 0, Dev 4 - PCIe Bridge for x4 PCIe Slot black */ Package(){0x0004FFFF, 0, 0, 16 }, Package(){0x0004FFFF, 1, 0, 17 }, Package(){0x0004FFFF, 2, 0, 18 }, Package(){0x0004FFFF, 3, 0, 19 },
- /* Bus 0, Funct 8 - Southbridge port (normally hidden) */ + /* Bus 0, Dev 5 - General purpose PCIe bridge 5 */ + /* Bus 0, Dev 6 - General purpose PCIe bridge 6 */ + /* Bus 0, Dev 7 - PCIe Bridge for network card */ + /* Bus 0, Dev 8 - Southbridge port (normally hidden) */
- /* SB devices in APIC mode */ /* Bus 0, Dev 20 - F0:SMBus/ACPI, F1:IDE; F2:HDAudio; F3:LPC; F4:PCIBridge; F5:USB */ Package(){0x0014FFFF, 0, 0, 16 }, Package(){0x0014FFFF, 1, 0, 17 }, Package(){0x0014FFFF, 2, 0, 18 }, Package(){0x0014FFFF, 3, 0, 19 },
- /* Bus 0, Dev 19 - USB: OHCI, dev 18,19 func 0-2, dev 20 func 5; - * EHCI, dev 18, 19 func 2 */ + /* SB devices in APIC mode */ + /* Bus 0, Dev 18,19,22 - USB: OHCI @ func 0 + * EHCI @ func 2 */ Package(){0x0012FFFF, 0, 0, 18 }, Package(){0x0012FFFF, 1, 0, 17 },
@@ -130,7 +131,7 @@ Scope(_SB) { Package(){0x0016FFFF, 0, 0, 18 }, Package(){0x0016FFFF, 1, 0, 17 },
- /* Bus 0, Dev 10 - USB: XHCI func 0, 1 */ + /* Bus 0, Dev 16 - USB: XHCI func 0, 1 */ Package(){0x0010FFFF, 0, 0, 0x12}, Package(){0x0010FFFF, 1, 0, 0x11},
@@ -153,26 +154,72 @@ Scope(_SB) { }) Name(APS2, Package(){ /* The external GFX - Hooked to PCIe slot 2 */ - Package(){0x0000FFFF, 0, 0, 0x12 }, - Package(){0x0000FFFF, 1, 0, 0x13 }, - Package(){0x0000FFFF, 2, 0, 0x10 }, - Package(){0x0000FFFF, 3, 0, 0x11 }, + Package(){0x0000FFFF, 0, 0, 18 }, + Package(){0x0000FFFF, 1, 0, 19 }, + Package(){0x0000FFFF, 2, 0, 16 }, + Package(){0x0000FFFF, 3, 0, 17 }, })
/* black slot */ Name(PS4, Package(){ - /* PCIe slot - Hooked to PCIe slot x4 */ + /* PCIe slot - Hooked to PCIe slot 4 */ Package(){0x0000FFFF, 0, INTA, 0 }, Package(){0x0000FFFF, 1, INTB, 0 }, Package(){0x0000FFFF, 2, INTC, 0 }, Package(){0x0000FFFF, 3, INTD, 0 }, }) Name(APS4, Package(){ - /* PCIe slot - Hooked to PCIe slot x4 */ - Package(){0x0000FFFF, 0, 0, 0x10 }, - Package(){0x0000FFFF, 1, 0, 0x11 }, - Package(){0x0000FFFF, 2, 0, 0x12 }, - Package(){0x0000FFFF, 3, 0, 0x13 }, + /* PCIe slot - Hooked to PCIe slot 4 */ + Package(){0x0000FFFF, 0, 0, 16 }, + Package(){0x0000FFFF, 1, 0, 17 }, + Package(){0x0000FFFF, 2, 0, 18 }, + Package(){0x0000FFFF, 3, 0, 19 }, + }) + + Name(PS5, Package(){ + /* PCIe slot - Hooked to PCIe slot 5 */ + Package(){0x0000FFFF, 0, INTB, 0 }, + Package(){0x0000FFFF, 1, INTC, 0 }, + Package(){0x0000FFFF, 2, INTD, 0 }, + Package(){0x0000FFFF, 3, INTA, 0 }, + }) + Name(APS5, Package(){ + /* PCIe slot - Hooked to PCIe slot 5 */ + Package(){0x0000FFFF, 0, 0, 17 }, + Package(){0x0000FFFF, 1, 0, 18 }, + Package(){0x0000FFFF, 2, 0, 19 }, + Package(){0x0000FFFF, 3, 0, 16 }, + }) + + Name(PS6, Package(){ + /* PCIe slot - Hooked to PCIe slot 6 */ + Package(){0x0000FFFF, 0, INTC, 0 }, + Package(){0x0000FFFF, 1, INTD, 0 }, + Package(){0x0000FFFF, 2, INTA, 0 }, + Package(){0x0000FFFF, 3, INTB, 0 }, + }) + Name(APS6, Package(){ + /* PCIe slot - Hooked to PCIe slot 6 */ + Package(){0x0000FFFF, 0, 0, 18 }, + Package(){0x0000FFFF, 1, 0, 19 }, + Package(){0x0000FFFF, 2, 0, 16 }, + Package(){0x0000FFFF, 3, 0, 17 }, + }) + + Name(PS7, Package(){ + /* The onboard Ethernet chip - Hooked to PCIe slot 7 */ + Package(){0x0000FFFF, 0, INTD, 0 }, + Package(){0x0000FFFF, 1, INTA, 0 }, + Package(){0x0000FFFF, 2, INTB, 0 }, + Package(){0x0000FFFF, 3, INTC, 0 }, + }) + + Name(APS7, Package(){ + /* The onboard Ethernet chip - Hooked to PCIe slot 7 */ + Package(){0x0000FFFF, 0, 0, 19 }, + Package(){0x0000FFFF, 1, 0, 16 }, + Package(){0x0000FFFF, 2, 0, 17 }, + Package(){0x0000FFFF, 3, 0, 18 }, })
Name(PBR0, Package(){ @@ -213,4 +260,3 @@ Scope(_SB) { Package(){0x0005FFFF, 2, 0, 0x16 }, Package(){0x0005FFFF, 3, 0, 0x17 }, }) -} diff --git a/src/mainboard/asus/f2a85-m/acpi/sata.asl b/src/mainboard/asus/f2a85-m/acpi/sata.asl index c817b6e..5c9f9ee 100644 --- a/src/mainboard/asus/f2a85-m/acpi/sata.asl +++ b/src/mainboard/asus/f2a85-m/acpi/sata.asl @@ -2,6 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -19,17 +20,6 @@
/* simple name description */
-/* -Scope (_SB) { - Device(PCI0) { - Device(SATA) { - Name(_ADR, 0x00110000) - #include "sata.asl" - } - } -} -*/ - Name(STTM, Buffer(20) { 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x78, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, diff --git a/src/mainboard/asus/f2a85-m/acpi/si.asl b/src/mainboard/asus/f2a85-m/acpi/si.asl new file mode 100644 index 0000000..1fb5254 --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/si.asl @@ -0,0 +1,28 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + Scope(_SI) { + Method(_SST, 1) { + /* DBGO("\_SI\_SST\n") */ + /* DBGO(" New Indicator state: ") */ + /* DBGO(Arg0) */ + /* DBGO("\n") */ + } + } /* End Scope SI */ + + diff --git a/src/mainboard/asus/f2a85-m/acpi/sleep.asl b/src/mainboard/asus/f2a85-m/acpi/sleep.asl new file mode 100644 index 0000000..77fd8f6 --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/sleep.asl @@ -0,0 +1,100 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* Wake status package */ +Name(WKST,Package(){Zero, Zero}) + +/* +* _PTS - Prepare to Sleep method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2, etc +* +* Exit: +* -none- +* +* The _PTS control method is executed at the beginning of the sleep process +* for S1-S5. The sleeping value is passed to the _PTS control method. This +* control method may be executed a relatively long time before entering the +* sleep state and the OS may abort the operation without notification to +* the ACPI driver. This method cannot modify the configuration or power +* state of any device in the system. +*/ +Method(_PTS, 1) { + /* DBGO("\_PTS\n") */ + /* DBGO("From S0 to S") */ + /* DBGO(Arg0) */ + /* DBGO("\n") */ + + /* Clear sleep SMI status flag and enable sleep SMI trap. */ + /*Store(One, CSSM) + Store(One, SSEN)*/ + + /* On older chips, clear PciExpWakeDisEn */ + /*if (LLessEqual(_SB.SBRI, 0x13)) { + * Store(0,_SB.PWDE) + *} + */ + + /* Clear wake status structure. */ + Store(0, Index(WKST,0)) + Store(0, Index(WKST,1)) + + Store (0x07, UPWS) +} /* End Method(_PTS) */ + +/* +* _BFS OEM Back From Sleep method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2 +* +* Exit: +* -none- +*/ +Method(_BFS, 1) { + /* DBGO("\_BFS\n") */ + /* DBGO("From S") */ + /* DBGO(Arg0) */ + /* DBGO(" to S0\n") */ +} + +/* +* _WAK System Wake method +* +* Entry: +* Arg0=The value of the sleeping state S1=1, S2=2 +* +* Exit: +* Return package of 2 DWords +* Dword 1 - Status +* 0x00000000 wake succeeded +* 0x00000001 Wake was signaled but failed due to lack of power +* 0x00000002 Wake was signaled but failed due to thermal condition +* Dword 2 - Power Supply state +* if non-zero the effective S-state the power supply entered +*/ +Method(_WAK, 1) { + /* DBGO("\_WAK\n") */ + /* DBGO("From S") */ + /* DBGO(Arg0) */ + /* DBGO(" to S0\n") */ + + Return(WKST) +} /* End Method(_WAK) */ diff --git a/src/mainboard/asus/f2a85-m/acpi/superio.asl b/src/mainboard/asus/f2a85-m/acpi/superio.asl new file mode 100644 index 0000000..ec72e36 --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/superio.asl @@ -0,0 +1,20 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* No Super I/O device or functionality yet */ diff --git a/src/mainboard/asus/f2a85-m/acpi/thermal.asl b/src/mainboard/asus/f2a85-m/acpi/thermal.asl new file mode 100644 index 0000000..0466a1b --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/thermal.asl @@ -0,0 +1,20 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* No thermal zone functionality */ diff --git a/src/mainboard/asus/f2a85-m/acpi/usb_oc.asl b/src/mainboard/asus/f2a85-m/acpi/usb_oc.asl new file mode 100644 index 0000000..1e63d97 --- /dev/null +++ b/src/mainboard/asus/f2a85-m/acpi/usb_oc.asl @@ -0,0 +1,31 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; version 2 of the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + * + * You should have received a copy of the GNU General Public License + * along with this program; if not, write to the Free Software + * Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA + */ + +/* USB overcurrent mapping pins. */ +Name(UOM0, 0) +Name(UOM1, 2) +Name(UOM2, 0) +Name(UOM3, 7) +Name(UOM4, 2) +Name(UOM5, 2) +Name(UOM6, 6) +Name(UOM7, 2) +Name(UOM8, 6) +Name(UOM9, 6) diff --git a/src/mainboard/asus/f2a85-m/dsdt.asl b/src/mainboard/asus/f2a85-m/dsdt.asl index 674f616..f074219 100644 --- a/src/mainboard/asus/f2a85-m/dsdt.asl +++ b/src/mainboard/asus/f2a85-m/dsdt.asl @@ -2,6 +2,7 @@ * This file is part of the coreboot project. * * Copyright (C) 2012 Advanced Micro Devices, Inc. + * Copyright (C) 2013 Sage Electronic Engineering, LLC * * This program is free software; you can redistribute it and/or modify * it under the terms of the GNU General Public License as published by @@ -19,1436 +20,87 @@
/* DefinitionBlock Statement */ DefinitionBlock ( - "DSDT.AML", /* Output filename */ - "DSDT", /* Signature */ - 0x02, /* DSDT Revision, needs to be 2 for 64bit */ - "ASUS ", /* OEMID */ - "COREBOOT", /* TABLE ID */ - 0x00010001 /* OEM Revision */ + "DSDT.AML", /* Output filename */ + "DSDT", /* Signature */ + 0x02, /* DSDT Revision, needs to be 2 for 64bit */ + "ASUS ", /* OEMID */ + "COREBOOT", /* TABLE ID */ + 0x00010001 /* OEM Revision */ ) { /* Start of ASL file */ - /* #include "../../../arch/x86/acpi/debug.asl" */ /* Include global debug methods if needed */ + /* #include <arch/x86/acpi/debug.asl> */ /* Include global debug methods if needed */
- /* Data to be patched by the BIOS during POST */ - /* FIXME the patching is not done yet! */ - /* Memory related values */ - Name(LOMH, 0x0) /* Start of unused memory in C0000-E0000 range */ - Name(PBAD, 0x0) /* Address of BIOS area (If TOM2 != 0, Addr >> 16) */ - Name(PBLN, 0x0) /* Length of BIOS area */ + /* Globals for the platform */ + #include "acpi/mainboard.asl"
- Name(PCBA, CONFIG_MMCONF_BASE_ADDRESS) /* Base address of PCIe config space */ - Name(PCLN, Multiply(0x100000, CONFIG_MMCONF_BUS_NUMBER)) /* Length of PCIe config space, 1MB each bus */ - Name(HPBA, 0xFED00000) /* Base address of HPET table */ + /* Describe the USB Overcurrent pins */ + #include "acpi/usb_oc.asl"
- Name(SSFG, 0x0D) /* S1 support: bit 0, S2 Support: bit 1, etc. S0 & S5 assumed */ + /* PCI IRQ mapping for the Southbridge */ + #include <southbridge/amd/agesa/hudson/acpi/pcie.asl>
- /* USB overcurrent mapping pins. */ - Name(UOM0, 0) - Name(UOM1, 2) - Name(UOM2, 0) - Name(UOM3, 7) - Name(UOM4, 2) - Name(UOM5, 2) - Name(UOM6, 6) - Name(UOM7, 2) - Name(UOM8, 6) - Name(UOM9, 6) + /* Describe the processor tree (_PR) */ + #include <cpu/amd/agesa/family15tn/acpi/cpu.asl>
- /* Some global data */ - Name(OSTP, 3) /* Assume nothing. WinXp = 1, Vista = 2, Linux = 3, WinCE = 4 */ - Name(OSV, Ones) /* Assume nothing */ - Name(PMOD, One) /* Assume APIC */ + /* Describe the supported Sleep States for this Southbridge */ + #include <southbridge/amd/agesa/hudson/acpi/sleepstates.asl>
- /* - * Processor Object - * - */ - Scope (_PR) { /* define processor scope */ - Processor( - P000, /* name space name */ - 0, /* Unique number for this processor */ - 0x810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - - Processor( - P001, /* name space name */ - 1, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P002, /* name space name */ - 2, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P003, /* name space name */ - 3, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P004, /* name space name */ - 4, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P005, /* name space name */ - 5, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P006, /* name space name */ - 6, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - Processor( - P007, /* name space name */ - 7, /* Unique number for this processor */ - 0x0810, /* PBLK system I/O address !hardcoded! */ - 0x06 /* PBLKLEN for boot processor */ - ) { - } - } /* End _PR scope */ - - /* PIC IRQ mapping registers, C00h-C01h. */ - OperationRegion(PRQM, SystemIO, 0x00000C00, 0x00000002) - Field(PRQM, ByteAcc, NoLock, Preserve) { - PRQI, 0x00000008, - PRQD, 0x00000008, /* Offset: 1h */ - } - IndexField(PRQI, PRQD, ByteAcc, NoLock, Preserve) { - PIRA, 0x00000008, /* Index 0 */ - PIRB, 0x00000008, /* Index 1 */ - PIRC, 0x00000008, /* Index 2 */ - PIRD, 0x00000008, /* Index 3 */ - PIRE, 0x00000008, /* Index 4 */ - PIRF, 0x00000008, /* Index 5 */ - PIRG, 0x00000008, /* Index 6 */ - PIRH, 0x00000008, /* Index 7 */ - } - - /* PCI Error control register */ - OperationRegion(PERC, SystemIO, 0x00000C14, 0x00000001) - Field(PERC, ByteAcc, NoLock, Preserve) { - SENS, 0x00000001, - PENS, 0x00000001, - SENE, 0x00000001, - PENE, 0x00000001, - } - - /* Client Management index/data registers */ - OperationRegion(CMT, SystemIO, 0x00000C50, 0x00000002) - Field(CMT, ByteAcc, NoLock, Preserve) { - CMTI, 8, - /* Client Management Data register */ - G64E, 1, - G64O, 1, - G32O, 2, - , 2, - GPSL, 2, - } - - /* GPM Port register */ - OperationRegion(GPT, SystemIO, 0x00000C52, 0x00000001) - Field(GPT, ByteAcc, NoLock, Preserve) { - GPB0,1, - GPB1,1, - GPB2,1, - GPB3,1, - GPB4,1, - GPB5,1, - GPB6,1, - GPB7,1, - } - - /* Flash ROM program enable register */ - OperationRegion(FRE, SystemIO, 0x00000C6F, 0x00000001) - Field(FRE, ByteAcc, NoLock, Preserve) { - , 0x00000006, - FLRE, 0x00000001, - } - - /* PM2 index/data registers */ - OperationRegion(PM2R, SystemIO, 0x00000CD0, 0x00000002) - Field(PM2R, ByteAcc, NoLock, Preserve) { - PM2I, 0x00000008, - PM2D, 0x00000008, - } - - /* Power Management I/O registers. */ - OperationRegion(PIOR, SystemIO, 0x00000CD6, 0x00000002) - Field(PIOR, ByteAcc, NoLock, Preserve) { - PIOI, 0x00000008, - PIOD, 0x00000008, - } - IndexField (PIOI, PIOD, ByteAcc, NoLock, Preserve) { - Offset(0xEE), - UPWS, 3, - } - - /* PM1 Event Block - * First word is PM1_Status, Second word is PM1_Enable - */ - Scope(_SB) { - /* PCIe Configuration Space for CONFIG_MMCONF_BUS_NUMBER busses */ - OperationRegion(PCFG, SystemMemory, PCBA, PCLN) - Field(PCFG, ByteAcc, NoLock, Preserve) { - /* Byte offsets are computed using the following technique: - * ((bus number + 1) * ((device number * 8) * 4096)) + register offset - * The 8 comes from 8 functions per device, and 4096 bytes per function config space - */ - Offset(0x00088024), /* Byte offset to SATA register 24h - Bus 0, Device 17, Function 0 */ - STB5, 32, - Offset(0x00098042), /* Byte offset to OHCI0 register 42h - Bus 0, Device 19, Function 0 */ - PT0D, 1, - PT1D, 1, - PT2D, 1, - PT3D, 1, - PT4D, 1, - PT5D, 1, - PT6D, 1, - PT7D, 1, - PT8D, 1, - PT9D, 1, - Offset(0x000A0004), /* Byte offset to SMBUS register 4h - Bus 0, Device 20, Function 0 */ - SBIE, 1, - SBME, 1, - Offset(0x000A0008), /* Byte offset to SMBUS register 8h - Bus 0, Device 20, Function 0 */ - SBRI, 8, - Offset(0x000A0014), /* Byte offset to SMBUS register 14h - Bus 0, Device 20, Function 0 */ - SBB1, 32, - Offset(0x000A0078), /* Byte offset to SMBUS register 78h - Bus 0, Device 20, Function 0 */ - ,14, - P92E, 1, /* Port92 decode enable */ - } - - OperationRegion(SB5, SystemMemory, STB5, 0x1000) - Field(SB5, AnyAcc, NoLock, Preserve){ - /* Port 0 */ - Offset(0x120), /* Port 0 Task file status */ - P0ER, 1, - , 2, - P0DQ, 1, - , 3, - P0BY, 1, - Offset(0x128), /* Port 0 Serial ATA status */ - P0DD, 4, - , 4, - P0IS, 4, - Offset(0x12C), /* Port 0 Serial ATA control */ - P0DI, 4, - Offset(0x130), /* Port 0 Serial ATA error */ - , 16, - P0PR, 1, - - /* Port 1 */ - offset(0x1A0), /* Port 1 Task file status */ - P1ER, 1, - , 2, - P1DQ, 1, - , 3, - P1BY, 1, - Offset(0x1A8), /* Port 1 Serial ATA status */ - P1DD, 4, - , 4, - P1IS, 4, - Offset(0x1AC), /* Port 1 Serial ATA control */ - P1DI, 4, - Offset(0x1B0), /* Port 1 Serial ATA error */ - , 16, - P1PR, 1, - - /* Port 2 */ - Offset(0x220), /* Port 2 Task file status */ - P2ER, 1, - , 2, - P2DQ, 1, - , 3, - P2BY, 1, - Offset(0x228), /* Port 2 Serial ATA status */ - P2DD, 4, - , 4, - P2IS, 4, - Offset(0x22C), /* Port 2 Serial ATA control */ - P2DI, 4, - Offset(0x230), /* Port 2 Serial ATA error */ - , 16, - P2PR, 1, - - /* Port 3 */ - Offset(0x2A0), /* Port 3 Task file status */ - P3ER, 1, - , 2, - P3DQ, 1, - , 3, - P3BY, 1, - Offset(0x2A8), /* Port 3 Serial ATA status */ - P3DD, 4, - , 4, - P3IS, 4, - Offset(0x2AC), /* Port 3 Serial ATA control */ - P3DI, 4, - Offset(0x2B0), /* Port 3 Serial ATA error */ - , 16, - P3PR, 1, - } - } - - #include "acpi/routing.asl" + /* Describe the Sleep Methods (WAK, PTS, GTS, etc.) for this platform */ + #include "acpi/sleep.asl"
Scope(_SB) { + /* global utility methods expected within the _SB scope */ + #include <arch/x86/acpi/globutil.asl>
- Method(CkOT, 0){ - - if(LNotEqual(OSTP, Ones)) {Return(OSTP)} /* OS version was already detected */ - - if(CondRefOf(_OSI,Local1)) - { - Store(1, OSTP) /* Assume some form of XP */ - if (_OSI("Windows 2006")) /* Vista */ - { - Store(2, OSTP) - } - } else { - If(WCMP(_OS,"Linux")) { - Store(3, OSTP) /* Linux */ - } Else { - Store(4, OSTP) /* Gotta be WinCE */ - } - } - Return(OSTP) - } - - Method(_PIC, 0x01, NotSerialized) - { - If (Arg0) - { - _SB.CIRQ() - } - Store(Arg0, PMOD) - } - Method(CIRQ, 0x00, NotSerialized){ - //Store(0, PIRA) - //Store(0, PIRB) - //Store(0, PIRC) - //Store(0, PIRD) - //Store(0, PIRE) - //Store(0, PIRF) - //Store(0, PIRG) - //Store(0, PIRH) - } - - Name(IRQB, ResourceTemplate(){ - IRQ(Level,ActiveLow,Shared){15} - }) - - Name(IRQP, ResourceTemplate(){ - IRQ(Level,ActiveLow,Exclusive){3, 4, 5, 7, 10, 11, 12, 15} - }) - - Name(PITF, ResourceTemplate(){ - IRQ(Level,ActiveLow,Exclusive){9} - }) - - Device(INTA) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 1) - - Method(_STA, 0) { - if (PIRA) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTA._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKA\_DIS\n") */ - //Store(0x1F, PIRA) - } /* End Method(_SB.INTA._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKA\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTA._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKA\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRA, IRQN) - Return(IRQB) - } /* Method(_SB.INTA._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKA\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - //Store(Local0, PIRA) - } /* End Method(_SB.INTA._SRS) */ - } /* End Device(INTA) */ - - Device(INTB) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 2) - - Method(_STA, 0) { - if (PIRB) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTB._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKB\_DIS\n") */ - //Store(0, PIRB) - } /* End Method(_SB.INTB._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKB\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTB._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKB\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRB, IRQN) - Return(IRQB) - } /* Method(_SB.INTB._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKB\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRB) - } /* End Method(_SB.INTB._SRS) */ - } /* End Device(INTB) */ - - Device(INTC) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 3) - - Method(_STA, 0) { - if (PIRC) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTC._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKC\_DIS\n") */ - //Store(0, PIRC) - } /* End Method(_SB.INTC._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKC\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTC._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKC\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRC, IRQN) - Return(IRQB) - } /* Method(_SB.INTC._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKC\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRC) - } /* End Method(_SB.INTC._SRS) */ - } /* End Device(INTC) */ - - Device(INTD) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 4) - - Method(_STA, 0) { - if (PIRD) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTD._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKD\_DIS\n") */ - //Store(0, PIRD) - } /* End Method(_SB.INTD._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKD\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTD._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKD\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRD, IRQN) - Return(IRQB) - } /* Method(_SB.INTD._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKD\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRD) - } /* End Method(_SB.INTD._SRS) */ - } /* End Device(INTD) */ - - Device(INTE) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 5) - - Method(_STA, 0) { - if (PIRE) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTE._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKE\_DIS\n") */ - //Store(0, PIRE) - } /* End Method(_SB.INTE._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKE\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTE._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKE\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRE, IRQN) - Return(IRQB) - } /* Method(_SB.INTE._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKE\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRE) - } /* End Method(_SB.INTE._SRS) */ - } /* End Device(INTE) */ - - Device(INTF) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 6) - - Method(_STA, 0) { - if (PIRF) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTF._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKF\_DIS\n") */ - //Store(0, PIRF) - } /* End Method(_SB.INTF._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKF\_PRS\n") */ - Return(PITF) - } /* Method(_SB.INTF._PRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKF\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRF, IRQN) - Return(IRQB) - } /* Method(_SB.INTF._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKF\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRF) - } /* End Method(_SB.INTF._SRS) */ - } /* End Device(INTF) */ - - Device(INTG) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 7) - - Method(_STA, 0) { - if (PIRG) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTG._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKG\_DIS\n") */ - //Store(0, PIRG) - } /* End Method(_SB.INTG._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKG\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTG._CRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKG\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRG, IRQN) - Return(IRQB) - } /* Method(_SB.INTG._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKG\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - Store(Local0, PIRG) - } /* End Method(_SB.INTG._SRS) */ - } /* End Device(INTG) */ - - Device(INTH) { - Name(_HID, EISAID("PNP0C0F")) - Name(_UID, 8) - - Method(_STA, 0) { - if (PIRH) { - Return(0x0B) /* sata is invisible */ - } else { - Return(0x09) /* sata is disabled */ - } - } /* End Method(_SB.INTH._STA) */ - - Method(_DIS ,0) { - /* DBGO("\_SB\LNKH\_DIS\n") */ - //Store(0, PIRH) - } /* End Method(_SB.INTH._DIS) */ - - Method(_PRS ,0) { - /* DBGO("\_SB\LNKH\_PRS\n") */ - Return(IRQP) - } /* Method(_SB.INTH._CRS) */ - - Method(_CRS ,0) { - /* DBGO("\_SB\LNKH\_CRS\n") */ - CreateWordField(IRQB, 0x1, IRQN) - ShiftLeft(1, PIRH, IRQN) - Return(IRQB) - } /* Method(_SB.INTH._CRS) */ - - Method(_SRS, 1) { - /* DBGO("\_SB\LNKH\_CRS\n") */ - CreateWordField(ARG0, 1, IRQM) - - /* Use lowest available IRQ */ - FindSetRightBit(IRQM, Local0) - if (Local0) { - Decrement(Local0) - } - //Store(Local0, PIRH) - } /* End Method(_SB.INTH._SRS) */ - } /* End Device(INTH) */ - - } /* End Scope(_SB) */ - - /* Supported sleep states: */ - Name(_S0, Package () {0x00, 0x00, 0x00, 0x00} ) /* (S0) - working state */ - - If (LAnd(SSFG, 0x01)) { - Name(_S1, Package () {0x01, 0x01, 0x00, 0x00} ) /* (S1) - sleeping w/CPU context */ - } - If (LAnd(SSFG, 0x02)) { - Name(_S2, Package () {0x02, 0x02, 0x00, 0x00} ) /* (S2) - "light" Suspend to RAM */ - } - If (LAnd(SSFG, 0x04)) { - Name(_S3, Package () {0x03, 0x03, 0x00, 0x00} ) /* (S3) - Suspend to RAM */ - } - If (LAnd(SSFG, 0x08)) { - Name(_S4, Package () {0x04, 0x04, 0x00, 0x00} ) /* (S4) - Suspend to Disk */ - } + /* Describe IRQ Routing mapping for this platform (within the _SB scope) */ + #include "acpi/routing.asl"
- Name(_S5, Package () {0x05, 0x05, 0x00, 0x00} ) /* (S5) - Soft Off */ - - Name(_SB.CSPS ,0) /* Current Sleep State (S0, S1, S2, S3, S4, S5) */ - Name(CSMS, 0) /* Current System State */ - - /* Wake status package */ - Name(WKST,Package(){Zero, Zero}) - - /* - * _PTS - Prepare to Sleep method - * - * Entry: - * Arg0=The value of the sleeping state S1=1, S2=2, etc - * - * Exit: - * -none- - * - * The _PTS control method is executed at the beginning of the sleep process - * for S1-S5. The sleeping value is passed to the _PTS control method. This - * control method may be executed a relatively long time before entering the - * sleep state and the OS may abort the operation without notification to - * the ACPI driver. This method cannot modify the configuration or power - * state of any device in the system. - */ - Method(_PTS, 1) { - /* DBGO("\_PTS\n") */ - /* DBGO("From S0 to S") */ - /* DBGO(Arg0) */ - /* DBGO("\n") */ - - /* Don't allow PCIRST# to reset USB */ - //if (LEqual(Arg0,3)){ - // Store(0,URRE) - //} - - /* Clear sleep SMI status flag and enable sleep SMI trap. */ - /*Store(One, CSSM) - Store(One, SSEN)*/ - - /* On older chips, clear PciExpWakeDisEn */ - /*if (LLessEqual(_SB.SBRI, 0x13)) { - * Store(0,_SB.PWDE) - *} - */ - - /* Clear wake status structure. */ - Store(0, Index(WKST,0)) - Store(0, Index(WKST,1)) - Store(7, UPWS) - } /* End Method(_PTS) */ - - /* - * The following method results in a "not a valid reserved NameSeg" - * warning so I have commented it out for the duration. It isn't - * used, so it could be removed. - * - * - * _GTS OEM Going To Sleep method - * - * Entry: - * Arg0=The value of the sleeping state S1=1, S2=2 - * - * Exit: - * -none- - * - * Method(_GTS, 1) { - * DBGO("\_GTS\n") - * DBGO("From S0 to S") - * DBGO(Arg0) - * DBGO("\n") - * } - */ - - /* - * _BFS OEM Back From Sleep method - * - * Entry: - * Arg0=The value of the sleeping state S1=1, S2=2 - * - * Exit: - * -none- - */ - Method(_BFS, 1) { - /* DBGO("\_BFS\n") */ - /* DBGO("From S") */ - /* DBGO(Arg0) */ - /* DBGO(" to S0\n") */ - } - - /* - * _WAK System Wake method - * - * Entry: - * Arg0=The value of the sleeping state S1=1, S2=2 - * - * Exit: - * Return package of 2 DWords - * Dword 1 - Status - * 0x00000000 wake succeeded - * 0x00000001 Wake was signaled but failed due to lack of power - * 0x00000002 Wake was signaled but failed due to thermal condition - * Dword 2 - Power Supply state - * if non-zero the effective S-state the power supply entered - */ - Method(_WAK, 1) { - /* DBGO("\_WAK\n") */ - /* DBGO("From S") */ - /* DBGO(Arg0) */ - /* DBGO(" to S0\n") */ - - /* Re-enable HPET */ - //Store(1,HPDE) - - /* Restore PCIRST# so it resets USB */ - //if (LEqual(Arg0,3)){ - // Store(1,URRE) - //} - - /* Arbitrarily clear PciExpWakeStatus */ - //Store(PWST, PWST) - - /* if(DeRefOf(Index(WKST,0))) { - * Store(0, Index(WKST,1)) - * } else { - * Store(Arg0, Index(WKST,1)) - * } - */ - Return(WKST) - } /* End Method(_WAK) */ - - Scope(_GPE) { /* Start Scope GPE */ - /* General event 0 */ - /* Method(_L00) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 1 */ - /* Method(_L01) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 2 */ - /* Method(_L02) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 3 */ - Method(_L03) { - /* DBGO("\_GPE\_L00\n") */ - Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* General event 4 */ - /* Method(_L04) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 5 */ - /* Method(_L05) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 6 - Used for GPM6, moved to USB.asl */ - /* Method(_L06) { - * DBGO("\_GPE\_L00\n") - * } - */ - - /* General event 7 - Used for GPM7, moved to USB.asl */ - /* Method(_L07) { - * DBGO("\_GPE\_L07\n") - * } - */ - - /* Legacy PM event */ - Method(_L08) { - /* DBGO("\_GPE\_L08\n") */ - } - - /* Temp warning (TWarn) event */ - Method(_L09) { - /* DBGO("\_GPE\_L09\n") */ - /* Notify (_TZ.TZ00, 0x80) */ - } - - /* Reserved */ - /* Method(_L0A) { - * DBGO("\_GPE\_L0A\n") - * } - */ - - /* USB controller PME# */ - Method(_L0B) { - /* DBGO("\_GPE\_L0B\n") */ - Notify(_SB.PCI0.UOH1, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH2, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH3, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH4, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH5, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UOH6, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.UEH1, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* AC97 controller PME# */ - /* Method(_L0C) { - * DBGO("\_GPE\_L0C\n") - * } - */ - - /* OtherTherm PME# */ - /* Method(_L0D) { - * DBGO("\_GPE\_L0D\n") - * } - */ - - /* GPM9 SCI event - Moved to USB.asl */ - /* Method(_L0E) { - * DBGO("\_GPE\_L0E\n") - * } - */ - - /* PCIe HotPlug event */ - /* Method(_L0F) { - * DBGO("\_GPE\_L0F\n") - * } - */ - - /* ExtEvent0 SCI event */ - Method(_L10) { - /* DBGO("\_GPE\_L10\n") */ - } - - /* ExtEvent1 SCI event */ - Method(_L11) { - /* DBGO("\_GPE\_L11\n") */ - } - - /* PCIe PME# event */ - /* Method(_L12) { - * DBGO("\_GPE\_L12\n") - * } - */ - - /* GPM0 SCI event - Moved to USB.asl */ - /* Method(_L13) { - * DBGO("\_GPE\_L13\n") - * } - */ - - /* GPM1 SCI event - Moved to USB.asl */ - /* Method(_L14) { - * DBGO("\_GPE\_L14\n") - * } - */ - - /* GPM2 SCI event - Moved to USB.asl */ - /* Method(_L15) { - * DBGO("\_GPE\_L15\n") - * } - */ - - /* GPM3 SCI event - Moved to USB.asl */ - /* Method(_L16) { - * DBGO("\_GPE\_L16\n") - * } - */ - - /* GPM8 SCI event - Moved to USB.asl */ - /* Method(_L17) { - * DBGO("\_GPE\_L17\n") - * } - */ - - /* GPIO0 or GEvent8 event */ - Method(_L18) { - /* DBGO("\_GPE\_L18\n") */ - Notify(_SB.PCI0.PBR4, 0x02) /* NOTIFY_DEVICE_WAKE */ -#if 0 - Notify(_SB.PCI0.PBR5, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.PBR6, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PCI0.PBR7, 0x02) /* NOTIFY_DEVICE_WAKE */ -#endif - Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* GPM4 SCI event - Moved to USB.asl */ - /* Method(_L19) { - * DBGO("\_GPE\_L19\n") - * } - */ - - /* GPM5 SCI event - Moved to USB.asl */ - /* Method(_L1A) { - * DBGO("\_GPE\_L1A\n") - * } - */ - - /* Azalia SCI event */ - Method(_L1B) { - /* DBGO("\_GPE\_L1B\n") */ - Notify(_SB.PCI0.AZHD, 0x02) /* NOTIFY_DEVICE_WAKE */ - Notify(_SB.PWRB, 0x02) /* NOTIFY_DEVICE_WAKE */ - } - - /* GPM6 SCI event - Reassigned to _L06 */ - /* Method(_L1C) { - * DBGO("\_GPE\_L1C\n") - * } - */ - - /* GPM7 SCI event - Reassigned to _L07 */ - /* Method(_L1D) { - * DBGO("\_GPE\_L1D\n") - * } - */ - - /* GPIO2 or GPIO66 SCI event */ - /* Method(_L1E) { - * DBGO("\_GPE\_L1E\n") - * } - */ - - /* SATA SCI event - Moved to sata.asl */ - /* Method(_L1F) { - * DBGO("\_GPE\_L1F\n") - * } - */ - - } /* End Scope GPE */ - - //#include "acpi/usb.asl" - - /* System Bus */ - Scope(_SB) { /* Start _SB scope */ - #include "../../../arch/x86/acpi/globutil.asl" /* global utility methods expected within the _SB scope */ - - /* _SB.PCI0 */ - /* Note: Only need HID on Primary Bus */ Device(PCI0) { - External (TOM1) - External (TOM2) - Name(_HID, EISAID("PNP0A03")) - Name(_ADR, 0x00180000) /* Dev# = BSP Dev#, Func# = 0 */ - Method(_BBN, 0) { /* Bus number = 0 */ - Return(0) - } - Method(_STA, 0) { - /* DBGO("\_SB\PCI0\_STA\n") */ - Return(0x0B) /* Status is visible */ - } - - Method(_PRT,0) { - If(PMOD){ Return(APR0) } /* APIC mode */ - Return (PR0) /* PIC Mode */ - } /* end _PRT */ - - /* Describe the Northbridge devices Dev0 ,Func0*/ - Device(AMRT) { - Name(_ADR, 0x00000000) - } /* end AMRT */ - - /* Dev2 is also an external GFX bridge */ - Device(PBR2) { - Name(_ADR, 0x00020000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PMOD){ Return(APS2) } /* APIC mode */ - Return (PS2) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR2 */ + /* Describe the AMD Northbridge */ + #include <northbridge/amd/agesa/family15tn/acpi/northbridge.asl>
- Device(PBR4) { - Name(_ADR, 0x00040000) - Name(_PRW, Package() {0x18, 4}) - Method(_PRT,0) { - If(PMOD){ Return(APS4) } /* APIC mode */ - Return (PS4) /* PIC Mode */ - } /* end _PRT */ - } /* end PBR4 */ - - /* PCI slot 1, 2, 3 */ - Device(PIBR) { - Name(_ADR, 0x00140004) - Name(_PRW, Package() {0x18, 4}) - /* TODO: non APIC rounting */ - Method(_PRT,0) { - Return (PCIB) - } - } + /* Describe the AMD Fusion Controller Hub Southbridge */ + #include <southbridge/amd/agesa/hudson/acpi/fch.asl>
- /* Describe the Southbridge devices */ - /* PCIe 1x SB */ - Device(SBR0) { + /** + * TODO: The devices listed here (SBR0 and SBR1) do not appear to + * be referenced anywhere and could possibly be removed. + */ + Device(SBR0) { /* PCIe 1x SB */ Name(_ADR, 0x00150000) Name(_PRW, Package() {0x18, 4}) Method(_PRT,0) { If(PMOD){ Return(ABR0) } /* APIC mode */ - Return (PBR0) /* PIC Mode */ - } /* end _PRT */ - } /* end SBR0 */ - - - /* Onboard network */ - Device(SBR1) { + Return (PBR0) /* PIC mode */ + } + } + + Device(SBR1) { /* Onboard network */ Name(_ADR, 0x00150001) Name(_PRW, Package() {0x18, 4}) Method(_PRT, 0) { If(PMOD){ Return(ABR1) } /* APIC mode */ - Return (PBR1) /* PIC Mode */ - } /* end _PRT */ - } /* end SBR1 */ - - Device(STCR) { - Name(_ADR, 0x00110000) - //#include "acpi/sata.asl" - } /* end STCR */ - - Device(UOH1) { - Name(_ADR, 0x00120000) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH1 */ - - Device(UOH2) { - Name(_ADR, 0x00120002) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH2 */ - - Device(UOH3) { - Name(_ADR, 0x00130000) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH3 */ - - Device(UOH4) { - Name(_ADR, 0x00130002) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH4 */ - - Device(UOH5) { - Name(_ADR, 0x00160000) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH5 */ - - Device(UOH6) { - Name(_ADR, 0x00160002) - Name(_PRW, Package() {0x0B, 3}) - } /* end UOH5 */ - - Device(UEH1) { - Name(_ADR, 0x00140005) - Name(_PRW, Package() {0x0B, 3}) - } /* end UEH1 */ - - Device(XHC0) { - Name(_ADR, 0x00100000) - Name(_PRW, Package() {0x0B, 4}) - } /* end XHC0 */ - Device(XHC1) { - Name(_ADR, 0x00100001) - Name(_PRW, Package() {0x0B, 4}) - } /* end XHC1 */ - - Device(SBUS) { - Name(_ADR, 0x00140000) - } /* end SBUS */ - - /* Primary (and only) IDE channel */ - Device(IDEC) { - Name(_ADR, 0x00140001) - //#include "acpi/ide.asl" - } /* end IDEC */ - - Device(AZHD) { - Name(_ADR, 0x00140002) - OperationRegion(AZPD, PCI_Config, 0x00, 0x100) - Field(AZPD, AnyAcc, NoLock, Preserve) { - offset (0x42), - NSDI, 1, - NSDO, 1, - NSEN, 1, - offset (0x44), - IPCR, 4, - offset (0x54), - PWST, 2, - , 6, - PMEB, 1, - , 6, - PMST, 1, - offset (0x62), - MMCR, 1, - offset (0x64), - MMLA, 32, - offset (0x68), - MMHA, 32, - offset (0x6C), - MMDT, 16, - } - - Method(_INI) { - If(LEqual(OSTP,3)){ /* If we are running Linux */ - Store(zero, NSEN) - Store(one, NSDO) - Store(one, NSDI) - } - } - } /* end AZHD */ - - Device(LIBR) { - Name(_ADR, 0x00140003) - /* Method(_INI) { - * DBGO("\_SB\PCI0\LpcIsaBr\_INI\n") - } */ /* End Method(_SB.SBRDG._INI) */ - - OperationRegion(CFG,PCI_Config,0x0,0x100) // Map PCI Configuration Space - Field(CFG,DWordAcc,NoLock,Preserve){ - Offset(0xA0), - BAR,32} // SPI Controller Base Address Register (Index 0xA0) - - Device(LDRC) // LPC device: Resource consumption - { - Name (_HID, EISAID("PNP0C02")) // ID for Motherboard resources - Name (CRS, ResourceTemplate () // Current Motherboard resources - { - Memory32Fixed(ReadWrite, // Setup for fixed resource location for SPI base address - 0x00000000, // Address Base - 0x00000000, // Address Length - BAR0 // Descriptor Name - ) - }) - - Method(_CRS,0,NotSerialized) - { - CreateDwordField(^CRS,^BAR0._BAS,SPIB) // Field to hold SPI base address - CreateDwordField(^CRS,^BAR0._LEN,SPIL) // Field to hold SPI address length - Store(BAR,SPIB) // SPI base address mapped - Store(0x1000,SPIL) // 4k space mapped - Return(CRS) - } + Return (PBR1) /* PIC mode */ } + } + }
- /* Real Time Clock Device */ - Device(RTC0) { - Name(_HID, EISAID("PNP0B00")) /* AT Real Time Clock (not PIIX4 compatible) */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){8} - IO(Decode16,0x0070, 0x0070, 0, 2) - /* IO(Decode16,0x0070, 0x0070, 0, 4) */ - }) - } /* End Device(_SB.PCI0.LpcIsaBr.RTC0) */ - - Device(TMR) { /* Timer */ - Name(_HID,EISAID("PNP0100")) /* System Timer */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){0} - IO(Decode16, 0x0040, 0x0040, 0, 4) - /* IO(Decode16, 0x0048, 0x0048, 0, 4) */ - }) - } /* End Device(_SB.PCI0.LpcIsaBr.TMR) */ - - Device(SPKR) { /* Speaker */ - Name(_HID,EISAID("PNP0800")) /* AT style speaker */ - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x0061, 0x0061, 0, 1) - }) - } /* End Device(_SB.PCI0.LpcIsaBr.SPKR) */ - - Device(PIC) { - Name(_HID,EISAID("PNP0000")) /* AT Interrupt Controller */ - Name(_CRS, ResourceTemplate() { - IRQNoFlags(){2} - IO(Decode16,0x0020, 0x0020, 0, 2) - IO(Decode16,0x00A0, 0x00A0, 0, 2) - /* IO(Decode16, 0x00D0, 0x00D0, 0x10, 0x02) */ - /* IO(Decode16, 0x04D0, 0x04D0, 0x10, 0x02) */ - }) - } /* End Device(_SB.PCI0.LpcIsaBr.PIC) */ - - Device(MAD) { /* 8257 DMA */ - Name(_HID,EISAID("PNP0200")) /* Hardware Device ID */ - Name(_CRS, ResourceTemplate() { - DMA(Compatibility,BusMaster,Transfer8){4} - IO(Decode16, 0x0000, 0x0000, 0x10, 0x10) - IO(Decode16, 0x0081, 0x0081, 0x01, 0x03) - IO(Decode16, 0x0087, 0x0087, 0x01, 0x01) - IO(Decode16, 0x0089, 0x0089, 0x01, 0x03) - IO(Decode16, 0x008F, 0x008F, 0x01, 0x01) - IO(Decode16, 0x00C0, 0x00C0, 0x10, 0x20) - }) /* End Name(_SB.PCI0.LpcIsaBr.MAD._CRS) */ - } /* End Device(_SB.PCI0.LpcIsaBr.MAD) */ - - Device(COPR) { - Name(_HID,EISAID("PNP0C04")) /* Math Coprocessor */ - Name(_CRS, ResourceTemplate() { - IO(Decode16, 0x00F0, 0x00F0, 0, 0x10) - IRQNoFlags(){13} - }) - } /* End Device(_SB.PCI0.LpcIsaBr.COPR) */ - } /* end LIBR */ - - Device(HPBR) { - Name(_ADR, 0x00140004) - } /* end HostPciBr */ - - Device(ACAD) { - Name(_ADR, 0x00140005) - } /* end Ac97audio */ - - Device(ACMD) { - Name(_ADR, 0x00140006) - } /* end Ac97modem */ - - Name(CRES, ResourceTemplate() { - /* Set the Bus number and Secondary Bus number for the PCI0 device - * The Secondary bus range for PCI0 lets the system - * know what bus values are allowed on the downstream - * side of this PCI bus if there is a PCI-PCI bridge. - * PCI busses can have 256 secondary busses which - * range from [0-0xFF] but they do not need to be - * sequential. - */ - WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, - 0x0000, /* address granularity */ - 0x0000, /* range minimum */ - 0x00FF, /* range maximum */ - 0x0000, /* translation */ - 0x0100, /* length */ - ,, PSB0) /* ResourceSourceIndex, ResourceSource, DescriptorName */ - - IO(Decode16, 0x0CF8, 0x0CF8, 1, 8) - - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x0000, /* range minimum */ - 0x0CF7, /* range maximum */ - 0x0000, /* translation */ - 0x0CF8 /* length */ - ) - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x03B0, /* range minimum */ - 0x03DF, /* range maximum */ - 0x0000, /* translation */ - 0x0030 /* length */ - ) - - WORDIO(ResourceProducer, MinFixed, MaxFixed, PosDecode, EntireRange, - 0x0000, /* address granularity */ - 0x0D00, /* range minimum */ - 0xFFFF, /* range maximum */ - 0x0000, /* translation */ - 0xF300 /* length */ - ) - - Memory32Fixed(READONLY, 0x000A0000, 0x00020000, VGAM) /* VGA memory space */ - Memory32Fixed(READONLY, 0x000C0000, 0x00020000, EMM1) /* Assume C0000-E0000 empty */ - /* memory space for PCI BARs below 4GB */ - Memory32Fixed(ReadOnly, 0x00000000, 0x00000000, MMIO) - }) /* End Name(_SB.PCI0.CRES) */ - - Method(_CRS, 0) { - /* DBGO("\_SB\PCI0\_CRS\n") */ - CreateDWordField(CRES, ^MMIO._BAS, MM1B) - CreateDWordField(CRES, ^MMIO._LEN, MM1L) - /* - * Declare memory between TOM1 and 4GB as available - * for PCI MMIO. - * Use ShiftLeft to avoid 64bit constant (for XP). - * This will work even if the OS does 32bit arithmetic, as - * 32bit (0x00000000 - TOM1) will wrap and give the same - * result as 64bit (0x100000000 - TOM1). - */ - Store(TOM1, MM1B) - ShiftLeft(0x10000000, 4, Local0) - Subtract(Local0, TOM1, Local0) - Store(Local0, MM1L) + /* Describe PCI INT[A-H] for the Southbridge */ + #include <southbridge/amd/agesa/hudson/acpi/pci_int.asl>
- Return(CRES) /* note to change the Name buffer */ - } /* end of Method(_SB.PCI0._CRS) */ + } /* End Scope(_SB) */
- /* - * - * FIRST METHOD CALLED UPON BOOT - * - * 1. If debugging, print current OS and ACPI interpreter. - * 2. Get PCI Interrupt routing from ACPI VSM, this - * value is based on user choice in BIOS setup. - */ - Method(_INI, 0) { - /* DBGO("\_SB\_INI\n") */ - /* DBGO(" DSDT.ASL code from ") */ - /* DBGO(__DATE__) */ - /* DBGO(" ") */ - /* DBGO(__TIME__) */ - /* DBGO("\n Sleep states supported: ") */ - /* DBGO("\n") */ - /* DBGO(" \_OS=") */ - /* DBGO(_OS) */ - /* DBGO("\n \_REV=") */ - /* DBGO(_REV) */ - /* DBGO("\n") */ + /* Describe SMBUS for the Southbridge */ + #include <southbridge/amd/agesa/hudson/acpi/smbus.asl>
- /* Determine the OS we're running on */ - CkOT() + /* Define the General Purpose Events for the platform */ + #include "acpi/gpe.asl"
- /* On older chips, clear PciExpWakeDisEn */ - /*if (LLessEqual(\SBRI, 0x13)) { - * Store(0,\PWDE) - * } - */ - } /* End Method(_SB._INI) */ - } /* End Device(PCI0) */ + /* Define the Thermal zones and methods for the platform */ + #include "acpi/thermal.asl"
- Device(PWRB) { /* Start Power button device */ - Name(_HID, EISAID("PNP0C0C")) - Name(_UID, 0xAA) - Name(_PRW, Package () {3, 0x04}) /* wake from S1-S4 */ - Name(_STA, 0x0B) /* sata is invisible */ - } - } /* End _SB scope */ + /* Define the System Indicators for the platform */ + #include "acpi/si.asl"
- Scope(_SI) { - Method(_SST, 1) { - /* DBGO("\_SI\_SST\n") */ - /* DBGO(" New Indicator state: ") */ - /* DBGO(Arg0) */ - /* DBGO("\n") */ - } - } /* End Scope SI */ } /* End of ASL file */ diff --git a/src/northbridge/amd/agesa/family15tn/acpi/northbridge.asl b/src/northbridge/amd/agesa/family15tn/acpi/northbridge.asl index cb442fd..28c0002 100755 --- a/src/northbridge/amd/agesa/family15tn/acpi/northbridge.asl +++ b/src/northbridge/amd/agesa/family15tn/acpi/northbridge.asl @@ -49,6 +49,16 @@ Device(AMRT) { Name(_ADR, 0x00000000) } /* end AMRT */
+/* Dev2 is also an external GFX bridge */ +Device(PBR2) { + Name(_ADR, 0x00020000) + Name(_PRW, Package() {0x18, 4}) + Method(_PRT,0) { + If(PMOD){ Return(APS2) } /* APIC mode */ + Return (PS2) /* PIC Mode */ + } /* end _PRT */ +} /* end PBR2 */ + /* Dev4 GPP0 Root Port Bridge */ Device(PBR4) { Name(_ADR, 0x00040000) diff --git a/src/southbridge/amd/agesa/hudson/acpi/fch.asl b/src/southbridge/amd/agesa/hudson/acpi/fch.asl index ee8b6f4..573fa9b 100755 --- a/src/southbridge/amd/agesa/hudson/acpi/fch.asl +++ b/src/southbridge/amd/agesa/hudson/acpi/fch.asl @@ -76,6 +76,14 @@ Name(CRES, ResourceTemplate() { * sequential. */
+ WordBusNumber (ResourceProducer, MinFixed, MaxFixed, PosDecode, + 0x0000, /* address granularity */ + 0x0000, /* range minimum */ + 0x00FF, /* range maximum */ + 0x0000, /* translation */ + 0x0100, /* length */ + ,, PSB0) /* ResourceSourceIndex, ResourceSource, DescriptorName */ + IO(Decode16, 0x0CF8, 0x0CF8, 1, 8)
