Sridhar Siricilla has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35546 )
Change subject: soc/intel/{common,skl,cnl,icl,apl,tgl}: Move HFSTS1 register definition to SoC ......................................................................
Patch Set 27:
(6 comments)
https://review.coreboot.org/c/coreboot/+/35546/25//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/35546/25//COMMIT_MSG@9 PS25, Line 9: Move me_hfsts1 structure from common code to SoC specific.
It would be good to document the reasoning behind this change here.
Done
This patch is doing much more than just moving the hfsts1 to SoC. […]
Done
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/apollolake/i... File src/soc/intel/apollolake/include/soc/me.h:
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/apollolake/i... PS25, Line 56: cse_is_hfs1_cws_normal
do we have to keep the hfs1 here? the common code is looking for current working state of the csme t […]
Done
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/apollolake/i... PS25, Line 52: /* : * Checks current working operation state is normal or not. : * Returns true if CSE's current working state is normal, otherwise false. : */ : bool cse_is_hfs1_cws_normal(void); : : /* : * Checks CSE's current operation mode is normal or not. : * Returns true if CSE's current operation mode is normal, otherwise false. : */ : bool cse_is_hfs1_com_normal(void); : : /* : * Checks CSE's current operation mode is SECOVER_MEI_MSG or not. : * Returns true if CSE's current operation mode is SECOVER_MEI_MSG, otherwise false. : */ : bool cse_is_hfs1_com_secover_mei_msg(void); : : /* : * Checks CSE's current operation mode is Soft Disable Mode or not. : * Returns true if CSE's current operation mode is Soft Disable Mode, otherwise false. : */ : bool cse_is_hfs1_com_soft_temp_disable(void);
you have multiple declarations of these functions in each SoC. […]
Done
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/common/block... File src/soc/intel/common/block/cse/cse.c:
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/common/block... PS25, Line 630: cse_is_hfs1_cws_normal
My comment was actually continuation of the one made on cse.h. Please see explanation there.
Done
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/common/block... File src/soc/intel/common/block/include/intelblocks/cse.h:
https://review.coreboot.org/c/coreboot/+/35546/25/src/soc/intel/common/block... PS25, Line 54: /* ME Host Firmware Status register 1 */ : union me_hfsts1 { : u32 data; : struct { : u32 working_state: 4; : u32 mfg_mode: 1; : u32 fpt_bad: 1; : u32 operation_state: 3; : u32 fw_init_complete: 1; : u32 ft_bup_ld_flr: 1; : u32 update_in_progress: 1; : u32 error_code: 4; : u32 operation_mode: 4; : u32 reset_count: 4; : u32 boot_options_present: 1; : u32 reserved1: 1; : u32 bist_test_state: 1; : u32 bist_reset_request: 1; : u32 current_power_source: 2; : u32 d3_support_valid: 1; : u32 d0i3_support_valid: 1; : } __packed fields; : };
What I meant is: […]
Yes, it make sense, and implemented the code accordingly.
